[U-Boot] s5pv210 smdkv210
Hi Lukasz,
I hope you may be able to offer me some advice.
I have a small project to update a tbs2900, tbs moi. which is a DVB-S2 network/iptv device.
The device is based on smdkv210, with the s5pv210 soc. I understand that in terms of the kernel this is well supported. However, no support appears to have been successfully up-streamed.
Can you shed any further light on u-boot status for this board?
Perhaps if you are familiar, you may also recognise this source here: https://code.google.com/archive/p/x210ii/source/default/source
The device as per OEM, boots with:
--- -Boot 1.3.4 (Mar 7 2013 - 16:38:41) for MOI2900
CPU: S5PV210@1000MHz(OK) APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz MPLL = 667MHz, EPLL = 80MHz HclkDsys = 166MHz, PclkDsys = 83MHz HclkPsys = 133MHz, PclkPsys = 66MHz SCLKA2M = 200MHz Serial = CLKUART Board: MOI2900 I2C: i2c1_init GPD1CON ready DRAM: 512 MB Flash: 8 MB SD/MMC: 3781MB NAND: 256 MB
bdinfo arch_number = 0x00000998 env_t = 0x00000000 boot_params = 0x30000100 DRAM bank = 0x00000000 -> start = 0x30000000 -> size = 0x10000000 DRAM bank = 0x00000001 -> start = 0x40000000 -> size = 0x10000000 ethaddr = 00:22:DE:AD:BE:EF ip_addr = 192.168.0.20 baudrate = 115200 bps ---
I believe 1.3.4 dates back to 2008, I think it was patched heavily from up-stream before making any s5pv210 specific work - so I don't know how representative the version number is.
Again, if you do know anything that could help me - please let me know.
Many thanks,
Andy.
Hi Andrew,
Hi Lukasz,
The S5PV210 CPU is supported in u-boot with GONI target board.
However, it seems that smdkv210 is not (there are smdkv310_defconfig and smdkc100_defconfig)
If I might ask, what is the exact problem?
If you wish to run your board with newest u-boot, I can recommend adding it to u-boot with using goni target as an example.
It is _very_ old indeed.
Many thanks,
Andy.
Andrew Barnes
Lukasz Majewski
