[U-Boot] [PATCH] ppc4xx: Replace 4xx lowercase SPR references
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- This patch replaces my patch from yesterday titled
[PATCH V2] ppc4xx: use SPRN_TCR macro instead of tcr
board/esd/pmc440/pmc440.c | 2 +- board/mpl/mip405/mip405.c | 2 +- board/mpl/pip405/pip405.c | 2 +- board/netstal/hcu5/hcu5.c | 8 +- board/netstal/hcu5/sdram.c | 4 +- board/netstal/mcu25/mcu25.c | 2 +- cpu/ppc4xx/cpu.c | 8 +- cpu/ppc4xx/cpu_init.c | 2 +- cpu/ppc4xx/interrupts.c | 18 ++-- cpu/ppc4xx/speed.c | 3 +- cpu/ppc4xx/start.S | 206 +++++++++++++++++++++--------------------- include/asm-ppc/processor.h | 46 ++++++++++ include/ppc405.h | 55 ------------ include/ppc440.h | 93 ------------------- post/cpu/ppc4xx/fpu.c | 6 +- 15 files changed, 178 insertions(+), 279 deletions(-)
diff --git a/board/esd/pmc440/pmc440.c b/board/esd/pmc440/pmc440.c index 2ab944d..f22a1c2 100644 --- a/board/esd/pmc440/pmc440.c +++ b/board/esd/pmc440/pmc440.c @@ -142,7 +142,7 @@ int board_early_init_f(void) reg |= CPR0_ICFG_RLI_MASK; mtcpr(clk_icfg, reg);
- mtspr(dbcr0, 0x20000000); /* do chip reset */ + mtspr(SPRN_DBCR0, 0x20000000); /* do chip reset */ }
/* diff --git a/board/mpl/mip405/mip405.c b/board/mpl/mip405/mip405.c index 24caa46..1738f54 100644 --- a/board/mpl/mip405/mip405.c +++ b/board/mpl/mip405/mip405.c @@ -688,7 +688,7 @@ int misc_init_r (void) start=get_timer(0); /* if MIP405 has booted from PCI, reset CCR0[24] as described in errata PCI_18 */ if (mfdcr(strap) & PSR_ROM_LOC) - mtspr(ccr0, (mfspr(ccr0) & ~0x80)); + mtspr(SPRN_CCR0, (mfspr(SPRN_CCR0) & ~0x80));
return (0); } diff --git a/board/mpl/pip405/pip405.c b/board/mpl/pip405/pip405.c index f31a5e8..677437d 100644 --- a/board/mpl/pip405/pip405.c +++ b/board/mpl/pip405/pip405.c @@ -669,7 +669,7 @@ int misc_init_r (void)
/* if PIP405 has booted from PCI, reset CCR0[24] as described in errata PCI_18 */ if (mfdcr(strap) & PSR_ROM_LOC) - mtspr(ccr0, (mfspr(ccr0) & ~0x80)); + mtspr(SPRN_CCR0, (mfspr(SPRN_CCR0) & ~0x80));
return (0); } diff --git a/board/netstal/hcu5/hcu5.c b/board/netstal/hcu5/hcu5.c index 6f4ec29..5eb33d3 100644 --- a/board/netstal/hcu5/hcu5.c +++ b/board/netstal/hcu5/hcu5.c @@ -89,8 +89,8 @@ int board_early_init_f(void) /* * Initiate system reset in debug control register DBCR */ - dbcr = mfspr(dbcr0); - mtspr(dbcr0, dbcr | CHIP_RESET); + dbcr = mfspr(SPRN_DBCR0); + mtspr(SPRN_DBCR0, dbcr | CHIP_RESET); } mtsdr(SDR0_CP440, 0x0EAAEA02); /* [Nto1] = 1*/ #endif @@ -307,14 +307,14 @@ int misc_init_r(void) /* We cannot easily enable trace before, as there are other * routines messing around with sdr0_pfc1. And I do not need it. */ - if (mfspr(dbcr0) & 0x80000000) { + if (mfspr(SPRN_DBCR0) & 0x80000000) { /* External debugger alive * enable trace facilty for Lauterbach * CCR0[DTB]=0 Enable broadcast of trace information * SDR0_PFC0[TRE] Trace signals are enabled instead of * GPIO49-63 */ - mtspr(ccr0, mfspr(ccr0) &~ (CCR0_DTB)); + mtspr(SPRN_CCR0, mfspr(SPRN_CCR0) &~ (CCR0_DTB)); mtsdr(SDR0_PFC0, sdr0_pfc1 | SDR0_PFC0_TRE_ENABLE); } return 0; diff --git a/board/netstal/hcu5/sdram.c b/board/netstal/hcu5/sdram.c index f59bd7d..5c2ec35 100644 --- a/board/netstal/hcu5/sdram.c +++ b/board/netstal/hcu5/sdram.c @@ -144,7 +144,7 @@ static void program_ecc(unsigned long start_address, unsigned long num_bytes) u32 *magicPtr; u32 magic;
- if ((mfspr(dbcr0) & 0x80000000) == 0) { + if ((mfspr(SPRN_DBCR0) & 0x80000000) == 0) { /* only if no external debugger is alive! * Check whether vxWorks is using EDR logging, if yes zero * also PostMortem and user reserved memory @@ -182,7 +182,7 @@ static void program_ecc(unsigned long start_address, unsigned long num_bytes) * If not done, then we could get an interrupt later on when * exceptions are enabled. */ - mtspr(mcsr, mfspr(mcsr)); + mtspr(SPRN_MCSR, mfspr(SPRN_MCSR));
/* Set 'int_mask' parameter to functionnal value */ mfsdram(DDR0_01, val); diff --git a/board/netstal/mcu25/mcu25.c b/board/netstal/mcu25/mcu25.c index 66ed95f..67c1b0b 100644 --- a/board/netstal/mcu25/mcu25.c +++ b/board/netstal/mcu25/mcu25.c @@ -77,7 +77,7 @@ int board_early_init_f (void) out32(GPIO0_OR, CONFIG_SYS_GPIO0_OR ); out32(GPIO0_TCR, CONFIG_SYS_GPIO0_TCR); out32(GPIO0_ODR, CONFIG_SYS_GPIO0_ODR); - mtspr(ccr0, 0x00700000); + mtspr(SPRN_CCR0, 0x00700000);
