[U-Boot] [PATCH v2 1/1] Add support for Eukrea CPU9260 SBC
CPUAT91 is built around Atmel's AT91SAM9260 and has up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND and includes a 10/100 Ethernet PHY in RMII mode.
Signed-off-by: Eric Benard eric@eukrea.com --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 13 ++ board/eukrea/cpu9260/Makefile | 59 +++++++ board/eukrea/cpu9260/config.mk | 1 + board/eukrea/cpu9260/cpu9260.c | 211 ++++++++++++++++++++++ board/eukrea/cpu9260/cpu9260_led.c | 46 +++++ cpu/arm926ejs/at91/lowlevel_init.S | 2 +- include/configs/cpu9260.h | 339 ++++++++++++++++++++++++++++++++++++ 9 files changed, 675 insertions(+), 1 deletions(-) create mode 100644 board/eukrea/cpu9260/Makefile create mode 100644 board/eukrea/cpu9260/config.mk create mode 100644 board/eukrea/cpu9260/cpu9260.c create mode 100644 board/eukrea/cpu9260/cpu9260_led.c create mode 100644 include/configs/cpu9260.h
diff --git a/MAINTAINERS b/MAINTAINERS index 575a7ec..b8d701a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -515,6 +515,10 @@ Dirk Behme dirk.behme@gmail.com
omap3_beagle ARM CORTEX-A8 (OMAP3530 SoC)
+Eric Benard eric@eukrea.com + + cpu9260 ARM926EJS (AT91SAM9260 SoC) + Rishi Bhattacharya rishi@ti.com
omap5912osk ARM926EJS diff --git a/MAKEALL b/MAKEALL index 020ff73..bdc80fa 100755 --- a/MAKEALL +++ b/MAKEALL @@ -592,6 +592,7 @@ LIST_at91=" \ at91sam9m10g45ek \ at91sam9rlek \ cmc_pu2 \ + cpu9260 \ csb637 \ kb9202 \ meesc \ diff --git a/Makefile b/Makefile index 090e645..7ae2bfe 100644 --- a/Makefile +++ b/Makefile @@ -2813,6 +2813,19 @@ at91sam9rlek_config : unconfig fi; @$(MKCONFIG) -a at91sam9rlek arm arm926ejs at91sam9rlek atmel at91
+cpu9260_64m_config \ +cpu9260_config : unconfig + @$(MKCONFIG) -a cpu9260 arm arm926ejs cpu9260 eukrea at91 + @if [ "$(findstring _64m,$@)" ] ; then \ + echo "#define CONFIG_SYS_SDRC_CR_VAL CONFIG_SYS_SDRC_CR_VAL_64MB" \ + >>$(obj)include/config.h ; \ + $(XECHO) "... with 64MB SDRAM" ; \ + else \ + echo "#define CONFIG_SYS_SDRC_CR_VAL CONFIG_SYS_SDRC_CR_VAL_128MB" \ + >>$(obj)include/config.h ; \ + $(XECHO) "... with 128MB SDRAM" ; \ + fi; + meesc_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs meesc esd at91
diff --git a/board/eukrea/cpu9260/Makefile b/board/eukrea/cpu9260/Makefile new file mode 100644 index 0000000..5b1acdc --- /dev/null +++ b/board/eukrea/cpu9260/Makefile @@ -0,0 +1,59 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# Ilko Iliev <www.ronetix.at> +# +# (C) Copyright 2009 +# Eric Benard eric@eukrea.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-y += $(BOARD)_led.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/eukrea/cpu9260/config.mk b/board/eukrea/cpu9260/config.mk new file mode 100644 index 0000000..9ce161e --- /dev/null +++ b/board/eukrea/cpu9260/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c new file mode 100644 index 0000000..1d95f96 --- /dev/null +++ b/board/eukrea/cpu9260/cpu9260.c @@ -0,0 +1,211 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/clk.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void cpu9260_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | + AT91_SMC_DBW_8 | + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void cpu9260_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PA17) => PHY normal mode (not Test mode) + * ERX0 (PA14) => PHY ADDR0 + * ERX1 (PA15) => PHY ADDR1 + * ERX2 (PA25) => PHY ADDR2 + * ERX3 (PA26) => PHY ADDR3 + * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + AT91_RSTC_ERSTL & (0x0D << 8) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of CPUAT9260-Board */ + gd->bd->bi_arch_number = MACH_TYPE_CPUAT9260; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + cpu9260_nand_hw_init(); +#endif +#ifdef CONFIG_MACB + cpu9260_macb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x1F); +#endif + return rc; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + char buf[32]; + + printf("Board : Eukrea Electromatique CPU9260\n"); + printf("Crystal frequency: %8s MHz\n", + strmhz(buf, get_main_clk_rate())); + printf("CPU clock : %8s MHz\n", + strmhz(buf, get_cpu_clk_rate())); + printf("Master clock : %8s MHz\n", + strmhz(buf, get_mck_clk_rate())); + printf("\n"); + return 0; +} +#endif diff --git a/board/eukrea/cpu9260/cpu9260_led.c b/board/eukrea/cpu9260/cpu9260_led.c new file mode 100644 index 0000000..33942c7 --- /dev/null +++ b/board/eukrea/cpu9260/cpu9260_led.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + at91_set_gpio_output(CONFIG_BLUE_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 1); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); + at91_set_gpio_value(CONFIG_BLUE_LED, 0); +} diff --git a/cpu/arm926ejs/at91/lowlevel_init.S b/cpu/arm926ejs/at91/lowlevel_init.S index 5ed518c..9962ae9 100644 --- a/cpu/arm926ejs/at91/lowlevel_init.S +++ b/cpu/arm926ejs/at91/lowlevel_init.S @@ -194,7 +194,7 @@ SMRDATA: .word CONFIG_SYS_PIOD_PPUDR_VAL .word (AT91_BASE_SYS + AT91_PIOD + PIO_ASR) .word CONFIG_SYS_PIOD_PPUDR_VAL -#elif defined(CONFIG_AT91SAM9261) +#elif defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9261) .word (AT91_BASE_SYS + AT91_PIOC + PIO_PDR) .word CONFIG_SYS_PIOC_PDR_VAL1 .word (AT91_BASE_SYS + AT91_PIOC + PIO_PUDR) diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h new file mode 100644 index 0000000..d701ade --- /dev/null +++ b/include/configs/cpu9260.h @@ -0,0 +1,339 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * Configuration settings for the Eukrea CPU9260 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_DISPLAY_BOARDINFO 1 + +#define CPU9260_CRYSTAL 18432000 +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 + +#define CONFIG_AT91SAM9260 1 + +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ + +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* clocks */ +#define MASTER_PLL_DIV 0x09 +#define MASTER_PLL_MUL 0x61 + +/* CKGR_MOR - enable main osc. */ +#define CONFIG_SYS_MOR_VAL \ + (AT91_PMC_MOSCEN | \ + (255 << 8)) /* Main Oscillator Start-up Time */ +#define CONFIG_SYS_PLLAR_VAL \ + (AT91_PMC_PLLA_WR_ERRATA | /* Bit 29 must be 1 when prog */ \ + AT91_PMC_OUT | \ + ((MASTER_PLL_MUL - 1) << 16) | (MASTER_PLL_DIV)) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR1_VAL \ + (AT91_PMC_CSS_SLOW | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR2_VAL \ + (AT91_PMC_CSS_PLLA | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* define PDC[31:16] as