[U-Boot] [PATCH] scripts: update checkpatch.pl to latest upstream version
Update to v3.14-rc4's version of checkpatch.pl. In doing so we drop the changes to top_of_kernel_tree() as we pass in --no-tree and drop our changes about MAINTAINERS as that's for reporting checkpatch.pl problems itself (and upstream has said they'll reword this section to be clearer).
Signed-off-by: Tom Rini trini@ti.com --- scripts/checkpatch.pl | 1275 +++++++++++++++++++++++++++++++++++++++++-------- 1 file changed, 1067 insertions(+), 208 deletions(-)
diff --git a/scripts/checkpatch.pl b/scripts/checkpatch.pl index df0820c..3fed5e46 100755 --- a/scripts/checkpatch.pl +++ b/scripts/checkpatch.pl @@ -6,6 +6,7 @@ # Licensed under the terms of the GNU GPL License version 2
use strict; +use POSIX;
my $P = $0; $P =~ s@.*/@@g; @@ -27,13 +28,20 @@ my $summary = 1; my $mailback = 0; my $summary_file = 0; my $show_types = 0; +my $fix = 0; +my $fix_inplace = 0; my $root; my %debug; +my %camelcase = (); +my %use_type = (); +my @use = (); my %ignore_type = (); my @ignore = (); my $help = 0; my $configuration_file = ".checkpatch.conf"; my $max_line_length = 80; +my $ignore_perl_version = 0; +my $minimum_perl_version = 5.10.0;
sub help { my ($exitcode) = @_; @@ -51,6 +59,7 @@ Options: --terse one line per report -f, --file treat FILE as regular source file --subjective, --strict enable more subjective tests + --types TYPE(,TYPE2...) show only these comma separated message types --ignore TYPE(,TYPE2...) ignore various comma separated message types --max-line-length=n set the maximum line length, if exceeded, warn --show-types show the message "types" in the output @@ -63,6 +72,16 @@ Options: is all off) --test-only=WORD report only warnings/errors containing WORD literally + --fix EXPERIMENTAL - may create horrible results + If correctable single-line errors exist, create + "<inputfile>.EXPERIMENTAL-checkpatch-fixes" + with potential errors corrected to the preferred + checkpatch style + --fix-inplace EXPERIMENTAL - may create horrible results + Is the same as --fix, but overwrites the input + file. It's your fault if there's no backup or git + --ignore-perl-version override checking of perl version. expect + runtime errors. -h, --help, --version display this help and exit
When FILE is - read standard input. @@ -108,13 +127,16 @@ GetOptions( 'subjective!' => $check, 'strict!' => $check, 'ignore=s' => @ignore, + 'types=s' => @use, 'show-types!' => $show_types, 'max-line-length=i' => $max_line_length, 'root=s' => $root, 'summary!' => $summary, 'mailback!' => $mailback, 'summary-file!' => $summary_file, - + 'fix!' => $fix, + 'fix-inplace!' => $fix_inplace, + 'ignore-perl-version!' => $ignore_perl_version, 'debug=s' => %debug, 'test-only=s' => $tst_only, 'h|help' => $help, @@ -123,26 +145,54 @@ GetOptions(
help(0) if ($help);
+$fix = 1 if ($fix_inplace); + my $exit = 0;
+if ($^V && $^V lt $minimum_perl_version) { + printf "$P: requires at least perl version %vd\n", $minimum_perl_version; + if (!$ignore_perl_version) { + exit(1); + } +} + if ($#ARGV < 0) { print "$P: no input files\n"; exit(1); }
-@ignore = split(/,/, join(',',@ignore)); -foreach my $word (@ignore) { - $word =~ s/\s*\n?$//g; - $word =~ s/^\s*//g; - $word =~ s/\s+/ /g; - $word =~ tr/[a-z]/[A-Z]/; +sub hash_save_array_words { + my ($hashRef, $arrayRef) = @_;
- next if ($word =~ m/^\s*#/); - next if ($word =~ m/^\s*$/); + my @array = split(/,/, join(',', @$arrayRef)); + foreach my $word (@array) { + $word =~ s/\s*\n?$//g; + $word =~ s/^\s*//g; + $word =~ s/\s+/ /g; + $word =~ tr/[a-z]/[A-Z]/;
- $ignore_type{$word}++; + next if ($word =~ m/^\s*#/); + next if ($word =~ m/^\s*$/); + + $hashRef->{$word}++; + } }
+sub hash_show_words { + my ($hashRef, $prefix) = @_; + + if ($quiet == 0 && keys %$hashRef) { + print "NOTE: $prefix message types:"; + foreach my $word (sort keys %$hashRef) { + print " $word"; + } + print "\n\n"; + } +} + +hash_save_array_words(%ignore_type, @ignore); +hash_save_array_words(%use_type, @use); + my $dbg_values = 0; my $dbg_possible = 0; my $dbg_type = 0; @@ -198,6 +248,11 @@ our $Sparse = qr{ __ref| __rcu }x; +our $InitAttributePrefix = qr{__(?:mem|cpu|dev|net_|)}; +our $InitAttributeData = qr{$InitAttributePrefix(?:initdata\b)}; +our $InitAttributeConst = qr{$InitAttributePrefix(?:initconst\b)}; +our $InitAttributeInit = qr{$InitAttributePrefix(?:init\b)}; +our $InitAttribute = qr{$InitAttributeData|$InitAttributeConst|$InitAttributeInit};
# Notes to $Attribute: # We need \b after 'init' otherwise 'initconst' will cause a false positive in a check @@ -219,7 +274,7 @@ our $Attribute = qr{ __deprecated| __read_mostly| __kprobes| - __(?:mem|cpu|dev|)(?:initdata|initconst|init\b)| + $InitAttribute| ____cacheline_aligned| ____cacheline_aligned_in_smp| ____cacheline_internodealigned_in_smp| @@ -230,20 +285,26 @@ our $Inline = qr{inline|__always_inline|noinline}; our $Member = qr{->$Ident|.$Ident|[[^]]*]}; our $Lval = qr{$Ident(?:$Member)*};
+our $Int_type = qr{(?i)llu|ull|ll|lu|ul|l|u}; +our $Binary = qr{(?i)0b[01]+$Int_type?}; +our $Hex = qr{(?i)0x[0-9a-f]+$Int_type?}; +our $Int = qr{[0-9]+$Int_type?}; our $Float_hex = qr{(?i)0x[0-9a-f]+p-?[0-9]+[fl]?}; our $Float_dec = qr{(?i)(?:[0-9]+.[0-9]*|[0-9]*.[0-9]+)(?:e-?[0-9]+)?[fl]?}; our $Float_int = qr{(?i)[0-9]+e-?[0-9]+[fl]?}; our $Float = qr{$Float_hex|$Float_dec|$Float_int}; -our $Constant = qr{$Float|(?i)(?:0x[0-9a-f]+|[0-9]+)[ul]*}; +our $Constant = qr{$Float|$Binary|$Hex|$Int}; our $Assignment = qr{*=|/=|%=|+=|-=|<<=|>>=|&=|^=||=|=}; our $Compare = qr{<=|>=|==|!=|<|>}; +our $Arithmetic = qr{+|-|*|/|%}; our $Operators = qr{ <=|>=|==|!=| =>|->|<<|>>|<|>|!|~| - &&||||,|^|++|--|&|||+|-|*|/|% + &&||||,|^|++|--|&|||$Arithmetic }x;
