[U-Boot] [PATCH 2/2] fsl-ddr: add the DDR3 SPD infrastructure
- support mirrored DIMMs, not support register DIMMs - test passed on P2020DS board with MT9JSF12872AY-1G1D1 - test passed on MPC8569MDS board with MT8JSF12864HY-1G1D1
Signed-off-by: Dave Liu daveliu@freescale.com Signed-off-by: Travis Wheatley travis.wheatley@freescale.com --- common/ddr_spd.c | 53 +++++ cpu/mpc85xx/ddr-gen3.c | 6 +- cpu/mpc8xxx/ddr/Makefile | 4 + cpu/mpc8xxx/ddr/ctrl_regs.c | 380 ++++++++++++++++++++++++++++--- cpu/mpc8xxx/ddr/ddr3_dimm_params.c | 314 +++++++++++++++++++++++++ cpu/mpc8xxx/ddr/lc_common_dimm_params.c | 74 ++++++- cpu/mpc8xxx/ddr/options.c | 28 ++- include/asm-ppc/fsl_ddr_dimm_params.h | 7 + include/asm-ppc/fsl_ddr_sdram.h | 31 +++- include/ddr_spd.h | 13 +- 10 files changed, 860 insertions(+), 50 deletions(-) create mode 100644 cpu/mpc8xxx/ddr/ddr3_dimm_params.c
diff --git a/common/ddr_spd.c b/common/ddr_spd.c index 78e3c5d..c058e4f 100644 --- a/common/ddr_spd.c +++ b/common/ddr_spd.c @@ -59,3 +59,56 @@ ddr2_spd_check(const ddr2_spd_eeprom_t *spd)
return spd_check(p, spd->spd_rev, spd->cksum); } + +/* + * CRC16 compute for DDR3 SPD + * Copied from DDR3 SPD spec. + */ +static int +crc16(char *ptr, int count) +{ + int crc, i; + + crc = 0; + while (--count >= 0) { + crc = crc ^ (int)*ptr++ << 8; + for (i = 0; i < 8; ++i) + if (crc & 0x8000) + crc = crc << 1 ^ 0x1021; + else + crc = crc << 1; + } + return crc & 0xffff; +} + +unsigned int +ddr3_spd_check(const ddr3_spd_eeprom_t *spd) +{ + char *p = (char *)spd; + int csum16; + int len; + char crc_lsb; /* byte 126 */ + char crc_msb; /* byte 127 */ + + /* + * SPD byte0[7] - CRC coverage + * 0 = CRC covers bytes 0~125 + * 1 = CRC covers bytes 0~116 + */ + + len = !(spd->info_size_crc & 0x80) ? 126 : 117; + csum16 = crc16(p, len); + + crc_lsb = (char) (csum16 & 0xff); + crc_msb = (char) (csum16 >> 8); + + if (spd->crc[0] == crc_lsb && spd->crc[1] == crc_msb) { + return 0; + } else { + printf("SPD checksum unexpected.\n" + "Checksum lsb in SPD = %02X, computed SPD = %02X\n" + "Checksum msb in SPD = %02X, computed SPD = %02X\n", + spd->crc[0], crc_lsb, spd->crc[1], crc_msb); + return 1; + } +} diff --git a/cpu/mpc85xx/ddr-gen3.c b/cpu/mpc85xx/ddr-gen3.c index 99c325a..8ac3d5f 100644 --- a/cpu/mpc85xx/ddr-gen3.c +++ b/cpu/mpc85xx/ddr-gen3.c @@ -98,10 +98,12 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, #endif
/* - * 200 painful micro-seconds must elapse between + * 500 painful micro-seconds must elapse between * the DDR clock setup and the DDR config enable. + * DDR2 need 200 us, and DDR3 need 500 us from spec, + * we choose the max, that is 500 us for all of case. */ - udelay(200); + udelay(500); asm volatile("sync;isync");
/* Let the controller go */ diff --git a/cpu/mpc8xxx/ddr/Makefile b/cpu/mpc8xxx/ddr/Makefile index b7f8d8c..cb7f856 100644 --- a/cpu/mpc8xxx/ddr/Makefile +++ b/cpu/mpc8xxx/ddr/Makefile @@ -18,6 +18,10 @@ COBJS-$(CONFIG_FSL_DDR2) += main.o util.o ctrl_regs.o options.o \ lc_common_dimm_params.o COBJS-$(CONFIG_FSL_DDR2) += ddr2_dimm_params.o
+COBJS-$(CONFIG_FSL_DDR3) += main.o util.o ctrl_regs.o options.o \ + lc_common_dimm_params.o +COBJS-$(CONFIG_FSL_DDR3) += ddr3_dimm_params.o + SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y))
diff --git a/cpu/mpc8xxx/ddr/ctrl_regs.c b/cpu/mpc8xxx/ddr/ctrl_regs.c index 4c1498c..490e3dc 100644 --- a/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -23,11 +23,18 @@ extern unsigned int picos_to_mclk(unsigned int picos); * * This should likely be either board or controller specific. * - * Rtt(nominal): + * Rtt(nominal) - DDR2: * 0 = Rtt disabled * 1 = 75 ohm * 2 = 150 ohm * 3 = 50 ohm + * Rtt(nominal) - DDR3: + * 0 = Rtt disabled + * 1 = 60 ohm + * 2 = 120 ohm + * 3 = 40 ohm + * 4 = 20 ohm + * 5 = 30 ohm * * FIXME: Apparently 8641 needs a value of 2 * FIXME: Old code seys if 667 MHz or higher, use 3 on 8572 @@ -53,12 +60,37 @@ static inline int fsl_ddr_get_rtt(void) #elif defined(CONFIG_FSL_DDR2) rtt = 3; #else -#error "Need Rtt value for DDR3" + rtt = 0; #endif
return rtt; }
+/* + * compute the CAS write latency according to DDR3 spec + * CWL = 5 if tCK >= 2.5ns + * 6 if 2.5ns > tCK >= 1.875ns + * 7 if 1.875ns > tCK >= 1.5ns + * 8 if 1.5ns > tCK >= 1.25ns + */ +static inline unsigned int compute_cas_write_latency(void) +{ + unsigned int cwl; + const unsigned int mclk_ps = get_memory_clk_period_ps(); + + if (mclk_ps >= 2500) + cwl = 5; + else if (mclk_ps >= 1875) + cwl = 6; + else if (mclk_ps >= 1500) + cwl = 7; + else if (mclk_ps >= 1250) + cwl = 8; + else + cwl = 8; + return cwl; +} + /* Chip Select Configuration (CSn_CONFIG) */ static void set_csn_config(int i, fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, @@ -126,7 +158,7 @@ static void set_csn_config_2(int i, fsl_ddr_cfg_regs_t *ddr)
/* -3E = 667 CL5, -25 = CL6 800, -25E = CL5 800 */