DATA[31:16] */ +#define CONFIG_SYS_PIOC_PDR_VAL1 0xFFFF0000 +/* no pull-up for D[31:16] */ +#define CONFIG_SYS_PIOC_PPUDR_VAL 0xFFFF0000 + +/* EBI_CSA, 3.3V, no pull-ups for D[15:0], CS1 SDRAM, CS3 NAND Flash */ +#define CONFIG_SYS_MATRIX_EBICSA_VAL \ + (AT91_MATRIX_DBPUC | AT91_MATRIX_CS1A_SDRAMC |\ + AT91_MATRIX_CS3A_SMC_SMARTMEDIA | AT91_MATRIX_VDDIOMSEL) + +/* SDRAM */ +/* SDRAMC_MR Mode register */ +#define CONFIG_SYS_SDRC_MR_VAL1 AT91_SDRAMC_MODE_NORMAL +/* SDRAMC_TR - Refresh Timer register */ +#define CONFIG_SYS_SDRC_TR_VAL1 0x287 +/* SDRAMC_CR - Configuration register*/ +#define CONFIG_SYS_SDRC_CR_VAL_64MB \ + (AT91_SDRAMC_NC_9 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +#define CONFIG_SYS_SDRC_CR_VAL_128MB \ + (AT91_SDRAMC_NC_10 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +/* Memory Device Register -> SDRAM */ +#define CONFIG_SYS_SDRC_MDR_VAL AT91_SDRAMC_MD_SDRAM +#define CONFIG_SYS_SDRC_MR_VAL2 AT91_SDRAMC_MODE_PRECHARGE +#define CONFIG_SYS_SDRAM_VAL1 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL3 AT91_SDRAMC_MODE_REFRESH +#define CONFIG_SYS_SDRAM_VAL2 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL3 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL4 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL5 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL6 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL7 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL8 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL9 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL4 AT91_SDRAMC_MODE_LMR +#define CONFIG_SYS_SDRAM_VAL10 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL5 AT91_SDRAMC_MODE_NORMAL +#define CONFIG_SYS_SDRAM_VAL11 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_TR_VAL2 1200 /* SDRAM_TR */ +#define CONFIG_SYS_SDRAM_VAL12 0 /* SDRAM_BASE */ + +/* setup SMC0, CS0 (NOR Flash) - 16-bit, 15 WS */ +#define CONFIG_SYS_SMC0_SETUP0_VAL \ + (AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | \ + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)) +#define CONFIG_SYS_SMC0_PULSE0_VAL \ + (AT91_SMC_NWEPULSE_(6) | AT91_SMC_NCS_WRPULSE_(6) | \ + AT91_SMC_NRDPULSE_(10) | AT91_SMC_NCS_RDPULSE_(10)) +#define CONFIG_SYS_SMC0_CYCLE0_VAL \ + (AT91_SMC_NWECYCLE_(6) | AT91_SMC_NRDCYCLE_(10)) +#define CONFIG_SYS_SMC0_MODE0_VAL \ + (AT91_SMC_READMODE | AT91_SMC_WRITEMODE | \ + AT91_SMC_DBW_16 | \ + AT91_SMC_TDFMODE | \ + AT91_SMC_TDF_(2)) + +/* user reset enable */ +#define CONFIG_SYS_RSTC_RMR_VAL \ + (AT91_RSTC_KEY | \ + AT91_RSTC_PROCRST | \ + AT91_RSTC_RSTTYP_WAKEUP | \ + AT91_RSTC_RSTTYP_WATCHDOG) + +/* Disable Watchdog */ +#define CONFIG_SYS_WDTC_WDMR_VAL \ + (AT91_WDT_WDIDLEHLT | AT91_WDT_WDDBGHLT | \ + AT91_WDT_WDV | \ + AT91_WDT_WDDIS | \ + AT91_WDT_WDD) + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_FAT 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +/* NAND flash */ +#define CONFIG_NAND_ATMEL 1 +#define NAND_MAX_CHIPS 1 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +#undef CONFIG_SYS_NAND_DBW_16 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) + +/* NOR flash */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define PHYS_FLASH_1 0x10000000 +#define PHYS_FLASH_2 0x12000000 +#define CONFIG_SYS_FLASH_BANKS_LIST \ + { PHYS_FLASH_1, PHYS_FLASH_2 } +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MAX_FLASH_SECT (255+4) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 + +/* LEDS */ +#define CONFIG_RED_LED AT91_PIN_PC11 +#define CONFIG_GREEN_LED AT91_PIN_PC12 +#define CONFIG_YELLOW_LED AT91_PIN_PC7 +#define CONFIG_BLUE_LED AT91_PIN_PC9 + +/* USB */ +#define CONFIG_USB_ATMEL 1 +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x27e00000 + +#undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_USE_FLASH 1 + +#if defined(CONFIG_SYS_USE_FLASH) +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_OVERWRITE 1 + +#define CONFIG_BOOTCOMMAND "run flashboot" + +#define MTDIDS_DEFAULT "nor0=physmap-flash.0,nand0=nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=physmap-flash.0:" \ + "256k(u-boot)ro," \ + "128k(u-boot-env)ro," \ + "1792k(kernel)," \ + "-(rootfs);" \ + "nand:-(nand)" + +#define CONFIG_BOOTARGS "root=/dev/mtdblock3 rootfstype=jffs2 " + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "partition=nand0,0\0" \ + "ramargs=setenv bootargs $(bootargs) $(mtdparts)\0" \ + "ramboot=tftpboot 0x22000000 cpu9260/uImage;" \ + "run ramargs;bootm 22000000\0" \ + "flashboot=run ramargs;bootm 0x10060000\0" \ + "updtub=tftp 0x24000000 cpu9260/u-boot.bin;protect off" \ + " 0x10000000 0x1003ffff;erase 0x10000000 " \ + "0x1003ffff;cp.b 0x24000000 0x10000000 " \ + "$(filesize)\0" \ + "updtui=tftp 0x24000000 cpu9260/uImage;protect off" \ + " 0x10060000 0x1021ffff;erase 0x10060000 " \ + "0x1021ffff;cp.b 0x24000000 0x10060000 " \ + "$(filesize)\0" \ + "updtrfs=tftp 0x24000000 cpu9260/rootfs.jffs2;protect " \ + "off 0x10220000 0x13ffffff;erase 0x10220000 " \ + "0x13ffffff;cp.b 0x24000000 0x10220000 " \ + "$(filesize)\0" \ + "" +#else +#error "Undefined memory device" +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "CPU9260=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SILENT_CONSOLE 1 +#define CONFIG_NETCONSOLE 1 + +#define ROUND(A, B) (((A) + (B)) & ~((B) - 1)) +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN \ + ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_STACKSIZE (32 * 1024) + +#if defined(CONFIG_USE_IRQ) +#error CONFIG_USE_IRQ not supported +#endif + +#endif
- char buf[32];
- printf("Board : Eukrea Electromatique CPU9260\n");
- printf("Crystal frequency: %8s MHz\n",
- printf("CPU clock : %8s MHz\n",
- printf("Master clock : %8s MHz\n",
please use CONFIG_DISPLAY_CPUINFO
- printf("\n");
+} +#endif
<snip>
please do this in a separate patch
<snip>
please remove if no-need
<snip>
- "mtdparts=physmap-flash.0:" \
"256k(u-boot)ro," \
"1792k(kernel)," \
"-(rootfs);" \
- "nand:-(nand)"
- "mtdids=" MTDIDS_DEFAULT "\0" \
- "mtdparts=" MTDPARTS_DEFAULT "\0" \
- "partition=nand0,0\0" \
- "ramargs=setenv bootargs $(bootargs) $(mtdparts)\0" \
- "ramboot=tftpboot 0x22000000 cpu9260/uImage;" \
- "flashboot=run ramargs;bootm 0x10060000\0" \
- "updtub=tftp 0x24000000 cpu9260/u-boot.bin;protect off" \
"$(filesize)\0" \
- "updtui=tftp 0x24000000 cpu9260/uImage;protect off" \
"$(filesize)\0" \
- "updtrfs=tftp 0x24000000 cpu9260/rootfs.jffs2;protect " \
"$(filesize)\0" \
why?