our $NonptrType; +our $NonptrTypeWithAttr; our $Type; our $Declare;
@@ -269,12 +330,14 @@ our $typeTypedefs = qr{(?x:
our $logFunctions = qr{(?x: printk(?:_ratelimited|_once|)| - [a-z0-9]+_(?:printk|emerg|alert|crit|err|warning|warn|notice|info|debug|dbg|vdbg|devel|cont|WARN)(?:_ratelimited|_once|)| + (?:[a-z0-9]+_){1,2}(?:printk|emerg|alert|crit|err|warning|warn|notice|info|debug|dbg|vdbg|devel|cont|WARN)(?:_ratelimited|_once|)| WARN(?:_RATELIMIT|_ONCE|)| panic| debug| printf| - MODULE_[A-Z_]+ + puts| + MODULE_[A-Z_]+| + seq_vprintf|seq_printf|seq_puts )};
our $signature_tags = qr{(?xi: @@ -283,6 +346,7 @@ our $signature_tags = qr{(?xi: Tested-by:| Reviewed-by:| Reported-by:| + Suggested-by:| To:| Cc: )}; @@ -307,6 +371,12 @@ our @typeList = ( qr{${Ident}_handler}, qr{${Ident}_handler_fn}, ); +our @typeListWithAttr = ( + @typeList, + qr{struct\s+$InitAttribute\s+$Ident}, + qr{union\s+$InitAttribute\s+$Ident}, +); + our @modifierList = ( qr{fastcall}, ); @@ -320,6 +390,7 @@ our $allowed_asm_includes = qr{(?x: sub build_types { my $mods = "(?x: \n" . join("|\n ", @modifierList) . "\n)"; my $all = "(?x: \n" . join("|\n ", @typeList) . "\n)"; + my $allWithAttr = "(?x: \n" . join("|\n ", @typeListWithAttr) . "\n)"; $Modifier = qr{(?:$Attribute|$Sparse|$mods)}; $NonptrType = qr{ (?:$Modifier\s+|const\s+)* @@ -330,6 +401,15 @@ sub build_types { ) (?:\s+$Modifier|\s+const)* }x; + $NonptrTypeWithAttr = qr{ + (?:$Modifier\s+|const\s+)* + (?: + (?:typeof|__typeof__)\s*([^)]*)| + (?:$typeTypedefs\b)| + (?:${allWithAttr}\b) + ) + (?:\s+$Modifier|\s+const)* + }x; $Type = qr{ $NonptrType (?:(?:\s|*|[])+\s*const|(?:\s|*|[])+|(?:\s*[\s*])+)? @@ -339,7 +419,6 @@ sub build_types { } build_types();
- our $Typecast = qr{\s*((\s*$NonptrType\s*)){0,1}\s*};
# Using $balanced_parens, $LvalOrFunc, or $FuncArg @@ -359,10 +438,95 @@ sub deparenthesize { return $string; }
+sub seed_camelcase_file { + my ($file) = @_; + + return if (!(-f $file)); + + local $/; + + open(my $include_file, '<', "$file") + or warn "$P: Can't read '$file' $!\n"; + my $text = <$include_file>; + close($include_file); + + my @lines = split('\n', $text); + + foreach my $line (@lines) { + next if ($line !~ /(?:[A-Z][a-z]|[a-z][A-Z])/); + if ($line =~ /^[ \t]*(?:#[ \t]*define|typedef\s+$Type)\s+(\w*(?:[A-Z][a-z]|[a-z][A-Z])\w*)/) { + $camelcase{$1} = 1; + } elsif ($line =~ /^\s*$Declare\s+(\w*(?:[A-Z][a-z]|[a-z][A-Z])\w*)\s*[([,;]/) { + $camelcase{$1} = 1; + } elsif ($line =~ /^\s*(?:union|struct|enum)\s+(\w*(?:[A-Z][a-z]|[a-z][A-Z])\w*)\s*[;{]/) { + $camelcase{$1} = 1; + } + } +} + +my $camelcase_seeded = 0; +sub seed_camelcase_includes { + return if ($camelcase_seeded); + + my $files; + my $camelcase_cache = ""; + my @include_files = (); + + $camelcase_seeded = 1; + + if (-e ".git") { + my $git_last_include_commit = `git log --no-merges --pretty=format:"%h%n" -1 -- include`; + chomp $git_last_include_commit; + $camelcase_cache = ".checkpatch-camelcase.git.$git_last_include_commit"; + } else { + my $last_mod_date = 0; + $files = `find $root/include -name "*.h"`; + @include_files = split('\n', $files); + foreach my $file (@include_files) { + my $date = POSIX::strftime("%Y%m%d%H%M", + localtime((stat $file)[9])); + $last_mod_date = $date if ($last_mod_date < $date); + } + $camelcase_cache = ".checkpatch-camelcase.date.$last_mod_date"; + } + + if ($camelcase_cache ne "" && -f $camelcase_cache) { + open(my $camelcase_file, '<', "$camelcase_cache") + or warn "$P: Can't read '$camelcase_cache' $!\n"; + while (<$camelcase_file>) { + chomp; + $camelcase{$_} = 1; + } + close($camelcase_file); + + return; + } + + if (-e ".git") { + $files = `git ls-files "include/*.h"`; + @include_files = split('\n', $files); + } + + foreach my $file (@include_files) { + seed_camelcase_file($file); + } + + if ($camelcase_cache ne "") { + unlink glob ".checkpatch-camelcase.*"; + open(my $camelcase_file, '>', "$camelcase_cache") + or warn "$P: Can't write '$camelcase_cache' $!\n"; + foreach (sort { lc($a) cmp lc($b) } keys(%camelcase)) { + print $camelcase_file ("$_\n"); + } + close($camelcase_file); + } +} + $chk_signoff = 0 if ($file);
my @rawlines = (); my @lines = (); +my @fixed = (); my $vname; for my $filename (@ARGV) { my $FILE; @@ -390,6 +554,7 @@ for my $filename (@ARGV) { } @rawlines = (); @lines = (); + @fixed = (); }
exit($exit); @@ -398,7 +563,7 @@ sub top_of_kernel_tree { my ($root) = @_;
my @tree_check = ( - "COPYING", "CREDITS", "Kbuild", "Makefile", + "COPYING", "CREDITS", "Kbuild", "MAINTAINERS", "Makefile", "README", "Documentation", "arch", "include", "drivers", "fs", "init", "ipc", "kernel", "lib", "scripts", ); @@ -430,7 +595,7 @@ sub parse_email { $comment = $2 if defined $2; $formatted_email =~ s/$address.*$//; $name = $formatted_email; - $name =~ s/^\s+|\s+$//g; + $name = trim($name); $name =~ s/^"|"$//g; # If there's a name left after stripping spaces and # leading quotes, and the address doesn't have both @@ -445,9 +610,9 @@ sub parse_email { } }
- $name =~ s/^\s+|\s+$//g; + $name = trim($name); $name =~ s/^"|"$//g; - $address =~ s/^\s+|\s+$//g; + $address = trim($address); $address =~ s/^<|>$//g;
if ($name =~ /[^\w -]/i) { ##has "must quote" chars @@ -463,9 +628,9 @@ sub format_email {
my $formatted_email;
if ($name =~ /[^\w -]/i) { ##has "must quote" chars $name =~ s/(?<!\)"/\"/g; ##escape quotes @@ -630,6 +795,13 @@ sub sanitise_line { return $res; }
