[U-Boot] [PATCH] Do not merge this to u-boot/master: disable fixdep
--- Do not merge this patch to the main line ---
This patch is used for Kbuild performance test.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- scripts/Kbuild.include | 4 +--- scripts/Makefile.build | 6 +----- 2 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 6504571..9d4dabe 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -232,9 +232,7 @@ if_changed = $(if $(strip $(any-prereq) $(arg-check)), \ if_changed_dep = $(if $(strip $(any-prereq) $(arg-check) ), \ @set -e; \ $(echo-cmd) $(cmd_$(1)); \ - scripts/basic/fixdep $(depfile) $@ '$(make-cmd)' > $(dot-target).tmp;\ - rm -f $(depfile); \ - mv -f $(dot-target).tmp $(dot-target).cmd) + echo 'cmd_$@ := $(make-cmd)' > $(dot-target).cmd)
# Usage: $(call if_changed_rule,foo) # Will check if $(cmd_foo) or any of the prerequisites changed, diff --git a/scripts/Makefile.build b/scripts/Makefile.build index f37957f..dae809b 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -322,11 +322,7 @@ define rule_cc_o_c $(call echo-cmd,cc_o_c) $(cmd_cc_o_c); \ $(cmd_modversions) \ $(call echo-cmd,record_mcount) \ - $(cmd_record_mcount) \ - scripts/basic/fixdep $(depfile) $@ '$(call make-cmd,cc_o_c)' > \ - $(dot-target).tmp; \ - rm -f $(depfile); \ - mv -f $(dot-target).tmp $(dot-target).cmd + $(cmd_record_mcount) endef
# Built-in and composite module parts
Masahiro Yamada
