[U-Boot] [PATCH 1/1] doc: Cope with Sphinx logging deprecations
Recent versions of sphinx will emit messages like:
doc/sphinx/kerneldoc.py:103: RemovedInSphinx20Warning: app.warning() is now deprecated. Use sphinx.util.logging instead.
Switch to sphinx.util.logging to make this unsightly message go away. Alas, that interface was only added in version 1.6, so we have to add a version check to keep things working with older sphinxes.
Signed-off-by: Jonathan Corbet corbet@lwn.net Rebased for U-Boot Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/sphinx/kerneldoc.py | 12 ++++++++---- doc/sphinx/kernellog.py | 28 ++++++++++++++++++++++++++++ doc/sphinx/kfigure.py | 40 +++++++++++++++++++++++----------------- 3 files changed, 59 insertions(+), 21 deletions(-) create mode 100644 doc/sphinx/kernellog.py
diff --git a/doc/sphinx/kerneldoc.py b/doc/sphinx/kerneldoc.py index fbedcc3946..e536360de1 100644 --- a/doc/sphinx/kerneldoc.py +++ b/doc/sphinx/kerneldoc.py @@ -39,6 +39,8 @@ from docutils.statemachine import ViewList from docutils.parsers.rst import directives, Directive from sphinx.ext.autodoc import AutodocReporter
+import kernellog + __version__ = '1.0'
class KernelDocDirective(Directive): @@ -86,7 +88,8 @@ class KernelDocDirective(Directive): cmd += [filename]
try: - env.app.verbose('calling kernel-doc '%s'' % (" ".join(cmd))) + kernellog.verbose(env.app, + 'calling kernel-doc '%s'' % (" ".join(cmd)))
p = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE) out, err = p.communicate() @@ -96,7 +99,8 @@ class KernelDocDirective(Directive): if p.returncode != 0: sys.stderr.write(err)
- env.app.warn('kernel-doc '%s' failed with return code %d' % (" ".join(cmd), p.returncode)) + kernellog.warn(env.app, + 'kernel-doc '%s' failed with return code %d' % (" ".join(cmd), p.returncode)) return [nodes.error(None, nodes.paragraph(text = "kernel-doc missing"))] elif env.config.kerneldoc_verbosity > 0: sys.stderr.write(err) @@ -128,8 +132,8 @@ class KernelDocDirective(Directive): return node.children
except Exception as e: # pylint: disable=W0703 - env.app.warn('kernel-doc '%s' processing failed with: %s' % - (" ".join(cmd), str(e))) + kernellog.warn(env.app, 'kernel-doc '%s' processing failed with: %s' % + (" ".join(cmd), str(e))) return [nodes.error(None, nodes.paragraph(text = "kernel-doc missing"))]
def setup(app): diff --git a/doc/sphinx/kernellog.py b/doc/sphinx/kernellog.py new file mode 100644 index 0000000000..af924f51a7 --- /dev/null +++ b/doc/sphinx/kernellog.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Sphinx has deprecated its older logging interface, but the replacement +# only goes back to 1.6. So here's a wrapper layer to keep around for +# as long as we support 1.4. +# +import sphinx + +if sphinx.__version__[:3] >= '1.6': + UseLogging = True + from sphinx.util import logging + logger = logging.getLogger('kerneldoc') +else: + UseLogging = False + +def warn(app, message): + if UseLogging: + logger.warning(message) + else: + app.warn(message) + +def verbose(app, message): + if UseLogging: + logger.verbose(message) + else: + app.verbose(message) + + diff --git a/doc/sphinx/kfigure.py b/doc/sphinx/kfigure.py index b97228d2cc..fbfe6693bb 100644 --- a/doc/sphinx/kfigure.py +++ b/doc/sphinx/kfigure.py @@ -60,6 +60,8 @@ import sphinx from sphinx.util.nodes import clean_astext from six import iteritems
+import kernellog + PY3 = sys.version_info[0] == 3
if PY3: @@ -171,20 +173,20 @@ def setupTools(app): This function is called once, when the builder is initiated. """ global dot_cmd, convert_cmd # pylint: disable=W0603 - app.verbose("kfigure: check installed tools ...") + kernellog.verbose(app, "kfigure: check installed tools ...")