please remove
Best Regards, J.
Signed-off-by: Eric Benard eric@eukrea.com --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 13 ++ board/eukrea/cpu9260/Makefile | 59 +++++++ board/eukrea/cpu9260/config.mk | 1 + board/eukrea/cpu9260/cpu9260.c | 211 +++++++++++++++++++++++ board/eukrea/cpu9260/cpu9260_led.c | 46 +++++ include/configs/cpu9260.h | 335 ++++++++++++++++++++++++++++++++++++ 8 files changed, 670 insertions(+), 0 deletions(-) create mode 100644 board/eukrea/cpu9260/Makefile create mode 100644 board/eukrea/cpu9260/config.mk create mode 100644 board/eukrea/cpu9260/cpu9260.c create mode 100644 board/eukrea/cpu9260/cpu9260_led.c create mode 100644 include/configs/cpu9260.h
diff --git a/board/eukrea/cpu9260/Makefile b/board/eukrea/cpu9260/Makefile new file mode 100644 index 0000000..5b1acdc --- /dev/null +++ b/board/eukrea/cpu9260/Makefile @@ -0,0 +1,59 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# Ilko Iliev <www.ronetix.at> +# +# (C) Copyright 2009 +# Eric Benard eric@eukrea.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-y += $(BOARD)_led.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/eukrea/cpu9260/config.mk b/board/eukrea/cpu9260/config.mk new file mode 100644 index 0000000..9ce161e --- /dev/null +++ b/board/eukrea/cpu9260/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c new file mode 100644 index 0000000..84707b6 --- /dev/null +++ b/board/eukrea/cpu9260/cpu9260.c @@ -0,0 +1,211 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/clk.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void cpu9260_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | + AT91_SMC_DBW_8 | + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void cpu9260_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PA17) => PHY normal mode (not Test mode) + * ERX0 (PA14) => PHY ADDR0 + * ERX1 (PA15) => PHY ADDR1 + * ERX2 (PA25) => PHY ADDR2 + * ERX3 (PA26) => PHY ADDR3 + * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + AT91_RSTC_ERSTL & (0x0D << 8) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of CPUAT9260-Board */ + gd->bd->bi_arch_number = MACH_TYPE_CPUAT9260; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + cpu9260_nand_hw_init(); +#endif +#ifdef CONFIG_MACB + cpu9260_macb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x1F); +#endif + return rc; +} + +#ifdef CONFIG_DISPLAY_CPUINFO +int checkboard(void) +{ + char buf[32]; + + printf("Board : Eukrea Electromatique CPU9260\n"); + printf("Crystal frequency: %8s MHz\n", + strmhz(buf, get_main_clk_rate())); + printf("CPU clock : %8s MHz\n", + strmhz(buf, get_cpu_clk_rate())); + printf("Master clock : %8s MHz\n", + strmhz(buf, get_mck_clk_rate())); + printf("\n"); + return 0; +} +#endif diff --git a/board/eukrea/cpu9260/cpu9260_led.c b/board/eukrea/cpu9260/cpu9260_led.c new file mode 100644 index 0000000..33942c7 --- /dev/null +++ b/board/eukrea/cpu9260/cpu9260_led.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + at91_set_gpio_output(CONFIG_BLUE_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 1); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); + at91_set_gpio_value(CONFIG_BLUE_LED, 0); +} diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h new file mode 100644 index 0000000..1342754 --- /dev/null +++ b/include/configs/cpu9260.h @@ -0,0 +1,335 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * Configuration settings for the Eukrea CPU9260 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_DISPLAY_CPUINFO 1 + +#define CPU9260_CRYSTAL 18432000 +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 + +#define CONFIG_AT91SAM9260 1 + +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ + +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* clocks */ +#define MASTER_PLL_DIV 0x09 +#define MASTER_PLL_MUL 0x61 + +/* CKGR_MOR - enable main osc. */ +#define CONFIG_SYS_MOR_VAL \ + (AT91_PMC_MOSCEN | \ + (255 << 8)) /* Main Oscillator Start-up Time */ +#define CONFIG_SYS_PLLAR_VAL \ + (AT91_PMC_PLLA_WR_ERRATA | /* Bit 29 must be 1 when prog */ \ + AT91_PMC_OUT | \ + ((MASTER_PLL_MUL - 1) << 16) | (MASTER_PLL_DIV)) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR1_VAL \ + (AT91_PMC_CSS_SLOW | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR2_VAL \ + (AT91_PMC_CSS_PLLA | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* define PDC[31:16] as DATA[31:16] */ +#define CONFIG_SYS_PIOC_PDR_VAL1 0xFFFF0000 +/* no pull-up for D[31:16] */ +#define CONFIG_SYS_PIOC_PPUDR_VAL 0xFFFF0000 + +/* EBI_CSA, 3.3V, no pull-ups for D[15:0], CS1 SDRAM, CS3 NAND Flash */ +#define CONFIG_SYS_MATRIX_EBICSA_VAL \ + (AT91_MATRIX_DBPUC | AT91_MATRIX_CS1A_SDRAMC |\ + AT91_MATRIX_CS3A_SMC_SMARTMEDIA | AT91_MATRIX_VDDIOMSEL) + +/* SDRAM */ +/* SDRAMC_MR Mode register */ +#define CONFIG_SYS_SDRC_MR_VAL1 AT91_SDRAMC_MODE_NORMAL +/* SDRAMC_TR - Refresh Timer register */ +#define CONFIG_SYS_SDRC_TR_VAL1 0x287 +/* SDRAMC_CR - Configuration register*/ +#define CONFIG_SYS_SDRC_CR_VAL_64MB \ + (AT91_SDRAMC_NC_9 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +#define CONFIG_SYS_SDRC_CR_VAL_128MB \ + (AT91_SDRAMC_NC_10 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +/* Memory Device Register -> SDRAM */ +#define CONFIG_SYS_SDRC_MDR_VAL AT91_SDRAMC_MD_SDRAM +#define CONFIG_SYS_SDRC_MR_VAL2 AT91_SDRAMC_MODE_PRECHARGE +#define CONFIG_SYS_SDRAM_VAL1 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL3 AT91_SDRAMC_MODE_REFRESH +#define CONFIG_SYS_SDRAM_VAL2 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL3 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL4 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL5 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL6 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL7 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL8 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL9 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL4 