[PATCH 1/2] mtd: call of_platform_populate() for MTD partitions
Until this change MTD subsystem supported handling partitions only with MTD partitions parsers. That's a specific / limited API designed around partitions.
Some MTD partitions may however require different handling. They may contain specific data that needs to be parsed and somehow extracted. For that purpose MTD subsystem should allow binding of standard platform drivers.
An example can be U-Boot (sub)partition with environment variables. There exist a "u-boot,env" DT binding for MTD (sub)partition that requires an NVMEM driver.
Ref: 5db1c2dbc04c ("dt-bindings: nvmem: add U-Boot environment variables binding") Signed-off-by: Rafał Miłecki rafal@milecki.pl --- drivers/mtd/mtdpart.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c index 357661b62c94..9fce946fa69c 100644 --- a/drivers/mtd/mtdpart.c +++ b/drivers/mtd/mtdpart.c @@ -17,6 +17,7 @@ #include <linux/mtd/partitions.h> #include <linux/err.h> #include <linux/of.h> +#include <linux/of_platform.h>
#include "mtdcore.h"
@@ -593,6 +594,7 @@ static int mtd_part_of_parse(struct mtd_info *master, continue; ret = mtd_part_do_parse(parser, master, pparts, NULL); if (ret > 0) { + of_platform_populate(np, NULL, NULL, &master->dev); of_node_put(np); return ret; } @@ -600,6 +602,7 @@ static int mtd_part_of_parse(struct mtd_info *master, if (ret < 0 && !err) err = ret; } + of_platform_populate(np, NULL, NULL, &master->dev); of_node_put(np);
U-Boot stores its setup as environment variables. It's a list of key-value pairs stored on flash device with a custom header.
This commit adds an NVMEM driver that: 1. Provides NVMEM access to environment vars binary data 2. Extracts variables as NVMEM cells
It can be used for: 1. Accessing env variables from user-space 2. Reading NVMEM cells by Linux drivers
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- MAINTAINERS | 1 + drivers/nvmem/Kconfig | 12 ++ drivers/nvmem/Makefile | 2 + drivers/nvmem/u-boot-env.c | 236 +++++++++++++++++++++++++++++++++++++ 4 files changed, 251 insertions(+) create mode 100644 drivers/nvmem/u-boot-env.c
diff --git a/MAINTAINERS b/MAINTAINERS index 4cb7fd127e68..122bf4230507 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -20121,6 +20121,7 @@ U-BOOT ENVIRONMENT VARIABLES M: Rafał Miłecki rafal@milecki.pl S: Maintained F: Documentation/devicetree/bindings/nvmem/u-boot,env.yaml +F: drivers/nvmem/u-boot-env.c
UACCE ACCELERATOR FRAMEWORK M: Zhangfei Gao zhangfei.gao@linaro.org diff --git a/drivers/nvmem/Kconfig b/drivers/nvmem/Kconfig index 555aa77a574d..17a78b1ba077 100644 --- a/drivers/nvmem/Kconfig +++ b/drivers/nvmem/Kconfig @@ -324,4 +324,16 @@ config NVMEM_SUNPLUS_OCOTP This driver can also be built as a module. If so, the module will be called nvmem-sunplus-ocotp.
+config NVMEM_U_BOOT_ENV + tristate "U-Boot environment variables support" + depends on ARCH_BCM4908 || COMPILE_TEST + depends on OF && MTD + select CRC32 + help + U-Boot stores its setup as environment variables. This driver adds + support for verifying & exporting such data. It also exposes variables + as NVMEM cells so they can be referenced by other drivers. + + If compiled as module it will be called nvmem_u-boot-env. + endif diff --git a/drivers/nvmem/Makefile b/drivers/nvmem/Makefile index 891958e29d25..84c8d75e59cf 100644 --- a/drivers/nvmem/Makefile +++ b/drivers/nvmem/Makefile @@ -65,3 +65,5 @@ obj-$(CONFIG_NVMEM_LAYERSCAPE_SFP) += nvmem-layerscape-sfp.o nvmem-layerscape-sfp-y := layerscape-sfp.o obj-$(CONFIG_NVMEM_SUNPLUS_OCOTP) += nvmem_sunplus_ocotp.o nvmem_sunplus_ocotp-y := sunplus-ocotp.o +obj-$(CONFIG_NVMEM_U_BOOT_ENV) += nvmem_u-boot-env.o +nvmem_u-boot-env-y := u-boot-env.o diff --git a/drivers/nvmem/u-boot-env.c b/drivers/nvmem/u-boot-env.c new file mode 100644 index 000000000000..c7945d7d5750 --- /dev/null +++ b/drivers/nvmem/u-boot-env.c @@ -0,0 +1,236 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2022 Rafał Miłecki rafal@milecki.pl + */ + +#include <linux/crc32.h> +#include <linux/mod_devicetable.h> +#include <linux/module.h> +#include <linux/mtd/mtd.h> +#include <linux/nvmem-consumer.h> +#include <linux/nvmem-provider.h> +#include <linux/of_device.h> +#include <linux/platform_device.h> +#include <linux/slab.h> + +enum u_boot_env_format { + U_BOOT_FORMAT_SINGLE, + U_BOOT_FORMAT_REDUNDANT, +}; + +struct u_boot_env { + struct device *dev; + enum u_boot_env_format format; + + /* Parent device */ + struct mtd_info *mtd; + size_t offset; + size_t size; + + /* Cells */ + struct nvmem_cell_info *cells; + int ncells; +}; + +struct u_boot_env_image_single { + __le32 crc32; + uint8_t data[0]; +} __packed; + +struct u_boot_env_image_redundant { + __le32 crc32; + u8 mark; + uint8_t data[0]; +} __packed; + +static int u_boot_env_read(void *context, unsigned int offset, void *val, + size_t bytes) +{ + struct u_boot_env *priv = context; + struct device *dev = priv->dev; + size_t bytes_read; + int err; + + err = mtd_read(priv->mtd, priv->offset + offset, bytes, &bytes_read, val); + if (err && !mtd_is_bitflip(err)) { + dev_err(dev, "Failed to read from mtd: %d\n", err); + return err; + } + + if (bytes_read != bytes) { + dev_err(dev, "Failed to read %zd bytes\n", bytes); + return -EIO; + } + + return 0; +} + +static int u_boot_env_add_cells(struct u_boot_env *priv, uint8_t *buf, + size_t data_offset, size_t data_len) +{ + struct device *dev = priv->dev; + char *data = buf + data_offset; + char *var, *value, *eq; + int idx; + + priv->ncells = 0; + for (var = data; var < data + data_len && *var; var += strlen(var) + 1) + priv->ncells++; + + priv->cells = devm_kcalloc(dev, priv->ncells, sizeof(*priv->cells), GFP_KERNEL); + if (!priv->cells) + return -ENOMEM; + + for (var = data, idx = 0; + var < data + data_len && *var; + var = value + strlen(value) + 1, idx++) { + eq = strchr(var, '='); + if (!eq) + break; + *eq = '\0'; + value = eq + 1; + + priv->cells[idx].name = devm_kstrdup(dev, var, GFP_KERNEL); + if (!priv->cells[idx].name) + return -ENOMEM; + priv->cells[idx].offset = data_offset + value - data; + priv->cells[idx].bytes = strlen(value); + } + + if (WARN_ON(idx != priv->ncells)) + priv->ncells = idx; + + return 0; +} + +static int u_boot_env_parse(struct u_boot_env *priv) +{ + struct device *dev = priv->dev; + size_t crc32_data_offset; + size_t crc32_data_len; + size_t crc32_offset; + size_t data_offset; + size_t data_len; + uint32_t crc32; + uint32_t calc; + size_t bytes; + uint8_t *buf; + int err; + + buf = kcalloc(1, priv->size, GFP_KERNEL); + if (!buf) { + err = -ENOMEM; + goto err_out; + } + + err = mtd_read(priv->mtd, priv->offset, priv->size, &bytes, buf); + if ((err && !mtd_is_bitflip(err)) || bytes != priv->size) { + dev_err(dev, "Failed to read from mtd: %d\n", err); + goto err_kfree; + } + + switch (priv->format) { + case U_BOOT_FORMAT_SINGLE: + crc32_offset = offsetof(struct u_boot_env_image_single, crc32); + crc32_data_offset = offsetof(struct u_boot_env_image_single, data); + data_offset = offsetof(struct u_boot_env_image_single, data); + break; + case U_BOOT_FORMAT_REDUNDANT: + crc32_offset = offsetof(struct u_boot_env_image_redundant, crc32); + crc32_data_offset = offsetof(struct u_boot_env_image_redundant, mark); + data_offset = offsetof(struct u_boot_env_image_redundant, data); + break; + } + crc32 = le32_to_cpu(*(uint32_t *)(buf + crc32_offset)); + crc32_data_len = priv->size - crc32_data_offset; + data_len = priv->size - data_offset; + + calc = crc32(~0, buf + crc32_data_offset, crc32_data_len) ^ ~0L; + if (calc != crc32) { + dev_err(dev, "Invalid calculated CRC32: 0x%08x (expected: 0x%08x)\n", calc, crc32); + err = -EINVAL; + goto err_kfree; + } + + buf[priv->size - 1] = '\0'; + err = u_boot_env_add_cells(priv, buf, data_offset, data_len); + if (err) + dev_err(dev, "Failed to add cells: %d\n", err); + +err_kfree: + kfree(buf); +err_out: + return err; +} + +static const struct of_device_id u_boot_env_of_match_table[] = { + { .compatible = "u-boot,env", .data = (void *)U_BOOT_FORMAT_SINGLE, }, + { .compatible = "u-boot,env-redundant-bool", .data = (void *)U_BOOT_FORMAT_REDUNDANT, }, + { .compatible = "u-boot,env-redundant-count", .data = (void *)U_BOOT_FORMAT_REDUNDANT, }, + {}, +}; + +static int u_boot_env_probe(struct platform_device *pdev) +{ + struct nvmem_config config = { + .name = "u-boot-env", + .reg_read = u_boot_env_read, + }; + struct device *dev = &pdev->dev; + struct device_node *np = dev->of_node; + const struct of_device_id *of_id; + struct u_boot_env *priv; + const char *label; + int err; + + priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL); + if (!priv) + return -ENOMEM; + priv->dev = dev; + + of_id = of_match_device(u_boot_env_of_match_table, dev); + if (!of_id) + return -EINVAL; + priv->format = (uintptr_t)of_id->data; + + if (of_property_read_u32(np, "reg", (u32 *)&priv->offset) || + of_property_read_u32_index(np, "reg", 1, (u32 *)&priv->size)) { + dev_err(dev, "Failed to read "reg" property\n"); + return -EINVAL; + } + + label = of_get_property(np->parent, "label", NULL); + if (!label) + label = np->parent->name; + + priv->mtd = get_mtd_device_nm(label); + if (IS_ERR(priv->mtd)) { + dev_err(dev, "Failed to find "%s" MTD device: %ld\n", label, PTR_ERR(priv->mtd)); + return PTR_ERR(priv->mtd); + } + + err = u_boot_env_parse(priv); + if (err) + return err; + + config.dev = dev; + config.cells = priv->cells; + config.ncells = priv->ncells; + config.priv = priv; + config.size = priv->size; + + return PTR_ERR_OR_ZERO(devm_nvmem_register(dev, &config)); +} + +static struct platform_driver u_boot_env_driver = { + .probe = u_boot_env_probe, + .driver = { + .name = "u_boot_env", + .of_match_table = u_boot_env_of_match_table, + }, +}; +module_platform_driver(u_boot_env_driver); + +MODULE_AUTHOR("Rafał Miłecki"); +MODULE_LICENSE("GPL"); +MODULE_DEVICE_TABLE(of, u_boot_env_of_match_table);
- Provides NVMEM access to environment vars binary data
- Extracts variables as NVMEM cells
It can be used for:
- Accessing env variables from user-space
- Reading NVMEM cells by Linux drivers
Applied to https://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux.git mtd/next, thanks.
Miquel
It can be used for:
Hi Miquel,
Any reason why this nvmem driver is taken via mtd tree?
This is going to conflict with other nvmem patches that are touching KConfig and Makefile
--srini
Miquel
Hi Srinivas,
srinivas.kandagatla@linaro.org wrote on Mon, 11 Apr 2022 10:45:53 +0100:
It can be used for:
Hi Miquel,
Sorry I selected it by mistake. I'll let you take it through nvmem unless there is still something missing on your side?
Anyway, it's now dropped from mtd.
Thanks, Miquèl
- tristate "U-Boot environment variables support"
- depends on ARCH_BCM4908 || COMPILE_TEST
This nvmem provider seems more generic, so why ARCH_BCM4908 dependency here?
--srini
- depends on OF && MTD
- select CRC32
- help
- endif
Miquel
Hi Rafal, Hi Miguel,
I'm trying to use next-20220422 and noticed a few new oops'es. Turns out it could be a problem with this commit according to
[daniel@box linux.git]$ git bisect good 68471517e883902cdff6ea399d043b17f803b1a8 is the first bad commit commit 68471517e883902cdff6ea399d043b17f803b1a8 Author: Rafał Miłecki rafal@milecki.pl Date: Wed Apr 6 16:32:24 2022 +0200
mtd: call of_platform_populate() for MTD partitions [...] ---
So when ever there is at least one 'compatible' node for any of the mtd partitions I get the oops messages below. It doesn't really matter what the compatible string is, "nvmem-cells" as well as "denx,fit" (used for OpenWrt mtdsplit not even present in linux-next, so just a dead hint in DTS) make the kernel to oops.
Despite the messages being shown, both accessing MTD partitions and also eth0 MAC address populated via NVMEM seem to work without problems (at least looks like it on first sight).
Find the full device tree here:
https://git.openwrt.org/?p=openwrt/openwrt.git;a=blob;f=target/linux/mediate...
