[U-Boot] [PATCH] tools/kwbimage: add DEBUG option
Offset 0x1 in the generated kwb image file is a set of flags, bit 0 enables debug output from the BootROM firmware. Allow a DEBUG option in the kwb configuration to request debug output from the BootROM firmware.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
tools/kwbimage.c | 9 +++++++++ tools/kwbimage.h | 2 +- 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/tools/kwbimage.c b/tools/kwbimage.c index ad182c5c5d9a..69844d916965 100644 --- a/tools/kwbimage.c +++ b/tools/kwbimage.c @@ -69,6 +69,7 @@ struct image_cfg_element { IMAGE_CFG_PAYLOAD, IMAGE_CFG_DATA, IMAGE_CFG_BAUDRATE, + IMAGE_CFG_DEBUG, } type; union { unsigned int version; @@ -87,6 +88,7 @@ struct image_cfg_element { unsigned int nandpagesz; struct ext_hdr_v0_reg regdata; unsigned int baudrate; + unsigned int debug; }; };
@@ -425,6 +427,9 @@ static void *image_create_v1(size_t *imagesz, struct image_tool_params *params, e = image_find_option(IMAGE_CFG_BAUDRATE); if (e) main_hdr->options = baudrate_to_option(e->baudrate); + e = image_find_option(IMAGE_CFG_DEBUG); + if (e) + main_hdr->flags = e->debug ? 0x1 : 0;
binarye = image_find_option(IMAGE_CFG_BINARY); if (binarye) { @@ -579,6 +584,10 @@ static int image_create_config_parse_oneline(char *line, char *value = strtok_r(NULL, deliminiters, &saveptr); el->type = IMAGE_CFG_BAUDRATE; el->baudrate = strtoul(value, NULL, 10); + } else if (!strcmp(keyword, "DEBUG")) { + char *value = strtok_r(NULL, deliminiters, &saveptr); + el->type = IMAGE_CFG_DEBUG; + el->debug = strtoul(value, NULL, 10); } else { fprintf(stderr, "Ignoring unknown line '%s'\n", line); } diff --git a/tools/kwbimage.h b/tools/kwbimage.h index 9b06004a0b10..01c2f1f3238b 100644 --- a/tools/kwbimage.h +++ b/tools/kwbimage.h @@ -73,7 +73,7 @@ struct kwb_header { /* Structure of the main header, version 1 (Armada 370, Armada XP) */ struct main_hdr_v1 { uint8_t blockid; /* 0 */ - uint8_t reserved1; /* 1 */ + uint8_t flags; /* 1 */ uint16_t reserved2; /* 2-3 */ uint32_t blocksize; /* 4-7 */ uint8_t version; /* 8 */
Applied to u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Stefan Roese