return 0; } diff --git a/cpu/ppc4xx/cpu.c b/cpu/ppc4xx/cpu.c index fb3837c..e12a784 100644 --- a/cpu/ppc4xx/cpu.c +++ b/cpu/ppc4xx/cpu.c @@ -272,7 +272,7 @@ static int do_chip_reset (unsigned long sys0, unsigned long sys1) mtdcr (cpc0_sys0, sys0); mtdcr (cpc0_sys1, sys1); mtdcr (cntrl0, mfdcr (cntrl0) & ~0x80000000); /* Clr SWE */ - mtspr (dbcr0, 0x20000000); /* Reset the chip */ + mtspr (SPRN_DBCR0, 0x20000000); /* Reset the chip */
return 1; } @@ -654,12 +654,12 @@ int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) board_reset(); #else #if defined(CONFIG_SYS_4xx_RESET_TYPE) - mtspr(dbcr0, CONFIG_SYS_4xx_RESET_TYPE << 28); + mtspr(SPRN_DBCR0, CONFIG_SYS_4xx_RESET_TYPE << 28); #else /* * Initiate system reset in debug control register DBCR */ - mtspr(dbcr0, 0x30000000); + mtspr(SPRN_DBCR0, 0x30000000); #endif /* defined(CONFIG_SYS_4xx_RESET_TYPE) */ #endif /* defined(CONFIG_BOARD_RESET) */
@@ -697,7 +697,7 @@ void reset_4xx_watchdog(void) /* * Clear TSR(WIS) bit */ - mtspr(tsr, 0x40000000); + mtspr(SPRN_TSR, 0x40000000); } #endif /* CONFIG_WATCHDOG */
diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index bbd795d..65092fb 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -123,7 +123,7 @@ void reconfigure_pll(u32 new_cpu_freq) /* Reset processor if configuration changed */ if (reset_needed) { __asm__ __volatile__ ("sync; isync"); - mtspr(dbcr0, 0x20000000); + mtspr(SPRN_DBCR0, 0x20000000); } #endif } diff --git a/cpu/ppc4xx/interrupts.c b/cpu/ppc4xx/interrupts.c index 494bd8c..6db8421 100644 --- a/cpu/ppc4xx/interrupts.c +++ b/cpu/ppc4xx/interrupts.c @@ -102,15 +102,15 @@ int interrupt_init_cpu (unsigned *decrementer_count) * Init PIT */ #if defined(CONFIG_440) - val = mfspr( tcr ); + val = mfspr( SPRN_TCR ); val &= (~0x04400000); /* clear DIS & ARE */ - mtspr( tcr, val ); - mtspr( dec, 0 ); /* Prevent exception after TSR clear*/ - mtspr( decar, 0 ); /* clear reload */ - mtspr( tsr, 0x08000000 ); /* clear DEC status */ + mtspr( SPRN_TCR, val ); + mtspr( SPRN_DEC, 0 ); /* Prevent exception after TSR clear*/ + mtspr( SPRN_DECAR, 0 ); /* clear reload */ + mtspr( SPRN_TSR, 0x08000000 ); /* clear DEC status */ val = gd->bd->bi_intfreq/1000; /* 1 msec */ - mtspr( decar, val ); /* Set auto-reload value */ - mtspr( dec, val ); /* Set inital val */ + mtspr( SPRN_DECAR, val ); /* Set auto-reload value */ + mtspr( SPRN_DEC, val ); /* Set inital val */ #else set_pit(gd->bd->bi_intfreq / 1000); #endif @@ -126,9 +126,9 @@ int interrupt_init_cpu (unsigned *decrementer_count) /* * Enable PIT */ - val = mfspr(tcr); + val = mfspr(SPRN_TCR); val |= 0x04400000; - mtspr(tcr, val); + mtspr(SPRN_TCR, val);
/* * Set EVPR to 0 diff --git a/cpu/ppc4xx/speed.c b/cpu/ppc4xx/speed.c index ed6e55b..e1a634c 100644 --- a/cpu/ppc4xx/speed.c +++ b/cpu/ppc4xx/speed.c @@ -394,7 +394,8 @@ void get_sys_info (sys_info_t *sysInfo) sysInfo->freqUART = sysInfo->freqPLB;
/* Figure which timer source to use */ - if (mfspr(ccr1) & 0x0080) { /* External Clock, assume same as SYS_CLK */ + if (mfspr(SPRN_CCR1) & 0x0080) { + /* External Clock, assume same as SYS_CLK */ temp = sysInfo->freqProcessor / 2; /* Max extern clock speed */ if (CONFIG_SYS_CLK_FREQ > temp) sysInfo->freqTmrClk = temp; diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index 582c781..90e66d9 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -297,7 +297,7 @@ _start_440: | Core bug fix. Clear the esr +-----------------------------------------------------------------*/ li r0,0 - mtspr esr,r0 + mtspr SPRN_ESR,r0 /*----------------------------------------------------------------*/ /* Clear and set up some registers. */ /*----------------------------------------------------------------*/ @@ -305,16 +305,16 @@ _start_440: dccci r0,r0 /* NOTE: operands not used for 440 */ sync li r0,0 - mtspr srr0,r0 - mtspr srr1,r0 - mtspr csrr0,r0 - mtspr csrr1,r0 + mtspr SPRN_SRR0,r0 + mtspr SPRN_SRR1,r0 + mtspr SPRN_CSRR0,r0 + mtspr SPRN_CSRR1,r0 /* NOTE: 440GX adds machine check status regs */ #if defined(CONFIG_440) && !defined(CONFIG_440GP) - mtspr mcsrr0,r0 - mtspr mcsrr1,r0 - mfspr r1,mcsr - mtspr mcsr,r1 + mtspr SPRN_MCSRR0,r0 + mtspr SPRN_MCSRR1,r0 + mfspr r1,SPRN_MCSR + mtspr SPRN_MCSR,r1 #endif
