[U-Boot] [PATCH 1/2] dm: pci: MIGRATION: Add migration plan for PCI
Add a migration plan for PCI which is an important subsystem in U-Boot.
Makefile | 10 ++++++++++ doc/driver-model/MIGRATION.txt | 10 ++++++++++ 2 files changed, 20 insertions(+)
diff --git a/Makefile b/Makefile index 5683714947f..4923722f82d 100644 --- a/Makefile +++ b/Makefile @@ -947,6 +947,16 @@ ifeq ($(CONFIG_LIBATA)$(CONFIG_DM_SCSI)$(CONFIG_MVSATA_IDE),y) @echo "See doc/driver-model/MIGRATION.txt for more info." @echo "====================================================" endif +ifeq ($(CONFIG_PCI),y) +ifneq ($(CONFIG_DM_PCI),y) + @echo >&2 "===================== WARNING ======================" + @echo >&2 "This board does not use CONFIG_DM_PCI Please update" + @echo >&2 "the board to use CONFIG_DM_PCI before the v2019.07 release." + @echo >&2 "Failure to update by the deadline may result in board removal." + @echo >&2 "See doc/driver-model/MIGRATION.txt for more info." + @echo >&2 "====================================================" +endif +endif ifeq ($(CONFIG_OF_EMBED),y) @echo "===================== WARNING ======================" @echo "CONFIG_OF_EMBED is enabled. This option should only" diff --git a/doc/driver-model/MIGRATION.txt b/doc/driver-model/MIGRATION.txt index dce4aa3e1dc..03a2cae7976 100644 --- a/doc/driver-model/MIGRATION.txt +++ b/doc/driver-model/MIGRATION.txt @@ -82,3 +82,13 @@ Partially converted: -- Jagan Teki jagan@openedev.com 03/14/2018 + + +CONFIG_DM_PCI +------------- +Deadline: 2019.07 + +The PCI subsystem has supported driver model since mid 2015. Maintainers should +submit patches switching over to using CONFIG_DM_PCI and other base driver +model options in time for inclusion in the 2019.04 rerelease. +
Add a migration plan for video which is an important subsystem in U-Boot.
Makefile | 10 ++++++++++ doc/driver-model/MIGRATION.txt | 8 ++++++++ 2 files changed, 18 insertions(+)
diff --git a/Makefile b/Makefile index 4923722f82d..4b5022a53c7 100644 --- a/Makefile +++ b/Makefile @@ -957,6 +957,16 @@ ifneq ($(CONFIG_DM_PCI),y) @echo >&2 "====================================================" endif endif +ifneq ($(CONFIG_LCD)$(CONFIG_VIDEO),) +ifneq ($(CONFIG_DM_VIDEO),y) + @echo >&2 "===================== WARNING ======================" + @echo >&2 "This board does not use CONFIG_DM_VIDEO Please update" + @echo >&2 "the board to use CONFIG_DM_VIDEO before the v2019.07 release." + @echo >&2 "Failure to update by the deadline may result in board removal." + @echo >&2 "See doc/driver-model/MIGRATION.txt for more info." + @echo >&2 "====================================================" +endif +endif ifeq ($(CONFIG_OF_EMBED),y) @echo "===================== WARNING ======================" @echo "CONFIG_OF_EMBED is enabled. This option should only" diff --git a/doc/driver-model/MIGRATION.txt b/doc/driver-model/MIGRATION.txt index 03a2cae7976..dba3f9fe307 100644 --- a/doc/driver-model/MIGRATION.txt +++ b/doc/driver-model/MIGRATION.txt @@ -92,3 +92,11 @@ The PCI subsystem has supported driver model since mid 2015. Maintainers should submit patches switching over to using CONFIG_DM_PCI and other base driver model options in time for inclusion in the 2019.04 rerelease.
+ +CONFIG_DM_VIDEO +--------------- +Deadline: 2019.07 + +The PCI subsystem has supported driver model since early 2016. Maintainers +should submit patches switching over to using CONFIG_DM_VIDEO and other base +driver model options in time for inclusion in the 2019.04 release.
This is probably cut&paste and should say something like 'The video subsystem' (not PCI)?
2.20.0.405.gbc1bbc6f85-goog
Right, so v2? :)
Many of the subsystems would have same release version for migrations, would better to have next release of v2019.07
I'm fine with a number of features having the same deadline.
Jagan Teki
Simon Goldschmidt