+sub get_quoted_string { + my ($line, $rawline) = @_; + + return "" if ($line !~ m/("[X]+")/g); + return substr($rawline, $-[0], $+[0] - $-[0]); +} + sub ctx_statement_block { my ($linenr, $remain, $off) = @_; my $line = $linenr - 1; @@ -1252,7 +1424,9 @@ sub possible { my $prefix = '';
sub show_type { - return !defined $ignore_type{$_[0]}; + return defined $use_type{$_[0]} if (scalar keys %use_type > 0); + + return !defined $ignore_type{$_[0]}; }
sub report { @@ -1280,19 +1454,25 @@ sub ERROR { if (report("ERROR", $_[0], $_[1])) { our $clean = 0; our $cnt_error++; + return 1; } + return 0; } sub WARN { if (report("WARNING", $_[0], $_[1])) { our $clean = 0; our $cnt_warn++; + return 1; } + return 0; } sub CHK { if ($check && report("CHECK", $_[0], $_[1])) { our $clean = 0; our $cnt_chk++; + return 1; } + return 0; }
sub check_absolute_file { @@ -1323,6 +1503,53 @@ sub check_absolute_file { } }
+sub trim { + my ($string) = @_; + + $string =~ s/^\s+|\s+$//g; + + return $string; +} + +sub ltrim { + my ($string) = @_; + + $string =~ s/^\s+//; + + return $string; +} + +sub rtrim { + my ($string) = @_; + + $string =~ s/\s+$//; + + return $string; +} + +sub string_find_replace { + my ($string, $find, $replace) = @_; + + $string =~ s/$find/$replace/g; + + return $string; +} + +sub tabify { + my ($leading) = @_; + + my $source_indent = 8; + my $max_spaces_before_tab = $source_indent - 1; + my $spaces_to_tab = " " x $source_indent; + + #convert leading spaces to tabs + 1 while $leading =~ s@^([\t]*)$spaces_to_tab@$1\t@g; + #Remove spaces before a tab + 1 while $leading =~ s@^([\t]*)( {1,$max_spaces_before_tab})\t@$1\t@g; + + return "$leading"; +} + sub pos_last_openparen { my ($line) = @_;
@@ -1400,7 +1627,7 @@ sub process { my %suppress_export; my $suppress_statement = 0;
- my %camelcase = (); + my %signatures = ();
# Pre-scan the patch sanitizing the lines. # Pre-scan the patch looking for any __setup documentation. @@ -1408,12 +1635,16 @@ sub process { my @setup_docs = (); my $setup_docs = 0;
+ my $camelcase_file_seeded = 0; + sanitise_line_reset(); my $line; foreach my $rawline (@rawlines) { $linenr++; $line = $rawline;
+ push(@fixed, $rawline) if ($fix); + if ($rawline=~/^+++\s+(\S+)/) { $setup_docs = 0; if ($1 =~ m@Documentation/kernel-parameters.txt$@) { @@ -1491,6 +1722,8 @@ sub process { $linenr = 0; foreach my $line (@lines) { $linenr++; + my $sline = $line; #copy of $line + $sline =~ s/$;/ /g; #with comments as spaces
my $rawline = $rawlines[$linenr - 1];
@@ -1546,11 +1779,11 @@ sub process { # extract the filename as it passes if ($line =~ /^diff --git.*?(\S+)$/) { $realfile = $1; - $realfile =~ s@^([^/]*)/@@; + $realfile =~ s@^([^/]*)/@@ if (!$file); $in_commit_log = 0; } elsif ($line =~ /^+++\s+(\S+)/) { $realfile = $1; - $realfile =~ s@^([^/]*)/@@; + $realfile =~ s@^([^/]*)/@@ if (!$file); $in_commit_log = 0;
$p1_prefix = $1; @@ -1578,7 +1811,8 @@ sub process { # Check for incorrect file permissions if ($line =~ /^new (file )?mode.*[7531]\d{0,2}$/) { my $permhere = $here . "FILE: $realfile\n"; - if ($realfile =~ /(Makefile|Kconfig|.c|.h|.S|.tmpl)$/) { + if ($realfile !~ m@scripts/@ && + $realfile !~ /.(py|pl|awk|sh)$/) { ERROR("EXECUTE_PERMISSIONS", "do not set execute permissions for source files\n" . $permhere); } @@ -1604,16 +1838,29 @@ sub process { "Non-standard signature: $sign_off\n" . $herecurr); } if (defined $space_before && $space_before ne "") { - WARN("BAD_SIGN_OFF", - "Do not use whitespace before $ucfirst_sign_off\n" . $herecurr); + if (WARN("BAD_SIGN_OFF", + "Do not use whitespace before $ucfirst_sign_off\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] = + "$ucfirst_sign_off $email"; + } } if ($sign_off =~ /-by:$/i && $sign_off ne $ucfirst_sign_off) { - WARN("BAD_SIGN_OFF", - "'$ucfirst_sign_off' is the preferred signature form\n" . $herecurr); + if (WARN("BAD_SIGN_OFF", + "'$ucfirst_sign_off' is the preferred signature form\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] = + "$ucfirst_sign_off $email"; + } + } if (!defined $space_after || $space_after ne " ") { - WARN("BAD_SIGN_OFF", - "Use a single space after $ucfirst_sign_off\n" . $herecurr); + if (WARN("BAD_SIGN_OFF", + "Use a single space after $ucfirst_sign_off\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] = + "$ucfirst_sign_off $email"; + } }
my ($email_name, $email_address, $comment) = parse_email($email); @@ -1634,6 +1881,17 @@ sub process { "email address '$email' might be better as '$suggested_email$comment'\n" . $herecurr); } } + +# Check for duplicate signatures + my $sig_nospace = $line; + $sig_nospace =~ s/\s//g; + $sig_nospace = lc($sig_nospace); + if (defined $signatures{$sig_nospace}) { + WARN("BAD_SIGN_OFF", + "Duplicate signature\n" . $herecurr); + } else { + $signatures{$sig_nospace} = 1; + } }
# Check for wrappage within a valid hunk of the file @@ -1698,16 +1956,33 @@ sub process { #trailing whitespace if ($line =~ /^+.*\015/) { my $herevet = "$here\n" . cat_vet($rawline) . "\n"; - ERROR("DOS_LINE_ENDINGS", - "DOS line endings\n" . $herevet); - + if (ERROR("DOS_LINE_ENDINGS", + "DOS line endings\n" . $herevet) && + $fix) { + $fixed[$linenr - 1] =~ s/[\s\015]+$//; + } } elsif ($rawline =~ /^+.*\S\s+$/ || $rawline =~ /^+\s+$/) { my $herevet = "$here\n" . cat_vet($rawline) . "\n"; - ERROR("TRAILING_WHITESPACE", - "trailing whitespace\n" . $herevet); + if (ERROR("TRAILING_WHITESPACE", + "trailing whitespace\n" . $herevet) && + $fix) { + $fixed[$linenr - 1] =~ s/\s+$//; + } + $rpt_cleaners = 1; }
+# Check for FSF mailing addresses. + if ($rawline =~ /\bwrite to the Free/i || + $rawline =~ /\b59\s+Temple\s+Pl/i || + $rawline =~ /\b51\s+Franklin\s+St/i) { + my $herevet = "$here\n" . cat_vet($rawline) . "\n"; + my $msg_type = &ERROR; + $msg_type = &CHK if ($file); + &{$msg_type}("FSF_MAILING_ADDRESS", + "Do not include the paragraph about writing to the Free Software Foundation's mailing address from the sample GPL notice. The FSF has changed addresses in the past, and may do so again. Linux already includes a copy of the GPL.\n" . $herevet) + } + # check for Kconfig help text having a real description # Only applies when adding the entry originally, after that we do not have # sufficient context to determine whether it is indeed long enough. @@ -1768,6 +2043,33 @@ sub process { "Use of $flag is deprecated, please use `$replacement->{$flag} instead.\n" . $herecurr) if ($replacement->{$flag}); }