--- [...] [ 0.549448] mtk-spi-nor 11014000.spi: IRQ not available. [ 0.556396] spi-nor spi0.0: w25q512jvq (65536 Kbytes) [ 0.933381] Freeing initrd memory: 2124K [ 0.941567] 7 fixed-partitions partitions found on MTD device spi0.0 [ 0.947966] OF: Bad cell count for /spi@11014000/flash@0/partitions [ 0.954286] OF: Bad cell count for /spi@11014000/flash@0/partitions [ 0.960583] ------------[ cut here ]------------ [ 0.965192] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_get() is being called. [ 0.974688] WARNING: CPU: 0 PID: 1 at kobject_get+0x68/0x94 [ 0.980263] Modules linked in: [ 0.983313] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S 5.18.0-rc1+ #0 [ 0.991049] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 0.997046] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1.004000] pc : kobject_get+0x68/0x94 [ 1.007743] lr : kobject_get+0x68/0x94 [ 1.011484] sp : ffffffc008bdb4a0 [ 1.014789] x29: ffffffc008bdb4a0 x28: 0000000000000000 x27: ffffff8005c57810 [ 1.021920] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 1.029050] x23: 0000000000000000 x22: 0000000000000000 x21: 0000000000000000 [ 1.036182] x20: ffffff8005c74a20 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 1.043312] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 0000000000000074 [ 1.050443] x14: 000000000000015c x13: 0000000000000074 x12: 00000000ffffffea [ 1.057574] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 1.064705] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 1.071835] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb1c0 [ 1.078966] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 1.086097] Call trace: [ 1.088534] kobject_get+0x68/0x94 [ 1.091930] device_add+0xa4/0x840 [ 1.095328] of_device_add+0x4c/0x5c [ 1.098898] of_platform_device_create_pdata+0xb8/0xf0 [ 1.104029] of_platform_bus_create+0x104/0x350 [ 1.108552] of_platform_populate+0x54/0xe0 [ 1.112728] parse_mtd_partitions+0x430/0x490 [ 1.117080] mtd_device_parse_register+0x90/0x2b0 [ 1.121777] spi_nor_probe+0x1f8/0x2b0 [ 1.125521] spi_mem_probe+0x68/0xa0 [ 1.129092] spi_probe+0x80/0xdc [ 1.132314] really_probe.part.0+0x98/0x280 [ 1.136490] __driver_probe_device+0x94/0x140 [ 1.140839] driver_probe_device+0x40/0x114 [ 1.145014] __device_attach_driver+0xb0/0x10c [ 1.149450] bus_for_each_drv+0x64/0xa0 [ 1.153280] __device_attach+0xa8/0x16c [ 1.157108] device_initial_probe+0x10/0x20 [ 1.161283] bus_probe_device+0x94/0x9c [ 1.165114] device_add+0x35c/0x840 [ 1.168596] __spi_add_device+0x70/0x114 [ 1.172510] spi_add_device+0x5c/0x90 [ 1.176165] of_register_spi_device+0x204/0x330 [ 1.180688] spi_register_controller+0x3e8/0x6dc [ 1.185299] devm_spi_register_controller+0x20/0x74 [ 1.190169] mtk_nor_probe+0x344/0x4c0 [ 1.193911] platform_probe+0x64/0xd0 [ 1.197566] really_probe.part.0+0x98/0x280 [ 1.201741] __driver_probe_device+0x94/0x140 [ 1.206089] driver_probe_device+0x40/0x114 [ 1.210264] __driver_attach+0xf0/0x180 [ 1.214092] bus_for_each_dev+0x5c/0x90 [ 1.217922] driver_attach+0x20/0x2c [ 1.221491] bus_add_driver+0x140/0x1ec [ 1.225320] driver_register+0x74/0x120 [ 1.229149] __platform_driver_register+0x24/0x30 [ 1.233845] mtk_nor_driver_init+0x18/0x20 [ 1.237938] do_one_initcall+0x4c/0x1c0 [ 1.241768] kernel_init_freeable+0x230/0x294 [ 1.246120] kernel_init+0x20/0x120 [ 1.249601] ret_from_fork+0x10/0x20 [ 1.253170] ---[ end trace 0000000000000000 ]--- [ 1.257796] ------------[ cut here ]------------ [ 1.262408] refcount_t: addition on 0; use-after-free. [ 1.267550] WARNING: CPU: 0 PID: 1 at refcount_warn_saturate+0x98/0x140 [ 1.274161] Modules linked in: [ 1.277206] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 1.284941] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 1.290937] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1.297891] pc : refcount_warn_saturate+0x98/0x140 [ 1.302675] lr : refcount_warn_saturate+0x98/0x140 [ 1.307459] sp : ffffffc008bdb490 [ 1.310764] x29: ffffffc008bdb490 x28: 0000000000000000 x27: ffffff8005c57810 [ 1.317895] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 1.325026] x23: 0000000000000000 x22: 0000000000000000 x21: 0000000000000000 [ 1.332157] x20: ffffff8005c74a20 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 1.339288] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 00000000000000b3 [ 1.346419] x14: 0000000000000219 x13: 00000000000000b3 x12: 00000000ffffffea [ 1.353550] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 1.360681] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 1.367811] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb1b0 [ 1.374942] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000002a [ 1.382073] Call trace: [ 1.384509] refcount_warn_saturate+0x98/0x140 [ 1.388946] kobject_get+0x90/0x94 [ 1.392342] device_add+0xa4/0x840 [ 1.395737] of_device_add+0x4c/0x5c [ 1.399305] of_platform_device_create_pdata+0xb8/0xf0 [ 1.404436] of_platform_bus_create+0x104/0x350 [ 1.408959] of_platform_populate+0x54/0xe0 [ 1.413134] parse_mtd_partitions+0x430/0x490 [ 1.417484] mtd_device_parse_register+0x90/0x2b0 [ 1.422182] spi_nor_probe+0x1f8/0x2b0 [ 1.425925] spi_mem_probe+0x68/0xa0 [ 1.429493] spi_probe+0x80/0xdc [ 1.432715] really_probe.part.0+0x98/0x280 [ 1.436890] __driver_probe_device+0x94/0x140 [ 1.441238] driver_probe_device+0x40/0x114 [ 1.445413] __device_attach_driver+0xb0/0x10c [ 1.449849] bus_for_each_drv+0x64/0xa0 [ 1.453678] __device_attach+0xa8/0x16c [ 1.457506] device_initial_probe+0x10/0x20 [ 1.461682] bus_probe_device+0x94/0x9c [ 1.465511] device_add+0x35c/0x840 [ 1.468993] __spi_add_device+0x70/0x114 [ 1.472908] spi_add_device+0x5c/0x90 [ 1.476562] of_register_spi_device+0x204/0x330 [ 1.481085] spi_register_controller+0x3e8/0x6dc [ 1.485695] devm_spi_register_controller+0x20/0x74 [ 1.490565] mtk_nor_probe+0x344/0x4c0 [ 1.494307] platform_probe+0x64/0xd0 [ 1.497962] really_probe.part.0+0x98/0x280 [ 1.502136] __driver_probe_device+0x94/0x140 [ 