[U-Boot] [RFC PATCH] common, kconfig: move VERSION_VARIABLE to Kconfig
move VERSION_VARIABLE from board config file into a Kconfig option.
Signed-off-by: Heiko Schocher hs@denx.de ---
Tested with tbot: http://lists.denx.de/pipermail/u-boot/2016-June/258119.html
result from first run: Boards : 1193 compile err : 60 not checked : 1 U-Boot good : 1129 bad 3 SPL good : 411 bad 0 ('compile err :', [...] ('not checked :', ['xtfpga']) ('bad :', ['sandbox', 'sandbox_noblk', 'sandbox_spl'])
The 3 bad boards are the sandbox builds, I must find time to find out, why the sandbox build is not reproducible ...
I had a toolchain issue with arm64 build, fixed now, result for the second run (only for the boards which had compile errors before): Boards : 60 compile err : 8 not checked : 0 U-Boot good : 52 bad 0 SPL good : 16 bad 0 ('compile err :', ['bf533-stamp', 'cm-bf527', 'colibri_pxa270', 'omap4_panda', 'openrisc-generic', 'smdk5250', 'snow', 'spring'])
So, this patch does not change the resulting binaries ...
One remark: define CONFIG_SPL_NET_VCI_STRING="..." is removed from some defconfigs, but not again added to the defconfig. This is for all boards, which use this define ... but as the resulting images are not changes, this seems no problem... This is the reason for the "RFC" state ... any comments?
common/Kconfig | 10 +++++++++ configs/10m50_defconfig | 5 +++-- configs/3c120_defconfig | 5 +++-- configs/CPCI2DP_defconfig | 1 + configs/CPCI4052_defconfig | 1 + configs/MigoR_defconfig | 1 + configs/PLU405_defconfig | 1 + configs/PMC405DE_defconfig | 1 + configs/PMC440_defconfig | 1 + configs/VOM405_defconfig | 1 + configs/acadia_defconfig | 1 + configs/alt_defconfig | 3 ++- configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 3 ++- configs/am335x_evm_defconfig | 11 +++++----- configs/am335x_evm_nor_defconfig | 2 +- configs/am335x_evm_norboot_defconfig | 4 ++-- configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 2 +- configs/am335x_igep0033_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_prompt_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_shc_sdboot_prompt_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 11 +++++----- configs/am43xx_evm_ethboot_defconfig | 2 +- configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 15 +++++++------- configs/am43xx_hs_evm_defconfig | 13 ++++++------ configs/am57xx_evm_defconfig | 25 +++++++++++----------- configs/am57xx_evm_nodt_defconfig | 11 +++++----- configs/am57xx_hs_evm_defconfig | 28 ++++++++++++------------- configs/ap325rxa_defconfig | 1 + configs/ap_sh4a_4a_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/arches_defconfig | 1 + configs/armadillo-800eva_defconfig | 1 + configs/bamboo_defconfig | 1 + configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bcm23550_w1d_defconfig | 1 + configs/bcm28155_ap_defconfig | 1 + configs/bcm28155_w1d_defconfig | 1 + configs/bcm911360_entphn-ns_defconfig | 1 + configs/bcm911360_entphn_defconfig | 1 + configs/bcm911360k_defconfig | 1 + configs/bcm958300k-ns_defconfig | 1 + configs/bcm958300k_defconfig | 1 + configs/bcm958305k_defconfig | 1 + configs/bcm958622hr_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/birdland_bav335a_defconfig | 2 +- configs/birdland_bav335b_defconfig | 2 +- configs/blanche_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/bubinga_defconfig | 1 + configs/cairo_defconfig | 1 + configs/calimain_defconfig | 1 + configs/canyonlands_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t43_defconfig | 5 +++-- configs/cm_t54_defconfig | 1 + configs/colibri_vf_defconfig | 7 ++++--- configs/da850_am18xxevm_defconfig | 1 + configs/da850evm_defconfig | 3 ++- configs/da850evm_direct_nor_defconfig | 1 + configs/devconcenter_defconfig | 1 + configs/devkit3250_defconfig | 9 ++++---- configs/devkit8000_defconfig | 1 + configs/dlvision-10g_defconfig | 1 + configs/dlvision_defconfig | 1 + configs/dra7xx_evm_defconfig | 29 +++++++++++++------------- configs/dra7xx_hs_evm_defconfig | 33 +++++++++++++++--------------- configs/duovero_defconfig | 1 + configs/ea20_defconfig | 1 + configs/ecovec_defconfig | 1 + configs/espt_defconfig | 1 + configs/gdppc440etx_defconfig | 1 + configs/glacier_defconfig | 1 + configs/glacier_ramboot_defconfig | 1 + configs/gose_defconfig | 3 ++- configs/haleakala_defconfig | 1 + configs/icon_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/igep0020_defconfig | 2 +- configs/igep0030_defconfig | 1 + configs/igep0030_nand_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/intip_defconfig | 1 + configs/io64_defconfig | 1 + configs/io_defconfig | 1 + configs/iocon_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/k2e_evm_defconfig | 8 ++++---- configs/k2g_evm_defconfig | 11 +++++----- configs/k2hk_evm_defconfig | 8 ++++---- configs/k2l_evm_defconfig | 8 ++++---- configs/katmai_defconfig | 1 + configs/kilauea_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge4_defconfig | 1 + configs/kmcoge5ne_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmeter1_defconfig | 1 + configs/kmlion1_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmopti2_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsupx5_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/kmtegr1_defconfig | 1 + configs/kmtepr2_defconfig | 1 + configs/kmvect1_defconfig | 1 + configs/koelsch_defconfig | 3 ++- configs/kzm9g_defconfig | 1 + configs/lager_defconfig | 3 ++- configs/legoev3_defconfig | 1 + configs/luan_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/ma5d4evk_defconfig | 1 + configs/makalu_defconfig | 1 + configs/mgcoge3ne_defconfig | 1 + configs/mgcoge3un_defconfig | 1 + configs/mgcoge_defconfig | 1 + configs/motionpro_defconfig | 1 + configs/mpr2_defconfig | 1 + configs/ms7720se_defconfig | 1 + configs/ms7722se_defconfig | 1 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/neo_defconfig | 1 + configs/novena_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_logic_defconfig | 2 +- configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omap5_uevm_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/pcm051_rev1_defconfig | 2 +- configs/pcm051_rev3_defconfig | 2 +- configs/pengwyn_defconfig | 1 + configs/pepper_defconfig | 1 + configs/porter_defconfig | 4 ++-- configs/portl2_defconfig | 1 + configs/r0p7734_defconfig | 1 + configs/rainier_defconfig | 1 + configs/rainier_ramboot_defconfig | 1 + configs/redwood_defconfig | 1 + configs/rsk7203_defconfig | 1 + configs/salvator-x_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sc_sps_1_defconfig | 1 + configs/sequoia_defconfig | 1 + configs/sequoia_ramboot_defconfig | 1 + configs/sh7752evb_defconfig | 1 + configs/sh7753evb_defconfig | 1 + configs/sh7757lcr_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 1 + configs/sh7785lcr_defconfig | 1 + configs/shmin_defconfig | 1 + configs/silk_defconfig | 3 ++- configs/socfpga_arria5_defconfig | 7 ++++--- configs/socfpga_cyclone5_defconfig | 7 ++++--- configs/socfpga_de0_nano_soc_defconfig | 7 ++++--- configs/socfpga_is1_defconfig | 5 +++-- configs/socfpga_mcvevk_defconfig | 7 ++++--- configs/socfpga_sockit_defconfig | 7 ++++--- configs/socfpga_socrates_defconfig | 7 ++++--- configs/socfpga_sr1500_defconfig | 7 ++++--- configs/socfpga_vining_fpga_defconfig | 7 ++++--- configs/stout_defconfig | 3 ++- configs/suvd3_defconfig | 1 + configs/sycamore_defconfig | 1 + configs/t3corp_defconfig | 1 + configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/tplink_wdr4300_defconfig | 7 ++++--- configs/tuge1_defconfig | 1 + configs/tuxx1_defconfig | 1 + configs/walnut_defconfig | 1 + configs/work_92105_defconfig | 9 ++++---- configs/xfi3_defconfig | 1 + configs/xilinx-ppc405-generic_defconfig | 1 + configs/xilinx-ppc440-generic_defconfig | 1 + configs/xtfpga_defconfig | 3 ++- configs/yellowstone_defconfig | 1 + configs/yosemite_defconfig | 1 + configs/yucca_defconfig | 1 + include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/CPCI2DP.h | 2 -- include/configs/CPCI4052.h | 2 -- include/configs/MigoR.h | 1 - include/configs/PLU405.h | 2 -- include/configs/PMC405DE.h | 1 - include/configs/PMC440.h | 1 - include/configs/VOM405.h | 2 -- include/configs/am335x_shc.h | 2 -- include/configs/am3517_evm.h | 1 - include/configs/amcc-common.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/apf27.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/bcm23550_w1d.h | 1 - include/configs/bcm28155_ap.h | 1 - include/configs/bcm_ep_board.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/calimain.h | 1 - include/configs/colibri_vf.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit3250.h | 1 - include/configs/ea20.h | 1 - include/configs/ecovec.h | 1 - include/configs/espt.h | 1 - include/configs/ids8313.h | 2 -- include/configs/ipam390.h | 1 - include/configs/km/keymile-common.h | 2 -- include/configs/kzm9g.h | 1 - include/configs/legoev3.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/motionpro.h | 2 -- include/configs/mpr2.h | 1 - include/configs/ms7720se.h | 1 - include/configs/ms7722se.h | 1 - include/configs/mxs.h | 1 - include/configs/novena.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/pengwyn.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/rsk7203.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7763rdp.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/shmin.