[U-Boot-Users] Re: PATCH: bi_iic_fast[] initialization
Dear Tolunay,
in message 14824.216.110.51.8.1079378410.squirrel@www.orkun.us you wrote:
- Allow bi_iic_fast[] to be initialized via env. variable "i2cfast"
I think you should rework this patch. At the moment, you call getenv() in board_init_f() - but board_init_f() is still running from flash, which means that we don't have a full C runtime environment (uninitialized BSS, no writable data, limited stack space) so the use of getenv() is not allowd in that function. You may use getenv_r() instead.
Please send a fix.
Wolfgang,
Dear Tolunay,
I can convert it to use getenv_r() or I think it would be better to move that section dealing with initialization of bi_iic_fast[] flags to board_init_r(). bi_iic_fast[] is not used by u-boot itself. It is passed to Linux.
I believe, there is no reason why it should be done by board_init_f().
Personally, the most appropriate place to initialize such things would be right before u-boot boots the OS. The immediate changes to the environment would also be captured without forcing an environment save and reset as well.
What do you think? Which fix should I attempt:
1) Fix in board_init_f() using getenv_r() 2) Fix by moving to board_init_r() 3) Create a new function (say board_init_preboot) and move that section into it. Hook board_init_preboot() to the existing boot functions (boot, bootm etc. somehow)
Please send a fix.
I will as soon as I get feedback from you.
Regards, Tolunay
Then move it to board_init_r(), please.
Be careful, though. Not everybody uses the same path to boot a kernel.
- Fix in board_init_f() using getenv_r()
- Fix by moving to board_init_r()
Go for 2.
- Create a new function (say board_init_preboot) and move that section
No, please not yet another xxx_init_pre_before_early_reallybefore_preinit function.
Attached patch fixes this.
Changelog:
- Relocate initialization of bi_iic_fast[] from board_init_f() to board_init_r()
Best regards, Tolunay Orkun
In message 33993.216.110.51.8.1081356365.squirrel@www.orkun.us you wrote:
Changelog:
Thanks, added.
Tolunay Orkun
