[U-Boot] [PATCH 2/6] sf: Optimize flash features code
- Shrink spi_slave {} - Shrink spi_flash_params {} - Documentation for sf features
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com Cc: Marek Vasut marex@denx.de --- doc/SPI/README.sf-features | 122 ++++++++++++++++++++++++++++++ drivers/mtd/spi/sf.c | 4 +- drivers/mtd/spi/sf_internal.h | 1 - drivers/mtd/spi/sf_ops.c | 8 +- drivers/mtd/spi/sf_params.c | 172 +++++++++++++++++++++--------------------- drivers/mtd/spi/sf_probe.c | 71 ++++++++--------- include/spi.h | 42 ++++------- include/spi_flash.h | 24 +++--- 8 files changed, 270 insertions(+), 174 deletions(-) create mode 100644 doc/SPI/README.sf-features
diff --git a/doc/SPI/README.sf-features b/doc/SPI/README.sf-features new file mode 100644 index 0000000..d35f56d --- /dev/null +++ b/doc/SPI/README.sf-features @@ -0,0 +1,122 @@ +SPI FLASH feature enhancements: +============================== + +This document describes how to extend the current data structures in spi subsystem +for making use of new flash features/operations w.r.t to controller driver support. + +1. spi_slave: + +struct spi_slave { + .......... + u32 mode_bits; + ........ +}; + +@mode_bits can be used to expose the SPI RX/TX operation modes, bus options and +few flags which are used to extended the flash specific features/operations +- include/spi.h + +mode_bits: +- SPI_TX_QPP: 4-Wire tx transfer operation quad page program +- SPI_RX_SLOW: 1-wire rx transfer operation array slow read +- SPI_RX_DUAL: 2-wire rx transfer operation dual fast read +- SPI_RX_DUAL_IO: 2-wire rx transfer operation dual io fast read +- SPI_RX_QUAD: 4-wire rx transfer operation quad fast read +- SPI_RX_QUAD_IO: 4-wire rx transfer operation quad io fast read +- SPI_SHARED: dual flash devices are connected in shared bus connection +- SPI_SEPARATED: dual flash devices are connected in separate bus connection +- SPI_U_PAGE: select the upper flash in dual flash shared bus connection [1] + +2. spi_flash_params: + +struct spi_flash_params { + ................ + u16 flags; + .............. +}; + +@flags can be use to verify the flash supported features/operations with respect +to controller driven through @mode_bits and also some internal flash specific +operations - include/spi_flash.h + +flags: +- SST_WP: SST flash write protection +- SECT_4K: 4K erase sector +- SECT_32K: 32 erase sector +- E_FSR: Flag status register for erase/write for micron < 256MB flash +- WR_QPP: Quad page program +- RD_SLOW: Array slow read +- RD_DUAL: Dual fast read +- RD_DUAL_IO: Dual IO read +- RD_QUAD: Quad fast read +- RD_QUAD_IO: Quad IO read +- RD_2WIRE: All 2-wire read commands +- RD_FULL: All read commands +- ALL_CMDS: All read and write commands [2] + +3. spi_flash: + +struct spi_flash { + ............... + u8 dual_flash; + u8 shift; + u8 poll_cmd; + u8 erase_cmd; + u8 read_cmd; + u8 write_cmd; + u8 dummy_byte; + ................ +}; + +Few varibles from spi_flash {} can be used to perform the internal operations +based on the selected flash features/operations from spi_slave {} and +spi_flash_params {} - include/spi_flash.h + +@dual_flash: flash can be operated in dual flash [3] +@shift: variable shift operator useful for dual parallel +@poll_cmd: find the read_status or flag_status for polling erase/write operations +@erase_cmd: discovered erase command +@read_cmd: discovered read command +@write_cmd: discovered write command +@dummy_byte: read dummy_byte based on read dummy_cycles. + +dummy byte is determined based on the dummy cycles of a particular command. +Fast commands - dummy_byte = dummy_cycles/8 +I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 +For I/O commands except cmd[0] everything goes on no.of lines based on +particular command but in case of fast commands except data all go on +single line irrespective of command. + +4. Usage: + +In drivers/spi/*.c assign spi_slave {} with supported features through mode_bits. +Ex: drivers/spi/ti_qspi.c + +struct ti_qspi_slave { + ................ + struct spi_slave slave; + .............. +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + ......... + + qslave = spi_alloc_slave(struct ti_qspi_slave, bus, cs); + if (!qslave) { + printf("SPI_error: Fail to allocate ti_qspi_slave\n"); + return NULL; + } + + qslave->slave.mode_bits = SPI_TX_QPP | SPI_RX_QUAD; + ........ +} + +[1] http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.... +[2] http://www.spansion.com/Support/Datasheets/S25FL128S_256S_00.pdf +[3] doc/SPI/README.dual-flash + +-- +Jagannadha Sutradharudu Teki jaganna@xilinx.com +Sat Jan 18 14:44:28 IST 2014 diff --git a/drivers/mtd/spi/sf.c b/drivers/mtd/spi/sf.c index 664e860..fb91ac6 100644 --- a/drivers/mtd/spi/sf.c +++ b/drivers/mtd/spi/sf.c @@ -19,8 +19,8 @@ static int spi_flash_read_write(struct spi_slave *spi, int ret;