AT91_SDRAMC_MODE_LMR +#define CONFIG_SYS_SDRAM_VAL10 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL5 AT91_SDRAMC_MODE_NORMAL +#define CONFIG_SYS_SDRAM_VAL11 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_TR_VAL2 1200 /* SDRAM_TR */ +#define CONFIG_SYS_SDRAM_VAL12 0 /* SDRAM_BASE */ + +/* setup SMC0, CS0 (NOR Flash) - 16-bit, 15 WS */ +#define CONFIG_SYS_SMC0_SETUP0_VAL \ + (AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | \ + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)) +#define CONFIG_SYS_SMC0_PULSE0_VAL \ + (AT91_SMC_NWEPULSE_(6) | AT91_SMC_NCS_WRPULSE_(6) | \ + AT91_SMC_NRDPULSE_(10) | AT91_SMC_NCS_RDPULSE_(10)) +#define CONFIG_SYS_SMC0_CYCLE0_VAL \ + (AT91_SMC_NWECYCLE_(6) | AT91_SMC_NRDCYCLE_(10)) +#define CONFIG_SYS_SMC0_MODE0_VAL \ + (AT91_SMC_READMODE | AT91_SMC_WRITEMODE | \ + AT91_SMC_DBW_16 | \ + AT91_SMC_TDFMODE | \ + AT91_SMC_TDF_(2)) + +/* user reset enable */ +#define CONFIG_SYS_RSTC_RMR_VAL \ + (AT91_RSTC_KEY | \ + AT91_RSTC_PROCRST | \ + AT91_RSTC_RSTTYP_WAKEUP | \ + AT91_RSTC_RSTTYP_WATCHDOG) + +/* Disable Watchdog */ +#define CONFIG_SYS_WDTC_WDMR_VAL \ + (AT91_WDT_WDIDLEHLT | AT91_WDT_WDDBGHLT | \ + AT91_WDT_WDV | \ + AT91_WDT_WDDIS | \ + AT91_WDT_WDD) + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_FAT 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +/* NAND flash */ +#define CONFIG_NAND_ATMEL 1 +#define NAND_MAX_CHIPS 1 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) + +/* NOR flash */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define PHYS_FLASH_1 0x10000000 +#define PHYS_FLASH_2 0x12000000 +#define CONFIG_SYS_FLASH_BANKS_LIST \ + { PHYS_FLASH_1, PHYS_FLASH_2 } +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MAX_FLASH_SECT (255+4) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 + +/* LEDS */ +#define CONFIG_RED_LED AT91_PIN_PC11 +#define CONFIG_GREEN_LED AT91_PIN_PC12 +#define CONFIG_YELLOW_LED AT91_PIN_PC7 +#define CONFIG_BLUE_LED AT91_PIN_PC9 + +/* USB */ +#define CONFIG_USB_ATMEL 1 +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x27e00000 + +#undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_USE_FLASH 1 + +#if defined(CONFIG_SYS_USE_FLASH) +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_OVERWRITE 1 + +#define CONFIG_BOOTCOMMAND "run flashboot" + +#define MTDIDS_DEFAULT "nor0=physmap-flash.0,nand0=nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=physmap-flash.0:" \ + "256k(u-boot)ro," \ + "128k(u-boot-env)ro," \ + "1792k(kernel)," \ + "-(rootfs);" \ + "nand:-(nand)" + +#define CONFIG_BOOTARGS "root=/dev/mtdblock3 rootfstype=jffs2 " + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "partition=nand0,0\0" \ + "ramargs=setenv bootargs $(bootargs) $(mtdparts)\0" \ + "ramboot=tftpboot 0x22000000 cpu9260/uImage;" \ + "run ramargs;bootm 22000000\0" \ + "flashboot=run ramargs;bootm 0x10060000\0" \ + "updtub=tftp 0x24000000 cpu9260/u-boot.bin;protect off" \ + " 0x10000000 0x1003ffff;erase 0x10000000 " \ + "0x1003ffff;cp.b 0x24000000 0x10000000 " \ + "$(filesize)\0" \ + "updtui=tftp 0x24000000 cpu9260/uImage;protect off" \ + " 0x10060000 0x1021ffff;erase 0x10060000 " \ + "0x1021ffff;cp.b 0x24000000 0x10060000 " \ + "$(filesize)\0" \ + "updtrfs=tftp 0x24000000 cpu9260/rootfs.jffs2;protect " \ + "off 0x10220000 0x13ffffff;erase 0x10220000 " \ + "0x13ffffff;cp.b 0x24000000 0x10220000 " \ + "$(filesize)\0" \ + "" +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "CPU9260=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SILENT_CONSOLE 1 +#define CONFIG_NETCONSOLE 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN \ + ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_STACKSIZE (32 * 1024) + +#if defined(CONFIG_USE_IRQ) +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Needed for AT91SAM9260 NOR Boot on Eukrea's CPU9260.
Signed-off-by: Eric Benard eric@eukrea.com --- cpu/arm926ejs/at91/lowlevel_init.S | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
Dear Eric Benard,
- @$(MKCONFIG) -a cpu9260 arm arm926ejs cpu9260 eukrea at91
- @if [ "$(findstring _64m,$@)" ] ; then \
- else \
- fi;
This makes no sense to me. "mkconfig -a" (i. e. in append mode) should be used AFTER manually initializing the config files. Either omit the "-a", or move the line down.
v3 : fix Makefile (run mkconfig after config.h configuration)
v4 : do the commit before generating/sending the patch ;-) v3 : fix Makefile (run mkconfig after config.h configuration)
omap5912osk ARM926EJS diff --git a/MAKEALL b/MAKEALL index 020ff73..bdc80fa 100755 --- a/MAKEALL +++ b/MAKEALL @@ -592,6 +592,7 @@ LIST_at91=" \ at91sam9m10g45ek \ at91sam9rlek \ cmc_pu2 \ + cpu9260 \ csb637 \ kb9202 \ meesc \ diff --git a/Makefile b/Makefile index 090e645..8c4178f 100644 --- a/Makefile +++ b/Makefile @@ -2813,6 +2813,19 @@ at91sam9rlek_config : unconfig fi; @$(MKCONFIG) -a at91sam9rlek arm arm926ejs at91sam9rlek atmel at91
+cpu9260_64m_config \ +cpu9260_config : unconfig + @if [ "$(findstring _64m,$@)" ] ; then \ + echo "#define CONFIG_SYS_SDRC_CR_VAL CONFIG_SYS_SDRC_CR_VAL_64MB" \ + >>$(obj)include/config.h ; \ + $(XECHO) "... CPU9260 with 64MB SDRAM" ; \ + else \ + echo "#define CONFIG_SYS_SDRC_CR_VAL CONFIG_SYS_SDRC_CR_VAL_128MB" \ + >>$(obj)include/config.h ; \ + $(XECHO) "... CPU9260 with 128MB SDRAM" ; \ + fi; + @$(MKCONFIG) -a cpu9260 arm arm926ejs cpu9260 eukrea at91 + meesc_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs meesc esd at91
- cpu9260 ARM926EJS (AT91SAM9260 SoC)
- cpu9260 \ csb637 \ kb9202 \ meesc \
- else \
- fi;
please keep the same way as all other at91sam COBJS-y += led.o
- $(AR) $(ARFLAGS) $@ $(OBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- (C) Copyright 2007-2008
- Stelian Pop stelian.pop@leadtechdesign.com
- Lead Tech Design <www.leadtechdesign.com>
- Ilko Iliev <www.ronetix.at>
- (C) Copyright 2009
- Eric Benard eric@eukrea.com
- project.
