[U-Boot] [PATCH] 8xxx: Fix PCI bus address setup for 36-bit configs
We want the outbound PCI memory map to end at the 4G boundary so we can maximize the amount of space available for inbound mappings if we have large amounts of memory.
This matches the device tree setup in the kernel for the 36-bit physical configs for the platforms that have one (MPC8641 HPCN & MPC8572 DS).
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/MPC8572DS.h | 6 +++--- include/configs/MPC8641HPCN.h | 2 +- include/configs/P2020DS.h | 6 +++--- 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 2aba689..6f1b1a4 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -404,7 +404,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* controller 3, direct to uli, tgtid 3, Base address 8000 */ #define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE3_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc00000000ull #else #define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 @@ -423,7 +423,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* controller 2, Slot 2, tgtid 2, Base address 9000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull #else #define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 @@ -442,7 +442,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* controller 1, Slot 1, tgtid 1, Base address a000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc40000000ull #else #define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index d8042fb..035874b 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -335,7 +335,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_SYS_PCI1_MEM_VIRT 0x80000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCI1_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCI1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCI1_MEM_PHYS 0x0000000c00000000ULL #else #define CONFIG_SYS_PCI1_MEM_BUS CONFIG_SYS_PCI1_MEM_VIRT diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index a39ff26..84b5686 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -437,7 +437,7 @@ extern unsigned long calculate_board_ddr_clk(unsigned long dummy); /* controller 3, Slot 1, tgtid 3, Base address b000 */ #define CONFIG_SYS_PCIE3_MEM_VIRT 0x80000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE3_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc00000000ull #else #define CONFIG_SYS_PCIE3_MEM_BUS 0x80000000 @@ -456,7 +456,7 @@ extern unsigned long calculate_board_ddr_clk(unsigned long dummy); /* controller 2, direct to uli, tgtid 2, Base address 9000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull #else #define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 @@ -475,7 +475,7 @@ extern unsigned long calculate_board_ddr_clk(unsigned long dummy); /* controller 1, Slot 2, tgtid 1, Base address a000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0xc0000000 #ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc40000000ull #else #define CONFIG_SYS_PCIE1_MEM_BUS 0xc0000000
Kumar Gala