+# check for DT compatible documentation + if (defined $root && $realfile =~ /.dts/ && + $rawline =~ /^+\s*compatible\s*=/) { + my @compats = $rawline =~ /"([a-zA-Z0-9-,.+_]+)"/g; + + foreach my $compat (@compats) { + my $compat2 = $compat; + my $dt_path = $root . "/Documentation/devicetree/bindings/"; + $compat2 =~ s/,[a-z]*-/,<.*>-/; + `grep -Erq "$compat|$compat2" $dt_path`; + if ( $? >> 8 ) { + WARN("UNDOCUMENTED_DT_STRING", + "DT compatible string "$compat" appears un-documented -- check $dt_path\n" . $herecurr); + } + + my $vendor = $compat; + my $vendor_path = $dt_path . "vendor-prefixes.txt"; + next if (! -f $vendor_path); + $vendor =~ s/^([a-zA-Z0-9]+),.*/$1/; + `grep -Eq "$vendor" $vendor_path`; + if ( $? >> 8 ) { + WARN("UNDOCUMENTED_DT_STRING", + "DT compatible string vendor "$vendor" appears un-documented -- check $vendor_path\n" . $herecurr); + } + } + } + # check we are in a valid source file if not then ignore this hunk next if ($realfile !~ /.(h|c|s|S|pl|sh)$/);
@@ -1783,24 +2085,24 @@ sub process { }
# Check for user-visible strings broken across lines, which breaks the ability -# to grep for the string. Limited to strings used as parameters (those -# following an open parenthesis), which almost completely eliminates false -# positives, as well as warning only once per parameter rather than once per -# line of the string. Make an exception when the previous string ends in a -# newline (multiple lines in one string constant) or \n\t (common in inline -# assembly to indent the instruction on the following line). +# to grep for the string. Make exceptions when the previous string ends in a +# newline (multiple lines in one string constant) or '\t', '\r', ';', or '{' +# (common in inline assembly) or is a octal \123 or hexadecimal \xaf value if ($line =~ /^+\s*"/ && $prevline =~ /"\s*$/ && - $prevline =~ /(/ && - $prevrawline !~ /\n(?:\t)*"\s*$/) { + $prevrawline !~ /(?:\(?:[ntr]|[0-7]{1,3}|x[0-9a-fA-F]{1,2})|;\s*|{\s*)"\s*$/) { WARN("SPLIT_STRING", "quoted string split across lines\n" . $hereprev); }
# check for spaces before a quoted newline if ($rawline =~ /^.*".*\s\n/) { - WARN("QUOTED_WHITESPACE_BEFORE_NEWLINE", - "unnecessary whitespace before a quoted newline\n" . $herecurr); + if (WARN("QUOTED_WHITESPACE_BEFORE_NEWLINE", + "unnecessary whitespace before a quoted newline\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/^(+.*".*)\s+\n/$1\n/; + } + }
# check for adding lines without a newline. @@ -1831,16 +2133,25 @@ sub process { if ($rawline =~ /^+\s* \t\s*\S/ || $rawline =~ /^+\s* \s*/) { my $herevet = "$here\n" . cat_vet($rawline) . "\n"; - ERROR("CODE_INDENT", - "code indent should use tabs where possible\n" . $herevet); $rpt_cleaners = 1; + if (ERROR("CODE_INDENT", + "code indent should use tabs where possible\n" . $herevet) && + $fix) { + $fixed[$linenr - 1] =~ s/^+([ \t]+)/"+" . tabify($1)/e; + } }
# check for space before tabs. if ($rawline =~ /^+/ && $rawline =~ / \t/) { my $herevet = "$here\n" . cat_vet($rawline) . "\n"; - WARN("SPACE_BEFORE_TAB", - "please, no space before tabs\n" . $herevet); + if (WARN("SPACE_BEFORE_TAB", + "please, no space before tabs\n" . $herevet) && + $fix) { + while ($fixed[$linenr - 1] =~ + s/(^+.*) {8,8}+\t/$1\t\t/) {} + while ($fixed[$linenr - 1] =~ + s/(^+.*) +\t/$1\t/) {} + } }
# check for && or || at the start of a line @@ -1868,25 +2179,43 @@ sub process {
if ($newindent ne $goodtabindent && $newindent ne $goodspaceindent) { - CHK("PARENTHESIS_ALIGNMENT", - "Alignment should match open parenthesis\n" . $hereprev); + + if (CHK("PARENTHESIS_ALIGNMENT", + "Alignment should match open parenthesis\n" . $hereprev) && + $fix && $line =~ /^+/) { + $fixed[$linenr - 1] =~ + s/^+[ \t]*/+$goodtabindent/; + } } } }
- if ($line =~ /^+.**[ \t]*)[ \t]+/) { - CHK("SPACING", - "No space is necessary after a cast\n" . $hereprev); + if ($line =~ /^+.**[ \t]*)[ \t]+(?!$Assignment|$Arithmetic)/) { + if (CHK("SPACING", + "No space is necessary after a cast\n" . $hereprev) && + $fix) { + $fixed[$linenr - 1] =~ + s/^(+.**[ \t]*))[ \t]+/$1/; + } }
if ($realfile =~ m@^(drivers/net/|net/)@ && - $rawline =~ /^+[ \t]*/*[ \t]*$/ && - $prevrawline =~ /^+[ \t]*$/) { + $prevrawline =~ /^+[ \t]*/*[ \t]*$/ && + $rawline =~ /^+[ \t]**/) { WARN("NETWORKING_BLOCK_COMMENT_STYLE", "networking block comments don't use an empty /* line, use /* Comment...\n" . $hereprev); }