-#if defined(CONFIG_FSL_DDR2) +#if !defined(CONFIG_FSL_DDR1) /* * DDR SDRAM Timing Configuration 0 (TIMING_CFG_0) * @@ -150,16 +182,32 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr) /* Mode register set cycle time (tMRD). */ unsigned char tmrd_mclk;
- /* (tXARD and tXARDS). Empirical? */ - act_pd_exit_mclk = 2; - - /* XXX: tXARD = 2, tXARDS = 7 - AL. * Empirical? */ +#if defined(CONFIG_FSL_DDR3) + /* + * (tXARD and tXARDS). Empirical? + * The DDR3 spec has not tXARD, + * we use the tXP instead of it. + * tXP=max(3nCK, 7.5ns) for DDR3. + * we use the tXP=6 + * spec has not the tAXPD, we use + * tAXPD=8, need design to confirm. + */ + act_pd_exit_mclk = 6; pre_pd_exit_mclk = 6; - - /* FIXME: tXP = 2 on Micron 667 MHz DIMM */ taxpd_mclk = 8; - + tmrd_mclk = 4; +#else /* CONFIG_FSL_DDR2 */ + /* + * (tXARD and tXARDS). Empirical? + * tXARD = 2 for DDR2 + * tXP=2 + * tAXPD=8 + */ + act_pd_exit_mclk = 2; + pre_pd_exit_mclk = 2; + taxpd_mclk = 8; tmrd_mclk = 2; +#endif
ddr->timing_cfg_0 = (0 | ((trwt_mclk & 0x3) << 30) /* RWT */ @@ -177,7 +225,8 @@ static void set_timing_cfg_0(fsl_ddr_cfg_regs_t *ddr)
/* DDR SDRAM Timing Configuration 3 (TIMING_CFG_3) */ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, - const common_timing_params_t *common_dimm) + const common_timing_params_t *common_dimm, + unsigned int cas_latency) { /* Extended Activate to precharge interval (tRAS) */ unsigned int ext_acttopre = 0; @@ -190,6 +239,11 @@ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr, ext_acttopre = 1;
ext_refrec = (picos_to_mclk(common_dimm->tRFC_ps) - 8) >> 4; + + /* If the CAS latency more than 8, use the ext mode */ + if (cas_latency > 8) + ext_caslat = 1; + ddr->timing_cfg_3 = (0 | ((ext_acttopre & 0x1) << 24) | ((ext_refrec & 0xF) << 16) @@ -201,6 +255,7 @@ static void set_timing_cfg_3(fsl_ddr_cfg_regs_t *ddr,
/* DDR SDRAM Timing Configuration 1 (TIMING_CFG_1) */ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, const common_timing_params_t *common_dimm, unsigned int cas_latency) { @@ -246,13 +301,42 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, #elif defined(CONFIG_FSL_DDR2) caslat_ctrl = 2 * cas_latency - 1; #else -#error "Need CAS Latency help for DDR3 in fsl_ddr_sdram.c" + /* + * if the CAS latency more than 8 cycle, + * we need set extend bit for it at + * TIMING_CFG_3[EXT_CASLAT] + */ + if (cas_latency > 8) + cas_latency -= 8; + caslat_ctrl = 2 * cas_latency - 1; #endif
refrec_ctrl = picos_to_mclk(common_dimm->tRFC_ps) - 8; wrrec_mclk = picos_to_mclk(common_dimm->tWR_ps); + if (popts->OTF_burst_chop_en) + wrrec_mclk += 2; + acttoact_mclk = picos_to_mclk(common_dimm->tRRD_ps); + /* + * JEDEC has min requirement for tRRD + */ +#if defined(CONFIG_FSL_DDR3) + if (acttoact_mclk < 4) + acttoact_mclk = 4; +#endif wrtord_mclk = picos_to_mclk(common_dimm->tWTR_ps); + /* + * JEDEC has some min requirements for tWTR + */ +#if defined(CONFIG_FSL_DDR2) + if (wrtord_mclk < 2) + wrtord_mclk = 2; +#elif defined(CONFIG_FSL_DDR3) + if (wrtord_mclk < 4) + wrtord_mclk = 4; +#endif + if (popts->OTF_burst_chop_en) + wrtord_mclk += 2;
ddr->timing_cfg_1 = (0 | ((pretoact_mclk & 0x0F) << 28) @@ -304,13 +388,25 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, #elif defined(CONFIG_FSL_DDR2) wr_lat = cas_latency - 1; #else -#error "Fix WR_LAT for DDR3" + wr_lat = compute_cas_write_latency(); #endif
rd_to_pre = picos_to_mclk(common_dimm->tRTP_ps); + /* + * JEDEC has some min requirements for tRTP + */ #if defined(CONFIG_FSL_DDR2) - rd_to_pre += additive_latency; + if (rd_to_pre < 2) + rd_to_pre = 2; +#elif defined(CONFIG_FSL_DDR3) + if (rd_to_pre < 4) + rd_to_pre = 4; #endif + if (additive_latency) + rd_to_pre += additive_latency; + if (popts->OTF_burst_chop_en) + rd_to_pre += 2; /* according to UM */ + wr_data_delay = popts->write_data_delay; cke_pls = picos_to_mclk(popts->tCKE_clock_pulse_width_ps); four_act = picos_to_mclk(popts->tFAW_window_four_activates_ps); @@ -319,8 +415,8 @@ static void set_timing_cfg_2(fsl_ddr_cfg_regs_t *ddr, | ((add_lat_mclk & 0xf) << 28) | ((cpo & 0x1f) << 23) | ((wr_lat & 0xf) << 19) - | ((rd_to_pre & 0x7) << 13) - | ((wr_data_delay & 0x7) << 10) + | ((rd_to_pre & RD_TO_PRE_MASK) << RD_TO_PRE_SHIFT) + | ((wr_data_delay & WR_DATA_DELAY_MASK) << WR_DATA_DELAY_SHIFT) | ((cke_pls & 0x7) << 6) | ((four_act & 0x3f) << 0) ); @@ -366,9 +462,19 @@ static void set_ddr_sdram_cfg(fsl_ddr_cfg_regs_t *ddr,