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/tplink_wdr4300.h | 1 - include/configs/work_92105.h | 1 - include/configs/xilinx-ppc.h | 1 - include/configs/xtfpga.h | 1 - 270 files changed, 369 insertions(+), 241 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 4494112..63c4a67 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -203,3 +203,13 @@ config SYS_NO_FLASH default n help This option is used to disable support for parallel NOR flash. + +config VERSION_VARIABLE + bool "add U-Boot environment variable vers" + default n + help + If this variable is defined, an environment variable + named "ver" is created by U-Boot showing the U-Boot + version as printed by the "version" command. + Any change to this variable will be reverted at the + next reset. diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index 15952af..05fad1e 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -1,10 +1,9 @@ CONFIG_NIOS2=y CONFIG_SYS_CONFIG_NAME="10m50_devboard" -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="10m50_devboard" CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_CPU=y @@ -19,6 +18,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y CONFIG_MISC=y CONFIG_ALTERA_SYSID=y @@ -26,6 +26,7 @@ CONFIG_MTD=y CONFIG_ALTERA_QSPI=y CONFIG_DM_ETH=y CONFIG_ALTERA_TSE=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_TIMER=y CONFIG_ALTERA_TIMER=y diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index b19c956..dc0d74a 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -1,10 +1,9 @@ CONFIG_NIOS2=y CONFIG_SYS_CONFIG_NAME="3c120_devboard" -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="3c120_devboard" CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_CPU=y @@ -19,6 +18,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y CONFIG_MISC=y CONFIG_ALTERA_SYSID=y @@ -26,6 +26,7 @@ CONFIG_MTD=y CONFIG_CFI_FLASH=y CONFIG_DM_ETH=y CONFIG_ALTERA_TSE=y +CONFIG_DM_SERIAL=y CONFIG_ALTERA_JTAG_UART=y CONFIG_ALTERA_JTAG_UART_BYPASS=y CONFIG_TIMER=y diff --git a/configs/CPCI2DP_defconfig b/configs/CPCI2DP_defconfig index 99e4ad0..470e070 100644 --- a/configs/CPCI2DP_defconfig +++ b/configs/CPCI2DP_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_CPCI2DP=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/CPCI4052_defconfig b/configs/CPCI4052_defconfig index d7c71c1..32e1cb1 100644 --- a/configs/CPCI4052_defconfig +++ b/configs/CPCI4052_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_CPCI4052=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/MigoR_defconfig b/configs/MigoR_defconfig index 129403c..3a2b9bb 100644 --- a/configs/MigoR_defconfig +++ b/configs/MigoR_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_MIGOR=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/PLU405_defconfig b/configs/PLU405_defconfig index a0e8411..dbbd019 100644 --- a/configs/PLU405_defconfig +++ b/configs/PLU405_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_PLU405=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/PMC405DE_defconfig b/configs/PMC405DE_defconfig index cdb82d6..8f1410e 100644 --- a/configs/PMC405DE_defconfig +++ b/configs/PMC405DE_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_PMC405DE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index 704cd36..c505dd5 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_PMC440=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/VOM405_defconfig b/configs/VOM405_defconfig index 800731b..82446e0 100644 --- a/configs/VOM405_defconfig +++ b/configs/VOM405_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_VOM405=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/acadia_defconfig b/configs/acadia_defconfig index 24d802e..e00f70e 100644 --- a/configs/acadia_defconfig +++ b/configs/acadia_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_ACADIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 15964c6..772ddc5 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -2,10 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_ALT=y -CONFIG_BOOTDELAY=3 CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 78f55cc..84595dd 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index d310e0b..8e92fcc 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index c2f09cb..ecd3db3 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT,ENABLE_VBOOT" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" @@ -34,6 +35,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y @@ -49,4 +51,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_DM_I2C=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 6885230..f9ae570 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -4,7 +4,10 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_SPL_LOAD_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -27,6 +30,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2" +CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y @@ -42,11 +47,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL" CONFIG_RSA=y -CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2" -CONFIG_DM_I2C=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 76a004e..cf3921a 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -38,4 +39,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL" diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 99fc555..0c5ab35 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -1,8 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_AM335X_EVM=y CONFIG_NOR=y -CONFIG_NOR_BOOT=y CONFIG_FIT=y +CONFIG_NOR_BOOT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -35,4 +36,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL" diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 2fe1a25..0fec040 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SPI_BOOT" CONFIG_SPI_BOOT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index cba5e84..0984bb3 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND,SPL_USBETH_SUPPORT" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -38,4 +39,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL" diff --git a/configs/am335x_igep0033_defconfig b/configs/am335x_igep0033_defconfig index d6022a3..efa3a9c 100644 --- a/configs/am335x_igep0033_defconfig +++ b/configs/am335x_igep0033_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_AM335X_IGEP0033=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index c83311f..be9a99e 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index bfb56b2..8d6c8d9 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter 'shc' to enter prompt (times out) %d \nEnter 'noautoboot' to enter prompt without timeout\n" diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index d16c5f0..2e70a51 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter 'shc' to enter prompt (times out) %d \nEnter 'noautoboot' to enter prompt without timeout\n" diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index b9bc355..764fc9f 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter 'shc' to enter prompt (times out) %d \nEnter 'noautoboot' to enter prompt without timeout\n" CONFIG_AUTOBOOT_DELAY_STR="shc" diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index b0e8eff..ba77c2d 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter 'shc' to enter prompt (times out) %d \nEnter 'noautoboot' to enter prompt without timeout\n" diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index b0e8eff..ba77c2d 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter 'shc' to enter prompt (times out) %d \nEnter 'noautoboot' to enter prompt without timeout\n" diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 01c1eeb..dae8f1b 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index b4aa3c6..5fb33b7 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AM3517_EVM # " CONFIG_CMD_BOOTZ=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 56782f1..713e1aa 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -1,8 +1,6 @@ CONFIG_ARM=y CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_SPL=y @@ -10,6 +8,7 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,NAND" CONFIG_SPL_LOAD_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -34,10 +33,14 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_DM_ETH=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y CONFIG_TIMER=y @@ -55,5 +58,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 CONFIG_SPL_OF_LIBFDT=y -CONFIG_DM_I2C=y -CONFIG_DM_ETH=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 3b958d7..0794f86 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -3,6 +3,7 @@ CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_ETH_SUPPORT" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -41,4 +42,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="AM43xx U-Boot SPL" diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index c6bc8e4..5e7f1a7 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AM43XX_EVM=y CONFIG_ISW_ENTRY_ADDR=0x30000000 CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" CONFIG_QSPI_BOOT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 34c875e..03897f2 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -1,14 +1,15 @@ CONFIG_ARM=y CONFIG_AM43XX=y CONFIG_TARGET_AM43XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y +CONFIG_ISW_ENTRY_ADDR=0x40300350 CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_SPL=y -CONFIG_ISW_ENTRY_ADDR=0x40300350 CONFIG_SPL_STACK_R=y +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_USB_HOST_SUPPORT" +CONFIG_SPL_LOAD_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -31,10 +32,13 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" CONFIG_DM=y +CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y CONFIG_TIMER=y @@ -51,9 +55,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 -CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="AM43xx