[PATCH 0/5] Resync Devices trees with Linux 5.16-rc3 and fix breakages
The device trees for the RZ/G2[MNH] boards at kernel.org have undergone some changes over time. Some of these changes are MMC aliases and others are AVB refernece clocks. This series attempts to re-sync the device trees with Kernel.org then address some minor driver, defconfig, and config.h breakages caused by the resync. This series also consolidates the rz/g2[mnh] -u-boot.dtsi files into one common file to eliminate some duplicate code and make future maintenance easier.
Adam Ford (5): net: ravb: Support multiple clocks arm: dts: beacon-rzg2: Resync device trees with Linux 5.16-rc3 arm: dts: Create common rz-g2-beacon-u-boot file ARM: rmobile: Fix rzg2_beacon_defconfig to address new aliases configs: beacon-rzg2m: Config to address new aliases
arch/arm/dts/beacon-renesom-baseboard.dtsi | 16 +++- arch/arm/dts/beacon-renesom-som.dtsi | 45 +++-------- .../dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi | 32 +------- arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts | 3 + .../dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi | 32 +------- arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts | 3 + .../dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi | 42 +---------- arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts | 3 + arch/arm/dts/rz-g2-beacon-u-boot.dtsi | 75 +++++++++++++++++++ board/beacon/beacon-rzg2m/MAINTAINERS | 10 +++ configs/rzg2_beacon_defconfig | 1 - drivers/net/ravb.c | 10 +-- include/configs/beacon-rzg2m.h | 2 +- 13 files changed, 129 insertions(+), 145 deletions(-) create mode 100644 arch/arm/dts/rz-g2-beacon-u-boot.dtsi
The RZ/G2 series uses an external clock as a reference to the AVB. If this clock is controlled by an external programmable clock, it must be requested by the consumer or it will not turn on. In order to do this, update the driver to use bulk enable and disable functions to enable clocks for boards with multiple clocks.
Signed-off-by: Adam Ford aford173@gmail.com --- drivers/net/ravb.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 6953b7286a..d756dddb02 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -129,7 +129,7 @@ struct ravb_priv { struct phy_device *phydev; struct mii_dev *bus; void __iomem *iobase; - struct clk clk; + struct clk_bulk clks; struct gpio_desc reset_gpio; };
@@ -485,7 +485,7 @@ static int ravb_probe(struct udevice *dev) iobase = map_physmem(pdata->iobase, 0x1000, MAP_NOCACHE); eth->iobase = iobase;
- ret = clk_get_by_index(dev, 0, ð->clk); + ret = clk_get_bulk(dev, ð->clks); if (ret < 0) goto err_mdio_alloc;
@@ -518,7 +518,7 @@ static int ravb_probe(struct udevice *dev) eth->bus = miiphy_get_dev_by_name(dev->name);
/* Bring up PHY */ - ret = clk_enable(ð->clk); + ret = clk_enable_bulk(ð->clks); if (ret) goto err_mdio_register;
@@ -533,7 +533,7 @@ static int ravb_probe(struct udevice *dev) return 0;
err_mdio_reset: - clk_disable(ð->clk); + clk_release_bulk(ð->clks); err_mdio_register: mdio_free(mdiodev); err_mdio_alloc: @@ -545,7 +545,7 @@ static int ravb_remove(struct udevice *dev) { struct ravb_priv *eth = dev_get_priv(dev);
free(eth->phydev); mdio_unregister(eth->bus);
struct clk clk;
/* Bring up PHY */
err_mdio_reset:
clk_release_bulk(ð->clks); free(eth->phydev); mdio_unregister(eth->bus);
-- 2.32.0
Reviewed-by: Ramon Fried rfried.dev@gmail.com
The device trees for the Beacon RZ/G2[MNH] boards have undergone some changes over time, so resync them now.