dyn_pwr = popts->dynamic_power; dbw = popts->data_bus_width; - /* DDR3 must use 8-beat bursts when using 32-bit bus mode */ - if ((sdram_type == SDRAM_TYPE_DDR3) && (dbw == 0x1)) - eight_be = 1; + /* 8-beat burst enable DDR-III case + * we must clear it when use the on-the-fly mode, + * must set it when use the 32-bits bus mode. + */ + if (sdram_type == SDRAM_TYPE_DDR3) { + if (popts->burst_length == DDR_BL8) + eight_be = 1; + if (popts->burst_length == DDR_OTF) + eight_be = 0; + if (dbw == 0x1) + eight_be = 1; + } + threeT_en = popts->threeT_en; twoT_en = popts->twoT_en; ba_intlv_ctl = popts->ba_intlv_ctl; @@ -431,8 +537,12 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, * * ({EXT_REFREC || REFREC} + 8 + 2)]} * << DDR_SDRAM_INTERVAL[REFINT] */ +#if defined(CONFIG_FSL_DDR3) + obc_cfg = popts->OTF_burst_chop_en; +#else + obc_cfg = 0; +#endif
- obc_cfg = 0; /* Make this configurable? */ ap_en = 0; /* Make this configurable? */
#if defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) @@ -445,6 +555,9 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, d_init = 0; #endif
+#if defined(CONFIG_FSL_DDR3) + md_en = popts->mirrored_dimm; +#endif ddr->ddr_sdram_cfg_2 = (0 | ((frc_sr & 0x1) << 31) | ((sr_ie & 0x1) << 30) @@ -467,6 +580,20 @@ static void set_ddr_sdram_mode_2(fsl_ddr_cfg_regs_t *ddr) unsigned short esdmode2 = 0; /* Extended SDRAM mode 2 */ unsigned short esdmode3 = 0; /* Extended SDRAM mode 3 */
+#if defined(CONFIG_FSL_DDR3) + unsigned int rtt_wr = 2; /* 120 ohm Rtt_WR */ + unsigned int srt = 0; /* self-refresh temerature, normal range */ + unsigned int asr = 0; /* auto self-refresh disable */ + unsigned int cwl = compute_cas_write_latency() - 5; + unsigned int pasr = 0; /* partial array self refresh disable */ + + esdmode2 = (0 + | ((rtt_wr & 0x3) << 9) + | ((srt & 0x1) << 7) + | ((asr & 0x1) << 6) + | ((cwl & 0x7) << 3) + | ((pasr & 0x7) << 0)); +#endif ddr->ddr_sdram_mode_2 = (0 | ((esdmode2 & 0xFFFF) << 16) | ((esdmode3 & 0xFFFF) << 0) @@ -494,6 +621,139 @@ static void set_ddr_sdram_interval(fsl_ddr_cfg_regs_t *ddr, debug("FSLDDR: ddr_sdram_interval = 0x%08x\n", ddr->ddr_sdram_interval); }
+#if defined(CONFIG_FSL_DDR3) +/* DDR SDRAM Mode configuration set (DDR_SDRAM_MODE) */ +static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, + const memctl_options_t *popts, + const common_timing_params_t *common_dimm, + unsigned int cas_latency, + unsigned int additive_latency) +{ + unsigned short esdmode; /* Extended SDRAM mode */ + unsigned short sdmode; /* SDRAM mode */ + + /* Mode Register - MR1 */ + unsigned int qoff = 0; /* Output buffer enable 0=yes, 1=no */ + unsigned int tdqs_en = 0; /* TDQS Enable: 0=no, 1=yes */ + unsigned int rtt; + unsigned int wrlvl_en = 0; /* Write level enable: 0=no, 1=yes */ + unsigned int al = 0; /* Posted CAS# additive latency (AL) */ + unsigned int dic = 1; /* Output driver impedance, 34ohm */ + unsigned int dll_en = 0; /* DLL Enable 0=Enable (Normal), + 1=Disable (Test/Debug) */ + + /* Mode Register - MR0 */ + unsigned int dll_on; /* DLL control for precharge PD, 0=off, 1=on */ + unsigned int wr; /* Write Recovery */ + unsigned int dll_rst; /* DLL Reset */ + unsigned int mode; /* Normal=0 or Test=1 */ + unsigned int caslat = 4;/* CAS# latency, default set as 6 cycles */ + /* BT: Burst Type (0=Nibble Sequential, 1=Interleaved) */ + unsigned int bt; + unsigned int bl; /* BL: Burst Length */ + + unsigned int wr_mclk; + + const unsigned int mclk_ps = get_memory_clk_period_ps(); + + rtt = fsl_ddr_get_rtt(); + if (popts->rtt_override) + rtt = popts->rtt_override_value; + + if (additive_latency == (cas_latency - 1)) + al = 1; + if (additive_latency == (cas_latency - 2)) + al = 2; + + /* + * The esdmode value will also be used for writing + * MR1 during write leveling for DDR3, although the + * bits specifically related to the write leveling + * scheme will be handled automatically by the DDR + * controller. so we set the wrlvl_en = 0 here. + */ + esdmode = (0 + | ((qoff & 0x1) << 12) + | ((tdqs_en & 0x1) << 11) + | ((rtt & 0x4) << 9) /* rtt field is split */ + | ((wrlvl_en & 0x1) << 7) + | ((rtt & 0x2) << 6) /* rtt field is split */ + | ((dic & 0x2) << 5) /* DIC field is split */ + | ((al & 0x3) << 3) + | ((rtt & 0x1) << 2) /* rtt field is split */ + | ((dic & 0x1) << 1) /* DIC field is split */ + | ((dll_en & 0x1) << 0) + ); + + /* + * DLL control for precharge PD + * 0=slow exit DLL off (tXPDLL) + * 1=fast exit DLL on (tXP) + */ + dll_on = 1; + wr_mclk = (common_dimm->tWR_ps + mclk_ps - 1) / mclk_ps; + if (wr_mclk >= 12) + wr = 6; + else if (wr_mclk >= 9) + wr = 5; + else + wr = wr_mclk - 4; + dll_rst = 0; /* dll no reset */ + mode = 0; /* normal mode */ + + /* look up table to get the cas latency bits */ + if (cas_latency >= 5 && cas_latency <= 11) { + unsigned char cas_latency_table[7] = { + 0x2, /* 5 clocks */ + 0x4, /* 6 clocks */ + 0x6, /* 7 clocks */ + 0x8, /* 8 clocks */ + 0xa, /* 9 clocks */ + 0xc, /* 10 clocks */ + 0xe /* 11 clocks */ + }; + caslat = cas_latency_table[cas_latency - 5]; + } + bt = 0; /* Nibble sequential */ + + switch (popts->burst_length) { + case DDR_BL8: + bl = 0; + break; + case DDR_OTF: + bl = 1; + break; + case DDR_BC4: + bl = 2; + break; + default: + printf("Error: invalid burst length of %u specified. " + " Defaulting to on-the-fly BC4 or BL8 beats.