U-Boot SPL" -CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 7861035..74dd0de 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -2,19 +2,17 @@ CONFIG_ARM=y CONFIG_AM43XX=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TARGET_AM43XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y +CONFIG_ISW_ENTRY_ADDR=0x403018e0 CONFIG_SPL_STACK_R_ADDR=0x82000000 -# Device tree file can be same on HS evm CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_SPL=y -CONFIG_ISW_ENTRY_ADDR=0x403018e0 CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1, NAND" CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -37,11 +35,14 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y -CONFIG_OF_LIST="am437x-gp-evm" CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_DM_ETH=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y CONFIG_TIMER=y @@ -59,5 +60,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0403 CONFIG_G_DNL_PRODUCT_NUM=0xbd00 CONFIG_SPL_OF_LIBFDT=y -CONFIG_DM_I2C=y -CONFIG_DM_ETH=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index c95f45a..126af36 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -1,19 +1,21 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y CONFIG_TARGET_AM57XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_FIT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -28,21 +30,20 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="am57xx-beagle-x15 am572x-idk" CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_TI_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_OF_LIST="am57xx-beagle-x15 am572x-idk" -CONFIG_DM_I2C=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_TI_QSPI=y -CONFIG_CMD_SF=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index f518e6f..7b14273 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -2,12 +2,14 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y CONFIG_TARGET_AM57XX_EVM=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -21,13 +23,12 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y +CONFIG_TI_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_OF_LIBFDT=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_BAR=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_TI_QSPI=y -CONFIG_CMD_SF=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index afd37d4..83b85d1 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -2,19 +2,23 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TARGET_AM57XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_FIT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -30,22 +34,18 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_TI_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y -CONFIG_FIT_IMAGE_POST_PROCESS=y -CONFIG_OF_LIST="am57xx-beagle-x15" -CONFIG_DM_I2C=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_TI_QSPI=y -CONFIG_CMD_SF=y diff --git a/configs/ap325rxa_defconfig b/configs/ap325rxa_defconfig index 51a48de..818eb41 100644 --- a/configs/ap325rxa_defconfig +++ b/configs/ap325rxa_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_AP325RXA=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/ap_sh4a_4a_defconfig b/configs/ap_sh4a_4a_defconfig index 73e6f04..ee14e96 100644 --- a/configs/ap_sh4a_4a_defconfig +++ b/configs/ap_sh4a_4a_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_AP_SH4A_4A=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index a175274..3f24da9 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_APF27=y CONFIG_SPL=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="BIOS> " # CONFIG_CMD_IMLS is not set diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index a6bac0e..475885f 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_APX4DEVKIT=y CONFIG_SPL=y CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/arches_defconfig b/configs/arches_defconfig index d97715b..e367cd9 100644 --- a/configs/arches_defconfig +++ b/configs/arches_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCHES=y CONFIG_DEFAULT_DEVICE_TREE="arches" CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index 3bd4680..7d0a592 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_TARGET_ARMADILLO_800EVA=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/bamboo_defconfig b/configs/bamboo_defconfig index e1f1f3d..683a6d9 100644 --- a/configs/bamboo_defconfig +++ b/configs/bamboo_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_BAMBOO=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index d2a3b73..57cfbd2 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_MMC_ENV_DEV=0" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 5fc501f..586abc0 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index ca4feaf..579a2ba 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM23550_W1D=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y CONFIG_USB_FUNCTION_FASTBOOT=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index eb8aa35..768bd02 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_FASTBOOT=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index b849074..8a5111f 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="BCM_SF2_ETH,BCM_SF2_ETH_GMAC" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index a9403a8..97ccec6 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index aee2e2e..bfe358b 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index df76dac..ccdbd31 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 0b00ce3..ff5ee54 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index df76dac..ccdbd31 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index df76dac..ccdbd31 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index 99e5452..4a93a2d 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNSP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x01000000" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_AUTOBOOT is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index b3a13c6..ae54562 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_BG0900=y CONFIG_SPL=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index bb5db5c..1e9e377 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -4,6 +4,7 @@ CONFIG_BAV_VERSION=1 CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -38,4 +39,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="BAV335x U-Boot SPL" diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 39cc222..0821661 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -4,6 +4,7 @@ CONFIG_BAV_VERSION=2 CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -38,4 +39,3 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="BAV335x U-Boot SPL" diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 90c8889..fa6735d 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_BLANCHE=y CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index cf2800b..881930e 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index a14a130..9c7c07e 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_BOOTDELAY=-2 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index fee9973..fc1f1e6 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 2567a40..3895eec 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_BRXRE1=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_BOOTDELAY=-2 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_BOOTM is not set diff --git a/configs/bubinga_defconfig b/configs/bubinga_defconfig index 9bfe828..d18e89e 100644 --- a/configs/bubinga_defconfig +++ b/configs/bubinga_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_BUBINGA=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index c529c7c..7d8fe11 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_CAIRO=y CONFIG_SPL=y CONFIG_BOOTDELAY=-2 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Cairo # " CONFIG_CMD_BOOTZ=y diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 505ab37..9cc4a85 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_CALIMAIN=y CONFIG_BOOTDELAY=0 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Calimain > " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index fe9fbd0..c0f9eec 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -5,6 +5,7 @@ CONFIG_CANYONLANDS=y CONFIG_DEFAULT_DEVICE_TREE="canyonlands" CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 1b29331..1528d1b 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_CM_T335=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T335 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index b80ca0d..b13e228 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -1,8 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_CM_T43=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T43 # " CONFIG_CMD_BOOTZ=y @@ -26,6 +25,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DM=y +CONFIG_DM_GPIO=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_ATMEL=y @@ -36,6 +36,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 4f2425b..a145248 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_CM_T54=y CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T54 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 986cec4..943bd91 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -1,11 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_COLIBRI_VF=y -CONFIG_DM_SERIAL=y -CONFIG_DM_SPI=y -CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="vf610-colibri" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,ENV_IS_IN_NAND,IMX_NAND" CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri VFxx # " CONFIG_CMD_BOOTZ=y @@ -27,10 +25,13 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y +CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y +CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y +CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 69839df..ce49340 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DA850EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50" CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 40ab975..da6615f 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -4,9 +4,10 @@ CONFIG_TARGET_DA850EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 9c5428d..1ab9ff3 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_DA850EVM=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CMD_ASKENV=y diff --git a/configs/devconcenter_defconfig b/configs/devconcenter_defconfig index bf7f545..0f9b727 100644 --- a/configs/devconcenter_defconfig +++ b/configs/devconcenter_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="DEVCONCENTER" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 0795458..56d4e57 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -1,11 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_DEVKIT3250=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -18,5 +16,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index c8021c6..29a246c 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_DEVKIT8000=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/dlvision-10g_defconfig b/configs/dlvision-10g_defconfig index e22461d..4253b55 100644 --- a/configs/dlvision-10g_defconfig +++ b/configs/dlvision-10g_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/dlvision_defconfig b/configs/dlvision_defconfig index fba3611..8fd5add 100644 --- a/configs/dlvision_defconfig +++ b/configs/dlvision_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 956b83e..874a749 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -1,17 +1,16 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y CONFIG_TARGET_DRA7XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y -CONFIG_DM_GPIO=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_FIT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set @@ -26,18 +25,29 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="dra7-evm dra72-evm" CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_PCF8575_GPIO=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_DM_ETH=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y @@ -53,13 +63,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_OF_LIST="dra7-evm dra72-evm" -CONFIG_DM_I2C=y -CONFIG_PCF8575_GPIO=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_CMD_REGULATOR=y -CONFIG_DM_ETH=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index d6e4e07..7461e20 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -1,19 +1,20 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TI_SECURE_DEVICE=y CONFIG_TARGET_DRA7XX_EVM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y -CONFIG_DM_GPIO=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_FIT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y -CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y # CONFIG_CMD_FLASH is not set @@ -28,18 +29,28 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="dra7-evm dra72-evm" CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_PCF8575_GPIO=y +CONFIG_DM_I2C=y CONFIG_DM_MMC=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y @@ -55,14 +66,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y -CONFIG_OF_LIST="dra7-evm dra72-evm" -CONFIG_DM_I2C=y -CONFIG_PCF8575_GPIO=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_CMD_REGULATOR=y -CONFIG_FIT_IMAGE_POST_PROCESS=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index ad564e4..d2877d1 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y CONFIG_TARGET_DUOVERO=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="duovero # " CONFIG_CMD_BOOTZ=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 57df04f..5e31c1b 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_EA20=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " # CONFIG_CMD_IMLS is not set diff --git a/configs/ecovec_defconfig b/configs/ecovec_defconfig index a23f52a..286606d 100644 --- a/configs/ecovec_defconfig +++ b/configs/ecovec_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_ECOVEC=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/espt_defconfig b/configs/espt_defconfig index 81425bd..38ae66f 100644 --- a/configs/espt_defconfig +++ b/configs/espt_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_ESPT=y CONFIG_BOOTDELAY=-1 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/gdppc440etx_defconfig b/configs/gdppc440etx_defconfig index ef4c4ed..4df39f6 100644 --- a/configs/gdppc440etx_defconfig +++ b/configs/gdppc440etx_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_GDPPC440ETX=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index d8b4227..7546f33 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -5,6 +5,7 @@ CONFIG_GLACIER=y CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index 2875492..21f9357 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/canyonlands/u-boot-ram.lds" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 461f235..d67b918 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -2,10 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_GOSE=y -CONFIG_BOOTDELAY=3 CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 4130e27..270d2a3 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="HALEAKALA" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index a2a7073..6556fa6 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index b0487ef..02ca830 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFFF00000" CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter password - autoboot in %d seconds...\n" diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 649dd47..992d48f 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020" CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -25,5 +26,4 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y -CONFIG_USE_TINY_PRINTF=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 3ab5c69..84dd4ad 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/igep0030_nand_defconfig b/configs/igep0030_nand_defconfig index cdab71b..37417c1 100644 --- a/configs/igep0030_nand_defconfig +++ b/configs/igep0030_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index d609d89..9529631 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/intip_defconfig b/configs/intip_defconfig index cd0f234..71597a7 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="INTIB" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 27ffaea..2093210 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/io_defconfig b/configs/io_defconfig index 2392d9b..6cca9bf 100644 --- a/configs/io_defconfig +++ b/configs/io_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/iocon_defconfig b/configs/iocon_defconfig index c7b3b27..54b8c18 100644 --- a/configs/iocon_defconfig +++ b/configs/iocon_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_IOCON=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index cee6988..64fa54c 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_IPAM390=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 04c52f0..5f5639e 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -1,10 +1,10 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y CONFIG_TARGET_K2E_EVM=y -CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2e-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2E EVM # " CONFIG_CMD_BOOTZ=y @@ -26,16 +26,16 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y -CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_LIB_RAND=y -CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 825de72..1cacabf 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -1,10 +1,10 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y CONFIG_TARGET_K2G_EVM=y -CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2g-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -27,16 +27,17 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DM=y -CONFIG_DM_SPI=y +CONFIG_DM_MMC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y -CONFIG_DM_MMC=y CONFIG_REMOTEPROC_TI_POWER=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_BAR=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index c050f07..724348e 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -1,10 +1,10 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y CONFIG_TARGET_K2HK_EVM=y -CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2hk-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2HK EVM # " CONFIG_CMD_BOOTZ=y @@ -26,16 +26,16 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y -CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_LIB_RAND=y -CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index e1386f7..ed7bcd2 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -1,10 +1,10 @@ CONFIG_ARM=y CONFIG_ARCH_KEYSTONE=y CONFIG_TARGET_K2L_EVM=y -CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2l-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2L EVM # " CONFIG_CMD_BOOTZ=y @@ -26,16 +26,16 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y -CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_LIB_RAND=y -CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/katmai_defconfig b/configs/katmai_defconfig index 30c8bf0..bb00400 100644 --- a/configs/katmai_defconfig +++ b/configs/katmai_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_KATMAI=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index 