Please pull u-boot-dm/next
Hi Tom,
I have a passing run without the coreboot test. Are you seeing problems with that? I may need to move the downloads into the docker image.
https://source.denx.de/u-boot/custodians/u-boot-dm/-/pipelines/11350
The following changes since commit 297e6eb8dcf9d90aaf9b0d146cdd502403003d04:
Merge tag 'xilinx-for-v2022.07-rc1' of https://source.denx.de/u-boot/custodians/u-boot-microblaze into next (2022-03-16 12:52:02 -0400)
git://git.denx.de/u-boot-dm.git tags/dm-pull-18mar22
for you to fetch changes up to 40c8bdd87e3baa44314720d0d51d90c41e633ca3:
binman: Support splitting an ELF file into multiple nodes (2022-03-18 19:24:25 -0600)
---------------------------------------------------------------- binman FIT improvements various minor sandbox improvements
---------------------------------------------------------------- Jan Kiszka (1): binman: Include also subnodes in generator nodes
Philippe Reynes (1): tools: binman: main.py: add build-sandbox in sys.path
Simon Glass (28): binman: Complete elf test coverage sandbox: Show a message when writing out the ram buffer sandbox: Add the handoff header for spl sandbox: Open host file for read-only access if needed sandbox: Slow down the LCD sync rate sandbox: test: Tidy up spl_test_load() calls patman: Define Commit.path in the constructor dtoc: Make GetArgs() more flexible moveconfig: Remove remove_defconfig() moveconfig: Use re.fullmatch() to avoid extra check spl: Correct Kconfig help for TPL_BINMAN_SYMBOLS dtoc: Tidy up implementation of AddStringList() elf: Rename load_segments() and module failure binman: Tweak collect_contents_to_file() and docs binman: Rename ExpandToLimit to extend_to_limit binman: Rename ExpandEntries to gen_entries binman: Refactor fit to generate output at the end binman: Rename tools parameter to btools binman: Change how faked blobs are created binman: Make fake blobs zero-sized by default binman: Allow mkimage to use a non-zero fake-blob size binman: Read the fit entries only once binman: Update fit to move node reading into the ReadNode() method binman: Fix some pylint warnings in fit binman: Add a consistent way to report errors with fit binman: Update fit to use node instead of subnode binman: Keep a separate list of entries for fit binman: Support splitting an ELF file into multiple nodes
arch/sandbox/cpu/spl.c | 1 + arch/sandbox/cpu/state.c | 3 +- common/spl/Kconfig | 6 +- drivers/block/sandbox.c | 11 +- drivers/video/video-uclass.c | 2 +- test/image/spl_load.c | 6 +- tools/binman/binman.rst | 32 +- tools/binman/control.py | 2 +- tools/binman/elf.py | 10 +- tools/binman/elf_test.py | 66 +++- tools/binman/entries.rst | 146 ++++++++ tools/binman/entry.py | 51 +-- tools/binman/etype/_testing.py | 2 +- tools/binman/etype/blob.py | 10 +- tools/binman/etype/blob_ext_list.py | 2 +- tools/binman/etype/blob_phase.py | 2 +- tools/binman/etype/files.py | 2 +- tools/binman/etype/fit.py | 512 ++++++++++++++++++++------- tools/binman/etype/gbb.py | 4 +- tools/binman/etype/intel_ifwi.py | 4 +- tools/binman/etype/mkimage.py | 19 +- tools/binman/etype/section.py | 24 +- tools/binman/etype/vblock.py | 4 +- tools/binman/ftest.py | 209 +++++++++-- tools/binman/main.py | 1 + .../binman/test/{088_expand_size.dts => 088_extend_size.dts} | 8 +- .../{089_expand_size_bad.dts => 089_extend_size_bad.dts} | 2 +- .../test/{121_entry_expand.dts => 121_entry_extend.dts} | 0 ...122_entry_expand_twice.dts => 122_entry_extend_twice.dts} | 0 ...entry_expand_section.dts => 123_entry_extend_section.dts} | 0 tools/binman/test/170_fit_fdt.dts | 3 + tools/binman/test/224_fit_bad_oper.dts | 2 - tools/binman/test/225_expand_size_bad.dts | 10 + tools/binman/test/226_fit_split_elf.dts | 67 ++++ tools/binman/test/227_fit_bad_dir.dts | 9 + tools/binman/test/228_fit_bad_dir_config.dts | 9 + tools/binman/test/229_mkimage_missing.dts | 18 + tools/dtoc/fdt.py | 4 +- tools/dtoc/fdt_util.py | 12 +- tools/dtoc/test/dtoc_test_simple.dts | 2 + tools/dtoc/test_fdt.py | 14 +- tools/moveconfig.py | 16 +- tools/patman/commit.py | 2 + 43 files changed, 1051 insertions(+), 258 deletions(-) rename tools/binman/test/{088_expand_size.dts => 088_extend_size.dts} (88%) rename tools/binman/test/{089_expand_size_bad.dts => 089_extend_size_bad.dts} (90%) rename tools/binman/test/{121_entry_expand.dts => 121_entry_extend.dts} (100%) rename tools/binman/test/{122_entry_expand_twice.dts => 122_entry_extend_twice.dts} (100%) rename tools/binman/test/{123_entry_expand_section.dts => 123_entry_extend_section.dts} (100%) create mode 100644 tools/binman/test/225_expand_size_bad.dts create mode 100644 tools/binman/test/226_fit_split_elf.dts create mode 100644 tools/binman/test/227_fit_bad_dir.dts create mode 100644 tools/binman/test/228_fit_bad_dir_config.dts create mode 100644 tools/binman/test/229_mkimage_missing.dts
On Fri, Mar 18, 2022 at 09:46:04PM -0600, Simon Glass wrote:
Hi Tom,
