[U-Boot] [PATCH] arm64: zynqmp: Add support for verifying secure images
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch adds new command "zynqmp" to handle zynqmp specific commands like "zynqmp secure". This secure command is used for verifying zynqmp specific secure images. The secure image can either be authenticated or encrypted or both encrypted and authenticated. The secure image is prepared using bootgen and will be in xilinx specific BOOT.BIN format. The optional key can be used for decryption of encrypted image if user key was specified while creation BOOT.BIN.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/Kconfig | 1 + arch/arm/include/asm/arch-zynqmp/sys_proto.h | 2 + board/xilinx/zynqmp/Kconfig | 18 +++++ board/xilinx/zynqmp/Makefile | 4 + board/xilinx/zynqmp/cmds.c | 105 +++++++++++++++++++++++++++ configs/xilinx_zynqmp_mini_emmc_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + 7 files changed, 132 insertions(+) create mode 100644 board/xilinx/zynqmp/Kconfig create mode 100644 board/xilinx/zynqmp/cmds.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4b5c64c8ba8b..a6e152237a70 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1336,6 +1336,7 @@ source "board/toradex/colibri_pxa270/Kconfig" source "board/vscom/baltos/Kconfig" source "board/woodburn/Kconfig" source "board/work-microwave/work_92105/Kconfig" +source "board/xilinx/zynqmp/Kconfig" source "board/zipitz2/Kconfig"
source "arch/arm/Kconfig.debug" diff --git a/arch/arm/include/asm/arch-zynqmp/sys_proto.h b/arch/arm/include/asm/arch-zynqmp/sys_proto.h index 084d55a2b01f..ad3dc9aba50d 100644 --- a/arch/arm/include/asm/arch-zynqmp/sys_proto.h +++ b/arch/arm/include/asm/arch-zynqmp/sys_proto.h @@ -11,6 +11,8 @@ #define PAYLOAD_ARG_CNT 5
#define ZYNQMP_CSU_SILICON_VER_MASK 0xF +#define ZYNQMP_SIP_SVC_PM_SECURE_IMG_LOAD 0xC200002D +#define KEY_PTR_LEN 32
enum { IDCODE, diff --git a/board/xilinx/zynqmp/Kconfig b/board/xilinx/zynqmp/Kconfig new file mode 100644 index 000000000000..7d1f7398c3e9 --- /dev/null +++ b/board/xilinx/zynqmp/Kconfig @@ -0,0 +1,18 @@ +# Copyright (c) 2018, Xilinx, Inc. +# +# SPDX-License-Identifier: GPL-2.0 + +if ARCH_ZYNQMP + +config CMD_ZYNQMP + bool "Enable ZynqMP specific commands" + default y + help + Enable ZynqMP specific commands like "zynqmp secure" + which is used for zynqmp secure image verification. + The secure image is a xilinx specific BOOT.BIN with + either authentication or encryption or both encryption + and authentication feature enabled while generating + BOOT.BIN using Xilinx bootgen tool. + +endif diff --git a/board/xilinx/zynqmp/Makefile b/board/xilinx/zynqmp/Makefile index 75aab92f0473..3b7a10e202e5 100644 --- a/board/xilinx/zynqmp/Makefile +++ b/board/xilinx/zynqmp/Makefile @@ -26,6 +26,10 @@ ifneq ($(call ifdef_any_of, CONFIG_ZYNQMP_PSU_INIT_ENABLED CONFIG_SPL_BUILD),) obj-y += $(init-objs) endif
+ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_CMD_ZYNQMP) += cmds.o +endif + # Suppress "warning: function declaration isn't a prototype" CFLAGS_REMOVE_psu_init_gpl.o := -Wstrict-prototypes
