[PATCH 0/1] usb: gadget: ether: Disable USB pullup in eth probe
21 Aug
2024
21 Aug
'24
11:19 p.m.
With feedbacks from Marek and a deeper look the patch "usb: gadget: ether: Handle gadget driver registration in start and stop" doesn't fix the issue in the right way.
We can't keep pullup disabled in udc start and remove usb_gadget_connect from usb_gadget_register_driver since g_dnl doesn't call usb_gadget_connect after driver register (it does call before udc start in which case the controller may be not initialized yet eg. DWC2).
I think fix the issue in usb_ether probe is the simplest way to avoid touch too much things.
Zixun LI (1): usb: gadget: ether: Disable USB pullup in eth probe
drivers/usb/gadget/ether.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
-- 2.45.2
268
Zixun LI
