[U-Boot] [PATCH 0/3] ARM: uniphier: some more UniPhier SoC code updates
Masahiro Yamada (3): clk: uniphier: rework UniPhier clk driver ARM: uniphier: adjust fdt_file environment handling to latest Linux ARM: uniphier: remove unnecessary EHCI reset deassertion
arch/arm/mach-uniphier/board_late_init.c | 17 +-- arch/arm/mach-uniphier/clk/clk-ld4.c | 3 - arch/arm/mach-uniphier/clk/clk-pro4.c | 3 - drivers/clk/uniphier/Kconfig | 15 +-- drivers/clk/uniphier/Makefile | 5 +- drivers/clk/uniphier/clk-uniphier-core.c | 170 +++++++++++++--------------- drivers/clk/uniphier/clk-uniphier-mio.c | 183 +++++++++++-------------------- drivers/clk/uniphier/clk-uniphier.h | 46 +++++--- 8 files changed, 185 insertions(+), 257 deletions(-)
The initial design of the UniPhier clk driver for U-Boot was not very nice. Here is a re-work to sync it with Linux's clk and reset drivers, maximizing the code reuse from Linux's clk data.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/clk/uniphier/Kconfig | 15 +-- drivers/clk/uniphier/Makefile | 5 +- drivers/clk/uniphier/clk-uniphier-core.c | 170 +++++++++++++--------------- drivers/clk/uniphier/clk-uniphier-mio.c | 183 +++++++++++-------------------- drivers/clk/uniphier/clk-uniphier.h | 46 +++++--- 5 files changed, 179 insertions(+), 240 deletions(-)
diff --git a/drivers/clk/uniphier/Kconfig b/drivers/clk/uniphier/Kconfig index 0e90c01..da3e355 100644 --- a/drivers/clk/uniphier/Kconfig +++ b/drivers/clk/uniphier/Kconfig @@ -1,13 +1,10 @@ config CLK_UNIPHIER - bool + bool "Clock driver for UniPhier SoCs" + depends on ARCH_UNIPHIER select CLK select SPL_CLK - -menu "Clock drivers for UniPhier SoCs" - depends on CLK_UNIPHIER - -config CLK_UNIPHIER_MIO - bool "Clock driver for UniPhier Media I/O block" default y - -endmenu + help + Support for clock controllers on UniPhier SoCs. + Say Y if you want to control clocks provided by System Control + block, Media I/O block, Peripheral Block. diff --git a/drivers/clk/uniphier/Makefile b/drivers/clk/uniphier/Makefile index a3168f9..ed623aa 100644 --- a/drivers/clk/uniphier/Makefile +++ b/drivers/clk/uniphier/Makefile @@ -1,3 +1,2 @@ -obj-y += clk-uniphier-core.o - -obj-$(CONFIG_CLK_UNIPHIER_MIO) += clk-uniphier-mio.o +obj-y += clk-uniphier-core.o +obj-y += clk-uniphier-mio.o diff --git a/drivers/clk/uniphier/clk-uniphier-core.c b/drivers/clk/uniphier/clk-uniphier-core.c index 3948326..8ad0242 100644 --- a/drivers/clk/uniphier/clk-uniphier-core.c +++ b/drivers/clk/uniphier/clk-uniphier-core.c @@ -6,11 +6,11 @@ */
#include <common.h> +#include <clk-uclass.h> +#include <dm/device.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/sizes.h> -#include <clk-uclass.h> -#include <dm/device.h>
#include "clk-uniphier.h"
@@ -18,136 +18,106 @@ * struct uniphier_clk_priv - private data for UniPhier clock driver * * @base: base address of the clock provider - * @socdata: SoC specific data + * @data: SoC specific data */ struct uniphier_clk_priv { void __iomem *base; - const struct uniphier_clk_soc_data *socdata; + const struct uniphier_clk_data *data; };
-int uniphier_clk_probe(struct udevice *dev) +static int uniphier_clk_enable(struct clk *clk) { - struct uniphier_clk_priv *priv = dev_get_priv(dev); - fdt_addr_t addr; + struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); + unsigned long id = clk->id; + const struct uniphier_clk_gate_data *p;
- addr = dev_get_addr(dev->parent); - if (addr == FDT_ADDR_T_NONE) - return -EINVAL; + for (p = priv->data->gate; p->id != UNIPHIER_CLK_ID_END; p++) { + u32 val;
- priv->base = devm_ioremap(dev, addr, SZ_4K); - if (!priv->base) - return -ENOMEM; + if (p->id != id) + continue;
