[U-Boot] [PATCH 1/2] serial: Remove the "serial" console device
Each serial device is added as a console device. There was also the "serial" device that points to the most-recently-assigned-to-some- console-handle device. This can be confusing. Instead, only show the actual serial devices.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- common/console.c | 37 +++++++++++++++++++------------------ common/stdio.c | 12 +----------- 2 files changed, 20 insertions(+), 29 deletions(-)
diff --git a/common/console.c b/common/console.c index 1177f7d..9cc8197 100644 --- a/common/console.c +++ b/common/console.c @@ -26,6 +26,7 @@ #include <malloc.h> #include <stdio_dev.h> #include <exports.h> +#include <serial.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -550,6 +551,7 @@ int console_assign(int file, const char *devname) { int flag; struct stdio_dev *dev; + const char *realdevname;
/* Check for valid file */ switch (file) { @@ -565,8 +567,12 @@ int console_assign(int file, const char *devname) }
/* Check for valid device name */ + if (strcmp(devname, "serial") == 0) + realdevname = default_serial_console()->name; + else + realdevname = devname;
- dev = search_device(flag, devname); + dev = search_device(flag, realdevname);
if (dev) return console_setfile(file, dev); @@ -657,13 +663,16 @@ int console_init_r(void) } /* if the devices are overwritten or not found, use default device */ if (inputdev == NULL) { - inputdev = search_device(DEV_FLAGS_INPUT, "serial"); + inputdev = search_device(DEV_FLAGS_INPUT, + default_serial_console()->name); } if (outputdev == NULL) { - outputdev = search_device(DEV_FLAGS_OUTPUT, "serial"); + outputdev = search_device(DEV_FLAGS_OUTPUT, + default_serial_console()->name); } if (errdev == NULL) { - errdev = search_device(DEV_FLAGS_OUTPUT, "serial"); + errdev = search_device(DEV_FLAGS_OUTPUT, + default_serial_console()->name); } /* Initializes output console first */ if (outputdev != NULL) { @@ -713,18 +722,10 @@ int console_init_r(void) struct list_head *pos; struct stdio_dev *dev;
-#ifdef CONFIG_SPLASH_SCREEN - /* - * suppress all output if splash screen is enabled and we have - * a bmp to display. We redirect the output from frame buffer - * console to serial console in this case or suppress it if - * "silent" mode was requested. - */ - if (getenv("splashimage") != NULL) { - if (!(gd->flags & GD_FLG_SILENT)) - outputdev = search_device (DEV_FLAGS_OUTPUT, "serial"); - } -#endif + outputdev = search_device(DEV_FLAGS_OUTPUT, + default_serial_console()->name); + inputdev = search_device(DEV_FLAGS_INPUT, + default_serial_console()->name);
/* Scan devices looking for input and output devices */ list_for_each(pos, list) { @@ -760,13 +761,13 @@ int console_init_r(void)
gd->flags |= GD_FLG_DEVINIT; /* device initialization completed */
- stdio_print_current_devices(); - /* Setting environment variables */ for (i = 0; i < 3; i++) { setenv(stdio_names[i], stdio_devices[i]->name); }
+ stdio_print_current_devices(); + #if 0 /* If nothing usable installed, use only the initial console */ if ((stdio_devices[stdin] == NULL) && (stdio_devices[stdout] == NULL)) diff --git a/common/stdio.c b/common/stdio.c index 605ff3f..e9bdc0e 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -70,21 +70,11 @@ int nulldev_input(void)
static void drv_system_init (void) { +#ifdef CONFIG_SYS_DEVICE_NULLDEV struct stdio_dev dev;
memset (&dev, 0, sizeof (dev));
- strcpy (dev.name, "serial"); - dev.flags = DEV_FLAGS_OUTPUT | DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM; - dev.putc = serial_putc; - dev.puts = serial_puts; - dev.getc = serial_getc; - dev.tstc = serial_tstc; - stdio_register (&dev); - -#ifdef CONFIG_SYS_DEVICE_NULLDEV - memset (&dev, 0, sizeof (dev)); - strcpy (dev.name, "nulldev"); dev.flags = DEV_FLAGS_OUTPUT | DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM; dev.putc = nulldev_putc;
This allows the default console to be specified as the nulldev. This is specifically helpful when the real serial console's init() cannot run early in the boot process. When the init can be run, then the console can be switched to the real device using the std* env vars.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com --- common/stdio.c | 37 ----------------------------------- drivers/serial/serial.c | 52 +++++++++++++++++++++++++++++++++++++++++++++++++ include/serial.h | 4 ++++ 3 files changed, 56 insertions(+), 37 deletions(-)
diff --git a/common/stdio.c b/common/stdio.c index e9bdc0e..37d36cb 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -40,29 +40,6 @@ static struct stdio_dev devs; struct stdio_dev *stdio_devices[] = { NULL, NULL, NULL }; char *stdio_names[MAX_FILES] = { "stdin", "stdout", "stderr" };
-#if defined(CONFIG_SPLASH_SCREEN) && !defined(CONFIG_SYS_DEVICE_NULLDEV) -#define CONFIG_SYS_DEVICE_NULLDEV 1 -#endif - - -#ifdef CONFIG_SYS_DEVICE_NULLDEV -void nulldev_putc(const char c) -{ - /* nulldev is empty! */ -} - -void nulldev_puts(const char *s) -{ - /* nulldev is empty! */ -} - -int nulldev_input(void) -{ - /* nulldev is empty! */ - return 0; -} -#endif - /************************************************************************** * SYSTEM DRIVERS ************************************************************************** @@ -70,20 +47,6 @@ int nulldev_input(void)