if ($realfile =~ m@^(drivers/net/|net/)@ && + $prevrawline =~ /^+[ \t]*/*/ && #starting /* + $prevrawline !~ /*/[ \t]*$/ && #no trailing */ + $rawline =~ /^+/ && #line is new + $rawline !~ /^+[ \t]**/) { #no leading * + WARN("NETWORKING_BLOCK_COMMENT_STYLE", + "networking block comments start with * on subsequent lines\n" . $hereprev); + } + + if ($realfile =~ m@^(drivers/net/|net/)@ && $rawline !~ m@^+[ \t]**/[ \t]*$@ && #trailing */ $rawline !~ m@^+.*/*.**/[ \t]*$@ && #inline /*...*/ $rawline !~ m@^+.**{2,}/[ \t]*$@ && #trailing **/ @@ -1900,10 +2229,13 @@ sub process { # 1) within comments # 2) indented preprocessor commands # 3) hanging labels - if ($rawline =~ /^+ / && $line !~ /+ *(?:$;|#|$Ident:)/) { + if ($rawline =~ /^+ / && $line !~ /^+ *(?:$;|#|$Ident:)/) { my $herevet = "$here\n" . cat_vet($rawline) . "\n"; - WARN("LEADING_SPACE", - "please, no spaces at the start of a line\n" . $herevet); + if (WARN("LEADING_SPACE", + "please, no spaces at the start of a line\n" . $herevet) && + $fix) { + $fixed[$linenr - 1] =~ s/^+([ \t]+)/"+" . tabify($1)/e; + } }
# check we are in a valid C source file if not then ignore this hunk @@ -1944,7 +2276,7 @@ sub process { $realline_next); #print "LINE<$line>\n"; if ($linenr >= $suppress_statement && - $realcnt && $line =~ /.\s*\S/) { + $realcnt && $sline =~ /.\s*\S/) { ($stat, $cond, $line_nr_next, $remain_next, $off_next) = ctx_statement_block($linenr, $realcnt, 0); $stat =~ s/\n./\n /g; @@ -2193,7 +2525,7 @@ sub process { $prev_values = substr($curr_values, -1);
#ignore lines not being added - if ($line=~/^[^+]/) {next;} + next if ($line =~ /^[^+]/);
# TEST: allow direct testing of the type matcher. if ($dbg_type) { @@ -2244,8 +2576,15 @@ sub process {
# no C99 // comments if ($line =~ m{//}) { - ERROR("C99_COMMENTS", - "do not use C99 // comments\n" . $herecurr); + if (ERROR("C99_COMMENTS", + "do not use C99 // comments\n" . $herecurr) && + $fix) { + my $line = $fixed[$linenr - 1]; + if ($line =~ ///(.*)$/) { + my $comment = trim($1); + $fixed[$linenr - 1] =~ s@//(.*)$@/* $comment */@; + } + } } # Remove C99 comments. $line =~ s@//.*@@; @@ -2297,16 +2636,22 @@ sub process { }
# check for global initialisers. - if ($line =~ /^.$Type\s*$Ident\s*(?:\s+$Modifier)*\s*=\s*(0|NULL|false)\s*;/) { - ERROR("GLOBAL_INITIALISERS", - "do not initialise globals to 0 or NULL\n" . - $herecurr); + if ($line =~ /^+(\s*$Type\s*$Ident\s*(?:\s+$Modifier))*\s*=\s*(0|NULL|false)\s*;/) { + if (ERROR("GLOBAL_INITIALISERS", + "do not initialise globals to 0 or NULL\n" . + $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/($Type\s*$Ident\s*(?:\s+$Modifier))*\s*=\s*(0|NULL|false)\s*;/$1;/; + } } # check for static initialisers. - if ($line =~ /\bstatic\s.*=\s*(0|NULL|false)\s*;/) { - ERROR("INITIALISED_STATIC", - "do not initialise statics to 0 or NULL\n" . - $herecurr); + if ($line =~ /^+.*\bstatic\s.*=\s*(0|NULL|false)\s*;/) { + if (ERROR("INITIALISED_STATIC", + "do not initialise statics to 0 or NULL\n" . + $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/(\bstatic\s.*?)\s*=\s*(0|NULL|false)\s*;/$1;/; + } }
# check for static const char * arrays. @@ -2323,10 +2668,22 @@ sub process { $herecurr); }
-# check for declarations of struct pci_device_id - if ($line =~ /\bstruct\s+pci_device_id\s+\w+\s*[\s*]\s*=\s*{/) { - WARN("DEFINE_PCI_DEVICE_TABLE", - "Use DEFINE_PCI_DEVICE_TABLE for struct pci_device_id\n" . $herecurr); +# check for function declarations without arguments like "int foo()" + if ($line =~ /(\b$Type\s+$Ident)\s*(\s*)/) { + if (ERROR("FUNCTION_WITHOUT_ARGS", + "Bad function definition - $1() should probably be $1(void)\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/(\b($Type)\s+($Ident))\s*(\s*)/$2 $3(void)/; + } + } + +# check for uses of DEFINE_PCI_DEVICE_TABLE + if ($line =~ /\bDEFINE_PCI_DEVICE_TABLE\s*(\s*(\w+)\s*)\s*=/) { + if (WARN("DEFINE_PCI_DEVICE_TABLE", + "Prefer struct pci_device_id over deprecated DEFINE_PCI_DEVICE_TABLE\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\b(?:static\s+|)DEFINE_PCI_DEVICE_TABLE\s*(\s*(\w+)\s*)\s*=\s*/static const struct pci_device_id $1[] = /; + } }
# check for new typedefs, only function parameters and sparse annotations @@ -2344,7 +2701,7 @@ sub process { # (char*[ const]) while ($line =~ m{(($NonptrType(\s*(?:$Modifier\b\s*|*\s*)+)))}g) { #print "AA<$1>\n"; - my ($from, $to) = ($2, $2); + my ($ident, $from, $to) = ($1, $2, $2);
# Should start with a space. $to =~ s/^(\S)/ $1/; @@ -2354,15 +2711,22 @@ sub process { while ($to =~ s/*\s+*/**/) { }
- #print "from<$from> to<$to>\n"; +## print "1: from<$from> to<$to> ident<$ident>\n"; if ($from ne $to) { - ERROR("POINTER_LOCATION", - ""(foo$from)" should be "(foo$to)"\n" . $herecurr); + if (ERROR("POINTER_LOCATION", + ""(foo$from)" should be "(foo$to)"\n" . $herecurr) && + $fix) { + my $sub_from = $ident; + my $sub_to = $ident; + $sub_to =~ s/\Q$from\E/$to/; + $fixed[$linenr - 1] =~ + s@\Q$sub_from\E@$sub_to@; + } } } while ($line =~ m{(\b$NonptrType(\s*(?:$Modifier\b\s*|*\s*)+)($Ident))}g) { #print "BB<$1>\n"; - my ($from, $to, $ident) = ($2, $2, $3); + my ($match, $from, $to, $ident) = ($1, $2, $2, $3);
# Should start with a space. $to =~ s/^(\S)/ $1/; @@ -2374,10 +2738,18 @@ sub process { # Modifiers should have spaces. $to =~ s/(\b$Modifier$)/$1 /;
- #print "from<$from> to<$to> ident<$ident>\n"; +## print "2: from<$from> to<$to> ident<$ident>\n"; if ($from ne $to && $ident !~ /^$Modifier$/) { - ERROR("POINTER_LOCATION", - ""foo${from}bar" should be "foo${to}bar"\n" . $herecurr); + if (ERROR("POINTER_LOCATION", + ""foo${from}bar" should be "foo${to}bar"\n" . $herecurr) && + $fix) { + + my $sub_from = $match; + my $sub_to = $match; + $sub_to =~ s/\Q$from\E/$to/; + $fixed[$linenr - 1] =~ + s@\Q$sub_from\E@$sub_to@; + } } }
@@ -2434,8 +2806,12 @@ sub process { }
if ($line =~ /\bpr_warning\s*(/) { - WARN("PREFER_PR_LEVEL", - "Prefer pr_warn(... to pr_warning(...\n" . $herecurr); + if (WARN("PREFER_PR_LEVEL", + "Prefer pr_warn(... to pr_warning(...\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/\bpr_warning\b/pr_warn/; + } }
