[PATCH] xilinx: Introduce board_late_init_xilinx()
This function should keep common shared late configurations for Xilinx SoCs.
board/xilinx/common/board.c | 8 ++++++++ board/xilinx/common/board.h | 12 ++++++++++++ board/xilinx/versal/board.c | 5 ++--- board/xilinx/zynq/board.c | 5 ++--- board/xilinx/zynqmp/zynqmp.c | 5 ++--- 5 files changed, 26 insertions(+), 9 deletions(-) create mode 100644 board/xilinx/common/board.h
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index e83c692f2174..7c191e53fb71 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -8,6 +8,7 @@ #include <asm/sections.h> #include <dm/uclass.h> #include <i2c.h> +#include "board.h"
int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) { @@ -71,3 +72,10 @@ void *board_fdt_blob_setup(void) return NULL; } #endif + +int board_late_init_xilinx(void) +{ + env_set_hex("script_offset_f", CONFIG_BOOT_SCRIPT_OFFSET); + + return 0; +} diff --git a/board/xilinx/common/board.h b/board/xilinx/common/board.h new file mode 100644 index 000000000000..180dfbca1082 --- /dev/null +++ b/board/xilinx/common/board.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * (C) Copyright 2020 Xilinx, Inc. + * Michal Simek michal.simek@xilinx.com + */ + +#ifndef _BOARD_XILINX_COMMON_BOARD_H +#define _BOARD_XILINX_COMMON_BOARD_H + +int board_late_init_xilinx(void); + +#endif /* BOARD_XILINX_COMMON_BOARD_H */ diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 75aedb092922..908ea87163f8 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -17,6 +17,7 @@ #include <dm/uclass.h> #include <versalpl.h> #include <linux/sizes.h> +#include "../common/board.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -204,9 +205,7 @@ int board_late_init(void) initrd_hi = round_down(initrd_hi, SZ_16M); env_set_addr("initrd_high", (void *)initrd_hi);
- env_set_hex("script_offset_f", CONFIG_BOOT_SCRIPT_OFFSET); - - return 0; + return board_late_init_xilinx(); }
int dram_init_banksize(void) diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 420a5ca66311..2164eac8d518 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -17,6 +17,7 @@ #include <zynqpl.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> +#include "../common/board.h"
@@ -76,9 +77,7 @@ int board_late_init(void)
env_set("boot_targets", new_targets);
#if !defined(CONFIG_SYS_SDRAM_BASE) && !defined(CONFIG_SYS_SDRAM_SIZE) diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 3c92b1a5825f..b2172356ad0a 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -27,6 +27,7 @@ #include <zynqmp_firmware.h> #include <g_dnl.h> #include <linux/sizes.h> +#include "../common/board.h"
#include "pm_cfg_obj.h"
@@ -695,11 +696,9 @@ int board_late_init(void) initrd_hi = round_down(initrd_hi, SZ_16M); env_set_addr("initrd_high", (void *)initrd_hi);
- env_set_hex("script_offset_f", CONFIG_BOOT_SCRIPT_OFFSET); - reset_reason();
- return 0; + return board_late_init_xilinx(); } #endif
st 8. 4. 2020 v 10:50 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
- (C) Copyright 2020 Xilinx, Inc.
- Michal Simek michal.simek@xilinx.com
reset_reason();
} #endif
-- 2.26.0
Applied but also fix antminer and topic Makefiles.
Thanks, Michal
Michal Simek
Michal Simek