/*----------------------------------------------------------------*/ @@ -326,27 +326,27 @@ _start_440: */ lis r1,0x0030 /* store gathering & broadcast disable */ ori r1,r1,0x6000 /* cache touch */ - mtspr ccr0,r1 + mtspr SPRN_CCR0,r1
/*----------------------------------------------------------------*/ /* Initialize debug */ /*----------------------------------------------------------------*/ - mfspr r1,dbcr0 + mfspr r1,SPRN_DBCR0 andis. r1, r1, 0x8000 /* test DBCR0[EDM] bit */ bne skip_debug_init /* if set, don't clear debug register */ - mtspr dbcr0,r0 - mtspr dbcr1,r0 - mtspr dbcr2,r0 - mtspr iac1,r0 - mtspr iac2,r0 - mtspr iac3,r0 - mtspr dac1,r0 - mtspr dac2,r0 - mtspr dvc1,r0 - mtspr dvc2,r0 - - mfspr r1,dbsr - mtspr dbsr,r1 /* Clear all valid bits */ + mtspr SPRN_DBCR0,r0 + mtspr SPRN_DBCR1,r0 + mtspr SPRN_DBCR2,r0 + mtspr SPRN_IAC1,r0 + mtspr SPRN_IAC2,r0 + mtspr SPRN_IAC3,r0 + mtspr SPRN_DAC1,r0 + mtspr SPRN_DAC2,r0 + mtspr SPRN_DVC1,r0 + mtspr SPRN_DVC2,r0 + + mfspr r1,SPRN_DBSR + mtspr SPRN_DBSR,r1 /* Clear all valid bits */ skip_debug_init:
#if defined (CONFIG_440SPE) @@ -364,68 +364,68 @@ skip_debug_init: | j. TCS: Timebase increments from CPU clock. +-----------------------------------------------------------------*/ li r0,0 - mtspr ccr1, r0 + mtspr SPRN_CCR1, r0
/*----------------------------------------------------------------+ | Reset the timebase. | The previous write to CCR1 sets the timebase source. +-----------------------------------------------------------------*/ - mtspr tbl, r0 - mtspr tbu, r0 + mtspr SPRN_TBWL, r0 + mtspr SPRN_TBWU, r0 #endif
/*----------------------------------------------------------------*/ /* Setup interrupt vectors */ /*----------------------------------------------------------------*/ - mtspr ivpr,r0 /* Vectors start at 0x0000_0000 */ + mtspr SPRN_IVPR,r0 /* Vectors start at 0x0000_0000 */ li r1,0x0100 - mtspr ivor0,r1 /* Critical input */ + mtspr SPRN_IVOR0,r1 /* Critical input */ li r1,0x0200 - mtspr ivor1,r1 /* Machine check */ + mtspr SPRN_IVOR1,r1 /* Machine check */ li r1,0x0300 - mtspr ivor2,r1 /* Data storage */ + mtspr SPRN_IVOR2,r1 /* Data storage */ li r1,0x0400 - mtspr ivor3,r1 /* Instruction storage */ + mtspr SPRN_IVOR3,r1 /* Instruction storage */ li r1,0x0500 - mtspr ivor4,r1 /* External interrupt */ + mtspr SPRN_IVOR4,r1 /* External interrupt */ li r1,0x0600 - mtspr ivor5,r1 /* Alignment */ + mtspr SPRN_IVOR5,r1 /* Alignment */ li r1,0x0700 - mtspr ivor6,r1 /* Program check */ + mtspr SPRN_IVOR6,r1 /* Program check */ li r1,0x0800 - mtspr ivor7,r1 /* Floating point unavailable */ + mtspr SPRN_IVOR7,r1 /* Floating point unavailable */ li r1,0x0c00 - mtspr ivor8,r1 /* System call */ + mtspr SPRN_IVOR8,r1 /* System call */ li r1,0x0a00 - mtspr ivor9,r1 /* Auxiliary Processor unavailable */ + mtspr SPRN_IVOR9,r1 /* Auxiliary Processor unavailable */ li r1,0x0900 - mtspr ivor10,r1 /* Decrementer */ + mtspr SPRN_IVOR10,r1 /* Decrementer */ li r1,0x1300 - mtspr ivor13,r1 /* Data TLB error */ + mtspr SPRN_IVOR13,r1 /* Data TLB error */ li r1,0x1400 - mtspr ivor14,r1 /* Instr TLB error */ + mtspr SPRN_IVOR14,r1 /* Instr TLB error */ li r1,0x2000 - mtspr ivor15,r1 /* Debug */ + mtspr SPRN_IVOR15,r1 /* Debug */
/*----------------------------------------------------------------*/ /* Configure cache regions */ /*----------------------------------------------------------------*/ - mtspr inv0,r0 - mtspr inv1,r0 - mtspr inv2,r0 - mtspr inv3,r0 - mtspr dnv0,r0 - mtspr dnv1,r0 - mtspr dnv2,r0 - mtspr dnv3,r0 - mtspr itv0,r0 - mtspr itv1,r0 - mtspr itv2,r0 - mtspr itv3,r0 - mtspr dtv0,r0 - mtspr dtv1,r0 - mtspr dtv2,r0 - mtspr dtv3,r0 + mtspr SPRN_INV0,r0 + mtspr SPRN_INV1,r0 + mtspr SPRN_INV2,r0 + mtspr SPRN_INV3,r0 + mtspr SPRN_DNV0,r0 + mtspr SPRN_DNV1,r0 + mtspr SPRN_DNV2,r0 + mtspr SPRN_DNV3,r0 + mtspr SPRN_ITV0,r0 + mtspr SPRN_ITV1,r0 + mtspr SPRN_ITV2,r0 + mtspr SPRN_ITV3,r0 + mtspr SPRN_DTV0,r0 + mtspr SPRN_DTV1,r0 + mtspr SPRN_DTV2,r0 + mtspr SPRN_DTV3,r0