diff --git a/board/xilinx/zynqmp/cmds.c b/board/xilinx/zynqmp/cmds.c new file mode 100644 index 000000000000..6712d7b8cfaa --- /dev/null +++ b/board/xilinx/zynqmp/cmds.c @@ -0,0 +1,105 @@ +/* + * (C) Copyright 2018 Xilinx, Inc. + * Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> + +static int zynqmp_verify_secure(u8 *key_ptr, u8 *src_ptr, u32 len) +{ + int ret; + u32 src_lo, src_hi; + u32 key_lo = 0; + u32 key_hi = 0; + u32 ret_payload[PAYLOAD_ARG_CNT]; + u64 addr; + + if ((ulong)src_ptr != ALIGN((ulong)src_ptr, + CONFIG_SYS_CACHELINE_SIZE)) { + printf("Failed: source address not aligned:%p\n", src_ptr); + return -EINVAL; + } + + src_lo = lower_32_bits((ulong)src_ptr); + src_hi = upper_32_bits((ulong)src_ptr); + flush_dcache_range((ulong)src_ptr, (ulong)(src_ptr + len)); + + if (key_ptr) { + key_lo = lower_32_bits((ulong)key_ptr); + key_hi = upper_32_bits((ulong)key_ptr); + flush_dcache_range((ulong)key_ptr, + (ulong)(key_ptr + KEY_PTR_LEN)); + } + + ret = invoke_smc(ZYNQMP_SIP_SVC_PM_SECURE_IMG_LOAD, src_lo, src_hi, + key_lo, key_hi, ret_payload); + if (ret) { + printf("Failed: secure op status:0x%x\n", ret); + } else { + addr = (u64)ret_payload[1] << 32 | ret_payload[2]; + printf("Verified image at 0x%llx\n", addr); + env_set_hex("zynqmp_verified_img_addr", addr); + } + + return ret; +} + +/** + * do_zynqmp - Handle the "zynqmp" command-line command + * @cmdtp: Command data struct pointer + * @flag: Command flag + * @argc: Command-line argument count + * @argv: Array of command-line arguments + * + * Processes the zynqmp specific commands + * + * Return: return 0 on success and CMD_RET_USAGE incase of misuse and error + */ +static int do_zynqmp(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + u64 src_addr; + u32 len; + u8 *key_ptr = NULL; + u8 *src_ptr; + int ret; + + if (argc > 5 || argc < 4 || strncmp(argv[1], "secure", 6)) + return CMD_RET_USAGE; + + src_addr = simple_strtoull(argv[2], NULL, 16); + + len = simple_strtoul(argv[3], NULL, 16); + + if (argc > 4) + key_ptr = (uint8_t *)(uintptr_t)simple_strtoull(argv[4], + NULL, 16); + + src_ptr = (uint8_t *)(uintptr_t)src_addr; + + ret = zynqmp_verify_secure(key_ptr, src_ptr, len); + if (ret) + return CMD_RET_FAILURE; + + return CMD_RET_SUCCESS; +} + +/***************************************************/ +#ifdef CONFIG_SYS_LONGHELP +static char zynqmp_help_text[] = + "secure src len [key_addr] - verifies secure images of $len bytes\n" + " long at address $src. Optional key_addr\n" + " can be specified if user key needs to\n" + " be used for decryption\n"; +#endif + +U_BOOT_CMD( + zynqmp, 5, 1, do_zynqmp, + "Verify and load secure images", + zynqmp_help_text +) diff --git a/configs/xilinx_zynqmp_mini_emmc_defconfig b/configs/xilinx_zynqmp_mini_emmc_defconfig index b15120e0fae4..8f2596a8940e 100644 --- a/configs/xilinx_zynqmp_mini_emmc_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_emmc" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 +# CONFIG_CMD_ZYNQMP is not set CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 55200bcb058d..1fec9bab7c0c 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_nand" CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 +# CONFIG_CMD_ZYNQMP is not set CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" CONFIG_ENV_VARS_UBOOT_CONFIG=y CONFIG_FIT=y
Michal Simek
