[U-Boot] [PATCH] fsl_ifc:Fixed a bug in the erratum handling code for IFC_A003399
Wrong pointer was being used to copy code into L2SRAM. Also removed the unreferenced variable l2srbar. Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- Thanks Wolfgang and Kumar for identifying the issue. arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c index 4ef3c9a..091af7c 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_early.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_early.c @@ -71,7 +71,7 @@ void cpu_init_early_f(void) #endif #if defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) && !defined(CONFIG_SYS_RAMBOOT) ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR; - u32 *l2srbar, *dst, *src; + u32 *dst, *src; void (*setup_ifc_sram)(void); #endif
@@ -137,7 +137,7 @@ void cpu_init_early_f(void) dst = (u32 *) SRAM_BASE_ADDR; src = (u32 *) setup_ifc; for (i = 0; i < 1024; i++) - *l2srbar++ = *src++; + *dst++ = *src++;
setup_ifc_sram();
applied to 85xx
- k
Kumar Gala
Poonam Aggrwal