/*----------------------------------------------------------------*/ /* Cache victim limits */ @@ -434,17 +434,17 @@ skip_debug_init: */ lis r1,0x0001 ori r1,r1,0xf800 - mtspr ivlim,r1 - mtspr dvlim,r1 + mtspr SPRN_IVLIM,r1 + mtspr SPRN_DVLIM,r1
/*----------------------------------------------------------------+ |Initialize MMUCR[STID] = 0. +-----------------------------------------------------------------*/ - mfspr r0,mmucr + mfspr r0,SPRN_MMUCR addis r1,0,0xFFFF ori r1,r1,0xFF00 and r0,r0,r1 - mtspr mmucr,r0 + mtspr SPRN_MMUCR,r0
/*----------------------------------------------------------------*/ /* Clear all TLB entries -- TID = 0, TS = 0 */ @@ -516,9 +516,9 @@ tlbnx2: addi r4,r4,1 /* Next TLB */ b _start
3: li r0,0 - mtspr srr1,r0 /* Keep things disabled for now */ + mtspr SPRN_SRR1,r0 /* Keep things disabled for now */ mflr r1 - mtspr srr0,r1 + mtspr SPRN_SRR0,r1 rfi #endif /* CONFIG_440 */
@@ -622,12 +622,12 @@ _start: /*----------------------------------------------------------------*/ li r0,0x0000 lis r1,0xffff - mtspr dec,r0 /* prevent dec exceptions */ - mtspr tbl,r0 /* prevent fit & wdt exceptions */ - mtspr tbu,r0 - mtspr tsr,r1 /* clear all timer exception status */ - mtspr tcr,r0 /* disable all */ - mtspr esr,r0 /* clear exception syndrome register */ + mtspr SPRN_DEC,r0 /* prevent dec exceptions */ + mtspr SPRN_TBWL,r0 /* prevent fit & wdt exceptions */ + mtspr SPRN_TBWU,r0 + mtspr SPRN_TSR,r1 /* clear all timer exception status */ + mtspr SPRN_TCR,r0 /* disable all */ + mtspr SPRN_ESR,r0 /* clear exception syndrome register */ mtxer r0 /* clear integer exception register */
/*----------------------------------------------------------------*/ @@ -638,10 +638,10 @@ _start: #if defined(CONFIG_SYS_INIT_DBCR) lis r1,0xffff ori r1,r1,0xffff - mtspr dbsr,r1 /* Clear all status bits */ + mtspr SPRN_DBSR,r1 /* Clear all status bits */ lis r0,CONFIG_SYS_INIT_DBCR@h ori r0,r0,CONFIG_SYS_INIT_DBCR@l - mtspr dbcr0,r0 + mtspr SPRN_DBCR0,r0 isync #endif
@@ -680,17 +680,17 @@ _start: /* 8. set TFLOOR/NFLOOR to 8 (-> 8*16*32 bytes locked -> 4k) */ lis r1,0x0201 ori r1,r1,0xf808 - mtspr dvlim,r1 + mtspr SPRN_DVLIM,r1 lis r1,0x0808 ori r1,r1,0x0808 - mtspr dnv0,r1 - mtspr dnv1,r1 - mtspr dnv2,r1 - mtspr dnv3,r1 - mtspr dtv0,r1 - mtspr dtv1,r1 - mtspr dtv2,r1 - mtspr dtv3,r1 + mtspr SPRN_DNV0,r1 + mtspr SPRN_DNV1,r1 + mtspr SPRN_DNV2,r1 + mtspr SPRN_DNV3,r1 + mtspr SPRN_DTV0,r1 + mtspr SPRN_DTV1,r1 + mtspr SPRN_DTV2,r1 + mtspr SPRN_DTV3,r1 msync isync #endif /* CONFIG_SYS_INIT_RAM_DCACHE */ @@ -809,7 +809,7 @@ _start: /* Set up some machine state registers. */ /*----------------------------------------------------------------------- */ addi r0,r0,0x0000 /* initialize r0 to zero */ - mtspr esr,r0 /* clear Exception Syndrome Reg */ + mtspr SPRN_ESR,r0 /* clear Exception Syndrome Reg */ mttcr r0 /* timer control register */ mtexier r0 /* disable all interrupts */ addis r4,r0,0xFFFF /* set r4 to 0xFFFFFFFF (status in the */ @@ -919,7 +919,7 @@ _start: /*----------------------------------------------------------------------- */ addi r4,r0,0x0000 #if !defined(CONFIG_405EX) - mtspr sgr,r4 + mtspr SPRN_SGR,r4 #else /* * On 405EX, completely clearing the SGR leads to PPC hangup @@ -928,9 +928,9 @@ _start: */ lis r3,0x0000 ori r3,r3,0x7FFC - mtspr sgr,r3 + mtspr SPRN_SGR,r3 #endif - mtspr dcwr,r4 + mtspr SPRN_DCWR,r4 mtesr r4 /* clear Exception Syndrome Reg */ mttcr r4 /* clear Timer Control Reg */ mtxer r4 /* clear Fixed-Point Exception Reg */ @@ -1266,8 +1266,8 @@ crit_return: REST_GPR(31, r1) lwz r2,_NIP(r1) /* Restore environment */ lwz r0,_MSR(r1) - mtspr csrr0,r2 - mtspr csrr1,r0 + mtspr SPRN_CSRR0,r2 + mtspr SPRN_CSRR1,r0 lwz r0,GPR0(r1) lwz r2,GPR2(r1) lwz r1,GPR1(r1) @@ -1297,8 +1297,8 @@ mck_return: REST_GPR(31, r1) lwz r2,_NIP(r1) /* Restore environment */ lwz r0,_MSR(r1) - mtspr mcsrr0,r2 - mtspr mcsrr1,r0 + mtspr SPRN_MCSRR0,r2 + mtspr SPRN_MCSRR1,r0 lwz r0,GPR0(r1) lwz r2,GPR2(r1) lwz r1,GPR1(r1) @@ -1448,17 +1448,17 @@ relocate_code: /* set TFLOOR/NFLOOR to 0 again */ lis r6,0x0001 ori r6,r6,0xf800 - mtspr dvlim,r6 + mtspr SPRN_DVLIM,r6 lis r6,0x0000 ori r6,r6,0x0000 - mtspr dnv0,r6 - mtspr dnv1,r6 - mtspr dnv2,r6 - mtspr dnv3,r6 - mtspr dtv0,r6 - mtspr dtv1,r6 - mtspr dtv2,r6 - mtspr dtv3,r6 + mtspr SPRN_DNV0,r6 + mtspr SPRN_DNV1,r6 + mtspr SPRN_DNV2,r6 + mtspr SPRN_DNV3,r6 + mtspr SPRN_DTV0,r6 + mtspr SPRN_DTV1,r6 + mtspr SPRN_DTV2,r6 + mtspr SPRN_DTV3,r6 msync isync #endif /* CONFIG_SYS_INIT_RAM_DCACHE */ @@ -1478,8 +1478,8 @@ relocate_code: isync