- MA 02111-1307 USA
please #include <asm/arch/at91sam9_matrix.h>
- Miscelaneous platform dependent initialisations
- unsigned long csa;
- /* Enable CS3 */
- csa = at91_sys_read(AT91_MATRIX_EBICSA);
- at91_sys_write(AT91_MATRIX_EBICSA,
- /* Configure SMC CS3 for NAND/SmartMedia */
- at91_sys_write(AT91_SMC_SETUP(3),
- at91_sys_write(AT91_SMC_PULSE(3),
- at91_sys_write(AT91_SMC_CYCLE(3),
- at91_sys_write(AT91_SMC_MODE(3),
AT91_SMC_DBW_8 |
AT91_SMC_TDF_(2));
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC);
- /* Configure RDY/BSY */
- at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
- /* Enable NandFlash */
- at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1);
+} +#endif
- unsigned long rstc;
- /* Enable clock */
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC);
- writel(pin_to_mask(AT91_PIN_PA14) |
- rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL;
- /* Need to reset PHY -> 500ms reset */
- at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY |
AT91_RSTC_URSTEN);
- at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST);
- /* Wait for end hardware reset */
- while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL));
- /* Restore NRST value */
(rstc) |
AT91_RSTC_URSTEN);
- /* Re-enable pull-up */
- at91_macb_hw_init();
+} +#endif
- /* Enable Ctrlc */
- console_init_f();
- /* arch number of CPUAT9260-Board */
- gd->bd->bi_arch_number = MACH_TYPE_CPUAT9260;
- /* adress of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91_serial_hw_init();
- cpu9260_nand_hw_init();
- cpu9260_macb_hw_init();
- gd->bd->bi_dram[0].start = PHYS_SDRAM;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE;
- eth_init(gd->bd);
+#endif +} +#endif
- int rc = 0;
+#ifdef CONFIG_MACB
- rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x1F);
- return rc;
- char buf[32];
- printf("\n");
it can not work CONFIG_DISPLAY_CPUINFO is for print_cpuinfo callback when I tell you use CONFIG_DISPLAY_CPUINFO it's because we already implement this printf in cpu/arm926ejs/at91/cpu.c so please update
- project.
- MA 02111-1307 USA
- at91_set_gpio_output(CONFIG_RED_LED, 1);
- at91_set_gpio_output(CONFIG_GREEN_LED, 1);
- at91_set_gpio_output(CONFIG_YELLOW_LED, 1);
- at91_set_gpio_output(CONFIG_BLUE_LED, 1);
- at91_set_gpio_value(CONFIG_RED_LED, 1);
- at91_set_gpio_value(CONFIG_GREEN_LED, 1);
- at91_set_gpio_value(CONFIG_YELLOW_LED, 1);
- at91_set_gpio_value(CONFIG_BLUE_LED, 0);
- Configuration settings for the Eukrea CPU9260 board.
- project.
- MA 02111-1307 USA
please use AT91_MAIN_CLOCK or you will let U-Boot detect it for the clock api
Best Regards, J.
Signed-off-by: Eric Benard eric@eukrea.com --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 13 ++ board/eukrea/cpu9260/Makefile | 59 +++++++ board/eukrea/cpu9260/config.mk | 1 + board/eukrea/cpu9260/cpu9260.c | 211 +++++++++++++++++++++++ board/eukrea/cpu9260/cpu9260_led.c | 46 +++++ board/eukrea/cpu9260/led.c | 46 +++++ include/configs/cpu9260.h | 335 ++++++++++++++++++++++++++++++++++++ 9 files changed, 716 insertions(+), 0 deletions(-) create mode 100644 board/eukrea/cpu9260/Makefile create mode 100644 board/eukrea/cpu9260/config.mk create mode 100644 board/eukrea/cpu9260/cpu9260.c create mode 100644 board/eukrea/cpu9260/cpu9260_led.c create mode 100644 board/eukrea/cpu9260/led.c create mode 100644 include/configs/cpu9260.h
diff --git a/MAINTAINERS b/MAINTAINERS index 620604c..fa85a45 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -521,6 +521,10 @@ Dirk Behme dirk.behme@gmail.com
omap5912osk ARM926EJS diff --git a/MAKEALL b/MAKEALL index edebaea..e081588 100755 --- a/MAKEALL +++ b/MAKEALL @@ -600,6 +600,7 @@ LIST_at91=" \ at91sam9m10g45ek \ at91sam9rlek \ cmc_pu2 \ + cpu9260 \ csb637 \ kb9202 \ meesc \ diff --git a/Makefile b/Makefile index 54c0b67..d1eeb42 100644 --- a/Makefile +++ b/Makefile @@ -2804,6 +2804,19 @@ at91sam9rlek_config : unconfig fi; @$(MKCONFIG) -a at91sam9rlek arm arm926ejs at91sam9rlek atmel at91
diff --git a/board/eukrea/cpu9260/Makefile b/board/eukrea/cpu9260/Makefile new file mode 100644 index 0000000..5b1acdc --- /dev/null +++ b/board/eukrea/cpu9260/Makefile @@ -0,0 +1,59 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# Ilko Iliev <www.ronetix.at> +# +# (C) Copyright 2009 +# Eric Benard eric@eukrea.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-y += $(BOARD)_led.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/eukrea/cpu9260/config.mk b/board/eukrea/cpu9260/config.mk new file mode 100644 index 0000000..9ce161e --- /dev/null +++ b/board/eukrea/cpu9260/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c new file mode 100644 index 0000000..84707b6 --- /dev/null +++ b/board/eukrea/cpu9260/cpu9260.c @@ -0,0 +1,211 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/clk.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void cpu9260_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | + AT91_SMC_DBW_8 | + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void cpu9260_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PA17) => PHY normal mode (not Test mode) + * ERX0 (PA14) => PHY ADDR0 + * ERX1 (PA15) => PHY ADDR1 + * ERX2 (PA25) => PHY ADDR2 + * ERX3 (PA26) => PHY ADDR3 + * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + AT91_RSTC_ERSTL & (0x0D << 8) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of CPUAT9260-Board */ + gd->bd->bi_arch_number = MACH_TYPE_CPUAT9260; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + cpu9260_nand_hw_init(); +#endif +#ifdef CONFIG_MACB + cpu9260_macb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x1F); +#endif + return rc; +} + +#ifdef CONFIG_DISPLAY_CPUINFO +int checkboard(void) +{ + char buf[32]; + + printf("Board : Eukrea Electromatique CPU9260\n"); + printf("Crystal frequency: %8s MHz\n", + strmhz(buf, get_main_clk_rate())); + printf("CPU clock : %8s MHz\n", + strmhz(buf, get_cpu_clk_rate())); + printf("Master clock : %8s MHz\n", + strmhz(buf, get_mck_clk_rate())); + printf("\n"); + return 0; +} +#endif diff --git a/board/eukrea/cpu9260/cpu9260_led.c b/board/eukrea/cpu9260/cpu9260_led.c new file mode 100644 index 0000000..33942c7 --- /dev/null +++ b/board/eukrea/cpu9260/cpu9260_led.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + at91_set_gpio_output(CONFIG_BLUE_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 1); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); + at91_set_gpio_value(CONFIG_BLUE_LED, 0); +} diff --git a/board/eukrea/cpu9260/led.c b/board/eukrea/cpu9260/led.c new file mode 100644 index 0000000..33942c7 --- /dev/null +++ b/board/eukrea/cpu9260/led.