[U-Boot] Can't boot my FIT image: 'Could not find configuration node'
I'm using U-boot to boot an ELF image. I am easily able to load the image into memory and boot it with the `bootelf` command. However, I'd like to create a FIT image in order to make use of the convenient hashing and secure boot features, but I'm having trouble getting my image to boot.
Here is my current `.its` file (currently as simple as possible until I get it to boot):
/dts-v1/;
/ { description = "SeL4"; #address-cells = <1>;
images { kerne-0 { description = "SeL4 image"; data = /incbin/("./test_app-image-arm-exynos5"); type = "kernel"; arch = "arm"; os = "qnx"; compression = "none"; load = <0x48000000>; entry = <0x48000000>; }; };
configurations { default = "config-0"; config-0 { description = "default config"; kernel = "kernel-0"; }; }; };
By the way, my ELF image isn't actually a qnx kernel. It is a sel4 kernel, however "sel4" is not an option. (I can make a uImage with `mkimage -A arm -a 0x48000000 -e 0x48000000 -C none -T kernel -O qnx -d test_app-image-exynos5 image` and can actually boot the resulting image here with `bootm` no problem, so I believe using the qnx OS setting shouldn't be a problem.)
I am then able to create the FIT image with `mkimage -f sel4.its sel4.itb`. I copy this image to my SD card, successfully load the fit image into memory (with `fatload`), but then `bootm` fails with the following message:
## Loading kernel from FIT Image at 50000000 ... Could not find configuration node ERROR: can't get kernel image!
I can't make sense of this error. `iminfo` recognizes my default configuration, yet `bootm` can't find the configuration node?
Thanks, Grant
Dear Grant,
I see there is a typo in your kernel node name.
In the image section you wrote kerne-0 and in the config section you wrote kernel = "kernel-0"; Probably this is the issue that no config and kernel image is found.
Regards,
Johann Neuhauser
-----Ursprüngliche Nachricht----- Von: U-Boot [mailto:u-boot-bounces@lists.denx.de] Im Auftrag von Grant Jurgensen Gesendet: Montag, 6. August 2018 19:50 An: u-boot@lists.denx.de Betreff: [U-Boot] Can't boot my FIT image: 'Could not find configuration node'
/dts-v1/;
images { kerne-0 { description = "SeL4 image"; data = /incbin/("./test_app-image-arm-exynos5"); type = "kernel"; arch = "arm"; os = "qnx"; compression = "none"; load = <0x48000000>; entry = <0x48000000>; }; }; configurations { default = "config-0"; config-0 { description = "default config"; kernel = "kernel-0"; }; };
Thanks, Grant _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Johann,
I apologize, that typo is actually just in the email. My actual file has "kernel-0" in both locations. It seems my fit image is formed correctly based on the header information:
...$ mkimage -F sel4.itb FIT description: SeL4 Created: Tue Aug 7 10:56:42 2018 Image 0 (kernel-0) Description: SeL4 image Created: Tue Aug 7 10:56:42 2018 Type: Kernel Image Compression: uncompressed Data Size: 1033080 Bytes = 1008.87 kB = 0.99 MB Architecture: ARM OS: QNX Load Address: 0x48000000 Entry Point: 0x48000000 Default Configuration: 'config-0' Configuration 0 (config-0) Description: default config Kernel: kernel-0
Likewise, I get the same information using the `iminfo` command within u-boot.
Sorry again for the typo, Grant
On Tue, Aug 7, 2018 at 12:16 AM Johann Neuhauser < jneuhauser@dh-electronics.de> wrote:
Dear Grant,
Regards,
Johann Neuhauser
image into
create
boot
get it to
boot):
/dts-v1/;
kernel,
arm
sel4.itb`.
memory
configuration,
Grant Jurgensen
Johann Neuhauser