/* Clear all potential pending exceptions */ - mfspr r1,mcsr - mtspr mcsr,r1 + mfspr r1,SPRN_MCSR + mtspr SPRN_MCSR,r1 #ifdef CONFIG_SYS_TLB_FOR_BOOT_FLASH addi r1,r0,CONFIG_SYS_TLB_FOR_BOOT_FLASH /* Use defined TLB */ #else @@ -1723,9 +1723,9 @@ trap_init: __440_msr_set: addi r7,r0,0x1000 /* set ME bit (Machine Exceptions) */ oris r7,r7,0x0002 /* set CE bit (Critical Exceptions) */ - mtspr srr1,r7 + mtspr SPRN_SRR1,r7 mflr r7 - mtspr srr0,r7 + mtspr SPRN_SRR0,r7 rfi __440_msr_continue: #endif @@ -2059,7 +2059,7 @@ pll_wait: * Not sure if this is needed... */ addis r3,0,0x1000 - mtspr dbcr0,r3 /* This will cause a CPU core reset, and */ + mtspr SPRN_DBCR0,r3 /* This will cause a CPU core reset, and */ /* execution will continue from the poweron */ /* vector of 0xfffffffc */ #endif /* CONFIG_405EP */ diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 65546ad..2c0c0ce 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -96,6 +96,10 @@ #define CONFIG_BOOKE #endif
+#define SPRN_CCR0 0x3B3 /* Core Configuration Register 0 */ +#ifdef CONFIG_BOOKE +#define SPRN_CCR1 0x378 /* Core Configuration Register for 440 only */ +#endif #define SPRN_CDBCR 0x3D7 /* Cache Debug Control Register */ #define SPRN_CTR 0x009 /* Count Register */ #define SPRN_DABR 0x3F5 /* Data Address Breakpoint Register */ @@ -166,6 +170,9 @@ #define SPRN_DBSR 0x3F0 /* Debug Status Register */ #else #define SPRN_DBCR1 0x135 /* Book E Debug Control Register 1 */ +#ifdef CONFIG_BOOKE +#define SPRN_DBDR 0x3f3 /* Debug Data Register */ +#endif #define SPRN_DBSR 0x130 /* Book E Debug Status Register */ #define DBSR_IC 0x08000000 /* Book E Instruction Completion */ #define DBSR_TIE 0x01000000 /* Book E Trap Instruction Event */ @@ -173,6 +180,10 @@ #define SPRN_DCCR 0x3FA /* Data Cache Cacheability Register */ #define DCCR_NOCACHE 0 /* Noncacheable */ #define DCCR_CACHE 1 /* Cacheable */ +#ifndef CONFIG_BOOKE +#define SPRN_DCDBTRL 0x39c /* Data Cache Debug Tag Register Low */ +#define SPRN_DCDBTRH 0x39d /* Data Cache Debug Tag Register High */ +#endif #define SPRN_DCMP 0x3D1 /* Data TLB Compare Register */ #define SPRN_DCWR 0x3BA /* Data Cache Write-thru Register */ #define DCWR_COPY 0 /* Copy-back */ @@ -184,7 +195,20 @@ #endif /* CONFIG_BOOKE */ #define SPRN_DEC 0x016 /* Decrement Register */ #define SPRN_DMISS 0x3D0 /* Data TLB Miss Register */ +#ifdef CONFIG_BOOKE +#define SPRN_DNV0 0x390 /* Data Cache Normal Victim 0 */ +#define SPRN_DNV1 0x391 /* Data Cache Normal Victim 1 */ +#define SPRN_DNV2 0x392 /* Data Cache Normal Victim 2 */ +#define SPRN_DNV3 0x393 /* Data Cache Normal Victim 3 */ +#endif #define SPRN_DSISR 0x012 /* Data Storage Interrupt Status Register */ +#ifdef CONFIG_BOOKE +#define SPRN_DTV0 0x394 /* Data Cache Transient Victim 0 */ +#define SPRN_DTV1 0x395 /* Data Cache Transient Victim 1 */ +#define SPRN_DTV2 0x396 /* Data Cache Transient Victim 2 */ +#define SPRN_DTV3 0x397 /* Data Cache Transient Victim 3 */ +#define SPRN_DVLIM 0x398 /* Data Cache Victim Limit */ +#endif #define SPRN_EAR 0x11A /* External Address Register */ #ifndef CONFIG_BOOKE #define SPRN_ESR 0x3D4 /* Exception Syndrome Register */ @@ -269,16 +293,34 @@ #define ICCR_NOCACHE 0 /* Noncacheable */ #define ICCR_CACHE 1 /* Cacheable */ #define SPRN_ICDBDR 0x3D3 /* Instruction Cache Debug Data Register */ +#ifdef CONFIG_BOOKE +#define SPRN_ICDBTRL 0x39e /* instruction cache debug tag register low */ +#define SPRN_ICDBTRH 0x39f /* instruction cache debug tag register high */ +#endif #define SPRN_ICMP 0x3D5 /* Instruction TLB Compare Register */ #define SPRN_ICTC 