[U-Boot] [PATCH] MIPS: fix mips_cache fallback without __builtin_mips_cache
The "R" constraint supplies the address of an variable in a register. Use "r" instead and adjust asm to supply the content of addr in a register instead.
Fixes: 2b8bcc5a ("MIPS: avoid .set ISA for cache operations") Signed-off-by: Matthias Schiffer mschiffer@universe-factory.net Cc: Paul Burton paul.burton@imgtec.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com ---
Hi, I've noticed this when reading the code to understand how the cache instruction is used. I'm not sure if this bug had any practical consequences, or if nowadays all relevant compilers have __builtin_mips_cache anyways.
Please keep me in Cc in follow-up mails, I'm not subscribed to the u-boot ML.
Matthias
arch/mips/include/asm/cacheops.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/mips/include/asm/cacheops.h b/arch/mips/include/asm/cacheops.h index a3b07c6..002b839 100644 --- a/arch/mips/include/asm/cacheops.h +++ b/arch/mips/include/asm/cacheops.h @@ -16,7 +16,7 @@ static inline void mips_cache(int op, const volatile void *addr) #ifdef __GCC_HAVE_BUILTIN_MIPS_CACHE __builtin_mips_cache(op, addr); #else - __asm__ __volatile__("cache %0, %1" : : "i"(op), "R"(addr)); + __asm__ __volatile__("cache %0, 0(%1)" : : "i"(op), "r"(addr)); #endif }
Am 05.03.2016 um 04:15 schrieb Matthias Schiffer:
Matthias
I've disabled the builtin code and compared dissaemblies with and without your patch. Without your patch, gcc adds an additional store instruction before each cache instruction.
E.g. for flush_dcache_range():
18: afa20008 sw v0,8(sp) 1c: bfb50008 cache 0x15,8(sp)
vs.
14: bc550000 cache 0x15,0(v0)
The cache operation works anyway, but with your patch better code is generated.
- __asm__ __volatile__("cache %0, 0(%1)" : : "i"(op), "r"(addr));
#endif }
applied to u-boot-mips/next, thanks!
Matthias
vs.
If I understand this correctly, the code without my patch would rather invalidate the cache for the address 8(sp), which is part of the stack, and not the memory pointed at by v0.
#endif }
Am 06.03.2016 um 20:53 schrieb Matthias Schiffer:
Matthias
vs.
"sw v0,8(sp)" stores the address in v0 on the stack (location is current stack pointer + 8 * 4 bytes). The cache op then loads this address from stack. Eventually the cache op always uses the address stored in v0 so there is/was no functional bug. But the extra copy to the stack causes a performance degradation.
Matthias Schiffer mschiffer@universe-factory.net writes:
vs.
generated.
Matthias is correct. These two code sequences will exhibit different overall behaviour. The latter is much more likely to be what you wanted from what I can see as the flush is to operate on the value of the 'addr' variable not the address of the addr variable.
The same behaviour could be achieved with:
and
__asm__ __volatile__("cache %0, 0(%1)" : : "i"(op), "r"(&addr));
Hope that's useful.
Matthew
Daniel Schwierzeck
Matthew Fortune
Matthias Schiffer