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/dts/beacon-renesom-baseboard.dtsi | 16 ++++++-- arch/arm/dts/beacon-renesom-som.dtsi | 45 ++++++---------------- arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts | 3 ++ arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts | 3 ++ arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts | 3 ++ 5 files changed, 32 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/beacon-renesom-baseboard.dtsi b/arch/arm/dts/beacon-renesom-baseboard.dtsi index 5f998d4706..2692cc64bf 100644 --- a/arch/arm/dts/beacon-renesom-baseboard.dtsi +++ b/arch/arm/dts/beacon-renesom-baseboard.dtsi @@ -197,6 +197,14 @@ compatible = "audio-graph-card"; label = "rcar-sound"; dais = <&rsnd_port0>, <&rsnd_port1>; + widgets = "Microphone", "Mic Jack", + "Line", "Line In Jack", + "Headphone", "Headphone Jack"; + mic-det-gpio = <&gpio0 2 GPIO_ACTIVE_LOW>; + routing = "Headphone Jack", "HPOUTL", + "Headphone Jack", "HPOUTR", + "IN3R", "MICBIAS", + "Mic Jack", "IN3R"; };
vccq_sdhi0: regulator-vccq-sdhi0 { @@ -271,12 +279,12 @@ &ehci0 { dr_mode = "otg"; status = "okay"; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&versaclock5 3>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&usb2_clksel>, <&versaclock5 3>; };
&ehci1 { status = "okay"; - clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>; + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&usb2_clksel>, <&versaclock5 3>; };
&hdmi0 { @@ -615,7 +623,7 @@ };
&rcar_sound { - pinctrl-0 = <&sound_pins &sound_clk_pins>; + pinctrl-0 = <&sound_pins>, <&sound_clk_pins>; pinctrl-names = "default";
/* Single DAI */ @@ -639,7 +647,7 @@ bitclock-master = <&rsnd_endpoint0>; frame-master = <&rsnd_endpoint0>;
- playback = <&ssi1 &dvc1 &src1>; + playback = <&ssi1>, <&dvc1>, <&src1>; capture = <&ssi0>; }; }; diff --git a/arch/arm/dts/beacon-renesom-som.dtsi b/arch/arm/dts/beacon-renesom-som.dtsi index d30bab3c8b..0d136809eb 100644 --- a/arch/arm/dts/beacon-renesom-som.dtsi +++ b/arch/arm/dts/beacon-renesom-som.dtsi @@ -7,19 +7,10 @@ #include <dt-bindings/clk/versaclock.h>
/ { - aliases { - spi0 = &rpc; - }; - memory@48000000 { device_type = "memory"; /* first 128MB is reserved for secure area. */ - reg = <0x0 0x48000000 0x0 0xc000000>; - }; - - memory@57000000 { - device_type = "memory"; - reg = <0x0 0x57000000 0x0 0x29000000>; + reg = <0x0 0x48000000 0x0 0x78000000>; };
osc_32k: osc_32k { @@ -59,12 +50,17 @@ &avb { pinctrl-0 = <&avb_pins>; pinctrl-names = "default"; + phy-mode = "rgmii-rxid"; phy-handle = <&phy0>; rx-internal-delay-ps = <1800>; tx-internal-delay-ps = <2000>; + clocks = <&cpg CPG_MOD 812>, <&versaclock5 4>; + clock-names = "fck", "refclk"; status = "okay";
phy0: ethernet-phy@0 { + compatible = "ethernet-phy-id004d.d074", + "ethernet-phy-ieee802.3-c22"; reg = <0>; interrupt-parent = <&gpio2>; interrupts = <11 IRQ_TYPE_LEVEL_LOW>; @@ -153,7 +149,7 @@ };
eeprom@50 { - compatible = "microchip,at24c64", "atmel,24c64"; + compatible = "microchip,24c64", "atmel,24c64"; pagesize = <32>; read-only; /* Manufacturing EEPROM programmed at factory */ reg = <0x50>; @@ -279,25 +275,6 @@ }; };
-&rpc { - compatible = "renesas,rcar-gen3-rpc"; - num-cs = <1>; - spi-max-frequency = <40000000>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - flash0: spi-flash@0 { - #address-cells = <1>; - #size-cells = <1>; - reg = <0>; - compatible = "spi-flash", "jedec,spi-nor"; - spi-max-frequency = <40000000>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <1>; - }; -}; - &scif_clk { clock-frequency = <14745600>; }; @@ -340,17 +317,17 @@ vqmmc-supply = <®_1p8v>; bus-width = <8>; mmc-hs200-1_8v; + no-sd; + no-sdio; non-removable; fixed-emmc-driver-type = <1>; status = "okay"; };
&usb2_clksel { - status = "okay"; clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, - <&versaclock5 3>, <&usb3s0_clk>; - clock-names = "ehci_ohci", "hs-usb-if", - "usb_extal", "usb_xtal"; + <&versaclock5 3>, <&usb3s0_clk>; + status = "okay"; };