0x3FB /* Instruction Cache Throttling Control Reg */ #define SPRN_IMISS 0x3D4 /* Instruction TLB Miss Register */ #define SPRN_IMMR 0x27E /* Internal Memory Map Register */ +#ifdef CONFIG_BOOKE +#define SPRN_INV0 0x370 /* Instruction Cache Normal Victim 0 */ +#define SPRN_INV1 0x371 /* Instruction Cache Normal Victim 1 */ +#define SPRN_INV2 0x372 /* Instruction Cache Normal Victim 2 */ +#define SPRN_INV3 0x373 /* Instruction Cache Normal Victim 3 */ +#define SPRN_ITV0 0x374 /* Instruction Cache Transient Victim 0 */ +#define SPRN_ITV1 0x375 /* Instruction Cache Transient Victim 1 */ +#define SPRN_ITV2 0x376 /* Instruction Cache Transient Victim 2 */ +#define SPRN_ITV3 0x377 /* Instruction Cache Transient Victim 3 */ +#define SPRN_IVLIM 0x399 /* Instruction Cache Victim Limit */ +#endif #define SPRN_LDSTCR 0x3F8 /* Load/Store Control Register */ #define SPRN_L2CR 0x3F9 /* Level 2 Cache Control Regsiter */ #define SPRN_LR 0x008 /* Link Register */ #define SPRN_MBAR 0x137 /* System memory base address */ #define SPRN_MMCR0 0x3B8 /* Monitor Mode Control Register 0 */ #define SPRN_MMCR1 0x3BC /* Monitor Mode Control Register 1 */ +#ifdef CONFIG_BOOKE +#define SPRN_MMUCR 0x3b2 /* MMU Control Register */ +#endif #define SPRN_PBL1 0x3FC /* Protection Bound Lower 1 */ #define SPRN_PBL2 0x3FE /* Protection Bound Lower 2 */ #define SPRN_PBU1 0x3FD /* Protection Bound Upper 1 */ @@ -297,6 +339,9 @@ #define SPRN_PMC4 0x3BE /* Performance Counter Register 4 */ #define SPRN_PVR 0x11F /* Processor Version Register */ #define SPRN_RPA 0x3D6 /* Required Physical Address Register */ +#ifdef CONFIG_BOOKE +#define SPRN_RSTCFG 0x39b /* Reset Configuration */ +#endif #define SPRN_SDA 0x3BF /* Sampled Data Address Register */ #define SPRN_SDR1 0x019 /* MMU Hash Base Register */ #define SPRN_SGR 0x3B9 /* Storage Guarded Register */ @@ -315,6 +360,7 @@ #define SPRN_SRR1 0x01B /* Save/Restore Register 1 */ #define SPRN_SRR2 0x3DE /* Save/Restore Register 2 */ #define SPRN_SRR3 0x3DF /* Save/Restore Register 3 */ + #ifdef CONFIG_BOOKE #define SPRN_SVR 0x3FF /* System Version Register */ #else diff --git a/include/ppc405.h b/include/ppc405.h index 917afec..a17dd35 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -32,61 +32,6 @@ #define CONFIG_SYS_DCACHE_SIZE (2 << 10) /* For PLX IOP480 (403) */ #endif
-/*--------------------------------------------------------------------- */ -/* Special Purpose Registers */ -/*--------------------------------------------------------------------- */ - #define srr2 0x3de /* save/restore register 2 */ - #define srr3 0x3df /* save/restore register 3 */ - - /* - * 405 does not really have CSRR0/1 but SRR2/3 are used during critical - * exception for the exact same purposes - let's alias them and have a - * common handling in crit_return() and CRIT_EXCEPTION - */ - #define csrr0 srr2 - #define csrr1 srr3 - - #define dbsr 0x3f0 /* debug status register */ - #define dbcr0 0x3f2 /* debug control register 0 */ - #define dbcr1 0x3bd /* debug control register 1 */ - #define iac1 0x3f4 /* instruction address comparator 1 */ - #define iac2 0x3f5 /* instruction address comparator 2 */ - #define iac3 0x3b4 /* instruction address comparator 3 */ - #define iac4 0x3b5 /* instruction address comparator 4 */ - #define dac1 0x3f6 /* data address comparator 1 */ - #define dac2 0x3f7 /* data address comparator 2 */ - #define dccr 0x3fa /* data cache control register */ - #define iccr 0x3fb /* instruction cache control register */ - #define esr 0x3d4 /* execption syndrome register */ - #define dear 0x3d5 /* data exeption address register */ - #define evpr 0x3d6 /* exeption vector prefix register */ - #define tsr 0x3d8 /* timer status register */ - #define tcr 0x3da /* timer control register */ - #define pit 0x3db /* programmable interval timer */ - #define sgr 0x3b9 /* storage guarded reg */ - #define dcwr 0x3ba /* data cache write-thru reg*/ - #define sler 0x3bb /* storage little-endian reg */ - #define cdbcr 0x3d7 /* cache debug cntrl reg */ - #define icdbdr 0x3d3 /* instr cache dbug data reg*/ - #define ccr0 0x3b3 /* core configuration register */ - #define