#ifdef CONFIG_SF_DUAL_FLASH - if (spi->flags & SPI_XFER_U_PAGE) - flags |= SPI_XFER_U_PAGE; + if (spi->mode_bits & SPI_U_PAGE) + flags |= SPI_U_PAGE; #endif if (data_len == 0) flags |= SPI_XFER_END; diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 6bcd522..47d5ac2 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -67,7 +67,6 @@
/* SST specific */ #ifdef CONFIG_SPI_FLASH_SST -# define SST_WP 0x01 /* Supports AAI word program */ # define CMD_SST_BP 0x02 /* Byte Program */ # define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */
diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 1fac63a..2f3b03a 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -138,9 +138,9 @@ static void spi_flash_dual_flash(struct spi_flash *flash, u32 *addr) case SF_DUAL_STACKED_FLASH: if (*addr >= (flash->size >> 1)) { *addr -= flash->size >> 1; - flash->spi->flags |= SPI_XFER_U_PAGE; + flash->spi->mode_bits |= SPI_U_PAGE; } else { - flash->spi->flags &= ~SPI_XFER_U_PAGE; + flash->spi->mode_bits &= ~SPI_U_PAGE; } break; case SF_DUAL_PARALLEL_FLASH: @@ -170,8 +170,8 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) }
#ifdef CONFIG_SF_DUAL_FLASH - if (spi->flags & SPI_XFER_U_PAGE) - flags |= SPI_XFER_U_PAGE; + if (spi->mode_bits & SPI_U_PAGE) + flags |= SPI_U_PAGE; #endif ret = spi_xfer(spi, 8, &cmd, NULL, flags); if (ret) { diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index eb372b7..9b394f2 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -14,106 +14,106 @@ /* SPI/QSPI flash device params structure */ const struct spi_flash_params spi_flash_params_table[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ - {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, 0, SECT_4K}, - {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, 0, SECT_4K}, - {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, 0, SECT_4K}, - {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, 0, SECT_4K}, - {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, 0, SECT_4K}, - {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, 0, SECT_4K}, - {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, 0, SECT_4K}, - {"AT25DF321", 0x1f4701, 0x0, 64 * 1024, 64, 0, SECT_4K}, + {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, SECT_4K}, + {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, SECT_4K}, + {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, SECT_4K}, + {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, SECT_4K}, + {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, SECT_4K}, + {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, SECT_4K}, + {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, SECT_4K}, + {"AT25DF321", 0x1f4701, 0x0, 64 * 1024, 64, SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ - {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0, 0}, - {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, 0, SECT_4K}, - {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0, 0}, - {"EN25S64", 0x1c3817, 0x0, 64 * 1024, 128, 0, 0}, + {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0}, + {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, SECT_4K}, + {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0}, + {"EN25S64", 0x1c3817, 0x0, 64 * 1024, 128, 0}, #endif #ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ - {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, 0, SECT_4K}, - {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, 0, SECT_4K}, + {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, SECT_4K}, + {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ - {"MX25L2006E", 0xc22012, 0x0, 64 * 1024, 4, 0, 0}, - {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0, 0}, - {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0, 0}, - {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0, 0}, - {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0, 0}, - {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0, 0}, - {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP}, - {"MX25L51235F", 0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP}, - {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, + {"MX25L2006E", 0xc22012, 0x0, 64 * 1024, 4, 