\n", + popts->burst_length); + bl = 1; + break; + } + + sdmode = (0 + | ((dll_on & 0x1) << 12) + | ((wr & 0x7) << 9) + | ((dll_rst & 0x1) << 8) + | ((mode & 0x1) << 7) + | (((caslat >> 1) & 0x7) << 4) + | ((bt & 0x1) << 3) + | ((bl & 0x3) << 0) + ); + + ddr->ddr_sdram_mode = (0 + | ((esdmode & 0xFFFF) << 16) + | ((sdmode & 0xFFFF) << 0) + ); + + debug("FSLDDR: ddr_sdram_mode = 0x%08x\n", ddr->ddr_sdram_mode); +} + +#else /* !CONFIG_FSL_DDR3 */ + /* DDR SDRAM Mode configuration set (DDR_SDRAM_MODE) */ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, const memctl_options_t *popts, @@ -570,8 +830,6 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, wr = 0; /* Historical */ #elif defined(CONFIG_FSL_DDR2) wr = (common_dimm->tWR_ps + mclk_ps - 1) / mclk_ps - 1; -#else -#error "Write tWR_auto for DDR3" #endif dll_res = 0; mode = 0; @@ -590,16 +848,14 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, } #elif defined(CONFIG_FSL_DDR2) caslat = cas_latency; -#else -#error "Fix the mode CAS Latency for DDR3" #endif bt = 0;
switch (popts->burst_length) { - case 4: + case DDR_BL4: bl = 2; break; - case 8: + case DDR_BL8: bl = 3; break; default: @@ -627,7 +883,7 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, ); debug("FSLDDR: ddr_sdram_mode = 0x%08x\n", ddr->ddr_sdram_mode); } - +#endif
/* DDR SDRAM Data Initialization (DDR_DATA_INIT) */ static void set_ddr_data_init(fsl_ddr_cfg_regs_t *ddr) @@ -681,6 +937,12 @@ static void set_timing_cfg_4(fsl_ddr_cfg_regs_t *ddr) unsigned int wwt = 0; /* Write-to-write turnaround for same CS */ unsigned int dll_lock = 0; /* DDR SDRAM DLL Lock Time */
+#if defined(CONFIG_FSL_DDR3) + /* We need set BL/2 + 4 for BC4 or OTF */ + rrt = 4; /* BL/2 + 4 clocks */ + wwt = 4; /* BL/2 + 4 clocks */ + dll_lock = 1; /* tDLLK = 512 clocks from spec */ +#endif ddr->timing_cfg_4 = (0 | ((rwt & 0xf) << 28) | ((wrt & 0xf) << 24) @@ -699,6 +961,13 @@ static void set_timing_cfg_5(fsl_ddr_cfg_regs_t *ddr) unsigned int wodt_on = 0; /* Write to ODT on */ unsigned int wodt_off = 0; /* Write to ODT off */
+#if defined(CONFIG_FSL_DDR3) + rodt_on = 3; /* 2 clocks */ + rodt_off = 4; /* 4 clocks */ + wodt_on = 2; /* 1 clocks */ + wodt_off = 4; /* 4 clocks */ +#endif + ddr->timing_cfg_5 = (0 | ((rodt_on & 0x1f) << 24) | ((rodt_off & 0x7) << 20) @@ -709,15 +978,20 @@ static void set_timing_cfg_5(fsl_ddr_cfg_regs_t *ddr) }
/* DDR ZQ Calibration Control (DDR_ZQ_CNTL) */ -static void set_ddr_zq_cntl(fsl_ddr_cfg_regs_t *ddr) +static void set_ddr_zq_cntl(fsl_ddr_cfg_regs_t *ddr, unsigned int zq_en) { - unsigned int zq_en = 0; /* ZQ Calibration Enable */ unsigned int zqinit = 0;/* POR ZQ Calibration Time (tZQinit) */ /* Normal Operation Full Calibration Time (tZQoper) */ unsigned int zqoper = 0; /* Normal Operation Short Calibration Time (tZQCS) */ unsigned int zqcs = 0;
+ if (zq_en) { + zqinit = 9; /* 512 clocks */ + zqoper = 8; /* 256 clocks */ + zqcs = 6; /* 64 clocks */ + } + ddr->ddr_zq_cntl = (0 | ((zq_en & 0x1) << 31) | ((zqinit & 0xF) << 24) @@ -727,9 +1001,9 @@ static void set_ddr_zq_cntl(fsl_ddr_cfg_regs_t *ddr) }
/* DDR Write Leveling Control (DDR_WRLVL_CNTL) */ -static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr) +static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr, + unsigned int wrlvl_en) { - unsigned int wrlvl_en = 0; /* Write Leveling Enable */ /* * First DQS pulse rising edge after margining mode * is programmed (tWL_MRD) @@ -746,6 +1020,34 @@ static void set_ddr_wrlvl_cntl(fsl_ddr_cfg_regs_t *ddr) /* WRLVL_START: Write leveling start time */ unsigned int wrlvl_start = 0;
+ /* suggest enable write leveling for DDR3 due to fly-by topology */ + if (wrlvl_en) { + /* tWL_MRD min = 40 nCK, we set it 64 */ + wrlvl_mrd = 0x6; + /* tWL_ODTEN 128 */ + wrlvl_odten = 0x7; + /* tWL_DQSEN min = 25 nCK, we set it 32 */ + wrlvl_dqsen = 0x5; + /* + * Write leveling sample time at least need 14 clocks + * due to tWLO = 9, we set it 15 clocks + */ + wrlvl_smpl = 0xf; + /* + * Write leveling repetition time + * at least tWLO + 6 clocks clocks + * we set it 32 + */ + wrlvl_wlr = 0x5; + /* + * Write leveling start time + * The value use for the DQS_ADJUST for the first sample + * when write leveling is enabled. + * we set it 1 clock delay + */ + wrlvl_start = 0x8; + } + ddr->ddr_wrlvl_cntl = (0 | ((wrlvl_en & 0x1) << 31) | ((wrlvl_mrd & 0x7) << 24) @@ -864,6 +1166,8 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, unsigned int cas_latency; unsigned int additive_latency; unsigned int sr_it; + unsigned int zq_en; + unsigned int wrlvl_en;
memset(ddr, 0, sizeof(fsl_ddr_cfg_regs_t));
@@ -888,6 +1192,10 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, sr_it = (popts->auto_self_refresh_en) ? popts->sr_it : 0; + /* ZQ calibration */ + zq_en = (popts->zq_en) ? 1 : 0; + /* write leveling */ + wrlvl_en = (popts->wrlvl_en) ? 1 : 0;