dvc1 0x3b6 /* data value compare register 1 */ - #define dvc2 0x3b7 /* data value compare register 2 */ - #define pid 0x3b1 /* process ID */ - #define su0r 0x3bc /* storage user-defined register 0 */ - #define zpr 0x3b0 /* zone protection regsiter */ - - #define tbl 0x11c /* time base lower - privileged write */ - #define tbu 0x11d /* time base upper - privileged write */ - - #define sprg4r 0x104 /* Special purpose general 4 - read only */ - #define sprg5r 0x105 /* Special purpose general 5 - read only */ - #define sprg6r 0x106 /* Special purpose general 6 - read only */ - #define sprg7r 0x107 /* Special purpose general 7 - read only */ - #define sprg4w 0x114 /* Special purpose general 4 - write only */ - #define sprg5w 0x115 /* Special purpose general 5 - write only */ - #define sprg6w 0x116 /* Special purpose general 6 - write only */ - #define sprg7w 0x117 /* Special purpose general 7 - write only */ - /****************************************************************************** * Special for PPC405GP ******************************************************************************/ diff --git a/include/ppc440.h b/include/ppc440.h index 01f6eaf..6ce53a6 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -48,99 +48,6 @@
#define CONFIG_SYS_DCACHE_SIZE (32 << 10) /* For AMCC 440 CPUs */
-/*--------------------------------------------------------------------- */ -/* Special Purpose Registers */ -/*--------------------------------------------------------------------- */ -#define xer_reg 0x001 -#define lr_reg 0x008 -#define dec 0x016 /* decrementer */ -#define srr0 0x01a /* save/restore register 0 */ -#define srr1 0x01b /* save/restore register 1 */ -#define pid 0x030 /* process id */ -#define decar 0x036 /* decrementer auto-reload */ -#define csrr0 0x03a /* critical save/restore register 0 */ -#define csrr1 0x03b /* critical save/restore register 1 */ -#define dear 0x03d /* data exception address register */ -#define esr 0x03e /* exception syndrome register */ -#define ivpr 0x03f /* interrupt prefix register */ -#define usprg0 0x100 /* user special purpose register general 0 */ -#define usprg1 0x110 /* user special purpose register general 1 */ -#define tblr 0x10c /* time base lower, read only */ -#define tbur 0x10d /* time base upper, read only */ -#define sprg1 0x111 /* special purpose register general 1 */ -#define sprg2 0x112 /* special purpose register general 2 */ -#define sprg3 0x113 /* special purpose register general 3 */ -#define sprg4 0x114 /* special purpose register general 4 */ -#define sprg5 0x115 /* special purpose register general 5 */ -#define sprg6 0x116 /* special purpose register general 6 */ -#define sprg7 0x117 /* special purpose register general 7 */ -#define tbl 0x11c /* time base lower (supervisor)*/ -#define tbu 0x11d /* time base upper (supervisor)*/ -#define pir 0x11e /* processor id register */ -#define dbsr 0x130 /* debug status register */ -#define dbcr0 0x134 /* debug control register 0 */ -#define dbcr1 0x135 /* debug control register 1 */ -#define dbcr2 0x136 /* debug control register 2 */ -#define iac1 0x138 /* instruction address compare 1 */ -#define iac2 0x139 /* instruction address compare 2 */ -#define iac3 0x13a /* instruction address compare 3 */ -#define iac4 0x13b /* instruction address compare 4 */ -#define dac1 0x13c /* data address compare 1 */ -#define dac2 0x13d /* data address compare 2 */ -#define dvc1 0x13e /* data value compare 1 */ -#define dvc2 0x13f /* data value compare 2 */ -#define tsr 0x150 /* timer status register */ -#define tcr 0x154 /* timer control register */ -#define ivor0 0x190 /* interrupt vector offset register 0 */ -#define ivor1 0x191 /* interrupt vector offset register 1 */ -#define ivor2 0x192 /* interrupt vector offset register 2 */ -#define ivor3 0x193 /* interrupt vector offset register 3 */ -#define ivor4 0x194 /* interrupt vector offset register 4 */ -#define ivor5 0x195 /* interrupt vector offset register 5 */ -#define ivor6 0x196 /* interrupt vector offset register 6 */ -#define ivor7 0x197 /* interrupt vector offset register 7 */ -#define ivor8 0x198 /* interrupt