[PATCH 1/1] miiphy.h: Remove CONFIG_DM_xxx guards
Function prototypes must not be guarded with ifdef tests. Doing so prevents us from doing: if (CONFIG_IS_ENABLED(FOO)) func();
as that results in a warning when CONFIG_FOO is not enabled.
Signed-off-by: Tom Rini trini@konsulko.com --- I forgot that I had this applied when pushing before, as it's required by the aspeed mii changes.
include/miiphy.h | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/include/miiphy.h b/include/miiphy.h index 8b77bac01e6a..77a00359587b 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -126,8 +126,6 @@ int bb_miiphy_write(struct mii_dev *miidev, int addr, int devad, int reg, #define ESTATUS_1000XF 0x8000 #define ESTATUS_1000XH 0x4000
-#ifdef CONFIG_DM_MDIO - /** * struct mdio_perdev_priv - Per-device class data for MDIO DM * @@ -185,10 +183,6 @@ struct phy_device *dm_mdio_phy_connect(struct udevice *mdiodev, int phyaddr, */ struct phy_device *dm_eth_phy_connect(struct udevice *ethdev);
-#endif - -#ifdef CONFIG_DM_MDIO_MUX - /* indicates none of the child buses is selected */ #define MDIO_MUX_SELECT_NONE -1
@@ -206,5 +200,3 @@ struct mdio_mux_ops { #define mdio_mux_get_ops(dev) ((struct mdio_mux_ops *)(dev)->driver->ops)
#endif - -#endif