&usb3s0_clk { diff --git a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts index 501cb05da2..3cf2e07694 100644 --- a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts +++ b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts @@ -21,6 +21,9 @@ serial4 = &hscif2; serial5 = &scif5; ethernet0 = &avb; + mmc0 = &sdhi3; + mmc1 = &sdhi0; + mmc2 = &sdhi2; };
chosen { diff --git a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts index 71763f4402..3c0d59def8 100644 --- a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts +++ b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts @@ -22,6 +22,9 @@ serial5 = &scif5; serial6 = &scif4; ethernet0 = &avb; + mmc0 = &sdhi3; + mmc1 = &sdhi0; + mmc2 = &sdhi2; };
chosen { diff --git a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts index 273f062f29..7b6649a3de 100644 --- a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts +++ b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts @@ -22,6 +22,9 @@ serial5 = &scif5; serial6 = &scif4; ethernet0 = &avb; + mmc0 = &sdhi3; + mmc1 = &sdhi0; + mmc2 = &sdhi2; };
chosen {
The rzg2_beacon_defconfig creates an image for RZ/G2[MNH] and as such creates three different device trees and each of them have a corresponding -u-boot.dtsi file which are basically copies of each other. Create a common include file to be referenced by each of the respective board-u-boot.dtsi files to reduce duplicate code and simplify support going forward. This also restores some lost functionality from the device tree re-sync and updates the MAINTAINER file to include all beacon-renesom device tree files.
Signed-off-by: Adam Ford aford173@gmail.com --- .../dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi | 32 +------- .../dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi | 32 +------- .../dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi | 42 +---------- arch/arm/dts/rz-g2-beacon-u-boot.dtsi | 75 +++++++++++++++++++ board/beacon/beacon-rzg2m/MAINTAINERS | 10 +++ 5 files changed, 91 insertions(+), 100 deletions(-) create mode 100644 arch/arm/dts/rz-g2-beacon-u-boot.dtsi
diff --git a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi index a0c0a7f35c..85336d5f3b 100644 --- a/arch/arm/dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi +++ b/arch/arm/dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi @@ -1,34 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright 2020 Compass Electronics Group, LLC + * Copyright 2021 LogicPD dba Beacon EmbeddedWorks */
-/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - -&cpg { - u-boot,dm-pre-reloc; -}; - -&extal_clk { - u-boot,dm-pre-reloc; -}; - -&prr { - u-boot,dm-pre-reloc; -}; - -&extalr_clk { - u-boot,dm-pre-reloc; -}; - -&sdhi0 { - /delete-property/ cd-gpios; -}; - -&sdhi2 { - status = "disabled"; -}; +#include "rz-g2-beacon-u-boot.dtsi" diff --git a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi index a0c0a7f35c..85336d5f3b 100644 --- a/arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi +++ b/arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi @@ -1,34 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright 2020 Compass Electronics Group, LLC + * Copyright 2021 LogicPD dba Beacon EmbeddedWorks */
-/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - -&cpg { - u-boot,dm-pre-reloc; -}; - -&extal_clk { - u-boot,dm-pre-reloc; -}; - -&prr { - u-boot,dm-pre-reloc; -}; - -&extalr_clk { - u-boot,dm-pre-reloc; -}; - -&sdhi0 { - /delete-property/ cd-gpios; -}; - -&sdhi2 { - status = "disabled"; -}; +#include "rz-g2-beacon-u-boot.dtsi" diff --git a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi index eef200af2d..85336d5f3b 100644 --- a/arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi +++ b/arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi @@ -1,44 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright 2020 Compass Electronics Group, LLC + * Copyright 2021 LogicPD dba Beacon EmbeddedWorks */