1.506485] driver_probe_device+0x40/0x114 [ 1.510660] __driver_attach+0xf0/0x180 [ 1.514488] bus_for_each_dev+0x5c/0x90 [ 1.518317] driver_attach+0x20/0x2c [ 1.521887] bus_add_driver+0x140/0x1ec [ 1.525716] driver_register+0x74/0x120 [ 1.529543] __platform_driver_register+0x24/0x30 [ 1.534240] mtk_nor_driver_init+0x18/0x20 [ 1.538330] do_one_initcall+0x4c/0x1c0 [ 1.542158] kernel_init_freeable+0x230/0x294 [ 1.546508] kernel_init+0x20/0x120 [ 1.549990] ret_from_fork+0x10/0x20 [ 1.553558] ---[ end trace 0000000000000000 ]--- [ 1.558176] ------------[ cut here ]------------ [ 1.562786] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_get() is being called. [ 1.572272] WARNING: CPU: 0 PID: 1 at kobject_get+0x68/0x94 [ 1.577839] Modules linked in: [ 1.580885] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 1.588620] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 1.594616] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1.601570] pc : kobject_get+0x68/0x94 [ 1.605312] lr : kobject_get+0x68/0x94 [ 1.609054] sp : ffffffc008bdb3a0 [ 1.612359] x29: ffffffc008bdb3a0 x28: 0000000000000000 x27: ffffff8005c57810 [ 1.619490] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 1.626620] x23: 0000000000000000 x22: 0000000000000000 x21: ffffff8005c74a20 [ 1.633751] x20: ffffff8005c57810 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 1.640882] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 00000000000000f3 [ 1.648013] x14: 00000000000002d9 x13: 00000000000000f3 x12: 00000000ffffffea [ 1.655144] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 1.662275] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 1.669405] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb0c0 [ 1.676536] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 1.683666] Call trace: [ 1.686102] kobject_get+0x68/0x94 [ 1.689498] kobject_add_internal+0x34/0x330 [ 1.693762] kobject_add+0x80/0xe0 [ 1.697158] device_add+0xd8/0x840 [ 1.700553] of_device_add+0x4c/0x5c [ 1.704121] of_platform_device_create_pdata+0xb8/0xf0 [ 1.709252] of_platform_bus_create+0x104/0x350 [ 1.713774] of_platform_populate+0x54/0xe0 [ 1.717949] parse_mtd_partitions+0x430/0x490 [ 1.722299] mtd_device_parse_register+0x90/0x2b0 [ 1.726996] spi_nor_probe+0x1f8/0x2b0 [ 1.730739] spi_mem_probe+0x68/0xa0 [ 1.734307] spi_probe+0x80/0xdc [ 1.737529] really_probe.part.0+0x98/0x280 [ 1.741704] __driver_probe_device+0x94/0x140 [ 1.746053] driver_probe_device+0x40/0x114 [ 1.750228] __device_attach_driver+0xb0/0x10c [ 1.754664] bus_for_each_drv+0x64/0xa0 [ 1.758493] __device_attach+0xa8/0x16c [ 1.762320] device_initial_probe+0x10/0x20 [ 1.766496] bus_probe_device+0x94/0x9c [ 1.770326] device_add+0x35c/0x840 [ 1.773808] __spi_add_device+0x70/0x114 [ 1.777723] spi_add_device+0x5c/0x90 [ 1.781378] of_register_spi_device+0x204/0x330 [ 1.785901] spi_register_controller+0x3e8/0x6dc [ 1.790511] devm_spi_register_controller+0x20/0x74 [ 1.795381] mtk_nor_probe+0x344/0x4c0 [ 1.799123] platform_probe+0x64/0xd0 [ 1.802777] really_probe.part.0+0x98/0x280 [ 1.806952] __driver_probe_device+0x94/0x140 [ 1.811300] driver_probe_device+0x40/0x114 [ 1.815474] __driver_attach+0xf0/0x180 [ 1.819302] bus_for_each_dev+0x5c/0x90 [ 1.823132] driver_attach+0x20/0x2c [ 1.826701] bus_add_driver+0x140/0x1ec [ 1.830530] driver_register+0x74/0x120 [ 1.834359] __platform_driver_register+0x24/0x30 [ 1.839056] mtk_nor_driver_init+0x18/0x20 [ 1.843146] do_one_initcall+0x4c/0x1c0 [ 1.846975] kernel_init_freeable+0x230/0x294 [ 1.851325] kernel_init+0x20/0x120 [ 1.854806] ret_from_fork+0x10/0x20 [ 1.858374] ---[ end trace 0000000000000000 ]--- [ 1.862989] ------------[ cut here ]------------ [ 1.867596] refcount_t: saturated; leaking memory. [ 1.872392] WARNING: CPU: 0 PID: 1 at refcount_warn_saturate+0x6c/0x140 [ 1.879001] Modules linked in: [ 1.882046] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 1.889781] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 1.895776] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1.902729] pc : refcount_warn_saturate+0x6c/0x140 [ 1.907513] lr : refcount_warn_saturate+0x6c/0x140 [ 1.912296] sp : ffffffc008bdb390 [ 1.915601] x29: ffffffc008bdb390 x28: 0000000000000000 x27: ffffff8005c57810 [ 1.922732] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 1.929864] x23: 0000000000000000 x22: 0000000000000000 x21: ffffff8005c74a20 [ 1.936995] x20: ffffff8005c57810 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 1.944127] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 0000000000000134 [ 1.951258] x14: 000000000000039c x13: 0000000000000134 x12: 00000000ffffffea [ 1.958389] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 1.965520] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 1.972650] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb0b0 [ 1.979780] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 0000000000000026 [ 1.986911] Call trace: [ 1.989348] refcount_warn_saturate+0x6c/0x140 [ 1.993786] kobject_get+0x78/0x94 [ 1.997181] kobject_add_internal+0x34/0x330 [ 2.001444] kobject_add+0x80/0xe0 [ 2.004840] device_add+0xd8/0x840 [ 2.008235] of_device_add+0x4c/0x5c [ 2.011802] of_platform_device_create_pdata+0xb8/0xf0 [ 2.016933] of_platform_bus_create+0x104/0x350 [ 2.021456] of_platform_populate+0x54/0xe0 [ 2.025631] parse_mtd_partitions+0x430/0x490 [ 2.029982] mtd_device_parse_register+0x90/0x2b0 [ 2.034679] spi_nor_probe+0x1f8/0x2b0 [ 2.038421] spi_mem_probe+0x68/0xa0 [ 2.041989] spi_probe+0x80/0xdc [ 2.045211] really_probe.part.0+0x98/0x280 [ 2.049385] __driver_probe_device+0x94/0x140 [ 2.053734] driver_probe_device+0x40/0x114 [ 2.057908] __device_attach_driver+0xb0/0x10c [ 2.062344] bus_for_each_drv+0x64/0xa0 [ 2.066174] __device_attach+0xa8/0x16c [ 2.070002] device_initial_probe+0x10/0x20 [ 2.074177] bus_probe_device+0x94/0x9c [ 2.078007] device_add+0x35c/0x840 [ 2.081489] __spi_add_device+0x70/0x114 [ 2.085404] spi_add_device+0x5c/0x90 [ 