[U-Boot-Users] How board_init_f funcion in board.c is being called?
Hello, I am a new U-boot user. Could you please tell me where the function "board_init_f" is being called? There is no mention of "board_init_f" anywhere else in U-boot except in bootseq.txt. How is this text file related to "board_init_f".
Thanks & Warm Regards, Prathima. ************************************************************************** This email (including any attachments) is intended for the sole use of the intended recipient/s and may contain material that is CONFIDENTIAL AND PRIVATE COMPANY INFORMATION. Any review or reliance by others or copying or distribution or forwarding of any or all of the contents in this message is STRICTLY PROHIBITED. If you are not the intended recipient, please contact the sender by email and delete all copies; your cooperation in this regard is appreciated. **************************************************************************
Prathima, It will be called from startup code located in the cpu/<processor name>/start.S For example see the the file : ./cpu/mips/start.S.
Regards Ganapathi C
----- Original Message ----- From: Prathima_Kolar To: 'u-boot-users@lists.sourceforge.net' Cc: Apoorv_Sangal Sent: Thursday, September 23, 2004 11:08 AM Subject: [U-Boot-Users] How board_init_f funcion in board.c is being called?
Hello,
Prathima.
You must be joking:
-> find . -type f | xargs egrep -l board_init_f ./board/evb64260/bootseq.txt ./board/gen860t/gen860t.c ./board/lwmon/lwmon.c ./board/mbx8xx/mbx8xx.c ./board/mpl/mip405/mip405.c ./board/sacsng/sacsng.c ./board/LEOX/elpt860/elpt860.c ./board/Marvell/common/bootseq.txt ./board/xpedite1k/xpedite1k.c ./board/ocotea/ocotea.c ./board/ssv/adnpesc1/adnpesc1.c ./board/kup/common/kup.c ./board/netta/netta.c ./board/jse/jse.c ./board/jse/sdram.c ./CHANGELOG ./cpu/74xx_7xx/start.S ./cpu/mpc824x/start.S ./cpu/mpc8260/start.S ./cpu/mpc8xx/start.S ./cpu/ppc4xx/start.S ./cpu/mips/start.S ./cpu/mpc5xx/start.S ./cpu/mpc5xx/cpu_init.c ./cpu/mpc5xxx/start.S ./cpu/mpc85xx/start.S ./cpu/mcf52x2/start.S ./doc/README.POST ./include/common.h ./lib_ppc/board.c ./lib_mips/board.c ./lib_m68k/board.c
This is just a board specific documentation file which is more or less irrelevant for all other boards.
What you really want to look at is the lib_*/board.c and cpu/*/start.S files. That's where board_init_f() is implemented resp. called.
ganapathi
Prathima_Kolar
