[U-Boot] [PATCH] mpc5xxx: Support CPU internal watchdog.
Signed-off-by: Detlev Zundel dzu@denx.de --- cpu/mpc5xxx/cpu.c | 20 +++++++++++++++++++- cpu/mpc5xxx/cpu_init.c | 14 +++++++++++++- include/watchdog.h | 5 +++++ 3 files changed, 37 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc5xxx/cpu.c b/cpu/mpc5xxx/cpu.c index 2a28df4..edfb828 100644 --- a/cpu/mpc5xxx/cpu.c +++ b/cpu/mpc5xxx/cpu.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2003 + * (C) Copyright 2000-2010 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -192,3 +192,21 @@ int cpu_eth_init(bd_t *bis) return mpc5xxx_fec_initialize(bis); } #endif + +#if defined(CONFIG_WATCHDOG) +void watchdog_reset(void) +{ + int re_enable = disable_interrupts(); + reset_5xxx_watchdog(); + if (re_enable) enable_interrupts(); +} + +void reset_5xxx_watchdog(void) +{ + volatile struct mpc5xxx_gpt *gpt0 = + (struct mpc5xxx_gpt *) MPC5XXX_GPT; + + /* Trigger TIMER_0 by writing A5 to OCPW */ + clrsetbits_be32(&gpt0->emsr, 0xff000000, 0xa5000000); +} +#endif /* CONFIG_WATCHDOG */ diff --git a/cpu/mpc5xxx/cpu_init.c b/cpu/mpc5xxx/cpu_init.c index acff5f5..b151464 100644 --- a/cpu/mpc5xxx/cpu_init.c +++ b/cpu/mpc5xxx/cpu_init.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2009 + * (C) Copyright 2000-2010 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -24,6 +24,7 @@ #include <common.h> #include <mpc5xxx.h> #include <asm/io.h> +#include <watchdog.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -45,6 +46,8 @@ void cpu_init_f (void) (struct mpc5xxx_gpio *) MPC5XXX_GPIO; volatile struct mpc5xxx_xlb *xlb = (struct mpc5xxx_xlb *) MPC5XXX_XLBARB; + volatile struct mpc5xxx_gpt *gpt0 = + (struct mpc5xxx_gpt *) MPC5XXX_GPT; unsigned long addecr = (1 << 25); /* Boot_CS */ #if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_MGT5100) addecr |= (1 << 22); /* SDRAM enable */ @@ -206,6 +209,15 @@ void cpu_init_f (void) /* Enable piplining */ clrbits_be32(&xlb->config, (1 << 31)); # endif + +#if defined(CONFIG_WATCHDOG) + /* Charge the watchdog timer - prescaler = 64k, count = 64k*/ + out_be32(&gpt0->cir, 0x0000ffff); + out_be32(&gpt0->emsr, 0x9004); /* wden|ce|timer_ms */ + + reset_5xxx_watchdog(); +#endif /* CONFIG_WATCHDOG */ + #endif /* CONFIG_MPC5200 */ }
diff --git a/include/watchdog.h b/include/watchdog.h index 9265be9..ef2f5aa 100644 --- a/include/watchdog.h +++ b/include/watchdog.h @@ -84,6 +84,11 @@ void reset_5xx_watchdog(volatile immap_t *immr); #endif
+/* MPC 5xxx */ +#if defined(CONFIG_MPC5xxx) && !defined(__ASSEMBLY__) + void reset_5xxx_watchdog(void); +#endif + /* AMCC 4xx */ #if defined(CONFIG_4xx) && !defined(__ASSEMBLY__) void reset_4xx_watchdog(void);
Dear Detlev Zundel,
Applied, thanks.
Detlev Zundel