if ($line =~ /\bdev_printk\s*(\s*KERN_([A-Z]+)/) { @@ -2463,9 +2839,72 @@ sub process { }
# missing space after union, struct or enum definition - if ($line =~ /^.\s*(?:typedef\s+)?(enum|union|struct)(?:\s+$Ident)?(?:\s+$Ident)?[={]/) { - WARN("SPACING", - "missing space after $1 definition\n" . $herecurr); + if ($line =~ /^.\s*(?:typedef\s+)?(enum|union|struct)(?:\s+$Ident){1,2}[={]/) { + if (WARN("SPACING", + "missing space after $1 definition\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/^(.\s*(?:typedef\s+)?(?:enum|union|struct)(?:\s+$Ident){1,2})([={])/$1 $2/; + } + } + +# Function pointer declarations +# check spacing between type, funcptr, and args +# canonical declaration is "type (*funcptr)(args...)" +# +# the $Declare variable will capture all spaces after the type +# so check it for trailing missing spaces or multiple spaces + if ($line =~ /^.\s*($Declare)((\s*)*(\s*)$Ident(\s*))(\s*)(/) { + my $declare = $1; + my $pre_pointer_space = $2; + my $post_pointer_space = $3; + my $funcname = $4; + my $post_funcname_space = $5; + my $pre_args_space = $6; + + if ($declare !~ /\s$/) { + WARN("SPACING", + "missing space after return type\n" . $herecurr); + } + +# unnecessary space "type (*funcptr)(args...)" + elsif ($declare =~ /\s{2,}$/) { + WARN("SPACING", + "Multiple spaces after return type\n" . $herecurr); + } + +# unnecessary space "type ( *funcptr)(args...)" + if (defined $pre_pointer_space && + $pre_pointer_space =~ /^\s/) { + WARN("SPACING", + "Unnecessary space after function pointer open parenthesis\n" . $herecurr); + } + +# unnecessary space "type (* funcptr)(args...)" + if (defined $post_pointer_space && + $post_pointer_space =~ /^\s/) { + WARN("SPACING", + "Unnecessary space before function pointer name\n" . $herecurr); + } + +# unnecessary space "type (*funcptr )(args...)" + if (defined $post_funcname_space && + $post_funcname_space =~ /^\s/) { + WARN("SPACING", + "Unnecessary space after function pointer name\n" . $herecurr); + } + +# unnecessary space "type (*funcptr) (args...)" + if (defined $pre_args_space && + $pre_args_space =~ /^\s/) { + WARN("SPACING", + "Unnecessary space before function pointer arguments\n" . $herecurr); + } + + if (show_type("SPACING") && $fix) { + $fixed[$linenr - 1] =~ + s/^(.\s*$Declare)(\s**\s*($Ident)\s*)\s*(/rtrim($1) . " " . "(*$2)("/ex; + } }
# check for spacing round square brackets; allowed: @@ -2477,8 +2916,12 @@ sub process { if ($prefix !~ /$Type\s+$/ && ($where != 0 || $prefix !~ /^.\s+$/) && $prefix !~ /[{,]\s+$/) { - ERROR("BRACKET_SPACE", - "space prohibited before open square bracket '['\n" . $herecurr); + if (ERROR("BRACKET_SPACE", + "space prohibited before open square bracket '['\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/^(+.*?)\s+[/$1[/; + } } }
@@ -2495,7 +2938,6 @@ sub process { __attribute__|format|__extension__| asm|__asm__)$/x) { - # cpp #define statements have non-optional spaces, ie # if there is a space between the name and the open # parenthesis it is simply not a parameter group. @@ -2509,32 +2951,53 @@ sub process { } elsif ($ctx =~ /$Type$/) {
} else { - WARN("SPACING", - "space prohibited between function name and open parenthesis '('\n" . $herecurr); + if (WARN("SPACING", + "space prohibited between function name and open parenthesis '('\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/\b$name\s+(/$name(/; + } } }
-# check for whitespace before a non-naked semicolon - if ($line =~ /^+.*\S\s+;/) { - CHK("SPACING", - "space prohibited before semicolon\n" . $herecurr); - } - # Check operator spacing. if (!($line=~/#\s*include/)) { + my $fixed_line = ""; + my $line_fixed = 0; + my $ops = qr{ <<=|>>=|<=|>=|==|!=| +=|-=|*=|/=|%=|^=||=|&=| =>|->|<<|>>|<|>|=|!|~| &&||||,|^|++|--|&|||+|-|*|/|%| - ?|: + ?:|?|: }x; my @elements = split(/($ops|;)/, $opline); + +## print("element count: <" . $#elements . ">\n"); +## foreach my $el (@elements) { +## print("el: <$el>\n"); +## } + + my @fix_elements = (); my $off = 0;
+ foreach my $el (@elements) { + push(@fix_elements, substr($rawline, $off, length($el))); + $off += length($el); + } + + $off = 0; + my $blank = copy_spacing($opline); + my $last_after = -1;
for (my $n = 0; $n < $#elements; $n += 2) { + + my $good = $fix_elements[$n] . $fix_elements[$n + 1]; + +## print("n: <$n> good: <$good>\n"); + $off += length($elements[$n]);
# Pick up the preceding and succeeding characters. @@ -2591,8 +3054,11 @@ sub process { } elsif ($op eq ';') { if ($ctx !~ /.x[WEBC]/ && $cc !~ /^\/ && $cc !~ /^;/) { - ERROR("SPACING", - "space required after that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space required after that '$op' $at\n" . $hereptr)) { + $good = $fix_elements[$n] . trim($fix_elements[$n + 1]) . " "; + $line_fixed = 1; + } }
# // is a comment @@ -2603,15 +3069,25 @@ sub process { # : when part of a bitfield } elsif ($op eq '->' || $opv eq ':B') { if ($ctx =~ /Wx.|.xW/) { - ERROR("SPACING", - "spaces prohibited around that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "spaces prohibited around that '$op' $at\n" . $hereptr)) { + $good = rtrim($fix_elements[$n]) . trim($fix_elements[$n + 1]); + if (defined $fix_elements[$n + 2]) { + $fix_elements[$n + 2] =~ s/^\s+//; + } + $line_fixed = 1; + } }
# , must have a space on the right. } elsif ($op eq ',') { if ($ctx !~ /.x[WEC]/ && $cc !