0}, + {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0}, + {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0}, + {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0}, + {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0}, + {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0}, + {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, ALL_CMDS}, + {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, ALL_CMDS}, + {"MX25L51235F", 0xc2201a, 0x0, 64 * 1024, 1024, ALL_CMDS}, + {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, ALL_CMDS}, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ - {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0, 0}, - {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0, 0}, - {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0, 0}, - {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0, 0}, - {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_FULL, WR_QPP}, - {"S25FL128S_256K", 0x012018, 0x4d00, 256 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL256S_256K", 0x010219, 0x4d00, 256 * 1024, 128, RD_FULL, WR_QPP}, - {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_FULL, WR_QPP}, - {"S25FL512S_256K", 0x010220, 0x4d00, 256 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL, WR_QPP}, + {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0}, + {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0}, + {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0}, + {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0}, + {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, ALL_CMDS}, + {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, ALL_CMDS}, + {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, ALL_CMDS}, + {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, ALL_CMDS}, + {"S25FL128S_256K", 0x012018, 0x4d00, 256 * 1024, 64, ALL_CMDS}, + {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, ALL_CMDS}, + {"S25FL256S_256K", 0x010219, 0x4d00, 256 * 1024, 128, ALL_CMDS}, + {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, ALL_CMDS}, + {"S25FL512S_256K", 0x010220, 0x4d00, 256 * 1024, 256, ALL_CMDS}, + {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, ALL_CMDS}, #endif #ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0, 0}, - {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0, 0}, - {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0, 0}, - {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0, 0}, - {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0, 0}, - {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0, 0}, - {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0, 0}, - {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0, 0}, - {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL, WR_QPP | E_FSR | SECT_4K}, + {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0}, + {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0}, + {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0}, + {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0}, + {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0}, + {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0}, + {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0}, + {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0}, + {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, ALL_CMDS | SECT_4K}, + {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, ALL_CMDS | SECT_4K}, + {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, ALL_CMDS | SECT_4K}, + {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, ALL_CMDS | SECT_4K}, + {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, ALL_CMDS}, + {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, ALL_CMDS}, + {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, ALL_CMDS | SECT_4K}, + {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, ALL_CMDS | SECT_4K}, + {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, ALL_CMDS | E_FSR | SECT_4K}, + {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, ALL_CMDS | E_FSR | SECT_4K}, + {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, ALL_CMDS | E_FSR | SECT_4K}, + {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, ALL_CMDS | E_FSR | SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */ - {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, 0, SECT_4K | SST_WP}, - {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, 0, SECT_4K | SST_WP}, - {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, 