/* Chip Select Memory Bounds (CSn_BNDS) */ for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { @@ -1022,12 +1330,12 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, set_csn_config_2(i, ddr); }
-#if defined(CONFIG_FSL_DDR2) +#if !defined(CONFIG_FSL_DDR1) set_timing_cfg_0(ddr); #endif
- set_timing_cfg_3(ddr, common_dimm); - set_timing_cfg_1(ddr, common_dimm, cas_latency); + set_timing_cfg_3(ddr, common_dimm, cas_latency); + set_timing_cfg_1(ddr, popts, common_dimm, cas_latency); set_timing_cfg_2(ddr, popts, common_dimm, cas_latency, additive_latency);
@@ -1045,8 +1353,8 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, set_timing_cfg_4(ddr); set_timing_cfg_5(ddr);
- set_ddr_zq_cntl(ddr); - set_ddr_wrlvl_cntl(ddr); + set_ddr_zq_cntl(ddr, zq_en); + set_ddr_wrlvl_cntl(ddr, wrlvl_en);
set_ddr_pd_cntl(ddr); set_ddr_sr_cntr(ddr, sr_it); diff --git a/cpu/mpc8xxx/ddr/ddr3_dimm_params.c b/cpu/mpc8xxx/ddr/ddr3_dimm_params.c new file mode 100644 index 0000000..ca4be78 --- /dev/null +++ b/cpu/mpc8xxx/ddr/ddr3_dimm_params.c @@ -0,0 +1,314 @@ +/* + * Copyright (C) 2008 Freescale Semiconductor, Inc. + * Dave Liu daveliu@freescale.com + * + * calculate the organization and timing parameter + * from ddr3 spd, please refer to the spec + * JEDEC standard No.21-C 4_01_02_11R18.pdf + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + +#include <common.h> +#include <asm/fsl_ddr_sdram.h> + +#include "ddr.h" + +/* + * Calculate the Density of each Physical Rank. + * Returned size is in bytes. + * + * each rank size = + * sdram capacity(bit) / 8 * primary bus width / sdram width + * + * where: sdram capacity = spd byte4[3:0] + * primary bus width = spd byte8[2:0] + * sdram width = spd byte7[2:0] + * + * SPD byte4 - sdram density and banks + * bit[3:0] size(bit) size(byte) + * 0000 256Mb 32MB + * 0001 512Mb 64MB + * 0010 1Gb 128MB + * 0011 2Gb 256MB + * 0100 4Gb 512MB + * 0101 8Gb 1GB + * 0110 16Gb 2GB + * + * SPD byte8 - module memory bus width + * bit[2:0] primary bus width + * 000 8bits + * 001 16bits + * 010 32bits + * 011 64bits + * + * SPD byte7 - module organiztion + * bit[2:0] sdram device width + * 000 4bits + * 001 8bits + * 010 16bits + * 011 32bits + * + */ +static phys_size_t +compute_ranksize(const ddr3_spd_eeprom_t *spd) +{ + phys_size_t bsize; + + int nbit_sdram_cap_bsize = 0; + int nbit_primary_bus_width = 0; + int nbit_sdram_width = 0; + + if ((spd->density_banks & 0xf) < 7) + nbit_sdram_cap_bsize = (spd->density_banks & 0xf) + 28; + if ((spd->bus_width & 0x7) < 4) + nbit_primary_bus_width = (spd->bus_width & 0x7) + 3; + if ((spd->organization & 0x7) < 4) + nbit_sdram_width = (spd->organization & 0x7) + 2; + + bsize = 1 << (nbit_sdram_cap_bsize - 3 + + nbit_primary_bus_width - nbit_sdram_width); + + debug("DDR: DDR III rank density = 0x%08x\n", bsize); + + return bsize; +} + +/* + * ddr_compute_dimm_parameters for DDR3 SPD + * + * Compute DIMM parameters based upon the SPD information in spd. + * Writes the results to the dimm_params_t structure pointed by pdimm. + * + */ +unsigned int +ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, + dimm_params_t *pdimm, + unsigned int dimm_number) +{ + unsigned int retval; + unsigned int mtb_ps; + + if (spd->mem_type) { + if (spd->mem_type != SPD_MEMTYPE_DDR3) { + printf("DIMM %u: is not a DDR3 SPD.\n", dimm_number); + return 1; + } + } else { + memset(pdimm, 0, sizeof(dimm_params_t)); + return 1; + } + + retval = ddr3_spd_check(spd); + if (retval) { + printf("DIMM %u: failed checksum\n", dimm_number); + return 2; + } + + /* + * The part name in ASCII in the SPD EEPROM is not null terminated. + * Guarantee null termination here by presetting all bytes to 0 + * and copying the part name in ASCII from the SPD onto it + */ + memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); + memcpy(pdimm->mpart, spd->mpart, sizeof(pdimm->mpart) - 1); + + /* DIMM organization parameters */ + pdimm->n_ranks = ((spd->organization >> 3) & 0x7) + 1; + pdimm->rank_density = compute_ranksize(spd); + pdimm->capacity = pdimm->n_ranks * pdimm->rank_density; + pdimm->primary_sdram_width = 1 << (3 + (spd->bus_width & 0x7)); + if ((spd->bus_width >> 3) & 0x3) + pdimm->ec_sdram_width = 8; + else + pdimm->ec_sdram_width = 0; + pdimm->data_width = pdimm->primary_sdram_width + + pdimm->ec_sdram_width; + + switch (spd->module_type & 0xf) { + case 0x01: /* RDIMM */ + case 0x05: /* Mini-RDIMM */ + pdimm->registered_dimm = 1; /* register buffered */ + break; + + case 0x02: /* UDIMM */ + case 0x03: /* SO-DIMM */ + case 0x04: /* Micro-DIMM */ + case 0x06: /* Mini-UDIMM */ + pdimm->registered_dimm = 0; /* unbuffered */ + break; + + default: + printf("unknown dimm_type 0x%02X\n", spd->module_type); + return 