[U-Boot] Pull request: u-boot-spi/master
Hi Tom,
Please pull this request.
thanks! Jagan.
The following changes since commit 08887ed4505ec14ee94ab32c482dc4dec5ddc1e4:
ARM: am57xx_evm: Enable QSPI support (2016-07-30 00:15:07 +0530)
git://git.denx.de/u-boot-spi.git master
for you to fetch changes up to 53208741d6c3448b7a7f5260d52c28f912ff6453:
dm: at91: Add driver model support for the spi driver (2016-07-31 17:03:33 +0530)
---------------------------------------------------------------- Lad, Prabhakar (1): spi: zynq_spi: Fix infinite looping while xfer
Wenyou Yang (1): dm: at91: Add driver model support for the spi driver
drivers/spi/Kconfig | 7 ++ drivers/spi/atmel_spi.c | 295 ++++++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/zynq_spi.c | 2 +- 3 files changed, 303 insertions(+), 1 deletion(-)
On Tue, Aug 09, 2016 at 05:33:59PM +0530, Jagan Teki wrote:
Hi Tom,
thanks! Jagan.
NAK. The atmel DM prep stuff needs to be taken in, all at once perhaps, by Andreas all at once to avoid warnings like: + sama5d4_xplained_spiflash +(sama5d4_xplained_spiflash) static int clk_get_by_name(struct udevice *dev, const char *name, +(sama5d4_xplained_spiflash) ^ w+(sama5d4_xplained_spiflash) In file included from drivers/spi/atmel_spi.c:7:0: w+(sama5d4_xplained_spiflash) include/clk.h:107:12: warning: 'clk_get_by_name' defined but not used [-Wunused-function] that Marek also hit with the USB patch.
Jagan Teki