dot_cmd = which('dot') convert_cmd = which('convert')
if dot_cmd: - app.verbose("use dot(1) from: " + dot_cmd) + kernellog.verbose(app, "use dot(1) from: " + dot_cmd) else: - app.warn("dot(1) not found, for better output quality install " - "graphviz from http://www.graphviz.org") + kernellog.warn(app, "dot(1) not found, for better output quality install " + "graphviz from http://www.graphviz.org") if convert_cmd: - app.verbose("use convert(1) from: " + convert_cmd) + kernellog.verbose(app, "use convert(1) from: " + convert_cmd) else: - app.warn( + kernellog.warn(app, "convert(1) not found, for SVG to PDF conversion install " "ImageMagick (https://www.imagemagick.org)")
@@ -220,12 +222,13 @@ def convert_image(img_node, translator, src_fname=None):
# in kernel builds, use 'make SPHINXOPTS=-v' to see verbose messages
- app.verbose('assert best format for: ' + img_node['uri']) + kernellog.verbose(app, 'assert best format for: ' + img_node['uri'])
if in_ext == '.dot':
if not dot_cmd: - app.verbose("dot from graphviz not available / include DOT raw.") + kernellog.verbose(app, + "dot from graphviz not available / include DOT raw.") img_node.replace_self(file2literal(src_fname))
elif translator.builder.format == 'latex': @@ -252,7 +255,8 @@ def convert_image(img_node, translator, src_fname=None):
if translator.builder.format == 'latex': if convert_cmd is None: - app.verbose("no SVG to PDF conversion available / include SVG raw.") + kernellog.verbose(app, + "no SVG to PDF conversion available / include SVG raw.") img_node.replace_self(file2literal(src_fname)) else: dst_fname = path.join(translator.builder.outdir, fname + '.pdf') @@ -265,18 +269,19 @@ def convert_image(img_node, translator, src_fname=None): _name = dst_fname[len(translator.builder.outdir) + 1:]
if isNewer(dst_fname, src_fname): - app.verbose("convert: {out}/%s already exists and is newer" % _name) + kernellog.verbose(app, + "convert: {out}/%s already exists and is newer" % _name)
else: ok = False mkdir(path.dirname(dst_fname))
if in_ext == '.dot': - app.verbose('convert DOT to: {out}/' + _name) + kernellog.verbose(app, 'convert DOT to: {out}/' + _name) ok = dot2format(app, src_fname, dst_fname)
elif in_ext == '.svg': - app.verbose('convert SVG to: {out}/' + _name) + kernellog.verbose(app, 'convert SVG to: {out}/' + _name) ok = svg2pdf(app, src_fname, dst_fname)
if not ok: @@ -305,7 +310,8 @@ def dot2format(app, dot_fname, out_fname): with open(out_fname, "w") as out: exit_code = subprocess.call(cmd, stdout = out) if exit_code != 0: - app.warn("Error #%d when calling: %s" % (exit_code, " ".join(cmd))) + kernellog.warn(app, + "Error #%d when calling: %s" % (exit_code, " ".join(cmd))) return bool(exit_code == 0)
def svg2pdf(app, svg_fname, pdf_fname): @@ -322,7 +328,7 @@ def svg2pdf(app, svg_fname, pdf_fname): # use stdout and stderr from parent exit_code = subprocess.call(cmd) if exit_code != 0: - app.warn("Error #%d when calling: %s" % (exit_code, " ".join(cmd))) + kernellog.warn(app, "Error #%d when calling: %s" % (exit_code, " ".join(cmd))) return bool(exit_code == 0)
@@ -415,15 +421,15 @@ def visit_kernel_render(self, node): app = self.builder.app srclang = node.get('srclang')
- app.verbose('visit kernel-render node lang: "%s"' % (srclang)) + kernellog.verbose(app, 'visit kernel-render node lang: "%s"' % (srclang))
tmp_ext = RENDER_MARKUP_EXT.get(srclang, None) if tmp_ext is None: - app.warn('kernel-render: "%s" unknown / include raw.' % (srclang)) + kernellog.warn(app, 'kernel-render: "%s" unknown / include raw.' % (srclang)) return
if not dot_cmd and tmp_ext == '.dot': - app.verbose("dot from graphviz not available / include raw.") + kernellog.verbose(app, "dot from graphviz not available / include raw.") return
literal_block = node[0] -- 2.20.1
