[RFC PATCH] serial: ns16550: Move PCI access from ofdata_to_platdata() to probe()
Currently the ofdata_to_platdata() method calls dev_read_addr_pci(), which potentially accesses the parent PCI bus. If this happens before the parent PCI bus is probed the resulting address will be wrong.
This behavior was triggered by commit 82de42fa1468 ("dm: core: Allocate parent data separate from probing parent").
According to a comment in drivers/pci/pci-uclass.c [1] accessing the PCI parent bus in ofdata_to_platdata() is not allowed, and the access should be moved to the probe() function.
Move the call to dev_read_addr_pci() and the related handling of the 'addr' value from the ofdata_to_platdata() to the probe() method.
While moving the code, the comment /* try Processor Local Bus device first */ was dropped. It was initially added with commit 3db886a5bf38 ("serial: ns16550: Support ns16550 compatible pci uart devices") and later made obsolete with commit 33c215af4b9d ("dm: pci: Add a function to read a PCI BAR").
[1] Comment in drivers/pci/pci-uclass.c: "A common cause of this problem is that this function is called in the ofdata_to_platdata() method of @dev. Accessing the PCI bus in that method is not allowed, since it has not yet been probed. To fix this, move that access to the probe() method of @dev instead."
Signed-off-by: Wolfgang Wallner wolfgang.wallner@br-automation.com
Fixes: 82de42fa1468 ("dm: core: Allocate parent data separate from probing parent")
--- The discussion leading to this patch is located at https://lists.denx.de/pipermail/u-boot/2020-February/399811.html
drivers/serial/ns16550.c | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 1fcbc35015..07b32abd38 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -484,12 +484,24 @@ int ns16550_serial_probe(struct udevice *dev) struct NS16550 *const com_port = dev_get_priv(dev); struct reset_ctl_bulk reset_bulk; int ret; + fdt_addr_t addr; + + com_port->plat = dev_get_platdata(dev); + + addr = dev_read_addr_pci(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + +#ifdef CONFIG_SYS_NS16550_PORT_MAPPED + com_port->plat->base = addr; +#else + com_port->plat->base = (unsigned long)map_physmem(addr, 0, MAP_NOCACHE); +#endif
ret = reset_get_bulk(dev, &reset_bulk); if (!ret) reset_deassert_bulk(&reset_bulk);
- com_port->plat = dev_get_platdata(dev); NS16550_init(com_port, -1);
return 0; @@ -507,21 +519,9 @@ int ns16550_serial_ofdata_to_platdata(struct udevice *dev) { struct ns16550_platdata *plat = dev->platdata; const u32 port_type = dev_get_driver_data(dev); - fdt_addr_t addr; struct clk clk; int err;
- /* try Processor Local Bus device first */ - addr = dev_read_addr_pci(dev); - if (addr == FDT_ADDR_T_NONE) - return -EINVAL; - -#ifdef CONFIG_SYS_NS16550_PORT_MAPPED - plat->base = addr; -#else - plat->base = (unsigned long)map_physmem(addr, 0, MAP_NOCACHE); -#endif - plat->reg_offset = dev_read_u32_default(dev, "reg-offset", 0); plat->reg_shift = dev_read_u32_default(dev, "reg-shift", 0); plat->reg_width = dev_read_u32_default(dev, "reg-io-width", 1);
On Tue, 18 Feb 2020 at 05:36, Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
On Tue, Feb 18, 2020 at 8:36 PM Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
This fixed the boot failure of Intel Galileo
Tested on Intel Galileo Tested-by: Bin Meng bmeng.cn@gmail.com
applied to u-boot-x86, thanks!
Hi Wolfgang,
Unfortunately this patch breaks several ARM board:
+drivers/built-in.o: In function `ofnode_get_parent': +drivers/core/ofnode.c:235: undefined reference to `fdt_parent_offset' +drivers/built-in.o: In function `ofnode_read_simple_addr_cells': +drivers/core/ofnode.c:717: undefined reference to `fdt_address_cells' +drivers/built-in.o: In function `ofnode_read_simple_size_cells': +drivers/core/ofnode.c:725: undefined reference to `fdt_size_cells' +drivers/built-in.o: In function `ofnode_get_addr_size_index': +drivers/core/ofnode.c:294: undefined reference to `fdtdec_get_addr_size_fixed'
See https://dev.azure.com/bmeng/GitHub/_build/results?buildId=158&view=logs&...
Would you please send a v2 to address this? thanks!
Regards, Bin
Hi Bin,
-----"Bin Meng" bmeng.cn@gmail.com schrieb: -----
Hi Wolfgang,
[snip]
Thanks for pointing this out.
I have missed that the code was guarded with #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) before, and is not guarded anymore now.
Yes, I will follow up with a v2.
regards, Wolfgang
Bin Meng
Wolfgang Wallner
