[U-Boot] [PATCH v2 2/2] pci: Disable expansion ROM address decoding when signature check fails
We should not leave the expansion ROM address window open when there is not a valid ROM.
Suggested-by: Matt Porter mporter@konsulko.com Signed-off-by: Bin Meng bmeng.cn@gmail.com
--- I did not update pci_rom_probe() to handle the header type1 ROM address, as I think pci_rom_probe() is a static routine which is only used for VGA ROM only so far, so we don't need consider type1 case.
Changes in v2: - New patch to disable expansion ROM address decoding when signature check fails
drivers/pci/pci_rom.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index f364799..e6f4806 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -103,6 +103,10 @@ static int pci_rom_probe(pci_dev_t dev, uint class, if (le16_to_cpu(rom_header->signature) != PCI_ROM_HDR) { printf("Incorrect expansion ROM header signature %04x\n", le16_to_cpu(rom_header->signature)); +#ifndef CONFIG_X86_OPTION_ROM_ADDR + /* Disable expansion ROM address decoding */ + pci_write_config_dword(dev, PCI_ROM_ADDRESS, rom_address); +#endif return -EINVAL; }
Bin Meng
