Re: [DNX#2006040142000848] [U-Boot-Users] [PATCH] cleanup duplicated ARM inte [...]
1 Apr
2006
1 Apr
'06
12:20 a.m.
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000848] was created:
<snip>
CHANGELOG: Cleaned up duplicated code: moved common ARM interrupt handling code from cpu specific interrupts.c files into lib_arm/interrupts.c. Patch by Andreas Engel, 21 Nov 2005
Signed-off-by: Andreas Engel
Note: there were two cases (cpu/arm720t/ and cpu/sa1100/) where the disable_interrupts function only disabled IRQ, but not FIQ. I just ignored this in the generic function in lib_arm/, which disables both IRQ and FIQ. Perhaps someone with more knowledge of ARM cores can check whether or not this is ok.
Regards, Andreas Engel
</snip>
Your U-Boot support team
6978
DENX Support System