1; + } + + /* SDRAM device parameters */ + pdimm->n_row_addr = ((spd->addressing >> 3) & 0x7) + 12; + pdimm->n_col_addr = (spd->addressing & 0x7) + 9; + pdimm->n_banks_per_sdram_device = 8 << ((spd->density_banks >> 4) & 0x7); + + /* + * The SPD spec has not the ECC bit, + * We consider the DIMM as ECC capability + * when the extension bus exist + */ + if (pdimm->ec_sdram_width) + pdimm->edc_config = 0x02; + else + pdimm->edc_config = 0x00; + + /* + * The SPD spec has not the burst length byte + * but DDR3 spec has nature BL8 and BC4, + * BL8 -bit3, BC4 -bit2 + */ + pdimm->burst_lengths_bitmask = 0x0c; + pdimm->row_density = __ilog2(pdimm->rank_density); + + /* MTB - medium timebase + * The unit in the SPD spec is ns, + * We convert it to ps. + * eg: MTB = 0.125ns (125ps) + */ + mtb_ps = (spd->mtb_dividend * 1000) /spd->mtb_divisor; + pdimm->mtb_ps = mtb_ps; + + /* + * sdram minimum cycle time + * we assume the MTB is 0.125ns + * eg: + * tCK_min=15 MTB (1.875ns) ->DDR3-1066 + * =12 MTB (1.5ns) ->DDR3-1333 + * =10 MTB (1.25ns) ->DDR3-1600 + */ + pdimm->tCKmin_X_ps = spd->tCK_min * mtb_ps; + + /* + * CAS latency supported + * bit4 - CL4 + * bit5 - CL5 + * bit18 - CL18 + */ + pdimm->caslat_X = ((spd->caslat_msb << 8) | spd->caslat_lsb) << 4; + + /* + * min CAS latency time + * eg: tAA_min = + * DDR3-800D 100 MTB (12.5ns) + * DDR3-1066F 105 MTB (13.125ns) + * DDR3-1333H 108 MTB (13.5ns) + * DDR3-1600H 90 MTB (11.25ns) + */ + pdimm->tAA_ps = spd->tAA_min * mtb_ps; + + /* + * min write recovery time + * eg: + * tWR_min = 120 MTB (15ns) -> all speed grades. + */ + pdimm->tWR_ps = spd->tWR_min * mtb_ps; + + /* + * min RAS to CAS delay time + * eg: tRCD_min = + * DDR3-800 100 MTB (12.5ns) + * DDR3-1066F 105 MTB (13.125ns) + * DDR3-1333H 108 MTB (13.5ns) + * DDR3-1600H 90 MTB (11.25) + */ + pdimm->tRCD_ps = spd->tRCD_min * mtb_ps; + + /* + * min row active to row active delay time + * eg: tRRD_min = + * DDR3-800(1KB page) 80 MTB (10ns) + * DDR3-1333(1KB page) 48 MTB (6ns) + */ + pdimm->tRRD_ps = spd->tRRD_min * mtb_ps; + + /* + * min row precharge delay time + * eg: tRP_min = + * DDR3-800D 100 MTB (12.5ns) + * DDR3-1066F 105 MTB (13.125ns) + * DDR3-1333H 108 MTB (13.5ns) + * DDR3-1600H 90 MTB (11.25ns) + */ + pdimm->tRP_ps = spd->tRP_min * mtb_ps; + + /* min active to precharge delay time + * eg: tRAS_min = + * DDR3-800D 300 MTB (37.5ns) + * DDR3-1066F 300 MTB (37.5ns) + * DDR3-1333H 288 MTB (36ns) + * DDR3-1600H 280 MTB (35ns) + */ + pdimm->tRAS_ps = (((spd->tRAS_tRC_ext & 0xf) << 8) | spd->tRAS_min_lsb) + * mtb_ps; + /* + * min active to actice/refresh delay time + * eg: tRC_min = + * DDR3-800D 400 MTB (50ns) + * DDR3-1066F 405 MTB (50.625ns) + * DDR3-1333H 396 MTB (49.5ns) + * DDR3-1600H 370 MTB (46.25ns) + */ + pdimm->tRC_ps = (((spd->tRAS_tRC_ext & 0xf0) << 4) | spd->tRC_min_lsb) + * mtb_ps; + /* + * min refresh recovery delay time + * eg: tRFC_min = + * 512Mb 720 MTB (90ns) + * 1Gb 880 MTB (110ns) + * 2Gb 1280 MTB (160ns) + */ + pdimm->tRFC_ps = ((spd->tRFC_min_msb << 8) | spd->tRFC_min_lsb) + * mtb_ps; + /* + * min internal write to read command delay time + * eg: tWTR_min = 40 MTB (7.5ns) - all speed bins. + * tWRT is at least 4 mclk independent of operating freq. + */ + pdimm->tWTR_ps = spd->tWTR_min * mtb_ps; + + /* + * min internal read to precharge command delay time + * eg: tRTP_min = 40 MTB (7.5ns) - all speed bins. + * tRTP is at least 4 mclk independent of operating freq. + */ + pdimm->tRTP_ps = spd->tRTP_min * mtb_ps; + + /* + * Average periodic refresh interval + * tREFI = 7.8 us at normal temperature range + * = 3.9 us at ext temperature range + */ + pdimm->refresh_rate_ps = 7800000; + + /* + * min four active window delay time + * eg: tFAW_min = + * DDR3-800(1KB page) 320 MTB (40ns) + * DDR3-1066(1KB page) 300 MTB (37.5ns) + * DDR3-1333(1KB page) 240 MTB (30ns) + * DDR3-1600(1KB page) 240 MTB (30ns) + */ + pdimm->tFAW_ps = (((spd->tFAW_msb & 0xf) << 8) | spd->tFAW_min) + * mtb_ps; + + /* + * We need check the address mirror for unbuffered DIMM + * If SPD indicate the address map mirror, The DDR controller + * need care it. + */ + if ((spd->module_type == SPD_MODULETYPE_UDIMM) || + (spd->module_type == SPD_MODULETYPE_SODIMM) || + (spd->module_type == SPD_MODULETYPE_MICRODIMM) || + (spd->module_type == SPD_MODULETYPE_MINIUDIMM)) + pdimm->mirrored_dimm = spd->mod_section.unbuffered.addr_mapping & 0x1; + + return 0; +} diff --git a/cpu/mpc8xxx/ddr/lc_common_dimm_params.c b/cpu/mpc8xxx/ddr/lc_common_dimm_params.c index fbeb236..a845a89 100644 --- a/cpu/mpc8xxx/ddr/lc_common_dimm_params.c +++ b/cpu/mpc8xxx/ddr/lc_common_dimm_params.c @@ -11,6 +11,59 @@
#include "ddr.h"