2.089058] of_register_spi_device+0x204/0x330 [ 2.093581] spi_register_controller+0x3e8/0x6dc [ 2.098191] devm_spi_register_controller+0x20/0x74 [ 2.103062] mtk_nor_probe+0x344/0x4c0 [ 2.106803] platform_probe+0x64/0xd0 [ 2.110458] really_probe.part.0+0x98/0x280 [ 2.114633] __driver_probe_device+0x94/0x140 [ 2.118981] driver_probe_device+0x40/0x114 [ 2.123156] __driver_attach+0xf0/0x180 [ 2.126984] bus_for_each_dev+0x5c/0x90 [ 2.130812] driver_attach+0x20/0x2c [ 2.134382] bus_add_driver+0x140/0x1ec [ 2.138212] driver_register+0x74/0x120 [ 2.142039] __platform_driver_register+0x24/0x30 [ 2.146736] mtk_nor_driver_init+0x18/0x20 [ 2.150826] do_one_initcall+0x4c/0x1c0 [ 2.154654] kernel_init_freeable+0x230/0x294 [ 2.159004] kernel_init+0x20/0x120 [ 2.162485] ret_from_fork+0x10/0x20 [ 2.166052] ---[ end trace 0000000000000000 ]--- [ 2.170675] ------------[ cut here ]------------ [ 2.175282] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_put() is being called. [ 2.184768] WARNING: CPU: 0 PID: 1 at kobject_put+0x68/0xf0 [ 2.190335] Modules linked in: [ 2.193381] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 2.201115] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 2.207111] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.214065] pc : kobject_put+0x68/0xf0 [ 2.217808] lr : kobject_put+0x68/0xf0 [ 2.221550] sp : ffffffc008bdb390 [ 2.224855] x29: ffffffc008bdb390 x28: 0000000000000000 x27: ffffff8005c57810 [ 2.231986] x26: ffffff8005c74a20 x25: 0000000000000000 x24: ffffffc008b55368 [ 2.239117] x23: 0000000000000000 x22: 00000000fffffffe x21: ffffff8005c74a20 [ 2.246248] x20: ffffff8005c57810 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 2.253379] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 0000000000000176 [ 2.260510] x14: 0000000000000462 x13: 0000000000000176 x12: 00000000ffffffea [ 2.267640] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 2.274771] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 2.281902] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb0b0 [ 2.289032] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 2.296163] Call trace: [ 2.298599] kobject_put+0x68/0xf0 [ 2.301995] kobject_add_internal+0x130/0x330 [ 2.306345] kobject_add+0x80/0xe0 [ 2.309740] device_add+0xd8/0x840 [ 2.313135] of_device_add+0x4c/0x5c [ 2.316702] of_platform_device_create_pdata+0xb8/0xf0 [ 2.321833] of_platform_bus_create+0x104/0x350 [ 2.326356] of_platform_populate+0x54/0xe0 [ 2.330531] parse_mtd_partitions+0x430/0x490 [ 2.334881] mtd_device_parse_register+0x90/0x2b0 [ 2.339578] spi_nor_probe+0x1f8/0x2b0 [ 2.343321] spi_mem_probe+0x68/0xa0 [ 2.346888] spi_probe+0x80/0xdc [ 2.350110] really_probe.part.0+0x98/0x280 [ 2.354285] __driver_probe_device+0x94/0x140 [ 2.358634] driver_probe_device+0x40/0x114 [ 2.362809] __device_attach_driver+0xb0/0x10c [ 2.367245] bus_for_each_drv+0x64/0xa0 [ 2.371073] __device_attach+0xa8/0x16c [ 2.374900] device_initial_probe+0x10/0x20 [ 2.379075] bus_probe_device+0x94/0x9c [ 2.382906] device_add+0x35c/0x840 [ 2.386388] __spi_add_device+0x70/0x114 [ 2.390303] spi_add_device+0x5c/0x90 [ 2.393958] of_register_spi_device+0x204/0x330 [ 2.398480] spi_register_controller+0x3e8/0x6dc [ 2.403090] devm_spi_register_controller+0x20/0x74 [ 2.407961] mtk_nor_probe+0x344/0x4c0 [ 2.411702] platform_probe+0x64/0xd0 [ 2.415357] really_probe.part.0+0x98/0x280 [ 2.419532] __driver_probe_device+0x94/0x140 [ 2.423881] driver_probe_device+0x40/0x114 [ 2.428056] __driver_attach+0xf0/0x180 [ 2.431884] bus_for_each_dev+0x5c/0x90 [ 2.435714] driver_attach+0x20/0x2c [ 2.439283] bus_add_driver+0x140/0x1ec [ 2.443113] driver_register+0x74/0x120 [ 2.446941] __platform_driver_register+0x24/0x30 [ 2.451638] mtk_nor_driver_init+0x18/0x20 [ 2.455728] do_one_initcall+0x4c/0x1c0 [ 2.459556] kernel_init_freeable+0x230/0x294 [ 2.463906] kernel_init+0x20/0x120 [ 2.467386] ret_from_fork+0x10/0x20 [ 2.470955] ---[ end trace 0000000000000000 ]--- [ 2.475571] ------------[ cut here ]------------ [ 2.480182] refcount_t: underflow; use-after-free. [ 2.484974] WARNING: CPU: 0 PID: 1 at refcount_warn_saturate+0xec/0x140 [ 2.491583] Modules linked in: [ 2.494628] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 2.502363] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 2.508358] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.515312] pc : refcount_warn_saturate+0xec/0x140 [ 2.520097] lr : refcount_warn_saturate+0xec/0x140 [ 2.524881] sp : ffffffc008bdb380 [ 2.528186] x29: ffffffc008bdb380 x28: 0000000000000000 x27: ffffff8005c57810 [ 2.535317] x26: ffffff8005c74a20 x25: 0000000000000000 x24: ffffffc008b55368 [ 2.542448] x23: 0000000000000000 x22: 00000000fffffffe x21: ffffff8005c74a20 [ 2.549580] x20: ffffff8005c57810 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 2.556710] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 00000000000001b7 [ 2.563841] x14: 0000000000000525 x13: 00000000000001b7 x12: 00000000ffffffea [ 2.570971] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 2.578103] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 2.585234] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb0a0 [ 2.592364] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 0000000000000026 [ 2.599494] Call trace: [ 2.601931] refcount_warn_saturate+0xec/0x140 [ 2.606367] kobject_put+0xe4/0xf0 [ 2.609763] kobject_add_internal+0x130/0x330 [ 2.614113] kobject_add+0x80/0xe0 [ 2.617509] device_add+0xd8/0x840 [ 2.620904] of_device_add+0x4c/0x5c [ 2.624472] of_platform_device_create_pdata+0xb8/0xf0 [ 2.629602] of_platform_bus_create+0x104/0x350 [ 2.634125] of_platform_populate+0x54/0xe0 [ 2.638300] parse_mtd_partitions+0x430/0x490 [ 2.642651] mtd_device_parse_register+0x90/0x2b0 [ 2.647348] spi_nor_probe+0x1f8/0x2b0 [ 2.651091] spi_mem_probe+0x68/0xa0 [ 2.654659] spi_probe+0x80/0xdc [ 2.657881] really_probe.part.0+0x98/0x280 [ 2.662056] __driver_probe_device+0x94/0x140 [ 2.666404] driver_probe_device+0x40/0x114 [ 