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + at91_set_gpio_output(CONFIG_BLUE_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 1); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); + at91_set_gpio_value(CONFIG_BLUE_LED, 0); +} diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h new file mode 100644 index 0000000..1342754 --- /dev/null +++ b/include/configs/cpu9260.h @@ -0,0 +1,335 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * Configuration settings for the Eukrea CPU9260 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_DISPLAY_CPUINFO 1 + +#define CPU9260_CRYSTAL 18432000 +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 + +#define CONFIG_AT91SAM9260 1 + +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ + +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* clocks */ +#define MASTER_PLL_DIV 0x09 +#define MASTER_PLL_MUL 0x61 + +/* CKGR_MOR - enable main osc. */ +#define CONFIG_SYS_MOR_VAL \ + (AT91_PMC_MOSCEN | \ + (255 << 8)) /* Main Oscillator Start-up Time */ +#define CONFIG_SYS_PLLAR_VAL \ + (AT91_PMC_PLLA_WR_ERRATA | /* Bit 29 must be 1 when prog */ \ + AT91_PMC_OUT | \ + ((MASTER_PLL_MUL - 1) << 16) | (MASTER_PLL_DIV)) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR1_VAL \ + (AT91_PMC_CSS_SLOW | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR2_VAL \ + (AT91_PMC_CSS_PLLA | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* define PDC[31:16] as DATA[31:16] */ +#define CONFIG_SYS_PIOC_PDR_VAL1 0xFFFF0000 +/* no pull-up for D[31:16] */ +#define CONFIG_SYS_PIOC_PPUDR_VAL 0xFFFF0000 + +/* EBI_CSA, 3.3V, no pull-ups for D[15:0], CS1 SDRAM, CS3 NAND Flash */ +#define CONFIG_SYS_MATRIX_EBICSA_VAL \ + (AT91_MATRIX_DBPUC | AT91_MATRIX_CS1A_SDRAMC |\ + AT91_MATRIX_CS3A_SMC_SMARTMEDIA | AT91_MATRIX_VDDIOMSEL) + +/* SDRAM */ +/* SDRAMC_MR Mode register */ +#define CONFIG_SYS_SDRC_MR_VAL1 AT91_SDRAMC_MODE_NORMAL +/* SDRAMC_TR - Refresh Timer register */ +#define CONFIG_SYS_SDRC_TR_VAL1 0x287 +/* SDRAMC_CR - Configuration register*/ +#define CONFIG_SYS_SDRC_CR_VAL_64MB \ + (AT91_SDRAMC_NC_9 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +#define CONFIG_SYS_SDRC_CR_VAL_128MB \ + (AT91_SDRAMC_NC_10 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +/* Memory Device Register -> SDRAM */ +#define CONFIG_SYS_SDRC_MDR_VAL AT91_SDRAMC_MD_SDRAM +#define CONFIG_SYS_SDRC_MR_VAL2 AT91_SDRAMC_MODE_PRECHARGE +#define CONFIG_SYS_SDRAM_VAL1 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL3 AT91_SDRAMC_MODE_REFRESH +#define CONFIG_SYS_SDRAM_VAL2 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL3 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL4 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL5 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL6 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL7 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL8 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL9 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL4 AT91_SDRAMC_MODE_LMR +#define CONFIG_SYS_SDRAM_VAL10 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL5 AT91_SDRAMC_MODE_NORMAL +#define CONFIG_SYS_SDRAM_VAL11 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_TR_VAL2 1200 /* SDRAM_TR */ +#define CONFIG_SYS_SDRAM_VAL12 0 /* SDRAM_BASE */ + +/* setup SMC0, CS0 (NOR Flash) - 16-bit, 15 WS */ +#define CONFIG_SYS_SMC0_SETUP0_VAL \ + (AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | \ + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)) +#define CONFIG_SYS_SMC0_PULSE0_VAL \ + (AT91_SMC_NWEPULSE_(6) | AT91_SMC_NCS_WRPULSE_(6) | \ + AT91_SMC_NRDPULSE_(10) | AT91_SMC_NCS_RDPULSE_(10)) +#define CONFIG_SYS_SMC0_CYCLE0_VAL \ + (AT91_SMC_NWECYCLE_(6) | AT91_SMC_NRDCYCLE_(10)) +#define CONFIG_SYS_SMC0_MODE0_VAL \ + (AT91_SMC_READMODE | AT91_SMC_WRITEMODE | \ + AT91_SMC_DBW_16 | \ + AT91_SMC_TDFMODE | \ + AT91_SMC_TDF_(2)) + +/* user reset enable */ +#define CONFIG_SYS_RSTC_RMR_VAL \ + (AT91_RSTC_KEY | \ + AT91_RSTC_PROCRST | \ + AT91_RSTC_RSTTYP_WAKEUP | \ + AT91_RSTC_RSTTYP_WATCHDOG) + +/* Disable Watchdog */ +#define CONFIG_SYS_WDTC_WDMR_VAL \ + (AT91_WDT_WDIDLEHLT | AT91_WDT_WDDBGHLT | \ + AT91_WDT_WDV | \ + AT91_WDT_WDDIS | \ + AT91_WDT_WDD) + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_FAT 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +/* NAND flash */ +#define CONFIG_NAND_ATMEL 1 +#define NAND_MAX_CHIPS 1 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) + +/* NOR flash */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define PHYS_FLASH_1 0x10000000 +#define PHYS_FLASH_2 0x12000000 +#define CONFIG_SYS_FLASH_BANKS_LIST \ + { PHYS_FLASH_1, PHYS_FLASH_2 } +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MAX_FLASH_SECT (255+4) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 + +/* LEDS */ +#define CONFIG_RED_LED AT91_PIN_PC11 +#define CONFIG_GREEN_LED AT91_PIN_PC12 +#define CONFIG_YELLOW_LED AT91_PIN_PC7 +#define CONFIG_BLUE_LED AT91_PIN_PC9 + +/* USB */ +#define CONFIG_USB_ATMEL 1 +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x27e00000 + +#undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_USE_FLASH 1 + +#if defined(CONFIG_SYS_USE_FLASH) +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_OVERWRITE 1 + +#define CONFIG_BOOTCOMMAND "run flashboot" + +#define MTDIDS_DEFAULT "nor0=physmap-flash.0,nand0=nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=physmap-flash.0:" \ + "256k(u-boot)ro," \ + "128k(u-boot-env)ro," \ + "1792k(kernel)," \ + "-(rootfs);" \ + "nand:-(nand)" + +#define CONFIG_BOOTARGS "root=/dev/mtdblock3 rootfstype=jffs2 " + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "partition=nand0,0\0" \ + "ramargs=setenv bootargs $(bootargs) $(mtdparts)\0" \ + "ramboot=tftpboot 0x22000000 cpu9260/uImage;" \ + "run ramargs;bootm 22000000\0" \ + "flashboot=run ramargs;bootm 0x10060000\0" \ + "updtub=tftp 0x24000000 cpu9260/u-boot.bin;protect off" \ + " 0x10000000 0x1003ffff;erase 0x10000000 " \ + "0x1003ffff;cp.b 0x24000000 0x10000000 " \ + "$(filesize)\0" \ + "updtui=tftp 0x24000000 cpu9260/uImage;protect off" \ + " 0x10060000 0x1021ffff;erase 0x10060000 " \ + "0x1021ffff;cp.b 0x24000000 0x10060000 " \ + "$(filesize)\0" \ + "updtrfs=tftp 0x24000000 cpu9260/rootfs.jffs2;protect " \ + "off 0x10220000 0x13ffffff;erase 0x10220000 " \ + "0x13ffffff;cp.b 0x24000000 0x10220000 " \ + "$(filesize)\0" \ + "" +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "CPU9260=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SILENT_CONSOLE 1 +#define CONFIG_NETCONSOLE 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN \ + ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_STACKSIZE (32 * 1024) + +#if defined(CONFIG_USE_IRQ) +#error CONFIG_USE_IRQ not supported +#endif + +#endif
CPUAT91 is built around Atmel's AT91SAM9260 and has up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND and includes a 10/100 Ethernet PHY in RMII mode.