0, SECT_4K | SST_WP}, - {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, 0, SECT_4K | SST_WP}, - {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, 0, SECT_4K}, - {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, 0, SECT_4K | SST_WP}, - {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, 0, SECT_4K | SST_WP}, - {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, 0, SECT_4K | SST_WP}, - {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, 0, SECT_4K | SST_WP}, - {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, 0, SECT_4K | SST_WP}, + {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WP}, + {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WP}, + {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WP}, + {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WP}, + {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, SECT_4K}, + {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WP}, + {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WP}, + {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WP}, + {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WP}, + {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WP}, #endif #ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ - {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0, 0}, - {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0, 0}, - {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0, 0}, - {"W25X40", 0xef3013, 0x0, 64 * 1024, 8, 0, SECT_4K}, - {"W25X16", 0xef3015, 0x0, 64 * 1024, 32, 0, SECT_4K}, - {"W25X32", 0xef3016, 0x0, 64 * 1024, 64, 0, SECT_4K}, - {"W25X64", 0xef3017, 0x0, 64 * 1024, 128, 0, SECT_4K}, - {"W25Q80BL", 0xef4014, 0x0, 64 * 1024, 16, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q16CL", 0xef4015, 0x0, 64 * 1024, 32, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q32BV", 0xef4016, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q64CV", 0xef4017, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q128BV", 0xef4018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q256", 0xef4019, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q80BW", 0xef5014, 0x0, 64 * 1024, 16, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q16DW", 0xef6015, 0x0, 64 * 1024, 32, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q32DW", 0xef6016, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q64DW", 0xef6017, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q128FW", 0xef6018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP | SECT_4K}, + {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0}, + {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0}, + {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0}, + {"W25X40", 0xef3013, 0x0, 64 * 1024, 8, SECT_4K}, + {"W25X16", 0xef3015, 0x0, 64 * 1024, 32, SECT_4K}, + {"W25X32", 0xef3016, 0x0, 64 * 1024, 64, SECT_4K}, + {"W25X64", 0xef3017, 0x0, 64 * 1024, 128, SECT_4K}, + {"W25Q80BL", 0xef4014, 0x0, 64 * 1024, 16, ALL_CMDS | SECT_4K}, + {"W25Q16CL", 0xef4015, 0x0, 64 * 1024, 32, ALL_CMDS | SECT_4K}, + {"W25Q32BV", 0xef4016, 0x0, 64 * 1024, 64, ALL_CMDS | SECT_4K}, + {"W25Q64CV", 0xef4017, 0x0, 64 * 1024, 128, ALL_CMDS | SECT_4K}, + {"W25Q128BV", 0xef4018, 0x0, 64 * 1024, 256, ALL_CMDS | SECT_4K}, + {"W25Q256", 0xef4019, 0x0, 64 * 1024, 512, ALL_CMDS | SECT_4K}, + {"W25Q80BW", 0xef5014, 0x0, 64 * 1024, 16, ALL_CMDS | SECT_4K}, + {"W25Q16DW", 0xef6015, 0x0, 64 * 1024, 32, ALL_CMDS | SECT_4K}, + {"W25Q32DW", 0xef6016, 0x0, 64 * 1024, 64, ALL_CMDS | SECT_4K}, + {"W25Q64DW", 0xef6017, 0x0, 64 * 1024, 128, ALL_CMDS | SECT_4K}, + {"W25Q128FW", 0xef6018, 0x0, 64 * 1024, 256, ALL_CMDS | SECT_4K}, #endif /* * Note: diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index e84ab13..d1ebf72 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -19,15 +19,6 @@
DECLARE_GLOBAL_DATA_PTR;
-/* Read commands array */ -static u8 spi_read_cmds_array[] = { - CMD_READ_ARRAY_SLOW, - CMD_READ_DUAL_OUTPUT_FAST, - CMD_READ_DUAL_IO_FAST, - CMD_READ_QUAD_OUTPUT_FAST, - CMD_READ_QUAD_IO_FAST, -}; - #ifdef CONFIG_SPI_FLASH_MACRONIX static int spi_flash_set_qeb_mxic(struct spi_flash *flash) { @@ -100,7 +91,6 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, { const struct spi_flash_params *params; struct spi_flash *flash; - u8 cmd; u16 jedec = idcode[1] << 8 | idcode[2]; u16 ext_jedec = idcode[3] << 8 | idcode[4];
@@ -136,13 +126,13 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, flash->dual_flash = flash->spi->option;