+unsigned int +compute_cas_latency_ddr3(const dimm_params_t *dimm_params, + common_timing_params_t *outpdimm, + unsigned int number_of_dimms) +{ + unsigned int i; + unsigned int tAAmin_ps = 0; + unsigned int tCKmin_X_ps = 0; + unsigned int common_caslat; + unsigned int caslat_actual; + unsigned int retry = 16; + unsigned int tmp; + const unsigned int mclk_ps = get_memory_clk_period_ps(); + + /* compute the common CAS latency supported between slots */ + tmp = dimm_params[0].caslat_X; + for (i = 1; i < number_of_dimms; i++) + tmp &= dimm_params[i].caslat_X; + common_caslat = tmp; + + /* compute the max tAAmin tCKmin between slots */ + for (i = 0; i < number_of_dimms; i++) { + tAAmin_ps = max(tAAmin_ps, dimm_params[i].tAA_ps); + tCKmin_X_ps = max(tCKmin_X_ps, dimm_params[i].tCKmin_X_ps); + } + /* validate if the memory clk is in the range of dimms */ + if (mclk_ps < tCKmin_X_ps) { + printf("The DIMM max tCKmin is %d ps," + "doesn't support the MCLK cycle %d ps\n", + tCKmin_X_ps, mclk_ps); + return 1; + } + /* determine the acutal cas latency */ + caslat_actual = (tAAmin_ps + mclk_ps - 1) / mclk_ps; + /* check if the dimms support the CAS latency */ + while (!(common_caslat & (1 << caslat_actual)) && retry > 0) { + caslat_actual++; + retry--; + } + /* once the caculation of caslat_actual is completed + * we must verify that this CAS latency value does not + * exceed tAAmax, which is 20 ns for all DDR3 speed grades + */ + if (caslat_actual * mclk_ps > 20000) { + printf("The choosen cas latency %d is too large\n", + caslat_actual); + return 1; + } + outpdimm->lowest_common_SPD_caslat = caslat_actual; + + return 0; +} + /* * compute_lowest_common_dimm_parameters() * @@ -46,10 +99,12 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, unsigned int tQHS_ps = 0;
unsigned int temp1, temp2; - unsigned int lowest_good_caslat; unsigned int additive_latency = 0; const unsigned int mclk_ps = get_memory_clk_period_ps(); +#if !defined(CONFIG_FSL_DDR3) + unsigned int lowest_good_caslat; unsigned int not_ok; +#endif
debug("using mclk_ps = %u\n", mclk_ps);
@@ -164,6 +219,10 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, "DIMMs detected!\n"); }
+#if defined(CONFIG_FSL_DDR3) + if (compute_cas_latency_ddr3(dimm_params, outpdimm, number_of_dimms)) + return 1; +#else /* * Compute a CAS latency suitable for all DIMMs * @@ -281,6 +340,7 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, } outpdimm->highest_common_derated_caslat = temp1; debug("highest common dereated CAS latency = %u\n", temp1); +#endif /* #if defined(CONFIG_FSL_DDR3) */
/* Determine if all DIMMs ECC capable. */ temp1 = 1; @@ -297,14 +357,14 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, } outpdimm->all_DIMMs_ECC_capable = temp1;
- +#ifndef CONFIG_FSL_DDR3 /* FIXME: move to somewhere else to validate. */ if (mclk_ps > tCKmax_max_ps) { printf("Warning: some of the installed DIMMs " "can not operate this slowly.\n"); return 1; } - +#endif /* * Compute additive latency. * @@ -314,7 +374,7 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, * which comes from Trcd, and also note that: * add_lat + caslat must be >= 4 * - * For DDR3, FIXME additive latency determination + * For DDR3, we use the AL=0 * * When to use additive latency for DDR2: * @@ -371,7 +431,11 @@ compute_lowest_common_dimm_parameters(const dimm_params_t *dimm_params, }
#elif defined(CONFIG_FSL_DDR3) -error "FIXME determine additive latency for DDR3" + /* + * The system will not use the global auto-precharge mode. + * However, it uses the page mode, so we set AL=0 + */ + additive_latency = 0; #endif
/* diff --git a/cpu/mpc8xxx/ddr/options.c b/cpu/mpc8xxx/ddr/options.c index 29d4143..db44291 100644 --- a/cpu/mpc8xxx/ddr/options.c +++ b/cpu/mpc8xxx/ddr/options.c @@ -96,10 +96,8 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, */ #if defined(CONFIG_FSL_DDR1) popts->DQS_config = 0; -#elif defined(CONFIG_FSL_DDR2) +#elif defined(CONFIG_FSL_DDR2) || defined(CONFIG_FSL_DDR3) popts->DQS_config = 1; -#else -#error "Fix DQS for DDR3" #endif
/* Choose self-refresh during sleep. */ @@ -112,7 +110,17 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, popts->data_bus_width = 0;
/* Choose burst length. */ - popts->burst_length = 4; /* has to be 4 for DDR2 */ +#if defined(CONFIG_FSL_DDR3) + popts->OTF_burst_chop_en = 1; /* on-the-fly burst chop */ + popts->burst_length = DDR_OTF; /* on-the-fly BC4 and BL8 */ +#else + popts->burst_length = DDR_BL4; /* has to be 4 for DDR2 */ +#endif + + /* Choose ddr controller address mirror mode */ +#if defined(CONFIG_FSL_DDR3) + popts->mirrored_dimm = pdimm[0].mirrored_dimm; +#endif
/* Global Timing Parameters. */ debug("mclk_ps = %u ps\n", get_memory_clk_period_ps()); @@ -181,7 +189,17 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, popts->tFAW_window_four_activates_ps = 37500;