- priv->socdata = (void *)dev_get_driver_data(dev); + val = readl(priv->base + p->reg); + val |= BIT(p->bit); + writel(val, priv->base + p->reg);
- return 0; + return 0; + } + + dev_err(priv->dev, "clk_id=%lu was not handled\n", id); + return -EINVAL; }
-static int uniphier_clk_enable(struct clk *clk) +static const struct uniphier_clk_mux_data * +uniphier_clk_get_mux_data(struct uniphier_clk_priv *priv, unsigned long id) { - struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); - const struct uniphier_clk_gate_data *gate = priv->socdata->gate; - unsigned int nr_gate = priv->socdata->nr_gate; - void __iomem *reg; - u32 mask, data, tmp; - int i; - - for (i = 0; i < nr_gate; i++) { - if (gate[i].index != clk->id) - continue; - - reg = priv->base + gate[i].reg; - mask = gate[i].mask; - data = gate[i].data & mask; + const struct uniphier_clk_mux_data *p;
- tmp = readl(reg); - tmp &= ~mask; - tmp |= data & mask; - debug("%s: %p: %08x\n", __func__, reg, tmp); - writel(tmp, reg); + for (p = priv->data->mux; p->id != UNIPHIER_CLK_ID_END; p++) { + if (p->id == id) + return p; }
- return 0; + return NULL; }
static ulong uniphier_clk_get_rate(struct clk *clk) { struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); - const struct uniphier_clk_rate_data *rdata = priv->socdata->rate; - unsigned int nr_rdata = priv->socdata->nr_rate; - void __iomem *reg; - u32 mask, data; - ulong matched_rate = 0; + const struct uniphier_clk_mux_data *mux; + u32 val; int i;
- for (i = 0; i < nr_rdata; i++) { - if (rdata[i].index != clk->id) - continue; + mux = uniphier_clk_get_mux_data(priv, clk->id); + if (!mux) + return 0;
- if (rdata[i].reg == UNIPHIER_CLK_RATE_IS_FIXED) - return rdata[i].rate; - - reg = priv->base + rdata[i].reg; - mask = rdata[i].mask; - data = rdata[i].data & mask; - if ((readl(reg) & mask) == data) { - if (matched_rate && rdata[i].rate != matched_rate) { - printf("failed to get clk rate for insane register values\n"); - return -EINVAL; - } - matched_rate = rdata[i].rate; - } - } + if (!mux->nr_muxs) /* fixed-rate */ + return mux->rates[0]; + + val = readl(priv->base + mux->reg);
- debug("%s: rate = %lu\n", __func__, matched_rate); + for (i = 0; i < mux->nr_muxs; i++) + if ((mux->masks[i] & val) == mux->vals[i]) + return mux->rates[i];
- return matched_rate; + return -EINVAL; }
static ulong uniphier_clk_set_rate(struct clk *clk, ulong rate) { struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); - const struct uniphier_clk_rate_data *rdata = priv->socdata->rate; - unsigned int nr_rdata = priv->socdata->nr_rate; - void __iomem *reg; - u32 mask, data, tmp; + const struct uniphier_clk_mux_data *mux; + u32 val; + int i, best_rate_id = -1; ulong best_rate = 0; - int i;
- /* first, decide the best match rate */ - for (i = 0; i < nr_rdata; i++) { - if (rdata[i].index != clk->id) - continue; + mux = uniphier_clk_get_mux_data(priv, clk->id); + if (!mux) + return 0;
- if (rdata[i].reg == UNIPHIER_CLK_RATE_IS_FIXED) - return 0; + if (!mux->nr_muxs) /* fixed-rate */ + return mux->rates[0];
- if (rdata[i].rate > best_rate && rdata[i].rate <= rate) - best_rate = rdata[i].rate; + /* first, decide the best match rate */ + for (i = 0; i < mux->nr_muxs; i++) { + if (mux->rates[i] > best_rate && mux->rates[i] <= rate) { + best_rate = mux->rates[i]; + best_rate_id = i; + } }
- if (!best_rate) - return -ENODEV; + if (best_rate_id < 0) + return -EINVAL; + + val = readl(priv->base + mux->reg); + val &= ~mux->masks[best_rate_id]; + val |= mux->vals[best_rate_id]; + writel(val, priv->base + mux->reg);
debug("%s: requested rate = %lu, set rate = %lu\n", __func__, rate, best_rate);
