[U-Boot] [PATCH v3] at91: Update MEESC board support
This patch implements several updates: -disable CONFIG_ENV_OVERWRITE -add new hardware style variants and set the arch numbers appropriate (autodet.) -pass the serial# and hardware revision to the kernel -removed unused macros from include/configs/meesc.h
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu --- v2: - don't write the ethernet address to the EMAC module anymore
v3: - removed function meesc_set_arch_number and moved code to checkboard() - reworked function get_board_serial() - removed unused macros from include/configs/meesc.h
board/esd/meesc/meesc.c | 62 +++++++++++++++++++++++++++++++++++++++++++---- include/configs/meesc.h | 25 ++++++------------- 2 files changed, 65 insertions(+), 22 deletions(-)
diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c index 636d0ed..045fbe2 100644 --- a/board/esd/meesc/meesc.c +++ b/board/esd/meesc/meesc.c @@ -156,8 +156,35 @@ int board_eth_init(bd_t *bis) int checkboard(void) { char str[32]; - - puts("Board: esd CAN-EtherCAT Gateway"); + u_char hw_type; /* hardware type */ + + /* read the "Type" register of the ET1100 controller */ + hw_type = readb(CONFIG_ET1100_BASE); + + switch (hw_type) { + case 0x11: + case 0x3F: + /* ET1100 present, + arch number of MEESC-Board */ + gd->bd->bi_arch_number = MACH_TYPE_MEESC; + puts("Board: CAN-EtherCAT Gateway"); + break; + case 0xFF: + /* no ET1100 present, + arch number of EtherCAN/2-Board */ + gd->bd->bi_arch_number = MACH_TYPE_ETHERCAN2; + puts("Board: EtherCAN/2 Gateway"); + /* switch on LED1D */ + at91_set_gpio_output(AT91_PIN_PB12, 1); + break; + default: + /* assume, no ET1100 present, + arch number of EtherCAN/2-Board */ + gd->bd->bi_arch_number = MACH_TYPE_ETHERCAN2; + printf("FATAL! Read invalid hw_type: %02X\n", hw_type); + puts("Board: EtherCAN/2 Gateway"); + break; + } if (getenv_r("serial#", str, sizeof(str)) > 0) { puts(", serial# "); puts(str); @@ -167,6 +194,32 @@ int checkboard(void) return 0; }
+#ifdef CONFIG_SERIAL_TAG +void get_board_serial(struct tag_serialnr *serialnr) +{ + char *str; + + char *serial = getenv("serial#"); + if (serial) { + str = strchr(serial, '_'); + if (str && (strlen(str) >= 4)) { + serialnr->high = (*(str + 1) << 8) | *(str + 2); + serialnr->low = simple_strtoul(str + 3, NULL, 16); + } + } else { + serialnr->high = 0; + serialnr->low = 0; + } +} +#endif + +#ifdef CONFIG_REVISION_TAG +u32 get_board_rev(void) +{ + return hw_rev | 0x100; +} +#endif + int board_init(void) { /* Peripheral Clock Enable Register */ @@ -174,8 +227,8 @@ int board_init(void) 1 << AT91SAM9263_ID_PIOB | 1 << AT91SAM9263_ID_PIOCDE);
- /* arch number of MEESC-Board */ - gd->bd->bi_arch_number = MACH_TYPE_MEESC; + /* initialize ET1100 Controller */ + meesc_ethercat_hw_init();
/* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; @@ -184,7 +237,6 @@ int board_init(void) #ifdef CONFIG_CMD_NAND meesc_nand_hw_init(); #endif - meesc_ethercat_hw_init(); #ifdef CONFIG_HAS_DATAFLASH at91_spi0_hw_init(1 << 0); #endif diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 8253172..b996854 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -36,13 +36,14 @@ #define CONFIG_MEESC 1 /* Board is esd MEESC */ #define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ #define CONFIG_AT91SAM9263 1 /* It's an AT91SAM9263 SoC */ -#define CONFIG_ENV_OVERWRITE 1 /* necessary on prototypes */ #define CONFIG_DISPLAY_BOARDINFO 1 #define CONFIG_DISPLAY_CPUINFO 1 /* display cpu info and speed */ #define CONFIG_PREBOOT /* enable preboot variable */ #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1 +#define CONFIG_SERIAL_TAG 1 +#define CONFIG_REVISION_TAG 1 #undef CONFIG_USE_IRQ /* don't need IRQ/FIQ stuff */
#define CONFIG_SKIP_LOWLEVEL_INIT @@ -138,12 +139,13 @@ #define CONFIG_SYS_USE_DATAFLASH 1 #undef CONFIG_SYS_USE_NANDFLASH
-#ifdef CONFIG_SYS_USE_DATAFLASH - /* CAN */ #define CONFIG_AT91_CAN 1
-/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +/* hw-controller addresses */ +#define CONFIG_ET1100_BASE 0x70000000 + +/* bootstrap + u-boot + env in dataflash on CS0 */ #define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ 0x8400) @@ -151,18 +153,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b C0042000 22000000 210000; bootm" - -#else /* CONFIG_SYS_USE_NANDFLASH */ - -/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND 1 -#define CONFIG_ENV_OFFSET 0x60000 -#define CONFIG_ENV_OFFSET_REDUND 0x80000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ -#define CONFIG_BOOTCOMMAND "nand read 22000000 A0000 200000; bootm" - -#endif
#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } @@ -178,7 +168,8 @@ /* * Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN 0x2D000 +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + \ + 128*1024, 0x1000) #define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */
Dear Wolfgang Denk and Jean-Christophe PLAGNIOL-VILLARD,
<snip>
what about this patch? No more comments, no "NACK", no "applied to..."?
Best regards, Daniel Gorsulowski
Dear Daniel Gorsulowski,
As you might have noticed, Jean-Christophe just throw in the towel as AT91 (and PXA and IXP) custodian. Until we find a new one (volunteers welcome!) Tom will have to handles this - additionally to his other work. Please be a bit patient with him. You can usually just relax as long as there is no NAK :-)
<snip>
Daniel, Please resend or point me to the latest version of this patch. We will resolve this shortly. Thanks, Tom
Best regards, Daniel Gorsulowski _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
In message 12525916852655-git-send-email-Daniel.Gorsulowski@esd.eu you wrote:
LIne too long.
- u_char hw_type; /* hardware type */
- /* read the "Type" register of the ET1100 controller */
- hw_type = readb(CONFIG_ET1100_BASE);
- switch (hw_type) {
case 0x11:
case 0x3F:
Incorrect indentation - the "case" must have the same indent as the "switch". Please fix globally.
/* ET1100 present,
Incorrect multiline comment style. Please fix globally.
Daniel Gorsulowski
Tom