/* Assign spi_flash ops */ + flash->read = spi_flash_cmd_read_ops; + flash->erase = spi_flash_cmd_erase_ops; flash->write = spi_flash_cmd_write_ops; #ifdef CONFIG_SPI_FLASH_SST if (params->flags & SST_WP) flash->write = sst_write_wp; #endif - flash->erase = spi_flash_cmd_erase_ops; - flash->read = spi_flash_cmd_read_ops;
/* Compute the flash size */ flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; @@ -166,18 +156,38 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, flash->erase_size = flash->sector_size; }
- /* Look for the fastest read cmd */ - cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); - if (cmd) { - cmd = spi_read_cmds_array[cmd - 1]; - flash->read_cmd = cmd; - } else { - /* Go for default supported read cmd */ - flash->read_cmd = CMD_READ_ARRAY_FAST; + /* Compute read command and dummy_byte */ + flash->read_cmd = CMD_READ_ARRAY_FAST; + flash->dummy_byte = 1; + switch (SPI_RX_MODES & flash->spi->mode_bits) { + case SPI_RX_SLOW: + if (params->flags & RD_SLOW) { + flash->read_cmd = CMD_READ_ARRAY_FAST; + flash->dummy_byte = 0; + } + break; + case SPI_RX_DUAL: + if (params->flags & RD_DUAL) + flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST; + break; + case SPI_RX_DUAL_IO: + if (params->flags & RD_DUAL_IO) + flash->read_cmd = CMD_READ_DUAL_OUTPUT_IO; + break; + case SPI_RX_QUAD: + if (params->flags & RD_QUAD) + flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; + break; + case SPI_RX_QUAD_IO: + if (params->flags & RD_QUAD_IO) { + flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST_IO; + flash->dummy_byte = 2; + } + break; }
/* Not require to look for fastest only two write cmds yet */ - if (params->flags & WR_QPP && flash->spi->op_mode_tx & SPI_OPM_TX_QPP) + if (flash->spi->mode_bits & SPI_TX_QPP && params->flags & WR_QPP) flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; else /* Go for default supported write cmd */ @@ -193,25 +203,6 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, } }
- /* Read dummy_byte: dummy byte is determined based on the - * dummy cycles of a particular command. - * Fast commands - dummy_byte = dummy_cycles/8 - * I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 - * For I/O commands except cmd[0] everything goes on no.of lines - * based on particular command but incase of fast commands except - * data all go on single line irrespective of command. - */ - switch (flash->read_cmd) { - case CMD_READ_QUAD_IO_FAST: - flash->dummy_byte = 2; - break; - case CMD_READ_ARRAY_SLOW: - flash->dummy_byte = 0; - break; - default: - flash->dummy_byte = 1; - } - /* Poll cmd selection */ flash->poll_cmd = CMD_READ_STATUS; #ifdef CONFIG_SPI_FLASH_STMICRO diff --git a/include/spi.h b/include/spi.h index ffd6647..45a3094 100644 --- a/include/spi.h +++ b/include/spi.h @@ -30,29 +30,23 @@ #define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ #define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */ #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) -#define SPI_XFER_U_PAGE (1 << 5) - -/* SPI TX operation modes */ -#define SPI_OPM_TX_QPP 1 << 0 - -/* SPI RX operation modes */ -#define SPI_OPM_RX_AS 1 << 0 -#define SPI_OPM_RX_DOUT 1 << 1 -#define SPI_OPM_RX_DIO 1 << 2 -#define SPI_OPM_RX_QOF 1 << 3 -#define SPI_OPM_RX_QIOF 1 << 4 -#define SPI_OPM_RX_EXTN SPI_OPM_RX_AS | SPI_OPM_RX_DOUT | \ - SPI_OPM_RX_DIO | SPI_OPM_RX_QOF | \ - SPI_OPM_RX_QIOF - -/* SPI bus connection options */ -#define SPI_CONN_DUAL_SHARED 1 << 0 -#define SPI_CONN_DUAL_SEPARATED 1 << 1
/* Header byte that marks the start of the message */ #define SPI_PREAMBLE_END_BYTE 0xec +#define SPI_DEFAULT_WORDLEN 8
-#define SPI_DEFAULT_WORDLEN 8 +/* SPI mode bits */ +#define SPI_TX_QPP 1 << 0 +#define SPI_RX_SLOW 1 << 1 +#define SPI_RX_DUAL 1 << 2 +#define SPI_RX_DUAL_IO 1 << 3 +#define SPI_RX_QUAD 1 << 4 +#define SPI_RX_QUAD_IO 1 << 5 +#define SPI_RX_MODES (SPI_RX_SLOW | SPI_RX_DUAL | SPI_RX_DUAL_IO | \ + SPI_RX_QUAD | SPI_RX_QUAD_IO) +#define SPI_SHARED 1 << 6 +#define SPI_SEPARATED 1 << 7 +#define SPI_U_PAGE 1 << 8
/** * struct spi_slave - Representation of a SPI slave @@ -61,25 +55,19 @@ * * @bus: ID of the bus that the slave is attached to. * @cs: ID of the chip select connected to the slave. - * @op_mode_rx: SPI RX operation mode. - * @op_mode_tx: SPI TX operation mode. * @wordlen: Size of SPI word in number of bits * @max_write_size: If non-zero, the maximum number of bytes which can * be written at once, excluding command bytes. + * @mode_bits: SPI RX/TX operation modes, bus options and few flags. * @memory_map: Address of read-only SPI flash access. - * @option: Varies SPI bus options - separate, shared bus. - * @flags: Indication of SPI flags. */ struct spi_slave { unsigned int bus; unsigned int cs; - u8 op_mode_rx; - u8 op_mode_tx; unsigned int wordlen; unsigned int max_write_size; + u16 mode_bits; void *memory_map; - u8 option; - u8 flags; };