~ /^}/) { - ERROR("SPACING", - "space required after that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space required after that '$op' $at\n" . $hereptr)) { + $good = $fix_elements[$n] . trim($fix_elements[$n + 1]) . " "; + $line_fixed = 1; + $last_after = $n; + } }
# '*' as part of a type definition -- reported already. @@ -2625,34 +3101,56 @@ sub process { $opv eq '*U' || $opv eq '-U' || $opv eq '&U' || $opv eq '&&U') { if ($ctx !~ /[WEBC]x./ && $ca !~ /(?:)|!|~|*|-|&|||++|--|{)$/) { - ERROR("SPACING", - "space required before that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space required before that '$op' $at\n" . $hereptr)) { + if ($n != $last_after + 2) { + $good = $fix_elements[$n] . " " . ltrim($fix_elements[$n + 1]); + $line_fixed = 1; + } + } } if ($op eq '*' && $cc =~/\s*$Modifier\b/) { # A unary '*' may be const
} elsif ($ctx =~ /.xW/) { - ERROR("SPACING", - "space prohibited after that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space prohibited after that '$op' $at\n" . $hereptr)) { + $good = $fix_elements[$n] . rtrim($fix_elements[$n + 1]); + if (defined $fix_elements[$n + 2]) { + $fix_elements[$n + 2] =~ s/^\s+//; + } + $line_fixed = 1; + } }
# unary ++ and unary -- are allowed no space on one side. } elsif ($op eq '++' or $op eq '--') { if ($ctx !~ /[WEOBC]x[^W]/ && $ctx !~ /[^W]x[WOBEC]/) { - ERROR("SPACING", - "space required one side of that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space required one side of that '$op' $at\n" . $hereptr)) { + $good = $fix_elements[$n] . trim($fix_elements[$n + 1]) . " "; + $line_fixed = 1; + } } if ($ctx =~ /Wx[BE]/ || ($ctx =~ /Wx./ && $cc =~ /^;/)) { - ERROR("SPACING", - "space prohibited before that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space prohibited before that '$op' $at\n" . $hereptr)) { + $good = rtrim($fix_elements[$n]) . trim($fix_elements[$n + 1]); + $line_fixed = 1; + } } if ($ctx =~ /ExW/) { - ERROR("SPACING", - "space prohibited after that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space prohibited after that '$op' $at\n" . $hereptr)) { + $good = $fix_elements[$n] . trim($fix_elements[$n + 1]); + if (defined $fix_elements[$n + 2]) { + $fix_elements[$n + 2] =~ s/^\s+//; + } + $line_fixed = 1; + } }
- # << and >> may either have or not have spaces both sides } elsif ($op eq '<<' or $op eq '>>' or $op eq '&' or $op eq '^' or $op eq '|' or @@ -2661,17 +3159,25 @@ sub process { $op eq '%') { if ($ctx =~ /Wx[^WCE]|[^WCE]xW/) { - ERROR("SPACING", - "need consistent spacing around '$op' $at\n" . - $hereptr); + if (ERROR("SPACING", + "need consistent spacing around '$op' $at\n" . $hereptr)) { + $good = rtrim($fix_elements[$n]) . " " . trim($fix_elements[$n + 1]) . " "; + if (defined $fix_elements[$n + 2]) { + $fix_elements[$n + 2] =~ s/^\s+//; + } + $line_fixed = 1; + } }
# A colon needs no spaces before when it is # terminating a case value or a label. } elsif ($opv eq ':C' || $opv eq ':L') { if ($ctx =~ /Wx./) { - ERROR("SPACING", - "space prohibited before that '$op' $at\n" . $hereptr); + if (ERROR("SPACING", + "space prohibited before that '$op' $at\n" . $hereptr)) { + $good = rtrim($fix_elements[$n]) . trim($fix_elements[$n + 1]); + $line_fixed = 1; + } }
# All the others need spaces both sides. @@ -2684,21 +3190,49 @@ sub process { ($op eq '>' && $ca =~ /<\S+@\S+$/)) { - $ok = 1; - } - - # Ignore ?: - if (($opv eq ':O' && $ca =~ /?$/) || - ($op eq '?' && $cc =~ /^:/)) { - $ok = 1; + $ok = 1; }
+ # messages are ERROR, but ?: are CHK if ($ok == 0) { - ERROR("SPACING", - "spaces required around that '$op' $at\n" . $hereptr); + my $msg_type = &ERROR; + $msg_type = &CHK if (($op eq '?:' || $op eq '?' || $op eq ':') && $ctx =~ /VxV/); + + if (&{$msg_type}("SPACING", + "spaces required around that '$op' $at\n" . $hereptr)) { + $good = rtrim($fix_elements[$n]) . " " . trim($fix_elements[$n + 1]) . " "; + if (defined $fix_elements[$n + 2]) { + $fix_elements[$n + 2] =~ s/^\s+//; + } + $line_fixed = 1; + } } } $off += length($elements[$n + 1]); + +## print("n: <$n> GOOD: <$good>\n"); + + $fixed_line = $fixed_line . $good; + } + + if (($#elements % 2) == 0) { + $fixed_line = $fixed_line . $fix_elements[$#elements]; + } + + if ($fix && $line_fixed && $fixed_line ne $fixed[$linenr - 1]) { + $fixed[$linenr - 1] = $fixed_line; + } + + + } + +# check for whitespace before a non-naked semicolon + if ($line =~ /^+.*\S\s+;\s*$/) { + if (WARN("SPACING", + "space prohibited before semicolon\n" . $herecurr) && + $fix) { + 1 while $fixed[$linenr - 1] =~ + s/^(+.*\S)\s+;/$1;/; } }
@@ -2727,63 +3261,87 @@ sub process { #need space before brace following if, while, etc if (($line =~ /(.*){/ && $line !~ /($Type){/) || $line =~ /do{/) { - ERROR("SPACING", - "space required before the open brace '{'\n" . $herecurr); + if (ERROR("SPACING", + "space required before the open brace '{'\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/^(+.*(?:do|))){/$1 {/; + } }
+## # check for blank lines before declarations +## if ($line =~ /^.\t+$Type\s+$Ident(?:\s*=.*)?;/ && +## $prevrawline =~ /^.\s*$/) { +## WARN("SPACING", +## "No blank lines before declarations\n" . $hereprev); +## } +## + # closing brace should have a space following it when it has anything # on the line if ($line =~ /}(?!(?:,|;|)))\S/) { - ERROR("SPACING", - "space required after that close brace '}'\n" . $herecurr); + if (ERROR("SPACING", + "space required after that close brace '}'\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/}((?!(?:,|;|)))\S)/} $1/; + } }
