[U-Boot] [PATCH] powerpc/mpc85xx:IFC Errata A003399 is not valid for BSC913x
As per Errata list of BSC9131 and BSC9132, IFC Errata A003399 is no more valid. So donot compile its workaround.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git branch master
arch/powerpc/include/asm/config_mpc85xx.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index d57c178..71f143e 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -490,7 +490,6 @@ #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_NAND_FSL_IFC -#define CONFIG_SYS_FSL_ERRATUM_IFC_A003399 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111
#elif defined(CONFIG_BSC9132) @@ -503,7 +502,6 @@ #define CONFIG_NUM_DDR_CONTROLLERS 2 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_NAND_FSL_IFC -#define CONFIG_SYS_FSL_ERRATUM_IFC_A003399 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2"
Prabhakar Kushwaha