- /* second, really set registers */ - for (i = 0; i < nr_rdata; i++) { - if (rdata[i].index != clk->id || rdata[i].rate != best_rate) - continue; - - reg = priv->base + rdata[i].reg; - mask = rdata[i].mask; - data = rdata[i].data & mask; - - tmp = readl(reg); - tmp &= ~mask; - tmp |= data; - debug("%s: %p: %08x\n", __func__, reg, tmp); - writel(tmp, reg); - } - return best_rate; }
@@ -157,6 +127,24 @@ const struct clk_ops uniphier_clk_ops = { .set_rate = uniphier_clk_set_rate, };
+static int uniphier_clk_probe(struct udevice *dev) +{ + struct uniphier_clk_priv *priv = dev_get_priv(dev); + fdt_addr_t addr; + + addr = dev_get_addr(dev->parent); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = devm_ioremap(dev, addr, SZ_4K); + if (!priv->base) + return -ENOMEM; + + priv->data = (void *)dev_get_driver_data(dev); + + return 0; +} + static const struct udevice_id uniphier_clk_match[] = { { .compatible = "socionext,uniphier-sld3-mio-clock", diff --git a/drivers/clk/uniphier/clk-uniphier-mio.c b/drivers/clk/uniphier/clk-uniphier-mio.c index c1e7197..18e6856 100644 --- a/drivers/clk/uniphier/clk-uniphier-mio.c +++ b/drivers/clk/uniphier/clk-uniphier-mio.c @@ -5,136 +5,81 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <dm/device.h> - #include "clk-uniphier.h"
-#define UNIPHIER_MIO_CLK_GATE_SD(ch, idx) \ - { \ - .index = (idx), \ - .reg = 0x20 + 0x200 * (ch), \ - .mask = 0x00000100, \ - .data = 0x00000100, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x110 + 0x200 * (ch), \ - .mask = 0x00000001, \ - .data = 0x00000001, \ - } +#define UNIPHIER_MIO_CLK_SD_GATE(id, ch) \ + UNIPHIER_CLK_GATE((id), 0x20 + 0x200 * (ch), 8)
-#define UNIPHIER_MIO_CLK_RATE_SD(ch, idx) \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00000000, \ - .rate = 44444444, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00010000, \ - .rate = 33333333, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00020000, \ - .rate = 50000000, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00020000, \ - .rate = 66666666, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00001000, \ - .rate = 100000000, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00001100, \ - .rate = 40000000, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00001200, \ - .rate = 25000000, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x30 + 0x200 * (ch), \ - .mask = 0x00031300, \ - .data = 0x00001300, \ - .rate = 22222222, \ - } +#define UNIPHIER_MIO_CLK_USB2(id, ch) \ + UNIPHIER_CLK_GATE((id), 0x20 + 0x200 * (ch), 28)
-#define UNIPHIER_MIO_CLK_GATE_USB(ch, idx) \ - { \ - .index = (idx), \ - .reg = 0x20 + 0x200 * (ch), \ - .mask = 0x30000000, \ - .data = 0x30000000, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x110 + 0x200 * (ch), \ - .mask = 0x01000000, \ - .data = 0x01000000, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x114 + 0x200 * (ch), \ - .mask = 0x00000001, \ - .data = 0x00000001, \ - } +#define UNIPHIER_MIO_CLK_USB2_PHY(id, ch) \ + UNIPHIER_CLK_GATE((id), 0x20 + 0x200 * (ch), 29) + +#define UNIPHIER_MIO_CLK_DMAC(id) \ + UNIPHIER_CLK_GATE((id), 0x20, 25)
-#define UNIPHIER_MIO_CLK_GATE_DMAC(idx) \ - { \ - .index = (idx), \ - .reg = 0x20, \ - .mask = 0x02000000, \ - .data = 0x02000000, \ - }, \ - { \ - .index = (idx), \ - .reg = 0x110, \ - .mask = 0x00020000, \ - .data = 0x00020000, \ +#define UNIPHIER_MIO_CLK_SD_MUX(_id, ch) \ + { \ + .id = (_id), \ + .nr_muxs = 8, \ + .reg = 0x30 + 0x200 * (ch), \ + .masks = { \ + 0x00031000, \ + 0x00031000, \ + 0x00031000, \ + 0x00031000, \ + 0x00001300, \ + 0x00001300, \ + 0x00001300, \ + 0x00001300, \ + }, \ + .vals = { \ + 0x00000000, \ + 0x00010000, \ + 0x00020000, \ + 0x00030000, \ + 0x00001000, \ + 0x00001100, \ + 0x00001200, \ + 0x00001300, \ + }, \ + .rates = { \ + 44444444, \ + 33333333, \ + 50000000, \ + 66666666, \ + 100000000, \ + 40000000, \ + 25000000, \ + 22222222, \ + }, \ }