Signed-off-by: Eric Benard eric@eukrea.com --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 13 ++ board/eukrea/cpu9260/Makefile | 59 +++++++ board/eukrea/cpu9260/config.mk | 1 + board/eukrea/cpu9260/cpu9260.c | 194 +++++++++++++++++++++++ board/eukrea/cpu9260/led.c | 46 ++++++ include/configs/cpu9260.h | 335 ++++++++++++++++++++++++++++++++++++++++ 8 files changed, 653 insertions(+), 0 deletions(-) create mode 100644 board/eukrea/cpu9260/Makefile create mode 100644 board/eukrea/cpu9260/config.mk create mode 100644 board/eukrea/cpu9260/cpu9260.c create mode 100644 board/eukrea/cpu9260/led.c create mode 100644 include/configs/cpu9260.h
omap3_beagle ARM CORTEX-A8 (OMAP3530 SoC)
+Eric Benard eric@eukrea.com + + cpu9260 ARM926EJS (AT91SAM9260 SoC) + Rishi Bhattacharya rishi@ti.com
diff --git a/board/eukrea/cpu9260/Makefile b/board/eukrea/cpu9260/Makefile new file mode 100644 index 0000000..a718014 --- /dev/null +++ b/board/eukrea/cpu9260/Makefile @@ -0,0 +1,59 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# Ilko Iliev <www.ronetix.at> +# +# (C) Copyright 2009 +# Eric Benard eric@eukrea.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-y += led.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/eukrea/cpu9260/config.mk b/board/eukrea/cpu9260/config.mk new file mode 100644 index 0000000..9ce161e --- /dev/null +++ b/board/eukrea/cpu9260/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c new file mode 100644 index 0000000..a6910a9 --- /dev/null +++ b/board/eukrea/cpu9260/cpu9260.c @@ -0,0 +1,194 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/sizes.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91sam9_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/clk.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void cpu9260_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | + AT91_SMC_DBW_8 | + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void cpu9260_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PA17) => PHY normal mode (not Test mode) + * ERX0 (PA14) => PHY ADDR0 + * ERX1 (PA15) => PHY ADDR1 + * ERX2 (PA25) => PHY ADDR2 + * ERX3 (PA26) => PHY ADDR3 + * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + AT91_RSTC_ERSTL & (0x0D << 8) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* arch number of CPUAT9260-Board */ + gd->bd->bi_arch_number = MACH_TYPE_CPUAT9260; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + cpu9260_nand_hw_init(); +#endif +#ifdef CONFIG_MACB + cpu9260_macb_hw_init(); +#endif + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x1F); +#endif + return rc; +} diff --git a/board/eukrea/cpu9260/led.c b/board/eukrea/cpu9260/led.c new file mode 100644 index 0000000..33942c7 --- /dev/null +++ b/board/eukrea/cpu9260/led.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> + +void coloured_LED_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + at91_set_gpio_output(CONFIG_RED_LED, 1); + at91_set_gpio_output(CONFIG_GREEN_LED, 1); + at91_set_gpio_output(CONFIG_YELLOW_LED, 1); + at91_set_gpio_output(CONFIG_BLUE_LED, 1); + + at91_set_gpio_value(CONFIG_RED_LED, 1); + at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_gpio_value(CONFIG_YELLOW_LED, 1); + at91_set_gpio_value(CONFIG_BLUE_LED, 0); +} diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h new file mode 100644 index 0000000..c3ce3e4 --- /dev/null +++ b/include/configs/cpu9260.h @@ -0,0 +1,335 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Ilko Iliev <www.ronetix.at> + * + * (C) Copyright 2009 + * Eric Benard eric@eukrea.com + * + * Configuration settings for the Eukrea CPU9260 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_DISPLAY_CPUINFO 1 + +#define AT91_MAIN_CLOCK 18432000 +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 + +#define CONFIG_AT91SAM9260 1 + +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ + +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* clocks */ +#define MASTER_PLL_DIV 0x09 +#define MASTER_PLL_MUL 0x61 + +/* CKGR_MOR - enable main osc. */ +#define CONFIG_SYS_MOR_VAL \ + (AT91_PMC_MOSCEN | \ + (255 << 8)) /* Main Oscillator Start-up Time */ +#define CONFIG_SYS_PLLAR_VAL \ + (AT91_PMC_PLLA_WR_ERRATA | /* Bit 29 must be 1 when prog */ \ + AT91_PMC_OUT | \ + ((MASTER_PLL_MUL - 1) << 16) | (MASTER_PLL_DIV)) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR1_VAL \ + (AT91_PMC_CSS_SLOW | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* PCK/2 = MCK Master Clock from PLLA */ +#define CONFIG_SYS_MCKR2_VAL \ + (AT91_PMC_CSS_PLLA | \ + AT91_PMC_PRES_1 | \ + AT91SAM9_PMC_MDIV_2 | \ + AT91_PMC_PDIV_1) + +/* define PDC[31:16] as DATA[31:16] */ +#define CONFIG_SYS_PIOC_PDR_VAL1 0xFFFF0000 +/* no pull-up for D[31:16] */ +#define CONFIG_SYS_PIOC_PPUDR_VAL 0xFFFF0000 + +/* EBI_CSA, 3.3V, no pull-ups for D[15:0], CS1 SDRAM, CS3 NAND Flash */ +#define CONFIG_SYS_MATRIX_EBICSA_VAL \ + (AT91_MATRIX_DBPUC | AT91_MATRIX_CS1A_SDRAMC |\ + AT91_MATRIX_CS3A_SMC_SMARTMEDIA | AT91_MATRIX_VDDIOMSEL) + +/* SDRAM */ +/* SDRAMC_MR Mode register */ +#define CONFIG_SYS_SDRC_MR_VAL1 AT91_SDRAMC_MODE_NORMAL +/* SDRAMC_TR - Refresh Timer register */ +#define CONFIG_SYS_SDRC_TR_VAL1 0x287 +/* SDRAMC_CR - Configuration register*/ +#define CONFIG_SYS_SDRC_CR_VAL_64MB \ + (AT91_SDRAMC_NC_9 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +#define CONFIG_SYS_SDRC_CR_VAL_128MB \ + (AT91_SDRAMC_NC_10 | \ + AT91_SDRAMC_NR_13 | \ + AT91_SDRAMC_NB_4 | \ + AT91_SDRAMC_CAS_2 | \ + AT91_SDRAMC_DBW_32 | \ + (2 << 8) | /* Write