2.670579] __device_attach_driver+0xb0/0x10c [ 2.675015] bus_for_each_drv+0x64/0xa0 [ 2.678844] __device_attach+0xa8/0x16c [ 2.682672] device_initial_probe+0x10/0x20 [ 2.686847] bus_probe_device+0x94/0x9c [ 2.690677] device_add+0x35c/0x840 [ 2.694158] __spi_add_device+0x70/0x114 [ 2.698074] spi_add_device+0x5c/0x90 [ 2.701729] of_register_spi_device+0x204/0x330 [ 2.706252] spi_register_controller+0x3e8/0x6dc [ 2.710861] devm_spi_register_controller+0x20/0x74 [ 2.715731] mtk_nor_probe+0x344/0x4c0 [ 2.719473] platform_probe+0x64/0xd0 [ 2.723128] really_probe.part.0+0x98/0x280 [ 2.727302] __driver_probe_device+0x94/0x140 [ 2.731650] driver_probe_device+0x40/0x114 [ 2.735825] __driver_attach+0xf0/0x180 [ 2.739653] bus_for_each_dev+0x5c/0x90 [ 2.743483] driver_attach+0x20/0x2c [ 2.747052] bus_add_driver+0x140/0x1ec [ 2.750881] driver_register+0x74/0x120 [ 2.754709] __platform_driver_register+0x24/0x30 [ 2.759406] mtk_nor_driver_init+0x18/0x20 [ 2.763496] do_one_initcall+0x4c/0x1c0 [ 2.767324] kernel_init_freeable+0x230/0x294 [ 2.771674] kernel_init+0x20/0x120 [ 2.775155] ret_from_fork+0x10/0x20 [ 2.778723] ---[ end trace 0000000000000000 ]--- [ 2.783338] kobject_add_internal failed for 11014000.spi:flash@0:partitions:partition@110000 (error: -2 parent: (null)) [ 2.794116] ------------[ cut here ]------------ [ 2.798723] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_put() is being called. [ 2.808207] WARNING: CPU: 0 PID: 1 at kobject_put+0x68/0xf0 [ 2.813776] Modules linked in: [ 2.816821] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 2.824556] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 2.830552] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2.837506] pc : kobject_put+0x68/0xf0 [ 2.841248] lr : kobject_put+0x68/0xf0 [ 2.844990] sp : ffffffc008bdb490 [ 2.848295] x29: ffffffc008bdb490 x28: 0000000000000000 x27: ffffff8005c57810 [ 2.855426] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 2.862557] x23: 0000000000000000 x22: 0000000000000000 x21: 0000000000000000 [ 2.869688] x20: ffffff8005c74a20 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 2.876819] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 00000000000001fa [ 2.883949] x14: 00000000000005ee x13: 00000000000001fa x12: 00000000ffffffea [ 2.891081] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 2.898212] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 2.905343] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb1b0 [ 2.912473] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 2.919604] Call trace: [ 2.922040] kobject_put+0x68/0xf0 [ 2.925436] device_add+0xfc/0x840 [ 2.928832] of_device_add+0x4c/0x5c [ 2.932400] of_platform_device_create_pdata+0xb8/0xf0 [ 2.937530] of_platform_bus_create+0x104/0x350 [ 2.942053] of_platform_populate+0x54/0xe0 [ 2.946228] parse_mtd_partitions+0x430/0x490 [ 2.950579] mtd_device_parse_register+0x90/0x2b0 [ 2.955276] spi_nor_probe+0x1f8/0x2b0 [ 2.959018] spi_mem_probe+0x68/0xa0 [ 2.962586] spi_probe+0x80/0xdc [ 2.965808] really_probe.part.0+0x98/0x280 [ 2.969983] __driver_probe_device+0x94/0x140 [ 2.974332] driver_probe_device+0x40/0x114 [ 2.978507] __device_attach_driver+0xb0/0x10c [ 2.982943] bus_for_each_drv+0x64/0xa0 [ 2.986772] __device_attach+0xa8/0x16c [ 2.990599] device_initial_probe+0x10/0x20 [ 2.994775] bus_probe_device+0x94/0x9c [ 2.998605] device_add+0x35c/0x840 [ 3.002087] __spi_add_device+0x70/0x114 [ 3.006002] spi_add_device+0x5c/0x90 [ 3.009656] of_register_spi_device+0x204/0x330 [ 3.014178] spi_register_controller+0x3e8/0x6dc [ 3.018788] devm_spi_register_controller+0x20/0x74 [ 3.023658] mtk_nor_probe+0x344/0x4c0 [ 3.027400] platform_probe+0x64/0xd0 [ 3.031054] really_probe.part.0+0x98/0x280 [ 3.035230] __driver_probe_device+0x94/0x140 [ 3.039578] driver_probe_device+0x40/0x114 [ 3.043753] __driver_attach+0xf0/0x180 [ 3.047581] bus_for_each_dev+0x5c/0x90 [ 3.051410] driver_attach+0x20/0x2c [ 3.054980] bus_add_driver+0x140/0x1ec [ 3.058810] driver_register+0x74/0x120 [ 3.062638] __platform_driver_register+0x24/0x30 [ 3.067335] mtk_nor_driver_init+0x18/0x20 [ 3.071425] do_one_initcall+0x4c/0x1c0 [ 3.075253] kernel_init_freeable+0x230/0x294 [ 3.079604] kernel_init+0x20/0x120 [ 3.083084] ret_from_fork+0x10/0x20 [ 3.086653] ---[ end trace 0000000000000000 ]--- [ 3.091298] OF: Bad cell count for /spi@11014000/flash@0/partitions [ 3.097577] OF: Bad cell count for /spi@11014000/flash@0/partitions [ 3.103862] ------------[ cut here ]------------ [ 3.108468] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_get() is being called. [ 3.117953] WARNING: CPU: 0 PID: 1 at kobject_get+0x68/0x94 [ 3.123521] Modules linked in: [ 3.126566] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 3.134302] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 3.140297] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 3.147251] pc : kobject_get+0x68/0x94 [ 3.150994] lr : kobject_get+0x68/0x94 [ 3.154736] sp : ffffffc008bdb4a0 [ 3.158041] x29: ffffffc008bdb4a0 x28: 0000000000000000 x27: ffffff8005c57810 [ 3.165173] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 3.172304] x23: 0000000000000000 x22: 0000000000000000 x21: 0000000000000000 [ 3.179434] x20: ffffff8005c74a20 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 3.186565] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 000000000000023b [ 3.193696] x14: 00000000000006b1 x13: 000000000000023b x12: 00000000ffffffea [ 3.200826] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 3.207957] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 3.215088] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb1c0 [ 3.222218] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 3.229350] Call trace: [ 3.231786] kobject_get+0x68/0x94 [ 3.235182] device_add+0xa4/0x840 [ 3.238578] of_device_add+0x4c/0x5c [ 3.242145] of_platform_device_create_pdata+0xb8/0xf0 [ 3.247275] of_platform_bus_create+0x104/0x350 [ 3.251798] of_platform_populate+0x54/0xe0 [ 