static const struct uniphier_clk_gate_data uniphier_mio_clk_gate[] = { - UNIPHIER_MIO_CLK_GATE_SD(0, 0), - UNIPHIER_MIO_CLK_GATE_SD(1, 1), - UNIPHIER_MIO_CLK_GATE_SD(2, 2), /* for PH1-Pro4 only */ - UNIPHIER_MIO_CLK_GATE_USB(0, 3), - UNIPHIER_MIO_CLK_GATE_USB(1, 4), - UNIPHIER_MIO_CLK_GATE_USB(2, 5), - UNIPHIER_MIO_CLK_GATE_DMAC(6), - UNIPHIER_MIO_CLK_GATE_USB(3, 7), /* for PH1-sLD3 only */ + UNIPHIER_MIO_CLK_SD_GATE(0, 0), + UNIPHIER_MIO_CLK_SD_GATE(1, 1), + UNIPHIER_MIO_CLK_SD_GATE(2, 2), /* for PH1-Pro4 only */ + UNIPHIER_MIO_CLK_DMAC(7), + UNIPHIER_MIO_CLK_USB2(8, 0), + UNIPHIER_MIO_CLK_USB2(9, 1), + UNIPHIER_MIO_CLK_USB2(10, 2), + UNIPHIER_MIO_CLK_USB2(11, 3), /* for PH1-sLD3 only */ + UNIPHIER_MIO_CLK_USB2_PHY(12, 0), + UNIPHIER_MIO_CLK_USB2_PHY(13, 1), + UNIPHIER_MIO_CLK_USB2_PHY(14, 2), + UNIPHIER_MIO_CLK_USB2_PHY(15, 3), /* for PH1-sLD3 only */ + UNIPHIER_CLK_END };
-static const struct uniphier_clk_rate_data uniphier_mio_clk_rate[] = { - UNIPHIER_MIO_CLK_RATE_SD(0, 0), - UNIPHIER_MIO_CLK_RATE_SD(1, 1), - UNIPHIER_MIO_CLK_RATE_SD(2, 2), /* for PH1-Pro4 only */ +static const struct uniphier_clk_mux_data uniphier_mio_clk_mux[] = { + UNIPHIER_MIO_CLK_SD_MUX(0, 0), + UNIPHIER_MIO_CLK_SD_MUX(1, 1), + UNIPHIER_MIO_CLK_SD_MUX(2, 2), /* for PH1-Pro4 only */ + UNIPHIER_CLK_END };
-const struct uniphier_clk_soc_data uniphier_mio_clk_data = { +const struct uniphier_clk_data uniphier_mio_clk_data = { .gate = uniphier_mio_clk_gate, - .nr_gate = ARRAY_SIZE(uniphier_mio_clk_gate), - .rate = uniphier_mio_clk_rate, - .nr_rate = ARRAY_SIZE(uniphier_mio_clk_rate), + .mux = uniphier_mio_clk_mux, }; diff --git a/drivers/clk/uniphier/clk-uniphier.h b/drivers/clk/uniphier/clk-uniphier.h index 0b60337..f9a560e 100644 --- a/drivers/clk/uniphier/clk-uniphier.h +++ b/drivers/clk/uniphier/clk-uniphier.h @@ -10,36 +10,46 @@
#include <linux/kernel.h>
+#define UNIPHIER_CLK_MAX_NR_MUXS 8 + struct uniphier_clk_gate_data { - int index; + unsigned int id; unsigned int reg; - u32 mask; - u32 data; + unsigned int bit; };
-struct uniphier_clk_rate_data { - int index; +struct uniphier_clk_mux_data { + unsigned int id; + unsigned int nr_muxs; unsigned int reg; -#define UNIPHIER_CLK_RATE_IS_FIXED UINT_MAX - u32 mask; - u32 data; - unsigned long rate; + unsigned int masks[UNIPHIER_CLK_MAX_NR_MUXS]; + unsigned int vals[UNIPHIER_CLK_MAX_NR_MUXS]; + unsigned long rates[UNIPHIER_CLK_MAX_NR_MUXS]; };
-struct uniphier_clk_soc_data { +struct uniphier_clk_data { const struct uniphier_clk_gate_data *gate; - unsigned int nr_gate; - const struct uniphier_clk_rate_data *rate; - unsigned int nr_rate; + const struct uniphier_clk_mux_data *mux; };
-#define UNIPHIER_CLK_FIXED_RATE(i, f) \ +#define UNIPHIER_CLK_ID_END (unsigned int)(-1) + +#define UNIPHIER_CLK_END \ + { .id = UNIPHIER_CLK_ID_END } + +#define UNIPHIER_CLK_GATE(_id, _reg, _bit) \ + { \ + .id = (_id), \ + .reg = (_reg), \ + .bit = (_bit), \ + } + +#define UNIPHIER_CLK_FIXED_RATE(_id, _rate) \ { \ - .index = i, \ - .reg = UNIPHIER_CLK_RATE_IS_FIXED, \ - .rate = f, \ + .id = (_id), \ + .rates = {(_reg),}, \ }
-extern const struct uniphier_clk_soc_data uniphier_mio_clk_data; +extern const struct uniphier_clk_data uniphier_mio_clk_data;
#endif /* __CLK_UNIPHIER_H__ */
The environment fdt_file is useful to remember the appropriate DTB file name. Adjust it to the recent renaming in the upstream kernel.