/** diff --git a/include/spi_flash.h b/include/spi_flash.h index f79f0ea..16ca294 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -20,21 +20,19 @@ #include <linux/compiler.h>
/* sf param flags */ +#define SST_WP 1 << 0 #define SECT_4K 1 << 1 #define SECT_32K 1 << 2 #define E_FSR 1 << 3 #define WR_QPP 1 << 4 - -/* Enum list - Full read commands */ -enum spi_read_cmds { - ARRAY_SLOW = 1 << 0, - DUAL_OUTPUT_FAST = 1 << 1, - DUAL_IO_FAST = 1 << 2, - QUAD_OUTPUT_FAST = 1 << 3, - QUAD_IO_FAST = 1 << 4, -}; -#define RD_EXTN ARRAY_SLOW | DUAL_OUTPUT_FAST | DUAL_IO_FAST -#define RD_FULL RD_EXTN | QUAD_OUTPUT_FAST | QUAD_IO_FAST +#define RD_SLOW 1 << 5 +#define RD_DUAL 1 << 6 +#define RD_DUAL_IO 1 << 7 +#define RD_QUAD 1 << 8 +#define RD_QUAD_IO 1 << 9 +#define RD_2WIRE (RD_SLOW | RD_DUAL | RD_DUAL_IO) +#define RD_FULL (RD_2WIRE | RD_QUAD | RD_QUAD_IO) +#define ALL_CMDS (WR_QPP | RD_FULL)
/* Dual SPI flash memories */ enum spi_dual_flash { @@ -51,8 +49,7 @@ enum spi_dual_flash { * @ext_jedec: Device ext_jedec ID * @sector_size: Sector size of this device * @nr_sectors: No.of sectors on this device - * @e_rd_cmd: Enum list for read commands - * @flags: Importent param, for flash specific behaviour + * @flags: Importent params, for flash specific behaviour */ struct spi_flash_params { const char *name; @@ -60,7 +57,6 @@ struct spi_flash_params { u16 ext_jedec; u32 sector_size; u32 nr_sectors; - u8 e_rd_cmd; u16 flags; };
On Saturday, January 18, 2014 at 09:06:29 PM, Jagannadha Sutradharudu Teki wrote:
+struct spi_slave {
- u32 mode_bits;
A generic SPI controller _does_ _not_ _care_ about any SPI flash crud. The SPI bus controller (which is what this is for) and SPI-NOR controller are two different things and must have two different slave structures.
+struct spi_slave {
- u32 mode_bits;
You mean mode_bits need to move in one more structure. Just leave about new SPI-NOR as of now for this release we discuss more soon.
+struct spi_slave {
- u32 mode_bits;
The mode_bits have no place in this structure. The slave can indicate whether it can be connected over 1,2,4... lines , but must not indicate that it supports some SPI-flash specific properties.
Best regards, Marek Vasut
+struct spi_slave {
- u32 mode_bits;
What do you mean by this - can you elaborate. As of now drivers in drivers/spi need to inform the flash through spi_slave {} no other alternative ie way remaining flash properties memory_map etc.. handle. Even Linux follow the same w/o new SPI-NOR framework.
If your question, like need a separate structure for flash specific properties please wait will wound-up all these in new framework.
I'm planning to push in today release.
+struct spi_slave {
- u32 mode_bits;
I mean there do exist SPI controllers which can output data via more than one (MOSI) line . They do support 1, 2 or even 4 lines. This comes useful when driving SPI flashes indeed, _BUT_ (!) this is not tied to driving SPI flashes. On the contrary, you can connect any device which can be driven over such "parallelised" SPI and it will work. And only such property shall also land in the struct spi_slave {} .
Properties like "let's assume the SPI slave is a SPI NOR and it supports SPI NOR command FOO" do not go into struct spi_slave.
Linux is now going for a separate SPI-NOR controller framework and this is what we will do as well. The SF layer will be only a unifying layer providing access to either SPI-NOR API (for the SPI-NOR controllers) or a translation layer to communicate SPI-NOR commands over generic SPI API (for the old-school regular way of doing SPI NOR connection to SPI bus).
I doubt anything is going in today's release ;-)
Actually, you need to really start discerning which _must_ go into a release and which simply does not go into a release and waits for -next. This is important role of a maintainer and plays important role in keeping the codebase in good shape.
Code which is untested, code which changes core stuff and isn't an obvious bugfix etc. simply can wait. Code which is obvious bugfix goes in even in the - rc period. Of course, there are all kinds of exceptions, that depends on the rationale and negotiation.