698de8c..f740b0b 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="KILAUEA" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 24413a1..67356b1 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_128M16" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 991fe1d..7482b93 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 11c1b71..9b7a5fb 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_PCI" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 03e69f3..3125387 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMCOGE4" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index bdf98a4..e03d71b 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KM8360=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMCOGE5NE" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 3d1b986..221dcb5 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_COGE5UN" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 6256bb4..52f8be1 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KM8360=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMETER1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index 7911445..bb38814 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMLION1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index f5f36b7..01f4fce 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_NUSA" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index 14fb873..daf5a96 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMOPTI2" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index ef965ea..8e0f6da 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUGP1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index 33dab62..67e11f6 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMSUPX5" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 92d2787..eb4d583 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUV31" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index b450499..f0b1cca 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMTEGR1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index a27a9ef..936dd91 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMTEPR2" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/kmvect1_defconfig b/configs/kmvect1_defconfig index 2d74209..3e310ba 100644 --- a/configs/kmvect1_defconfig +++ b/configs/kmvect1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMVECT1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 665a432..4fcb32e 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -2,10 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_KOELSCH=y -CONFIG_BOOTDELAY=3 CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index f1ef1c4..ba75147 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_TARGET_KZM9G=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="KZM-A9-GT# " CONFIG_CMD_BOOTZ=y CONFIG_CMD_I2C=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 9bc893a..f6e9630 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -2,10 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_LAGER=y -CONFIG_BOOTDELAY=3 CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 8161f73..5ab3a61 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_LEGOEV3=y CONFIG_BOOTDELAY=0 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds - press 'l' to stop...\n" diff --git a/configs/luan_defconfig b/configs/luan_defconfig index 90801f4..1b93e5b 100644 --- a/configs/luan_defconfig +++ b/configs/luan_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_LUAN=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index eaf6c97..e233e0e 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_LWMON5=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index b505d29..7a2a1e3 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_M28EVK=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index 962e036..e9fe923 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index 75affaa..d2bfb20 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4" CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index 4967e10..bb9ee2f 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_MAKALU=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/mgcoge3ne_defconfig b/configs/mgcoge3ne_defconfig index d404c8b..3c3449c 100644 --- a/configs/mgcoge3ne_defconfig +++ b/configs/mgcoge3ne_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KM82XX=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MGCOGE3NE" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 484abbe..6f62fc0 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_MGCOGE3UN" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/mgcoge_defconfig b/configs/mgcoge_defconfig index 2cc8f44..54c277f 100644 --- a/configs/mgcoge_defconfig +++ b/configs/mgcoge_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KM82XX=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MGCOGE" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/motionpro_defconfig b/configs/motionpro_defconfig index eaaa5ed..add7c06 100644 --- a/configs/motionpro_defconfig +++ b/configs/motionpro_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_MOTIONPRO=y CONFIG_OF_BOARD_SETUP=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/mpr2_defconfig b/configs/mpr2_defconfig index 606b942..839298e 100644 --- a/configs/mpr2_defconfig +++ b/configs/mpr2_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_MPR2=y +CONFIG_VERSION_VARIABLE=y # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/ms7720se_defconfig b/configs/ms7720se_defconfig index 537ea7c..a02760a 100644 --- a/configs/ms7720se_defconfig +++ b/configs/ms7720se_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_MS7720SE=y +CONFIG_VERSION_VARIABLE=y # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/ms7722se_defconfig b/configs/ms7722se_defconfig index 026f566..c97ef61 100644 --- a/configs/ms7722se_defconfig +++ b/configs/ms7722se_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_MS7722SE=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index a028482..d31b72e 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX23_OLINUXINO=y CONFIG_SPL=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 5638c52..4444ef0 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX23EVK=y CONFIG_SPL=y CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index d43bb53..546e0f1 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 0a7564a..96f9e8e 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 65d4a6b..c7e2408 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index d5b001c..5b47134 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/neo_defconfig b/configs/neo_defconfig index b61b719..93a402f 100644 --- a/configs/neo_defconfig +++ b/configs/neo_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set CONFIG_CMD_ASKENV=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 69e5ea9..26d554f 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 78f71d6..7488be0 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_BEAGLE=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index e7bf385..dfd7611 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -1,10 +1,10 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_LOGIC=y -CONFIG_USE_TINY_PRINTF=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP Logic # " CONFIG_CMD_BOOTZ=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 6189296..0dced3d 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_OVERO=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Overo # " CONFIG_CMD_BOOTZ=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index ec50417..0c2c12b 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_PANDORA=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Pandora # " CONFIG_CMD_BOOTZ=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index db2aafc..e92d9c6 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_ZOOM1=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 406f0ac..38abb95 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_PANDA=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index c5d6d61..684f4e1 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_SDP4430=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index f67676f..da8fb75 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y CONFIG_TARGET_OMAP5_UEVM=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 51dc1db..8cb486d 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_OMAPL138_LCDK=y CONFIG_SPL=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 27f681f..9630b61 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_PCM051=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="REV1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -30,4 +31,3 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="pcm051 U-Boot SPL" diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index b277b3a..bc051c7 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_PCM051=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="REV3" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -30,4 +31,3 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_OF_LIBFDT=y -CONFIG_SPL_NET_VCI_STRING="pcm051 U-Boot SPL" diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 3eba3ce..ac7079b 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_PENGWYN=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 4a46f24..8a38b89 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_PEPPER=y CONFIG_SPL=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="pepper# " CONFIG_CMD_BOOTZ=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index