#elif defined(CONFIG_FSL_DDR3) -#error "FIXME determine four activates for DDR3" + popts->tFAW_window_four_activates_ps = pdimm[0].tFAW_ps; +#endif + popts->zq_en = 0; + popts->wrlvl_en = 0; +#if defined(CONFIG_FSL_DDR3) + /* + * due to ddr3 dimm is fly-by topology + * we suggest to enable write leveling to + * meet the tQDSS under different loading. + */ + popts->wrlvl_en = 1; #endif
/* diff --git a/include/asm-ppc/fsl_ddr_dimm_params.h b/include/asm-ppc/fsl_ddr_dimm_params.h index c794eed..55923e0 100644 --- a/include/asm-ppc/fsl_ddr_dimm_params.h +++ b/include/asm-ppc/fsl_ddr_dimm_params.h @@ -33,9 +33,15 @@ typedef struct dimm_params_s {
/* used in computing base address of DIMMs */ unsigned long long base_address; + /* mirrored DIMMs */ + unsigned int mirrored_dimm; /* only for ddr3 */
/* DIMM timing parameters */
+ unsigned int mtb_ps; /* medium timebase ps, only for ddr3 */ + unsigned int tAA_ps; /* minimum CAS latency time, only for ddr3 */ + unsigned int tFAW_ps; /* four active window delay, only for ddr3 */ + /* * SDRAM clock periods * The range for these are 1000-10000 so a short should be sufficient @@ -67,6 +73,7 @@ typedef struct dimm_params_s {
unsigned int refresh_rate_ps;
+ /* DDR3 doesn't need these as below */ unsigned int tIS_ps; /* byte 32, spd->ca_setup */ unsigned int tIH_ps; /* byte 33, spd->ca_hold */ unsigned int tDS_ps; /* byte 34, spd->data_setup */ diff --git a/include/asm-ppc/fsl_ddr_sdram.h b/include/asm-ppc/fsl_ddr_sdram.h index 6e3b255..c2e5aee 100644 --- a/include/asm-ppc/fsl_ddr_sdram.h +++ b/include/asm-ppc/fsl_ddr_sdram.h @@ -19,6 +19,11 @@ #define SDRAM_TYPE_LPDDR1 6 #define SDRAM_TYPE_DDR3 7
+#define DDR_BL4 4 /* burst length 4 */ +#define DDR_BC4 DDR_BL4 /* burst chop for ddr3 */ +#define DDR_OTF 6 /* on-the-fly BC4 and BL8 */ +#define DDR_BL8 8 /* burst length 8 */ + #if defined(CONFIG_FSL_DDR1) #define FSL_DDR_MIN_TCKE_PULSE_WIDTH_DDR (1) typedef ddr1_spd_eeprom_t generic_spd_eeprom_t; @@ -68,6 +73,18 @@ typedef ddr3_spd_eeprom_t generic_spd_eeprom_t; #define SDRAM_CFG_2T_EN 0x00008000 #define SDRAM_CFG_BI 0x00000001
+#if defined(CONFIG_P4080) +#define RD_TO_PRE_MASK 0xf +#define RD_TO_PRE_SHIFT 13 +#define WR_DATA_DELAY_MASK 0xf +#define WR_DATA_DELAY_SHIFT 9 +#else +#define RD_TO_PRE_MASK 0x7 +#define RD_TO_PRE_SHIFT 13 +#define WR_DATA_DELAY_MASK 0x7 +#define WR_DATA_DELAY_SHIFT 10 +#endif + /* Record of register values computed */ typedef struct fsl_ddr_cfg_regs_s { struct { @@ -145,7 +162,11 @@ typedef struct memctl_options_s { unsigned int dynamic_power; /* DYN_PWR */ /* memory data width to use (16-bit, 32-bit, 64-bit) */ unsigned int data_bus_width; - unsigned int burst_length; /* 4, 8 */ + unsigned int burst_length; /* BL4, OTF and BL8 */ + /* On-The-Fly Burst Chop enable */ + unsigned int OTF_burst_chop_en; + /* mirrior DIMMs for DDR3 */ + unsigned int mirrored_dimm;
/* Global Timing Parameters */ unsigned int cas_latency_override; @@ -164,9 +185,17 @@ typedef struct memctl_options_s { unsigned int tCKE_clock_pulse_width_ps; /* tCKE */ unsigned int tFAW_window_four_activates_ps; /* tFAW -- FOUR_ACT */
+ /* Rtt impedance */ + unsigned int rtt_override; /* rtt_override enable */ + unsigned int rtt_override_value; /* that is Rtt_Nom for DDR3 */ + /* Automatic self refresh */ unsigned int auto_self_refresh_en; unsigned int sr_it; + /* ZQ calibration */ + unsigned int zq_en; + /* Write leveling */ + unsigned int wrlvl_en; } memctl_options_t;
extern phys_size_t fsl_ddr_sdram(void); diff --git a/include/ddr_spd.h b/include/ddr_spd.h index 6fdcef0..10402c5 100644 --- a/include/ddr_spd.h +++ b/include/ddr_spd.h @@ -184,7 +184,7 @@ typedef struct ddr3_spd_eeprom_s { unsigned char module_type; /* 3 Key Byte / Module Type */ unsigned char density_banks; /* 4 SDRAM Density and Banks */ unsigned char addressing; /* 5 SDRAM Addressing */ - unsigned char res_6; /* 6 Reserved */ + unsigned char module_vdd; /* 6 Module nominal voltage, VDD */ unsigned char organization; /* 7 Module Organization */ unsigned char bus_width; /* 8 Module Memory Bus Width */ unsigned char ftb_div; /* 9 Fine Timebase (FTB) @@ -273,6 +273,7 @@ extern unsigned int ddr1_spd_check(const ddr1_spd_eeprom_t *spd); extern void ddr1_spd_dump(const ddr1_spd_eeprom_t *spd); extern unsigned int ddr2_spd_check(const ddr2_spd_eeprom_t *spd); extern void ddr2_spd_dump(const ddr2_spd_eeprom_t *spd); +extern unsigned int ddr3_spd_check(const ddr3_spd_eeprom_t *spd);
/* * Byte 2 Fundamental Memory Types. @@ -289,4 +290,14 @@ extern void ddr2_spd_dump(const ddr2_spd_eeprom_t *spd); #define SPD_MEMTYPE_DDR2_FBDIMM_PROBE (0x0A) #define SPD_MEMTYPE_DDR3 (0x0B)
+/* + * Byte 3 Key Byte / Module Type for DDR3 SPD + */ +#define SPD_MODULETYPE_RDIMM (0x01) +#define SPD_MODULETYPE_UDIMM (0x02) +#define SPD_MODULETYPE_SODIMM (0x03) +#define SPD_MODULETYPE_MICRODIMM (0x04) +#define SPD_MODULETYPE_MINIRDIMM (0x05) +#define SPD_MODULETYPE_MINIUDIMM (0x06) + #endif /* _DDR_SPD_H_ */
Dave Liu