3.255973] parse_mtd_partitions+0x430/0x490 [ 3.260324] mtd_device_parse_register+0x90/0x2b0 [ 3.265022] spi_nor_probe+0x1f8/0x2b0 [ 3.268765] spi_mem_probe+0x68/0xa0 [ 3.272333] spi_probe+0x80/0xdc [ 3.275555] really_probe.part.0+0x98/0x280 [ 3.279730] __driver_probe_device+0x94/0x140 [ 3.284079] driver_probe_device+0x40/0x114 [ 3.288254] __device_attach_driver+0xb0/0x10c [ 3.292690] bus_for_each_drv+0x64/0xa0 [ 3.296519] __device_attach+0xa8/0x16c [ 3.300347] device_initial_probe+0x10/0x20 [ 3.304522] bus_probe_device+0x94/0x9c [ 3.308351] device_add+0x35c/0x840 [ 3.311833] __spi_add_device+0x70/0x114 [ 3.315749] spi_add_device+0x5c/0x90 [ 3.319404] of_register_spi_device+0x204/0x330 [ 3.323927] spi_register_controller+0x3e8/0x6dc [ 3.328537] devm_spi_register_controller+0x20/0x74 [ 3.333407] mtk_nor_probe+0x344/0x4c0 [ 3.337149] platform_probe+0x64/0xd0 [ 3.340804] really_probe.part.0+0x98/0x280 [ 3.344978] __driver_probe_device+0x94/0x140 [ 3.349327] driver_probe_device+0x40/0x114 [ 3.353502] __driver_attach+0xf0/0x180 [ 3.357329] bus_for_each_dev+0x5c/0x90 [ 3.361159] driver_attach+0x20/0x2c [ 3.364728] bus_add_driver+0x140/0x1ec [ 3.368557] driver_register+0x74/0x120 [ 3.372385] __platform_driver_register+0x24/0x30 [ 3.377081] mtk_nor_driver_init+0x18/0x20 [ 3.381172] do_one_initcall+0x4c/0x1c0 [ 3.385001] kernel_init_freeable+0x230/0x294 [ 3.389351] kernel_init+0x20/0x120 [ 3.392831] ret_from_fork+0x10/0x20 [ 3.396399] ---[ end trace 0000000000000000 ]--- [ 3.401017] ------------[ cut here ]------------ [ 3.405623] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_get() is being called. [ 3.415108] WARNING: CPU: 0 PID: 1 at kobject_get+0x68/0x94 [ 3.420676] Modules linked in: [ 3.423722] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 3.431456] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 3.437452] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 3.444405] pc : kobject_get+0x68/0x94 [ 3.448148] lr : kobject_get+0x68/0x94 [ 3.451890] sp : ffffffc008bdb3a0 [ 3.455194] x29: ffffffc008bdb3a0 x28: 0000000000000000 x27: ffffff8005c57810 [ 3.462325] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 3.469456] x23: 0000000000000000 x22: 0000000000000000 x21: ffffff8005c74a20 [ 3.476586] x20: ffffff8005c57810 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 3.483717] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 000000000000027a [ 3.490848] x14: 000000000000076e x13: 000000000000027a x12: 00000000ffffffea [ 3.497979] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 3.505109] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 3.512240] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb0c0 [ 3.519372] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 3.526502] Call trace: [ 3.528938] kobject_get+0x68/0x94 [ 3.532334] kobject_add_internal+0x34/0x330 [ 3.536598] kobject_add+0x80/0xe0 [ 3.539994] device_add+0xd8/0x840 [ 3.543389] of_device_add+0x4c/0x5c [ 3.546957] of_platform_device_create_pdata+0xb8/0xf0 [ 3.552088] of_platform_bus_create+0x104/0x350 [ 3.556611] of_platform_populate+0x54/0xe0 [ 3.560786] parse_mtd_partitions+0x430/0x490 [ 3.565137] mtd_device_parse_register+0x90/0x2b0 [ 3.569835] spi_nor_probe+0x1f8/0x2b0 [ 3.573578] spi_mem_probe+0x68/0xa0 [ 3.577146] spi_probe+0x80/0xdc [ 3.580368] really_probe.part.0+0x98/0x280 [ 3.584543] __driver_probe_device+0x94/0x140 [ 3.588891] driver_probe_device+0x40/0x114 [ 3.593066] __device_attach_driver+0xb0/0x10c [ 3.597502] bus_for_each_drv+0x64/0xa0 [ 3.601331] __device_attach+0xa8/0x16c [ 3.605159] device_initial_probe+0x10/0x20 [ 3.609334] bus_probe_device+0x94/0x9c [ 3.613164] device_add+0x35c/0x840 [ 3.616646] __spi_add_device+0x70/0x114 [ 3.620561] spi_add_device+0x5c/0x90 [ 3.624215] of_register_spi_device+0x204/0x330 [ 3.628739] spi_register_controller+0x3e8/0x6dc [ 3.633349] devm_spi_register_controller+0x20/0x74 [ 3.638219] mtk_nor_probe+0x344/0x4c0 [ 3.641961] platform_probe+0x64/0xd0 [ 3.645616] really_probe.part.0+0x98/0x280 [ 3.649791] __driver_probe_device+0x94/0x140 [ 3.654139] driver_probe_device+0x40/0x114 [ 3.658314] __driver_attach+0xf0/0x180 [ 3.662142] bus_for_each_dev+0x5c/0x90 [ 3.665971] driver_attach+0x20/0x2c [ 3.669540] bus_add_driver+0x140/0x1ec [ 3.673371] driver_register+0x74/0x120 [ 3.677199] __platform_driver_register+0x24/0x30 [ 3.681895] mtk_nor_driver_init+0x18/0x20 [ 3.685986] do_one_initcall+0x4c/0x1c0 [ 3.689814] kernel_init_freeable+0x230/0x294 [ 3.694164] kernel_init+0x20/0x120 [ 3.697644] ret_from_fork+0x10/0x20 [ 3.701212] ---[ end trace 0000000000000000 ]--- [ 3.705829] ------------[ cut here ]------------ [ 3.710440] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_put() is being called. [ 3.719924] WARNING: CPU: 0 PID: 1 at kobject_put+0x68/0xf0 [ 3.725493] Modules linked in: [ 3.728538] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 3.736274] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 3.742270] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 3.749224] pc : kobject_put+0x68/0xf0 [ 3.752966] lr : kobject_put+0x68/0xf0 [ 3.756708] sp : ffffffc008bdb390 [ 3.760012] x29: ffffffc008bdb390 x28: 0000000000000000 x27: ffffff8005c57810 [ 3.767143] x26: ffffff8005c74a20 x25: 0000000000000000 x24: ffffffc008b55368 [ 3.774274] x23: 0000000000000000 x22: 00000000fffffffe x21: ffffff8005c74a20 [ 3.781406] x20: ffffff8005c57810 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 3.788536] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 00000000000002bb [ 3.795667] x14: 0000000000000831 x13: 00000000000002bb x12: 00000000ffffffea [ 3.802798] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 3.809928] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 3.817059] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb0b0 [ 3.824189] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 3.831321] Call trace: [ 3.833757] kobject_put+0x68/0xf0 [ 3.837153] kobject_add_internal+0x130/0x330 [ 