acb039d..17eb1d7 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -2,10 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_PORTER=y -CONFIG_BOOTDELAY=3 CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -25,4 +26,3 @@ CONFIG_CMD_FAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y -# CONFIG_EFI_LOADER is not set diff --git a/configs/portl2_defconfig b/configs/portl2_defconfig index 87fd221..94f9349 100644 --- a/configs/portl2_defconfig +++ b/configs/portl2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_PORTL2" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/r0p7734_defconfig b/configs/r0p7734_defconfig index 5f77e05..e040003 100644 --- a/configs/r0p7734_defconfig +++ b/configs/r0p7734_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_R0P7734=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index 093207c..c0e647e 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index a7879ae..7030fe4 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/redwood_defconfig b/configs/redwood_defconfig index 1cf4832..b0400eb 100644 --- a/configs/redwood_defconfig +++ b/configs/redwood_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_REDWOOD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/rsk7203_defconfig b/configs/rsk7203_defconfig index f2e9deb..f92536b 100644 --- a/configs/rsk7203_defconfig +++ b/configs/rsk7203_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_RSK7203=y +CONFIG_VERSION_VARIABLE=y # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/salvator-x_defconfig b/configs/salvator-x_defconfig index e16acd3..9df4867 100644 --- a/configs/salvator-x_defconfig +++ b/configs/salvator-x_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_SALVATOR_X=y CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 16f61de..7af5935 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_SANSA_FUZE_PLUS=y CONFIG_SPL=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index a3bf903..7b72828 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_SC_SPS_1=y CONFIG_SPL=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 8619c57..3b16f80 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index 81cda46..2f37ae1 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index f7e055b..73b1ac6 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -2,6 +2,7 @@ CONFIG_SH=y CONFIG_SH_32BIT=y CONFIG_TARGET_SH7752EVB=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index fc6c7b1..e0037a6 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_SH7753EVB=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index b0d3f28..a80c10c 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -2,6 +2,7 @@ CONFIG_SH=y CONFIG_SH_32BIT=y CONFIG_TARGET_SH7757LCR=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index 41d2b55..5957a56 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_SH7763RDP=y CONFIG_BOOTDELAY=-1 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/sh7785lcr_32bit_defconfig b/configs/sh7785lcr_32bit_defconfig index d98e073..926f85e 100644 --- a/configs/sh7785lcr_32bit_defconfig +++ b/configs/sh7785lcr_32bit_defconfig @@ -2,6 +2,7 @@ CONFIG_SH=y CONFIG_SH_32BIT=y CONFIG_TARGET_SH7785LCR=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/sh7785lcr_defconfig b/configs/sh7785lcr_defconfig index 368cb30..83b956f 100644 --- a/configs/sh7785lcr_defconfig +++ b/configs/sh7785lcr_defconfig @@ -1,6 +1,7 @@ CONFIG_SH=y CONFIG_TARGET_SH7785LCR=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set diff --git a/configs/shmin_defconfig b/configs/shmin_defconfig index 65b4525..d5f04d8 100644 --- a/configs/shmin_defconfig +++ b/configs/shmin_defconfig @@ -1,5 +1,6 @@ CONFIG_SH=y CONFIG_TARGET_SHMIN=y +CONFIG_VERSION_VARIABLE=y # CONFIG_AUTOBOOT is not set # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 65a74f8..0cea607 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -2,10 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SILK=y -CONFIG_BOOTDELAY=3 CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index a3797af..9915cb2 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -31,7 +30,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 5798662..1253e0c 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -31,7 +30,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 9bba2de..850199e 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_TERASIC_DE0_NANO=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -31,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index b1d7fff..d23afbf 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -1,13 +1,12 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_IS1=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -27,7 +26,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_SPI_FLASH=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index f60b4d8..422bf0a 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_DENX_MCVEVK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -31,6 +30,8 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 3913984..954bc9b 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_TERASIC_SOCKIT=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -31,7 +30,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index bc9e894..00ff495 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_EBV_SOCRATES=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -32,7 +31,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 8d4791d..2a4494f 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_SR1500=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -30,7 +29,9 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 901721f..30399ff 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -1,15 +1,14 @@ CONFIG_ARM=y CONFIG_ARCH_SOCFPGA=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_GPIO=y CONFIG_TARGET_SOCFPGA_SAMTEC_VINING_FPGA=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set @@ -34,7 +33,9 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index 1a0f09b..8ab5bdf 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -2,10 +2,11 @@ CONFIG_ARM=y CONFIG_ARCH_RMOBILE=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_STOUT=y -CONFIG_BOOTDELAY=3 CONFIG_BOOTSTAGE_USER_COUNT=0x20 CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index ac6a9e2..86c258b 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SUVD3" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/sycamore_defconfig b/configs/sycamore_defconfig index 5f7b40d..f927c4c 100644 --- a/configs/sycamore_defconfig +++ b/configs/sycamore_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/t3corp_defconfig b/configs/t3corp_defconfig index 7505996..3e04031 100644 --- a/configs/t3corp_defconfig +++ b/configs/t3corp_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_T3CORP=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index ef9c074..122dc3d 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_TI814X_EVM=y CONFIG_SPL=y CONFIG_BOOTDELAY=1 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " # CONFIG_CMD_IMLS is not set diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index c4240e9..7df29cc 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_TI816X_EVM=y CONFIG_SPL=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="u-boot/ti816x# " # CONFIG_CMD_IMLS is not set diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index ed6239b..76a615c 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -1,12 +1,10 @@ CONFIG_MIPS=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_DM_SERIAL=y -CONFIG_DM_SPI=y -CONFIG_DM_SPI_FLASH=y CONFIG_ARCH_ATH79=y CONFIG_BOARD_TPLINK_WDR4300=y CONFIG_DEFAULT_DEVICE_TREE="tplink_wdr4300" CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMLS is not set @@ -20,6 +18,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y @@ -34,7 +33,9 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_DM_ETH=y CONFIG_AG7XXX=y CONFIG_PINCTRL=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y CONFIG_ATH79_SPI=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 475cf47..a042cf2 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TUGE1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index e2d86d9..f3f7857 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TUXX1" +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" diff --git a/configs/walnut_defconfig b/configs/walnut_defconfig index 5f7b40d..f927c4c 100644 --- a/configs/walnut_defconfig +++ b/configs/walnut_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index e9fa773..0c2fb99 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -1,11 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_WORK_92105=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_DM=y -CONFIG_DM_SERIAL=y -CONFIG_DM_GPIO=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set @@ -17,4 +15,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 31a647e..bc0828c 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_XFI3=y CONFIG_SPL=y CONFIG_BOOTDELAY=3 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/xilinx-ppc405-generic_defconfig b/configs/xilinx-ppc405-generic_defconfig index 8e07d40..a17cd4f 100644 --- a/configs/xilinx-ppc405-generic_defconfig +++ b/configs/xilinx-ppc405-generic_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="xlx-ppc405:/# " # CONFIG_CMD_IMLS is not set diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index 7f085de..a9dd5a7 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="board:/# " CONFIG_CMD_ASKENV=y diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index 535850c..129a62e 