static void drv_system_init (void) { -#ifdef CONFIG_SYS_DEVICE_NULLDEV - struct stdio_dev dev; - - memset (&dev, 0, sizeof (dev)); - - strcpy (dev.name, "nulldev"); - dev.flags = DEV_FLAGS_OUTPUT | DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM; - dev.putc = nulldev_putc; - dev.puts = nulldev_puts; - dev.getc = nulldev_input; - dev.tstc = nulldev_input; - - stdio_register (&dev); -#endif }
/************************************************************************** diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index f5f43a6..5031b00 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -110,6 +110,57 @@ serial_initfunc(s3c44b0_serial_initialize); serial_initfunc(sa1100_serial_initialize); serial_initfunc(sh_serial_initialize);
+#if defined(CONFIG_SPLASH_SCREEN) && !defined(CONFIG_SYS_DEVICE_NULLDEV) +#define CONFIG_SYS_DEVICE_NULLDEV +#endif + +#if defined(CONFIG_SYS_DEVICE_NULLDEV) +int nulldev_init(void) +{ + /* nulldev is empty! */ + return 0; +} + +void nulldev_setbrg(void) +{ + /* nulldev is empty! */ +} + +void nulldev_putc(const char c) +{ + /* nulldev is empty! */ +} + +void nulldev_puts(const char *s) +{ + /* nulldev is empty! */ +} + +int nulldev_input(void) +{ + /* nulldev is empty! */ + return 0; +} + +struct serial_device nulldev_serial_device = { + "nulldev", + nulldev_init, + NULL, + nulldev_setbrg, + nulldev_input, + nulldev_input, + nulldev_putc, + nulldev_puts, +}; + +void nulldev_serial_initalize(void) +{ + serial_register(&nulldev_serial_device); +} +#else +serial_initfunc(nulldev_serial_initalize); +#endif + /** * serial_register() - Register serial driver with serial driver core * @dev: Pointer to the serial driver structure @@ -154,6 +205,7 @@ void serial_register(struct serial_device *dev) */ void serial_initialize(void) { + nulldev_serial_initalize(); mpc8xx_serial_initialize(); ns16550_serial_initialize(); pxa_serial_initialize(); diff --git a/include/serial.h b/include/serial.h index 14f863e..3d404da 100644 --- a/include/serial.h +++ b/include/serial.h @@ -22,6 +22,10 @@ struct serial_device {
void default_serial_puts(const char *s);
+#if defined(CONFIG_SYS_DEVICE_NULLDEV) +extern struct serial_device nulldev_serial_device; +#endif + extern struct serial_device serial_smc_device; extern struct serial_device serial_scc_device; extern struct serial_device *default_serial_console(void);
Dear Joe Hershberger,
Isn't it actually better to have null stdio device? Some systems might not even use serial port (and so null serial will be useless on these systems)!
Best regards, Marek Vasut
Hi Marek,
As I described in my commit log, this is for the case where the serial and console init must not touch the hardware, (since it doesn't exist yet if it's in an FPGA or on a PCI or USB connection). Making the default serial port be the nulldev avoids this issue.
As for systems with no real serial port, there can still be the nulldev serial device... or not. Why is that a problem?
-Joe
Hi Marek,
So add nulldev serial device for this stupid case. Even though fixing iomux such that it'd not send anything to serial port at all if nulldev is selected would be even better idea.
That won't work?
-Joe
Hi Marek.
Hi Marek,
It's not a problem of something being sent to the serial port. It's the call to serial_init() in arch/*/lib/board.c that kills it. That call needs to be no-op-able.
-Joe
Hi Marek.
Hi Marek,
Why?
What about fixing serial_init like this:
struct serial_device *dev = get_current(); int ret = 0; if (dev) ret = dev->start();
return ret;
Hi Marek,
Hi Marek.
Hi Marek,
Why?
return ret;
How does this help? Are you suggesting that default_serial_console() return "NULL"? It seems that you would then have to add a ton of checks for NULL coming back from default_serial_console() all the places that just use it assuming it's actually a device pointer. Sounds ugly. If you aren't talking about having default_serial_console() return NULL, then I don't see how this helps.
-Joe
Hi Marek,
Hi Marek.
Hi Marek,
> This allows the default console to be specified as the nulldev. > This is specifically helpful when the real serial console's > init() cannot run early in the boot process. When the init can > be run, then the console can be switched to the real device using > the std* env vars. > > Signed-off-by: Joe Hershberger joe.hershberger@ni.com
Why?
ret = dev->start();
return ret;
Well what will default_serial_console() return in your case? You said the serial_init() is the problematic spot.
You also remove the nulldev, shouldn't it go via separate patch? ... but otherwise it's good.
Hi Marek,
I'm not sure what you mean. Where in this patch do I remove nulldev? That's the next patch.
Hi Marek,
The adjustment in common/stdio.c
Hi Marek,
Hi Marek,
I think you are reading the diff wrong. The only nulldev related "change" is to not get warnings due to a (now) unused variable. It simply guards the definition of the variable with the NULLDEV #ifdef.
-Joe
Hi Marek,
Hi Marek,
Ok
Joe Hershberger
Joe Hershberger