Recovery Delay */ \ + (7 << 12) | /* Row Cycle Delay */ \ + (2 << 16) | /* Row Precharge Delay */ \ + (2 << 20) | /* Row to Column Delay */ \ + (5 << 24) | /* Active to Precharge Delay */ \ + (8 << 28)) /* Exit Self Refresh to Active Delay */ + +/* Memory Device Register -> SDRAM */ +#define CONFIG_SYS_SDRC_MDR_VAL AT91_SDRAMC_MD_SDRAM +#define CONFIG_SYS_SDRC_MR_VAL2 AT91_SDRAMC_MODE_PRECHARGE +#define CONFIG_SYS_SDRAM_VAL1 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL3 AT91_SDRAMC_MODE_REFRESH +#define CONFIG_SYS_SDRAM_VAL2 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL3 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL4 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL5 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL6 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL7 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL8 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRAM_VAL9 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL4 AT91_SDRAMC_MODE_LMR +#define CONFIG_SYS_SDRAM_VAL10 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_MR_VAL5 AT91_SDRAMC_MODE_NORMAL +#define CONFIG_SYS_SDRAM_VAL11 0 /* SDRAM_BASE */ +#define CONFIG_SYS_SDRC_TR_VAL2 1200 /* SDRAM_TR */ +#define CONFIG_SYS_SDRAM_VAL12 0 /* SDRAM_BASE */ + +/* setup SMC0, CS0 (NOR Flash) - 16-bit, 15 WS */ +#define CONFIG_SYS_SMC0_SETUP0_VAL \ + (AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | \ + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)) +#define CONFIG_SYS_SMC0_PULSE0_VAL \ + (AT91_SMC_NWEPULSE_(6) | AT91_SMC_NCS_WRPULSE_(6) | \ + AT91_SMC_NRDPULSE_(10) | AT91_SMC_NCS_RDPULSE_(10)) +#define CONFIG_SYS_SMC0_CYCLE0_VAL \ + (AT91_SMC_NWECYCLE_(6) | AT91_SMC_NRDCYCLE_(10)) +#define CONFIG_SYS_SMC0_MODE0_VAL \ + (AT91_SMC_READMODE | AT91_SMC_WRITEMODE | \ + AT91_SMC_DBW_16 | \ + AT91_SMC_TDFMODE | \ + AT91_SMC_TDF_(2)) + +/* user reset enable */ +#define CONFIG_SYS_RSTC_RMR_VAL \ + (AT91_RSTC_KEY | \ + AT91_RSTC_PROCRST | \ + AT91_RSTC_RSTTYP_WAKEUP | \ + AT91_RSTC_RSTTYP_WATCHDOG) + +/* Disable Watchdog */ +#define CONFIG_SYS_WDTC_WDMR_VAL \ + (AT91_WDT_WDIDLEHLT | AT91_WDT_WDDBGHLT | \ + AT91_WDT_WDV | \ + AT91_WDT_WDDIS | \ + AT91_WDT_WDD) + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_FAT 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +/* NAND flash */ +#define CONFIG_NAND_ATMEL 1 +#define NAND_MAX_CHIPS 1 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) + +/* NOR flash */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define PHYS_FLASH_1 0x10000000 +#define PHYS_FLASH_2 0x12000000 +#define CONFIG_SYS_FLASH_BANKS_LIST \ + { PHYS_FLASH_1, PHYS_FLASH_2 } +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MAX_FLASH_SECT (255+4) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 + +/* LEDS */ +#define CONFIG_RED_LED AT91_PIN_PC11 +#define CONFIG_GREEN_LED AT91_PIN_PC12 +#define CONFIG_YELLOW_LED AT91_PIN_PC7 +#define CONFIG_BLUE_LED AT91_PIN_PC9 + +/* USB */ +#define CONFIG_USB_ATMEL 1 +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x27e00000 + +#undef CONFIG_SYS_USE_NANDFLASH +#define CONFIG_SYS_USE_FLASH 1 + +#if defined(CONFIG_SYS_USE_FLASH) +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_OVERWRITE 1 + +#define CONFIG_BOOTCOMMAND "run flashboot" + +#define MTDIDS_DEFAULT "nor0=physmap-flash.0,nand0=nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=physmap-flash.0:" \ + "256k(u-boot)ro," \ + "128k(u-boot-env)ro," \ + "1792k(kernel)," \ + "-(rootfs);" \ + "nand:-(nand)" + +#define CONFIG_BOOTARGS "root=/dev/mtdblock3 rootfstype=jffs2 " + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "partition=nand0,0\0" \ + "ramargs=setenv bootargs $(bootargs) $(mtdparts)\0" \ + "ramboot=tftpboot 0x22000000 cpu9260/uImage;" \ + "run ramargs;bootm 22000000\0" \ + "flashboot=run ramargs;bootm 0x10060000\0" \ + "updtub=tftp 0x24000000 cpu9260/u-boot.bin;protect off" \ + " 0x10000000 0x1003ffff;erase 0x10000000 " \ + "0x1003ffff;cp.b 0x24000000 0x10000000 " \ + "$(filesize)\0" \ + "updtui=tftp 0x24000000 cpu9260/uImage;protect off" \ + " 0x10060000 0x1021ffff;erase 0x10060000 " \ + "0x1021ffff;cp.b 0x24000000 0x10060000 " \ + "$(filesize)\0" \ + "updtrfs=tftp 0x24000000 cpu9260/rootfs.jffs2;protect " \ + "off 0x10220000 0x13ffffff;erase 0x10220000 " \ + "0x13ffffff;cp.b 0x24000000 0x10220000 " \ + "$(filesize)\0" \ + "" +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "CPU9260=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_SILENT_CONSOLE 1 +#define CONFIG_NETCONSOLE 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN \ + ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_STACKSIZE (32 * 1024) + +#if defined(CONFIG_USE_IRQ) +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Dear Eric Benard,
Would you please indicate what's the difference between the patches you submit? Such comment belongs below the '---' line!
What exactly is the difference between v5 and v6 of this patch? You sent these just 12 minutes apart, but without any word of explanation!
Dear Wolfgang Denx,
Is there a way to add these comments using git or should I edit the patch before sending it ?
sorry, it was a mistake using git ... v5 = v4 v6 fixes Jean Christophe's comments.
Eric
Dear =?ISO-8859-1?Q?Eric_B=E9nard?=,
Edit the patch, and insert your comments below the '---' line.
applied to u-boot-arm
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
Please undo. This patch is not ripe yet. NAK from me.
Eric Benard
Eric Bénard