Hi Marek,
+struct spi_slave {
- u32 mode_bits;
Please correct me logic here! Just take an example of ti qspi controller.
cmd_sf.c ------------ spi_flash.h -------------- sf (_probe, _ops), sf.c ------------------------------------------- drivers/spi/ti_qspi.c (inform flash info mode_bits through spi_slave {} ------------------------------------------------------------
Suppose If we have one more qspi controller(zynq) which is connected to SPI-NOR
cmd_sf.c ----------- spi_flash.h --------------- SF-NOR ------------------------------------------------------------------------------------ drivers/spi/ti_qspi.c drivers/mtd/sf_nor/zynq_qspi.c (inform flash properties (inform flash properties through "mode_bits" of through "mode_bits" of spi_slave {})
Hi Marek,
Please ignore the last sent!
On Tue, Jan 21, 2014 at 1:09 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Marek,
wrote: > - Shrink spi_slave {} > - Shrink spi_flash_params {} > - Documentation for sf features > > Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com > Cc: Marek Vasut marex@denx.de > --- > > doc/SPI/README.sf-features | 122 ++++++++++++++++++++++++++++++ > drivers/mtd/spi/sf.c | 4 +- > drivers/mtd/spi/sf_internal.h | 1 - > drivers/mtd/spi/sf_ops.c | 8 +- > drivers/mtd/spi/sf_params.c | 172 > > +++++++++++++++++++++--------------------- drivers/mtd/spi/sf_probe.c > > 71 ++++++++--------- > include/spi.h | 42 ++++------- > include/spi_flash.h | 24 +++--- > 8 files changed, 270 insertions(+), 174 deletions(-) > create mode 100644 doc/SPI/README.sf-features > > diff --git a/doc/SPI/README.sf-features b/doc/SPI/README.sf-features > new file mode 100644 > index 0000000..d35f56d > --- /dev/null > +++ b/doc/SPI/README.sf-features > @@ -0,0 +1,122 @@ > +SPI FLASH feature enhancements: > +============================== > + > +This document describes how to extend the current data structures in > spi subsystem +for making use of new flash features/operations w.r.t > to controller driver support. + > +1. spi_slave: > + > +struct spi_slave { > + .......... > + u32 mode_bits; > + ........ > +}; > + > +@mode_bits can be used to expose the SPI RX/TX operation modes, bus > options and +few flags which are used to extended the flash specific > features/operations +- include/spi.h > + > +mode_bits: > +- SPI_TX_QPP: 4-Wire tx transfer operation quad page program > +- SPI_RX_SLOW: 1-wire rx transfer operation array slow read > +- SPI_RX_DUAL: 2-wire rx transfer operation dual fast read > +- SPI_RX_DUAL_IO: 2-wire rx transfer operation dual io fast read > +- SPI_RX_QUAD: 4-wire rx transfer operation quad fast read > +- SPI_RX_QUAD_IO: 4-wire rx transfer operation quad io fast read > +- SPI_SHARED: dual flash devices are connected in shared bus > connection +- SPI_SEPARATED: dual flash devices are connected in > separate bus connection +- SPI_U_PAGE: select the upper flash in > dual flash shared bus connection [1] +
Just take an example of ti qspi controller which is connected to serial nor
Current design:
cmd_sf.c ------------ spi_flash.h -------------- sf (_probe, _ops), sf.c ------------------------------------------- drivers/spi/ti_qspi.c (inform flash properties through "mode_bits" spi_slave {} -------------------------------------------------------------------------------
Proposed one (may be):
Suppose If we have one more qspi controller(zynq) which is connected to serial nor
cmd_sf.c ----------- spi_flash.h --------------- SF-NOR ------------------------------------------------------------------------------------------------ drivers/spi/ti_qspi.c drivers/mtd/sf_nor/zynq_qspi.c (inform flash properties (inform flash properties through "mode_bits" of through "mode_bits" of spi_slave {}) sf_nor_device {}
Please comment on above proposed design will ask you more once this set..thanks!
On Tuesday, January 21, 2014 at 08:45:52 AM, Jagan Teki wrote: [...]
Current design:
cmd_sf.c
This is just the one of the users of the SPI flash API, but not the only one.
spi_flash.h
Did the formating here go awry ?
But anyway, your sf_probe.c/sf_ops.c/sf.c will only need to somehow discern whether to call the regular SPI API or SPI-NOR API functions.
Jagan Teki