arch/arm/mach-uniphier/board_late_init.c | 17 ++++++----------- 1 file changed, 6 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index f23295f..a63b19d 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -28,15 +28,12 @@ static void nand_denali_wp_disable(void) #endif }
-#define VENDOR_PREFIX "socionext," -#define DTB_FILE_PREFIX "uniphier-" - static int uniphier_set_fdt_file(void) { DECLARE_GLOBAL_DATA_PTR; const char *compat; char dtb_name[256]; - int buf_len = 256; + int buf_len = sizeof(dtb_name);
if (getenv("fdt_file")) return 0; /* do nothing if it is already set */ @@ -45,15 +42,13 @@ static int uniphier_set_fdt_file(void) if (!compat) return -EINVAL;
- if (strncmp(compat, VENDOR_PREFIX, strlen(VENDOR_PREFIX))) + /* rip off the vendor prefix "socionext," */ + compat = strchr(compat, ','); + if (!compat) return -EINVAL; + compat++;
- compat += strlen(VENDOR_PREFIX); - - strncat(dtb_name, DTB_FILE_PREFIX, buf_len); - buf_len -= strlen(DTB_FILE_PREFIX); - - strncat(dtb_name, compat, buf_len); + strncpy(dtb_name, compat, buf_len); buf_len -= strlen(compat);
strncat(dtb_name, ".dtb", buf_len);
It is now deasserted by the reset controller driver. Drop the ad-hoc code.
arch/arm/mach-uniphier/clk/clk-ld4.c | 3 --- arch/arm/mach-uniphier/clk/clk-pro4.c | 3 --- 2 files changed, 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/clk-ld4.c b/arch/arm/mach-uniphier/clk/clk-ld4.c index 8744d26..02c9321 100644 --- a/arch/arm/mach-uniphier/clk/clk-ld4.c +++ b/arch/arm/mach-uniphier/clk/clk-ld4.c @@ -18,9 +18,6 @@ void uniphier_ld4_clk_init(void) #ifdef CONFIG_UNIPHIER_ETH tmp |= SC_RSTCTRL_NRST_ETHER; #endif -#ifdef CONFIG_USB_EHCI - tmp |= SC_RSTCTRL_NRST_STDMAC; -#endif #ifdef CONFIG_NAND_DENALI tmp |= SC_RSTCTRL_NRST_NAND; #endif diff --git a/arch/arm/mach-uniphier/clk/clk-pro4.c b/arch/arm/mach-uniphier/clk/clk-pro4.c index 8746d7d..7d09841 100644 --- a/arch/arm/mach-uniphier/clk/clk-pro4.c +++ b/arch/arm/mach-uniphier/clk/clk-pro4.c @@ -22,9 +22,6 @@ void uniphier_pro4_clk_init(void) #ifdef CONFIG_UNIPHIER_ETH tmp |= SC_RSTCTRL_NRST_ETHER; #endif -#ifdef CONFIG_USB_EHCI - tmp |= SC_RSTCTRL_NRST_STDMAC; -#endif #ifdef CONFIG_NAND_DENALI tmp |= SC_RSTCTRL_NRST_NAND; #endif
2016-10-17 22:18 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
