[U-Boot] [PATCH v3 1/2] rockchip: configs: only add available BOOT_TARGET_DEVICES
BOOT_TARGET_DEVICES should only be added if the corresponding u-boot command is enabled.
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v3: - Use CONFIG_IS_ENABLED macro instead of #ifdefs - Add missing else path
Changes in v2: - Add patch to series to prevent build errors if boards don't enable the required u-boot command for distroboot
include/configs/rockchip-common.h | 43 +++++++++++++++++++++++++++------------ 1 file changed, 30 insertions(+), 13 deletions(-)
diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 2d190a964a..a57ba1118f 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -11,22 +11,39 @@ #ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h>
-/* First try to boot from SD (index 0), then eMMC (index 1 */ -#ifdef CONFIG_CMD_USB -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(USB, usb, 0) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) +/* First try to boot from SD (index 0), then eMMC (index 1) */ +#if CONFIG_IS_ENABLED(CMD_MMC) + #define BOOT_TARGET_MMC(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) #else -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) + #define BOOT_TARGET_MMC(func) #endif
+#if CONFIG_IS_ENABLED(CMD_USB) + #define BOOT_TARGET_USB(func) func(USB, usb, 0) +#else + #define BOOT_TARGET_USB(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_PXE) + #define BOOT_TARGET_PXE(func) func(PXE, pxe, na) +#else + #define BOOT_TARGET_PXE(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_DHCP) + #define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) +#else + #define BOOT_TARGET_DHCP(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_MMC(func) \ + BOOT_TARGET_USB(func) \ + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) + #define CONFIG_RANDOM_UUID
#ifdef CONFIG_ARM64
rockchip-common.h already defines values that are missing from rk3368_common.h
For example BOOT_TARGET_DEVICES was defined empty and therefore distroboot had no boot targets.
include/configs/rk3368_common.h | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 8b4155f37c..b643cc2464 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -7,6 +7,8 @@ #ifndef __CONFIG_RK3368_COMMON_H #define __CONFIG_RK3368_COMMON_H
+#include "rockchip-common.h" + #define CONFIG_SYS_CACHELINE_SIZE 64
#include <asm/arch/hardware.h> @@ -44,10 +46,6 @@ "kernel_addr_r=0x280000\0" \ "ramdisk_addr_r=0x5bf0000\0"
-#include <config_distro_defaults.h> - -#define BOOT_TARGET_DEVICES(func) - #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \
Klaus Goger
