[PATCH] efi_loader: Expose relocated address for gdb debugging purposes
* If users want to debug EFI applications via qemu + GDB, they need to know the relocated address of the application to align their symbols to in GDB via add-symbol-file. * This exposes where EFI applications are relocated to enable debugging EFI applications via qemu + gdb * Usage is generally determining the address, then add-symbol-file (efi loader) (address) * The address can change, but is generally consistent with the same qemu version and u-boot binary. (allowing you to boot once, find the address, then reboot with qemu -s -S --- lib/efi_loader/efi_image_loader.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index 773bd0677c..2b8c1ef464 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -906,6 +906,8 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, ret = EFI_OUT_OF_RESOURCES; goto err; } + log_info("64-bit EFI image loaded at relocated address %p\n", efi_reloc); + handle->entry = efi_reloc + opt->AddressOfEntryPoint; rel_size = opt->DataDirectory[rel_idx].Size; rel = efi_reloc + opt->DataDirectory[rel_idx].VirtualAddress; @@ -922,6 +924,8 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, ret = EFI_OUT_OF_RESOURCES; goto err; } + log_info("32-bit EFI image loaded at relocated address %p\n", efi_reloc); + handle->entry = efi_reloc + opt->AddressOfEntryPoint; rel_size = opt->DataDirectory[rel_idx].Size; rel = efi_reloc + opt->DataDirectory[rel_idx].VirtualAddress;
On 3/24/22 17:22, Alexander von Gluck IV wrote:
- If users want to debug EFI applications via qemu + GDB, they need to know the relocated address of the application to align their symbols to in GDB via add-symbol-file.
- This exposes where EFI applications are relocated to enable debugging EFI applications via qemu + gdb
- Usage is generally determining the address, then add-symbol-file (efi loader) (address)
- The address can change, but is generally consistent with the same qemu version and u-boot binary. (allowing you to boot once, find the address, then reboot with qemu -s -S
- handle->entry = efi_reloc + opt->AddressOfEntryPoint; rel_size = opt->DataDirectory[rel_idx].Size; rel = efi_reloc + opt->DataDirectory[rel_idx].VirtualAddress;
Do we really always need this output for every invokation of LoadImage()?
Writing test messages during the runtime of a menu driven program like the UEFI SCT can be very disturbing.
Isn't it sufficient to show this output for binaries directly launched by U-Boot?
Best regards
Heinrich
March 24, 2022 12:06 PM, "Heinrich Schuchardt" xypron.glpk@gmx.de wrote:
On 3/24/22 17:22, Alexander von Gluck IV wrote: Do we really always need this output for every invokation of LoadImage()?
Ideally this would be exposed strictly for the binaries directly launched, however the bare relocated address isn't exposed outside of the brief usage by LoadImage.
I figured that adding a required pointer arg to expose the relocated address might be overkill.
using log_debug over log_info was brought up as a good change, but that still suffers the same potential impact.
Maybe adding reloc_addr storage to efi_loaded_image_obj would be cleaner? (then digging it up during the efi launch for a quick log_info?)
-- Alex
March 24, 2022 1:25 PM, "Alexander von Gluck IV" kallisti5@unixzen.com wrote:
"PATCH] efi_loader (v2): Expose relocated address for gdb debugging purposes" has been submitted. Instead of printing the relocated address out immediately, v2 stores it in the efi_loaded_image_obj and references it later during the initial EFI boot.
The output of v2 can be seen below.
54 bytes read in 0 ms uEnv.txt says to look for efi bootloader named EFI/BOOT/BOOTRISCV64.EFI on virtio 0! Found EFI/BOOT/BOOTRISCV64.EFI on virtio 0! Loading bootloader... 800283 bytes read in 1 ms (763.2 MiB/s) Using internal DTB... Launching EFI loader... Scanning disk virtio-blk#8... Found 3 disks ** Unable to read file ubootefi.var ** Failed to load EFI variables Booting /EFI\BOOT\BOOTRISCV64.EFI EFI image relocated to 0xbe68e000
Alex