-/ { - soc { - u-boot,dm-pre-reloc; - }; -}; - -&cpg { - u-boot,dm-pre-reloc; -}; - -&extal_clk { - u-boot,dm-pre-reloc; -}; - -&prr { - u-boot,dm-pre-reloc; -}; - -&extalr_clk { - u-boot,dm-pre-reloc; -}; - -&sdhi0 { - /delete-property/ cd-gpios; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr104; - max-frequency = <208000000>; -}; - -&sdhi2 { - status = "disabled"; -}; - -&sdhi3 { - mmc-ddr-1_8v; - mmc-hs200-1_8v; - mmc-hs400-1_8v; -}; +#include "rz-g2-beacon-u-boot.dtsi" diff --git a/arch/arm/dts/rz-g2-beacon-u-boot.dtsi b/arch/arm/dts/rz-g2-beacon-u-boot.dtsi new file mode 100644 index 0000000000..ef0b96a71e --- /dev/null +++ b/arch/arm/dts/rz-g2-beacon-u-boot.dtsi @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2021 LogicPD dba Beacon EmbeddedWorks + */ + +/ { + aliases { + spi0 = &rpc; + }; + + soc { + u-boot,dm-pre-reloc; + }; +}; + +&cpg { + u-boot,dm-pre-reloc; +}; + +&ehci0 { + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&versaclock5 3>; +}; + +&ehci1 { + clocks = <&cpg CPG_MOD 703>, <&cpg CPG_MOD 704>, <&versaclock5 3>; +}; + +&extal_clk { + u-boot,dm-pre-reloc; +}; + +&extalr_clk { + u-boot,dm-pre-reloc; +}; + +&prr { + u-boot,dm-pre-reloc; +}; + +&rpc { + compatible = "renesas,rcar-gen3-rpc"; + num-cs = <1>; + spi-max-frequency = <40000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + flash0: spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0>; + compatible = "spi-flash", "jedec,spi-nor"; + spi-max-frequency = <40000000>; + spi-tx-bus-width = <1>; + spi-rx-bus-width = <1>; + }; +}; + +&sdhi0 { + /delete-property/ cd-gpios; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + max-frequency = <208000000>; +}; + +&sdhi2 { + status = "disabled"; +}; + +&sdhi3 { + mmc-ddr-1_8v; + mmc-hs200-1_8v; + mmc-hs400-1_8v; +}; diff --git a/board/beacon/beacon-rzg2m/MAINTAINERS b/board/beacon/beacon-rzg2m/MAINTAINERS index 77c4057ab0..f8042bb2c4 100644 --- a/board/beacon/beacon-rzg2m/MAINTAINERS +++ b/board/beacon/beacon-rzg2m/MAINTAINERS @@ -4,3 +4,13 @@ S: Maintained F: board/beacon/beacon-rzg2m/ F: include/configs/beacon-rzg2m.h F: configs/rzg2_beacon_defconfig +F: arch/arm/dts/beacon-renesom-baseboard.dtsi +F: arch/arm/dts/beacon-renesom-som.dtsi +F: arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts +F: arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts +F: arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts +F: arch/arm/dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi +F: arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi +F: arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi +F: arch/arm/dts/rz-g2-beacon-u-boot.dtsi +
The resync of the device trees from Linux 5.16-rc3 caused aliases to appear on the MMC devices which changed the numbering. This broke the reading/writing of the environmental variables, so update the defconfig accordingly.
Signed-off-by: Adam Ford aford173@gmail.com --- configs/rzg2_beacon_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/rzg2_beacon_defconfig b/configs/rzg2_beacon_defconfig index b9bbc200b6..6c48c3b8c9 100644 --- a/configs/rzg2_beacon_defconfig +++ b/configs/rzg2_beacon_defconfig @@ -39,7 +39,6 @@ CONFIG_MULTI_DTB_FIT_LZO=y CONFIG_MULTI_DTB_FIT_USER_DEFINED_AREA=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_SYS_MMC_ENV_PART=2 CONFIG_VERSION_VARIABLE=y CONFIG_REGMAP=y
The resync of the device trees from Linux 5.16-rc3 caused aliases to appear on the MMC devices which changed the numbering. This changed the default boot device and caused boot failure. Update the mmcdev variable to reflect the new aliases.
Signed-off-by: Adam Ford aford173@gmail.com --- include/configs/beacon-rzg2m.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/beacon-rzg2m.h b/include/configs/beacon-rzg2m.h index 18d442e06a..14d6df328a 100644 --- a/include/configs/beacon-rzg2m.h +++ b/include/configs/beacon-rzg2m.h @@ -23,7 +23,7 @@ "boot_fdt=try\0" \ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "initrd_addr=0x43800000\0" \ - "mmcdev=0\0" \ + "mmcdev=1\0" \ "mmcpart=1\0" \ "mmcrootpart=2\0" \ "finduuid=part uuid mmc ${mmcdev}:${mmcrootpart} uuid\0" \
Adam Ford
Ramon Fried
