[U-Boot] [ppc4xx] Please pull git://www.denx.de/git/u-boot-ppc4xx.git
The following changes since commit 628ffd73bcff0c9f3bc5a8eeb2c7455fe9d28a51: Jean-Christophe PLAGNIOL-VILLARD (1): device: make device_register() clone the device
git://www.denx.de/git/u-boot-ppc4xx.git master
Matthias Fuchs (12): ppc4xx: Increase U-Boot size to 384kB for PLU405 boards ppc4xx: Add fdt support for PLU405 boards ppc4xx: Cleanup PLU405 linker script ppc4xx: Cleanup PLU405 platform file ppc4xx: Enable USB on PLU405 boards ppc4xx: Coding style cleanup ppc4xx: Add fdt support for VOM405 boards ppc4xx: Cleanup VOM405 linker script ppc4xx: Remove obsolete initdram() function from VOM405 board ppc4xx: Update VOM405 board configuration ppc4xx: Remove obsolete or unused functions from some esd boards ppx4xx: Fix broken DASA_SIM board
Stefan Roese (1): ppc4xx: Remove reference to common/lists.o from some esd linker scripts
board/esd/apc405/apc405.c | 10 -- board/esd/ar405/u-boot.lds | 1 - board/esd/ash405/ash405.c | 23 ----- board/esd/canbt/u-boot.lds | 1 - board/esd/cms700/cms700.c | 21 ----- board/esd/cpci2dp/cpci2dp.c | 21 ----- board/esd/cpci405/cpci405.c | 19 ---- board/esd/cpciiser4/cpciiser4.c | 19 ---- board/esd/dasa_sim/dasa_sim.c | 15 --- board/esd/dasa_sim/u-boot.lds | 1 - board/esd/dp405/dp405.c | 36 -------- board/esd/du405/du405.c | 15 --- board/esd/hh405/hh405.c | 17 ---- board/esd/hub405/hub405.c | 18 ---- board/esd/ocrtc/ocrtc.c | 32 ------- board/esd/plu405/config.mk | 3 +- board/esd/plu405/plu405.c | 58 +++++-------- board/esd/plu405/u-boot.lds | 14 --- board/esd/pmc405/pmc405.c | 18 ---- board/esd/voh405/voh405.c | 36 -------- board/esd/vom405/u-boot.lds | 12 --- board/esd/vom405/vom405.c | 25 ----- board/esd/wuh405/wuh405.c | 21 ----- include/configs/PLU405.h | 186 ++++++++++++++++++++------------------ include/configs/VOM405.h | 54 +++--------- 25 files changed, 131 insertions(+), 545 deletions(-)
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