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -2,6 +2,7 @@ CONFIG_XTENSA=y CONFIG_SYS_CPU="dc233c" CONFIG_XTFPGA_KC705=y CONFIG_BOOTDELAY=10 +CONFIG_VERSION_VARIABLE=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press <SPACE> to stop\n" @@ -14,9 +15,9 @@ CONFIG_DM=y # CONFIG_DM_DEVICE_REMOVE is not set # CONFIG_DM_STDIO is not set # CONFIG_DM_SEQ_ALIAS is not set -CONFIG_SYSRESET=y CONFIG_DM_ETH=y CONFIG_PHYLIB=y CONFIG_ETHOC=y CONFIG_SYS_NS16550=y +CONFIG_SYSRESET=y CONFIG_OF_LIBFDT=y diff --git a/configs/yellowstone_defconfig b/configs/yellowstone_defconfig index 059ff71..8c061e9 100644 --- a/configs/yellowstone_defconfig +++ b/configs/yellowstone_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YELLOWSTONE" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/yosemite_defconfig b/configs/yosemite_defconfig index df37b90..7506e7b 100644 --- a/configs/yosemite_defconfig +++ b/configs/yosemite_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YOSEMITE" CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/configs/yucca_defconfig b/configs/yucca_defconfig index d3ccad7..c261b32 100644 --- a/configs/yucca_defconfig +++ b/configs/yucca_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_YUCCA=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y diff --git a/include/configs/10m50_devboard.h b/include/configs/10m50_devboard.h index 7eb9e98..ebe018a 100644 --- a/include/configs/10m50_devboard.h +++ b/include/configs/10m50_devboard.h @@ -96,7 +96,6 @@ CONFIG_ENV_SIZE - \ CONFIG_SYS_MALLOC_LEN - \ 0x10000) -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index 6489de3..b2126a6 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -99,7 +99,6 @@ CONFIG_ENV_SIZE - \ CONFIG_SYS_MALLOC_LEN - \ 0x10000) -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index 8010f28..603de33 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -98,8 +98,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
-#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - #define CONFIG_SYS_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */
/*----------------------------------------------------------------------- diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index ffae107..06c5d3b 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -121,8 +121,6 @@
#define CONFIG_CMDLINE_EDITING /* add command line history */
/*----------------------------------------------------------------------- diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index 80d8fcd..a4eabe5 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -18,7 +18,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC0,115200 root=1f01"
-#define CONFIG_VERSION_VARIABLE #undef CONFIG_SHOW_BOOT_PROGRESS
/* SMC9111 */ diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index c2e067a..2534f8a 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -118,8 +118,6 @@
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */
/* diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index 619222f..0b0db20 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -92,7 +92,6 @@
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
/* * PCI stuff diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index d3183ff..2f89e39 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -312,7 +312,6 @@
/*----------------------------------------------------------------------- * PCI stuff diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index e87cea8..5e30511 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -106,8 +106,6 @@
/* diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index f2484cb..9327c3d 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -58,8 +58,6 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#define CONFIG_VERSION_VARIABLE - #define CONFIG_ENV_IS_IN_MMC 1
/* diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index c9bc093..635d12a 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -266,7 +266,6 @@ /* Miscellaneous configurable options */ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_VERSION_VARIABLE #define CONFIG_SYS_LONGHELP #define CONFIG_PARTITION_UUIDS
diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index 9bda7fa..f4261e9 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -78,7 +78,6 @@ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ -#define CONFIG_VERSION_VARIABLE /* include version env variable */ #define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
#define CONFIG_LOADS_ECHO /* echo on for serial download */ diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 7dd2461..32acb08 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -21,7 +21,6 @@ #define CONFIG_BAUDRATE 38400 #define CONFIG_BOOTARGS "console=ttySC2,38400"
/* SMC9118 */ diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index 37f2d30..d41b624 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -24,7 +24,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC4,115200"
/* Ether */ diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 51a16eb..e84cfb5 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -10,7 +10,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_VERSION_VARIABLE #define CONFIG_ENV_VERSION 10 #define CONFIG_IDENT_STRING " apf27 patch 3.10" #define CONFIG_BOARD_NAME apf27 diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index e9cab5c..e3f4a7b 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -24,7 +24,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS ""
#define CONFIG_ARCH_CPU_INIT diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index b968801..eb4c497 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -113,7 +113,6 @@ #define CONFIG_EFI_PARTITION
/* version string, parser, etc */ -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index f38f081..7a75fdb 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -112,7 +112,6 @@ #define CONFIG_EFI_PARTITION
/* version string, parser, etc */ -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index 4b255d8..b68fa1e 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -68,7 +68,6 @@ #define CONFIG_DOS_PARTITION
/* version string, parser, etc */ -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_COMMAND_HISTORY diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 22c3249..85510f0 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_VERSION_VARIABLE
/* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/calimain.h b/include/configs/calimain.h index 9c2b9e8..bf173ff 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -198,7 +198,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) #define CONFIG_LOADADDR 0xc0700000 -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index fb68e59..c2b38c2 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -39,7 +39,6 @@ /* Allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG -#define CONFIG_VERSION_VARIABLE #define CONFIG_BAUDRATE 115200
/* NAND support */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 3e4bba5..ef0fd59 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -261,7 +261,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index 22f4322..8942c3d 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -138,7 +138,6 @@
#define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_VERSION_VARIABLE #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 3f8578f..910bcd4 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -124,7 +124,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 706ad1d..493902e 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -39,7 +39,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC0,115200"
/* I2C */ diff --git a/include/configs/espt.h b/include/configs/espt.h index 86e726c..e76a4ee 100644 --- a/include/configs/espt.h +++ b/include/configs/espt.h @@ -23,7 +23,6 @@ #define CONFIG_BOOTARGS "console=ttySC0,115200 root=1f01" #define CONFIG_ENV_OVERWRITE 1
/* SCIF */ diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index b750d72..c9d3b93 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -545,8 +545,6 @@ #define CONFIG_BOOTCOUNT_ALEN 1 #define CONFIG_SYS_BOOTCOUNT_ADDR 0x9
-#define CONFIG_VERSION_VARIABLE - #define CONFIG_IMAGE_FORMAT_LEGACY #define CONFIG_CMD_HASH #define CONFIG_SHA1 diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index b36b75d..37a5fa4 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -208,7 +208,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index 6f2773b..8e1de7c 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -237,6 +237,4 @@ "" #endif /* CONFIG_KM_DEF_ENV */
-#define CONFIG_VERSION_VARIABLE /* include version env variable */ - #endif /* __CONFIG_KEYMILE_H */ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index a4b296a..409c30d 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -30,7 +30,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "root=/dev/null console=ttySC4,115200"
/* MEMORY */ diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 04f593e..d91e75d 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -151,7 +151,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 0abfb00..05a5589 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -437,7 +437,6 @@
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 781a162..1ed737d 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -70,7 +70,6 @@ #define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot argument buffer size */ -#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ #define CONFIG_AUTO_COMPLETE /* Command auto complete */ #define CONFIG_CMDLINE_EDITING /* Command history etc */
diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index b4bd6b0..1189229 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -51,7 +51,6 @@ /* * U-Boot general configurations */ -#define CONFIG_VERSION_VARIABLE /* U-BOOT version */
/* * Serial Driver diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index 2a83c60..bad85ba 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -67,8 +67,6 @@
-#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - /* * Default environment settings */ diff --git a/include/configs/mpr2.h b/include/configs/mpr2.h index 3f2bfa4..1a8909a 100644 --- a/include/configs/mpr2.h +++ b/include/configs/mpr2.h @@ -17,7 +17,6 @@ #define CONFIG_BOOTARGS "console=ttySC0,115200" #define CONFIG_BOOTFILE "/boot/zImage" #define CONFIG_LOADADDR 0x8E000000 -#define CONFIG_VERSION_VARIABLE
/* CPU and platform */ #define CONFIG_CPU_SH7720 1 diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 27ed1d5..d136726 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -21,7 +21,6 @@ #define CONFIG_BOOTFILE "/boot/zImage" #define CONFIG_LOADADDR 0x8E000000
/* MEMORY */ diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 27e9c0a..9b0c166 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -18,7 +18,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC0,115200 root=1f01"
/* SMC9111 */ diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 238b16d..d80dc5e 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -94,7 +94,6 @@ #define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot argument buffer size */ -#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ #define CONFIG_AUTO_COMPLETE /* Command auto complete */ #define CONFIG_CMDLINE_EDITING /* Command history etc */
diff --git a/include/configs/novena.h b/include/configs/novena.h index 57d8c3e..f598c64 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -27,7 +27,6 @@ #define CONFIG_VIDEO
/* U-Boot general configurations */ -#define CONFIG_VERSION_VARIABLE /* U-BOOT version */
/* U-Boot environment */ #define CONFIG_ENV_SIZE (16 * 1024) diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index d00cf50..43afecd 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -188,7 +188,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) -#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 816c571..af421d6 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -163,7 +163,6 @@
#define CONFIG_CMD_MTDPARTS
-#define CONFIG_VERSION_VARIABLE /* monitor functions : u-boot version */ #define CONFIG_CMD_DIAG /* monitor functions : Diagnostics */
#define MTDIDS_DEFAULT "nand0=omap2-nand.0" diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index c5e5724..2d7e326 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -24,7 +24,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC3,115200"
/* Ether */ diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 8f91e8e..5733da6 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -31,7 +31,6 @@ #define CONFIG_BAUDRATE 38400 #define CONFIG_BOOTARGS ""
#define CONFIG_ARCH_CPU_INIT diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index f9e5f59..7655417 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -40,7 +40,6 @@
#define CONFIG_ARCH_CPU_INIT diff --git a/include/configs/rsk7203.h b/include/configs/rsk7203.h index 1e4166c..9db73d3 100644 --- a/include/configs/rsk7203.h +++ b/include/configs/rsk7203.h @@ -20,7 +20,6 @@ #define CONFIG_BOOTARGS "console=ttySC0,115200" #define CONFIG_LOADADDR 0x0C100000 /* RSK7203_SDRAM_BASE + 1MB */
/* MEMORY */ diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index fb6e05f..cfcde81 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -26,7 +26,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp"
-#define CONFIG_VERSION_VARIABLE #undef CONFIG_SHOW_BOOT_PROGRESS #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 64e9e52..fefdbb4 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -26,7 +26,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp"
-#define CONFIG_VERSION_VARIABLE #undef CONFIG_SHOW_BOOT_PROGRESS #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index f9a9a03..262d390 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -26,7 +26,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_BOOTARGS "console=ttySC2,115200 root=/dev/nfs ip=dhcp"
/* MEMORY */ diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index 538ba98..2e45699 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -23,7 +23,6 @@ #define CONFIG_BOOTARGS "console=ttySC2,115200 root=1f01" #define CONFIG_ENV_OVERWRITE 1
/* SCIF */ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 794c48c..8b3187e 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -28,7 +28,6 @@ "bootdevice=0:1\0" \ "usbload=usb reset;usbboot;usb stop;bootm\0"
/* MEMORY */ diff --git a/include/configs/shmin.h b/include/configs/shmin.h index 897ba1d..e0fc3a2 100644 --- a/include/configs/shmin.h +++ b/include/configs/shmin.h @@ -25,7 +25,6 @@ * This board has original boot loader. If you write u-boot to 0x0, * you should set undef. */ -#define CONFIG_VERSION_VARIABLE #undef CONFIG_SHOW_BOOT_PROGRESS
/* system */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index ce5781b..d5c69d1 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -64,7 +64,6 @@ #define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot argument buffer size */ -#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ #define CONFIG_AUTO_COMPLETE /* Command auto complete */ #define CONFIG_CMDLINE_EDITING /* Command history etc */
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 198f649..82ab479 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -35,7 +35,6 @@ #define CONFIG_INITRD_TAG /* for ramdisk support */
/* commands to include */ -#define CONFIG_VERSION_VARIABLE
#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 071511c..e3cd647 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -29,7 +29,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG /* required for ramdisk support */
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index d60d213..32cb202 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -160,7 +160,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_VERSION_VARIABLE
/* We set the max number of command args high to avoid HUSH bugs. */ #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index b2ccb70..7bf8e4c 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -57,7 +57,6 @@ #define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot argument buffer size */ -#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ #define CONFIG_AUTO_COMPLETE /* Command auto complete */ #define CONFIG_CMDLINE_EDITING /* Command history etc */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index eae7eba..b2103b4 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -108,7 +108,6 @@
diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index 39c1bd8..6c52582 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -57,7 +57,6 @@ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ -#define CONFIG_VERSION_VARIABLE /* include version env variable */ #define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index c5b06e3..3e5d310 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -140,7 +140,6 @@
#define CONFIG_BOOT_RETRY_TIME 60 /* retry after 60 secs */
-#define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE /* Support tab autocompletion */ #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP
Heiko Schocher hs@denx.de schrieb am 09.09.2016 08:12:49:
[RFC PATCH] common, kconfig: move VERSION_VARIABLE to Kconfig
move VERSION_VARIABLE from board config file into a Kconfig option.
Signed-off-by: Heiko Schocher hs@denx.de
Tested with tbot: http://lists.denx.de/pipermail/u-boot/2016-June/258119.html
result from first run: Boards : 1193 compile err : 60 not checked : 1 U-Boot good : 1129 bad 3 SPL good : 411 bad 0 ('compile err :', [...] ('not checked :', ['xtfpga']) ('bad :', ['sandbox', 'sandbox_noblk', 'sandbox_spl'])
The 3 bad boards are the sandbox builds, I must find time to find out, why the sandbox build is not reproducible ...
I had a toolchain issue with arm64 build, fixed now, result for the second run (only for the boards which had compile errors before): Boards : 60 compile err : 8 not checked : 0 U-Boot good : 52 bad 0 SPL good : 16 bad 0 ('compile err :', ['bf533-stamp', 'cm-bf527', 'colibri_pxa270',
'omap4_panda',
'openrisc-generic', 'smdk5250', 'snow', 'spring'])
So, this patch does not change the resulting binaries ...
One remark: define CONFIG_SPL_NET_VCI_STRING="..." is removed from some defconfigs, but not again added to the defconfig. This is for all boards, which use this define ... but as the resulting images are not changes, this seems no problem... This is the reason for the "RFC" state ... any comments?
common/Kconfig | 10 +++++++++
configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 +
include/configs/bur_cfg_common.h | 1 -
270 files changed, 369 insertions(+), 241 deletions(-)
For B&R boards. Acked-by: hannes.schmelzer@br-automation.com
On Fri, Sep 09, 2016 at 08:12:49AM +0200, Heiko Schocher wrote:
[snip]
So we didn't properly migrate SPL_NET_VCI_STRING to Kconfig, but it also didn't fail as we didn't remove it from the headers. I just sent Simon off-list the Kconfig bits we need to migrate it for real (if we don't have the rest of his SPL Kconfig series it gets ugly).
After re-doing the configs/ and include/configs/ migration part and testing myself, applied to u-boot/master, thanks!
Hannes Schmelzer
Heiko Schocher
