[PATCH v2 1/2] rockchip: rk3399: Init clocks in U-Boot proper if SPL was not run
It's possible to chainload U-Boot proper from the vendor firmware in rk3399 chromebooks, but the way the vendor firmware sets up clocks is somehow different than what U-Boot expects. This causes the display to stay devoid of content even though vidconsole claims to work (with patches in process of being upstreamed).
This is meant to be a rk3399 version of commit d3cb46aa8c41 ("rockchip: Init clocks again when chain-loading") which can detect the discrepancy, but this patch instead checks whether SPL (and therefore the clock init) was run via the handoff functionality and runs the init if it was not.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com ---
Changes in v2: - Check for SPL handoff instead of always re-initializing
v1: https://patchwork.ozlabs.org/project/uboot/patch/20201022203740.24528-1-alpe...
drivers/clk/rockchip/clk_rk3399.c | 22 ++++++++++++++++------ 1 file changed, 16 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 1ea41f3c5b2e..64e0e2348db5 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -23,6 +23,8 @@ #include <linux/bitops.h> #include <linux/delay.h>
+DECLARE_GLOBAL_DATA_PTR; + #if CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3399_clk_plat { struct dtd_rockchip_rk3399_cru dtd; @@ -50,10 +52,9 @@ struct pll_div { .fbdiv = (u32)((u64)hz * _refdiv * _postdiv1 * _postdiv2 / OSC_HZ),\ .postdiv1 = _postdiv1, .postdiv2 = _postdiv2};
-#if defined(CONFIG_SPL_BUILD) static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 2, 2, 1); static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 2, 2); -#else +#if !defined(CONFIG_SPL_BUILD) static const struct pll_div ppll_init_cfg = PLL_DIVISORS(PPLL_HZ, 2, 2, 1); #endif
@@ -1274,7 +1275,6 @@ static struct clk_ops rk3399_clk_ops = { .disable = rk3399_clk_disable, };
-#ifdef CONFIG_SPL_BUILD static void rkclk_init(struct rockchip_cru *cru) { u32 aclk_div; @@ -1352,20 +1352,30 @@ static void rkclk_init(struct rockchip_cru *cru) hclk_div << HCLK_PERILP1_DIV_CON_SHIFT | HCLK_PERILP1_PLL_SEL_GPLL << HCLK_PERILP1_PLL_SEL_SHIFT); } -#endif
static int rk3399_clk_probe(struct udevice *dev) { -#ifdef CONFIG_SPL_BUILD struct rk3399_clk_priv *priv = dev_get_priv(dev); + bool init_clocks = false;
#if CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3399_clk_plat *plat = dev_get_platdata(dev);
priv->cru = map_sysmem(plat->dtd.reg[0], plat->dtd.reg[1]); #endif - rkclk_init(priv->cru); + +#if defined(CONFIG_SPL_BUILD) + init_clocks = true; +#elif CONFIG_IS_ENABLED(HANDOFF) + if (!(gd->flags & GD_FLG_RELOC)) { + if (!(gd->spl_handoff)) + init_clocks = true; + } #endif + + if (init_clocks) + rkclk_init(priv->cru); + return 0; }
Commit fe974716326c ("rockchip: rk3288: Allow setting up clocks in U-Boot proper") fixes some clock issues when chainloading U-Boot on rk3288 chromebooks. Part of that change is still available in veyron's board_early_init_r() function. Since chain-loading U-Boot proper from vendor firmware is possible on gru boards as well, do the same thing for them too.
On rk3399, this needs to detect whether SPL was run via handoff, so enable that and bloblist kconfigs it needs for chromebook_bob.
Changes in v2: - Enable kconfigs needed for using SPL handoff
v1: https://patchwork.ozlabs.org/project/uboot/patch/20201022203740.24528-2-alpe...
board/google/gru/gru.c | 23 +++++++++++++++++++++++ configs/chromebook_bob_defconfig | 5 +++++ 2 files changed, 28 insertions(+)
diff --git a/board/google/gru/gru.c b/board/google/gru/gru.c index 7dfbc3ac8676..441a1a376a9a 100644 --- a/board/google/gru/gru.c +++ b/board/google/gru/gru.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <dm.h> #include <init.h>
#ifdef CONFIG_SPL_BUILD @@ -31,3 +32,25 @@ int board_early_init_f(void) return 0; } #endif + +#ifndef CONFIG_SPL_BUILD +int board_early_init_r(void) +{ + struct udevice *clk; + int ret; + + /* + * This init is done in SPL, but when chain-loading U-Boot SPL will + * have been skipped. Allow the clock driver to check if it needs + * setting up. + */ + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_GET_DRIVER(clk_rk3399), &clk); + if (ret) { + debug("%s: CLK init failed: %d\n", __func__, ret); + return ret; + } + + return 0; +} +#endif diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 4608892fb567..73635f0d13f1 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -19,6 +19,11 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_BLOBLIST=y +CONFIG_BLOBLIST_SIZE=0x1000 +CONFIG_BLOBLIST_ADDR=0x100000 +CONFIG_HANDOFF=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000
On Tue, 27 Oct 2020 at 15:15, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Changes in v2:
Reviewed-by: Kever Yangkever.yang@rock-chips.com
Thanks, - Kever
Changes in v2:
- struct udevice *clk;
- int ret;
* setting up.
- ret = uclass_get_device_by_driver(UCLASS_CLK,
- if (ret) {
return ret;
Changes in v2:
Thanks, - Kever
Changes in v2:
- #if CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3399_clk_plat { struct dtd_rockchip_rk3399_cru dtd;
- init_clocks = true;
- if (!(gd->flags & GD_FLG_RELOC)) {
init_clocks = true;
- } #endif
- if (init_clocks)
- return 0; }
Alper Nebi Yasak
Kever Yang