3.841503] kobject_add+0x80/0xe0 [ 3.844899] device_add+0xd8/0x840 [ 3.848294] of_device_add+0x4c/0x5c [ 3.851861] of_platform_device_create_pdata+0xb8/0xf0 [ 3.856992] of_platform_bus_create+0x104/0x350 [ 3.861515] of_platform_populate+0x54/0xe0 [ 3.865690] parse_mtd_partitions+0x430/0x490 [ 3.870040] mtd_device_parse_register+0x90/0x2b0 [ 3.874737] spi_nor_probe+0x1f8/0x2b0 [ 3.878479] spi_mem_probe+0x68/0xa0 [ 3.882047] spi_probe+0x80/0xdc [ 3.885269] really_probe.part.0+0x98/0x280 [ 3.889444] __driver_probe_device+0x94/0x140 [ 3.893792] driver_probe_device+0x40/0x114 [ 3.897968] __device_attach_driver+0xb0/0x10c [ 3.902403] bus_for_each_drv+0x64/0xa0 [ 3.906233] __device_attach+0xa8/0x16c [ 3.910061] device_initial_probe+0x10/0x20 [ 3.914235] bus_probe_device+0x94/0x9c [ 3.918065] device_add+0x35c/0x840 [ 3.921547] __spi_add_device+0x70/0x114 [ 3.925461] spi_add_device+0x5c/0x90 [ 3.929116] of_register_spi_device+0x204/0x330 [ 3.933639] spi_register_controller+0x3e8/0x6dc [ 3.938248] devm_spi_register_controller+0x20/0x74 [ 3.943118] mtk_nor_probe+0x344/0x4c0 [ 3.946860] platform_probe+0x64/0xd0 [ 3.950514] really_probe.part.0+0x98/0x280 [ 3.954689] __driver_probe_device+0x94/0x140 [ 3.959037] driver_probe_device+0x40/0x114 [ 3.963212] __driver_attach+0xf0/0x180 [ 3.967039] bus_for_each_dev+0x5c/0x90 [ 3.970869] driver_attach+0x20/0x2c [ 3.974438] bus_add_driver+0x140/0x1ec [ 3.978268] driver_register+0x74/0x120 [ 3.982096] __platform_driver_register+0x24/0x30 [ 3.986792] mtk_nor_driver_init+0x18/0x20 [ 3.990882] do_one_initcall+0x4c/0x1c0 [ 3.994711] kernel_init_freeable+0x230/0x294 [ 3.999061] kernel_init+0x20/0x120 [ 4.002541] ret_from_fork+0x10/0x20 [ 4.006109] ---[ end trace 0000000000000000 ]--- [ 4.010725] kobject_add_internal failed for 11014000.spi:flash@0:partitions:partition@1000000 (error: -2 parent: (null)) [ 4.021590] ------------[ cut here ]------------ [ 4.026196] kobject: '(null)' (0000000097a89bbf): is not initialized, yet kobject_put() is being called. [ 4.035681] WARNING: CPU: 0 PID: 1 at kobject_put+0x68/0xf0 [ 4.041248] Modules linked in: [ 4.044294] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G S W 5.18.0-rc1+ #0 [ 4.052030] Hardware name: Ubiquiti UniFi 6 LR (U-Boot mod) (DT) [ 4.058025] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 4.064979] pc : kobject_put+0x68/0xf0 [ 4.068722] lr : kobject_put+0x68/0xf0 [ 4.072463] sp : ffffffc008bdb490 [ 4.075768] x29: ffffffc008bdb490 x28: 0000000000000000 x27: ffffff8005c57810 [ 4.082900] x26: ffffff8005c74a20 x25: 0000000000000000 x24: 0000000000000001 [ 4.090031] x23: 0000000000000000 x22: 0000000000000000 x21: 0000000000000000 [ 4.097162] x20: ffffff8005c74a20 x19: ffffff8005c74a20 x18: ffffffc008ab9630 [ 4.104293] x17: 6f6b20746579202c x16: 64657a696c616974 x15: 00000000000002fd [ 4.111424] x14: 00000000000008f7 x13: 00000000000002fd x12: 00000000ffffffea [ 4.118554] x11: 00000000ffffefff x10: 00000000ffffefff x9 : ffffffc008b11630 [ 4.125685] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000057fa8 [ 4.132816] x5 : 0000000000000fff x4 : 0000000000000000 x3 : ffffffc008bdb1b0 [ 4.139946] x2 : 0000000000000000 x1 : ffffffc008ab9580 x0 : 000000000000005c [ 4.147078] Call trace: [ 4.149514] kobject_put+0x68/0xf0 [ 4.152910] device_add+0xfc/0x840 [ 4.156305] of_device_add+0x4c/0x5c [ 4.159872] of_platform_device_create_pdata+0xb8/0xf0 [ 4.165003] of_platform_bus_create+0x104/0x350 [ 4.169525] of_platform_populate+0x54/0xe0 [ 4.173700] parse_mtd_partitions+0x430/0x490 [ 4.178051] mtd_device_parse_register+0x90/0x2b0 [ 4.182749] spi_nor_probe+0x1f8/0x2b0 [ 4.186491] spi_mem_probe+0x68/0xa0 [ 4.190059] spi_probe+0x80/0xdc [ 4.193281] really_probe.part.0+0x98/0x280 [ 4.197456] __driver_probe_device+0x94/0x140 [ 4.201804] driver_probe_device+0x40/0x114 [ 4.205979] __device_attach_driver+0xb0/0x10c [ 4.210414] bus_for_each_drv+0x64/0xa0 [ 4.214244] __device_attach+0xa8/0x16c [ 4.218072] device_initial_probe+0x10/0x20 [ 4.222248] bus_probe_device+0x94/0x9c [ 4.226078] device_add+0x35c/0x840 [ 4.229560] __spi_add_device+0x70/0x114 [ 4.233476] spi_add_device+0x5c/0x90 [ 4.237130] of_register_spi_device+0x204/0x330 [ 4.241653] spi_register_controller+0x3e8/0x6dc [ 4.246262] devm_spi_register_controller+0x20/0x74 [ 4.251132] mtk_nor_probe+0x344/0x4c0 [ 4.254875] platform_probe+0x64/0xd0 [ 4.258529] really_probe.part.0+0x98/0x280 [ 4.262705] __driver_probe_device+0x94/0x140 [ 4.267054] driver_probe_device+0x40/0x114 [ 4.271229] __driver_attach+0xf0/0x180 [ 4.275057] bus_for_each_dev+0x5c/0x90 [ 4.278887] driver_attach+0x20/0x2c [ 4.282456] bus_add_driver+0x140/0x1ec [ 4.286286] driver_register+0x74/0x120 [ 4.290113] __platform_driver_register+0x24/0x30 [ 4.294810] mtk_nor_driver_init+0x18/0x20 [ 4.298900] do_one_initcall+0x4c/0x1c0 [ 4.302728] kernel_init_freeable+0x230/0x294 [ 4.307079] kernel_init+0x20/0x120 [ 4.310559] ret_from_fork+0x10/0x20 [ 4.314127] ---[ end trace 0000000000000000 ]--- [ 4.318748] Creating 7 MTD partitions on "spi0.0": [ 4.323538] 0x000000000000-0x000000020000 : "bl2" [ 4.328902] 0x000000020000-0x0000000c0000 : "fip" [ 4.334231] 0x0000000c0000-0x0000000d0000 : "u-boot-env" [ 4.340495] 0x0000000d0000-0x000000110000 : "factory" [ 4.346152] 0x000000110000-0x000000120000 : "eeprom" [ 4.352108] 0x000000120000-0x000001000000 : "recovery" [ 4.357862] 0x000001000000-0x000004000000 : "firmware" [ 4.363746] mtk-spi-nor 11014000.spi: spi frequency: 46666653 Hz [...] ---
Best regards
Daniel
Hi Daniel,
daniel@makrotopia.org wrote on Mon, 25 Apr 2022 02:20:34 +0100:
Even though these compatibles are not mainline, it feels like the problem exists here as well. I'm dropping this change for now, let's fix this first.
Thanks, Miquèl
I found it! It used to happen (before dropping patch) with: # CONFIG_MTD_PARTITIONED_MASTER is not set
I'll work on V2 which doesn't require CONFIG_MTD_PARTITIONED_MASTER=y
Daniel Golle
Miquel Raynal
Rafał Miłecki
Srinivas Kandagatla