vector offset register 8 */ -#define ivor9 0x199 /* interrupt vector offset register 9 */ -#define ivor10 0x19a /* interrupt vector offset register 10 */ -#define ivor11 0x19b /* interrupt vector offset register 11 */ -#define ivor12 0x19c /* interrupt vector offset register 12 */ -#define ivor13 0x19d /* interrupt vector offset register 13 */ -#define ivor14 0x19e /* interrupt vector offset register 14 */ -#define ivor15 0x19f /* interrupt vector offset register 15 */ -#if defined(CONFIG_440) -#define mcsrr0 0x23a /* machine check save/restore register 0 */ -#define mcsrr1 0x23b /* mahcine check save/restore register 1 */ -#define mcsr 0x23c /* machine check status register */ -#endif -#define inv0 0x370 /* instruction cache normal victim 0 */ -#define inv1 0x371 /* instruction cache normal victim 1 */ -#define inv2 0x372 /* instruction cache normal victim 2 */ -#define inv3 0x373 /* instruction cache normal victim 3 */ -#define itv0 0x374 /* instruction cache transient victim 0 */ -#define itv1 0x375 /* instruction cache transient victim 1 */ -#define itv2 0x376 /* instruction cache transient victim 2 */ -#define itv3 0x377 /* instruction cache transient victim 3 */ -#define dnv0 0x390 /* data cache normal victim 0 */ -#define dnv1 0x391 /* data cache normal victim 1 */ -#define dnv2 0x392 /* data cache normal victim 2 */ -#define dnv3 0x393 /* data cache normal victim 3 */ -#define dtv0 0x394 /* data cache transient victim 0 */ -#define dtv1 0x395 /* data cache transient victim 1 */ -#define dtv2 0x396 /* data cache transient victim 2 */ -#define dtv3 0x397 /* data cache transient victim 3 */ -#define dvlim 0x398 /* data cache victim limit */ -#define ivlim 0x399 /* instruction cache victim limit */ -#define rstcfg 0x39b /* reset configuration */ -#define dcdbtrl 0x39c /* data cache debug tag register low */ -#define dcdbtrh 0x39d /* data cache debug tag register high */ -#define icdbtrl 0x39e /* instruction cache debug tag register low */ -#define icdbtrh 0x39f /* instruction cache debug tag register high */ -#define mmucr 0x3b2 /* mmu control register */ -#define ccr0 0x3b3 /* core configuration register 0 */ -#define ccr1 0x378 /* core configuration for 440x5 only */ -#define icdbdr 0x3d3 /* instruction cache debug data register */ -#define dbdr 0x3f3 /* debug data register */ - /****************************************************************************** * DCRs & Related ******************************************************************************/ diff --git a/post/cpu/ppc4xx/fpu.c b/post/cpu/ppc4xx/fpu.c index fff4169..e9b96dd 100644 --- a/post/cpu/ppc4xx/fpu.c +++ b/post/cpu/ppc4xx/fpu.c @@ -34,7 +34,7 @@
int fpu_status(void) { - if (mfspr(ccr0) & CCR0_DAPUIB) + if (mfspr(SPRN_CCR0) & CCR0_DAPUIB) return 0; /* Disabled */ else return 1; /* Enabled */ @@ -43,14 +43,14 @@ int fpu_status(void)
void fpu_disable(void) { - mtspr(ccr0, mfspr(ccr0) | CCR0_DAPUIB); + mtspr(SPRN_CCR0, mfspr(SPRN_CCR0) | CCR0_DAPUIB); mtmsr(mfmsr() & ~MSR_FP); }
void fpu_enable(void) { - mtspr(ccr0, mfspr(ccr0) & ~CCR0_DAPUIB); + mtspr(SPRN_CCR0, mfspr(SPRN_CCR0) & ~CCR0_DAPUIB); mtmsr(mfmsr() | MSR_FP); }
Dear Matthias Fuchs,
I understand the include/asm-ppc/processor.h changes are in sync with the Linux version of this file?
If so:
Acked-by: Wolfgang Denk wd@denx.de
Hi Wolfgang,
Matthias is not available for 2 days, so I'll answer instead.
No, it's not in sync with the Linux version. Reason is, that the Linux version you are referring to was an very old arch/ppc version. The current arch/powerpc version is completely different. No SPRN defines in this file any more.
But I'll double check the new defines in processor.h before applying this patch.
If so:
I hope you don't withdraw your Acked-by now. I would really like to apply this patch soon.
Thanks.
Best regards, Stefan
Dear Stefan Roese,
No, I did use the current code from arch/powerpc/include; I just didn't mention that it's split there into several files like asm/reg.h, asm/reg_booke.h etc.
OK, that's all I wanted to make sure :-)
I still ACK it.
Applied to ppc4xx/master. Thanks.
Matthias Fuchs
Stefan Roese