# check spacing on square brackets if ($line =~ /[\s/ && $line !~ /[\s*$/) { - ERROR("SPACING", - "space prohibited after that open square bracket '['\n" . $herecurr); + if (ERROR("SPACING", + "space prohibited after that open square bracket '['\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/[\s+/[/; + } } if ($line =~ /\s]/) { - ERROR("SPACING", - "space prohibited before that close square bracket ']'\n" . $herecurr); + if (ERROR("SPACING", + "space prohibited before that close square bracket ']'\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/\s+]/]/; + } }
# check spacing on parentheses if ($line =~ /(\s/ && $line !~ /(\s*(?:\)?$/ && $line !~ /for\s*(\s+;/) { - ERROR("SPACING", - "space prohibited after that open parenthesis '('\n" . $herecurr); + if (ERROR("SPACING", + "space prohibited after that open parenthesis '('\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/(\s+/(/; + } } if ($line =~ /(\s+))/ && $line !~ /^.\s*)/ && $line !~ /for\s*(.*;\s+)/ && $line !~ /:\s+)/) { - ERROR("SPACING", - "space prohibited before that close parenthesis ')'\n" . $herecurr); + if (ERROR("SPACING", + "space prohibited before that close parenthesis ')'\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/\s+)/)/; + } }
#goto labels aren't indented, allow a single space however if ($line=~/^.\s+[A-Za-z\d_]+:(?![0-9]+)/ and !($line=~/^. [A-Za-z\d_]+:/) and !($line=~/^.\s+default:/)) { - WARN("INDENTED_LABEL", - "labels should not be indented\n" . $herecurr); + if (WARN("INDENTED_LABEL", + "labels should not be indented\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/^(.)\s+/$1/; + } }
# Return is not a function. - if (defined($stat) && $stat =~ /^.\s*return(\s*)((.*);/s) { + if (defined($stat) && $stat =~ /^.\s*return(\s*)(/s) { my $spacing = $1; - my $value = $2; - - # Flatten any parentheses - $value =~ s/(/ (/g; - $value =~ s/)/) /g; - while ($value =~ s/[[^[]]*]/1/ || - $value !~ /(?:$Ident|-?$Constant)\s* - $Compare\s* - (?:$Ident|-?$Constant)/x && - $value =~ s/([^()]*)/1/) { - } -#print "value<$value>\n"; - if ($value =~ /^\s*(?:$Ident|-?$Constant)\s*$/) { + if ($^V && $^V ge 5.10.0 && + $stat =~ /^.\s*return\s*$balanced_parens\s*;\s*$/) { ERROR("RETURN_PARENTHESES", "return is not a function, parentheses are not required\n" . $herecurr);
@@ -2792,6 +3350,21 @@ sub process { "space required before the open parenthesis '('\n" . $herecurr); } } + +# if statements using unnecessary parentheses - ie: if ((foo == bar)) + if ($^V && $^V ge 5.10.0 && + $line =~ /\bif\s*((?:(\s*){2,})/) { + my $openparens = $1; + my $count = $openparens =~ tr@(@(@; + my $msg = ""; + if ($line =~ /\bif\s*(?:(\s*){$count,$count}$LvalOrFunc\s*($Compare)\s*$LvalOrFunc(?:\s*)){$count,$count}/) { + my $comp = $4; #Not $1 because of $LvalOrFunc + $msg = " - maybe == should be = ?" if ($comp eq "=="); + WARN("UNNECESSARY_PARENTHESES", + "Unnecessary parentheses$msg\n" . $herecurr); + } + } + # Return of what appears to be an errno should normally be -'ve if ($line =~ /^.\s*return\s*(E[A-Z]*)\s*;/) { my $name = $1; @@ -2802,8 +3375,13 @@ sub process { }
# Need a space before open parenthesis after if, while etc - if ($line=~/\b(if|while|for|switch)(/) { - ERROR("SPACING", "space required before the open parenthesis '('\n" . $herecurr); + if ($line =~ /\b(if|while|for|switch)(/) { + if (ERROR("SPACING", + "space required before the open parenthesis '('\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/\b(if|while|for|switch)(/$1 (/; + } }
# Check for illegal assignment in if conditional -- and check for trailing @@ -2830,6 +3408,7 @@ sub process { } } if (!defined $suppress_whiletrailers{$linenr} && + defined($stat) && defined($cond) && $line =~ /\b(?:if|while|for)\s*(/ && $line !~ /^.\s*#/) { my ($s, $c) = ($stat, $cond);
@@ -2927,23 +3506,54 @@ sub process { } }
-#CamelCase +#Specific variable tests while ($line =~ m{($Constant|$Lval)}g) { my $var = $1; - if ($var !~ /$Constant/ && - $var =~ /[A-Z]\w*[a-z]|[a-z]\w*[A-Z]/ && - $var !~ /"^(?:Clear|Set|TestClear|TestSet|)Page[A-Z]/ && - !defined $camelcase{$var}) { - $camelcase{$var} = 1; - WARN("CAMELCASE", - "Avoid CamelCase: <$var>\n" . $herecurr); + +#gcc binary extension + if ($var =~ /^$Binary$/) { + if (WARN("GCC_BINARY_CONSTANT", + "Avoid gcc v4.3+ binary constant extension: <$var>\n" . $herecurr) && + $fix) { + my $hexval = sprintf("0x%x", oct($var)); + $fixed[$linenr - 1] =~ + s/\b$var\b/$hexval/; + } + } + +#CamelCase + if ($var !~ /^$Constant$/ && + $var =~ /[A-Z][a-z]|[a-z][A-Z]/ && +#Ignore Page<foo> variants + $var !~ /^(?:Clear|Set|TestClear|TestSet|)Page[A-Z]/ && +#Ignore SI style variants like nS, mV and dB (ie: max_uV, regulator_min_uA_show) + $var !~ /^(?:[a-z_]*?)_?[a-z][A-Z](?:_[a-z_]+)?$/) { + while ($var =~ m{($Ident)}g) { + my $word = $1; + next if ($word !~ /[A-Z][a-z]|[a-z][A-Z]/); + if ($check) { + seed_camelcase_includes(); + if (!$file && !$camelcase_file_seeded) { + seed_camelcase_file($realfile); + $camelcase_file_seeded = 1; + } + } + if (!defined $camelcase{$word}) { + $camelcase{$word} = 1; + CHK("CAMELCASE", + "Avoid CamelCase: <$word>\n" . $herecurr); + } + } } }
#no spaces allowed after \ in define - if ($line=~/#\s*define.*\\s$/) { - WARN("WHITESPACE_AFTER_LINE_CONTINUATION", - "Whitepspace after \ makes next lines useless\n" . $herecurr); + if ($line =~ /#\s*define.*\\s+$/) { + if (WARN("WHITESPACE_AFTER_LINE_CONTINUATION", + "Whitespace after \ makes next lines useless\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\s+$//; + } }
#warn if <asm/foo.h> is #included and <linux/foo.h> is available (uses RAW line) @@ -3014,15 +3624,17 @@ sub process { if ($dstat ne '' && $dstat !~ /^(?:$Ident|-?$Constant),$/ && # 10, // foo(), $dstat !~ /^(?:$Ident|-?$Constant);$/ && # foo(); - $dstat !~ /^[!~-]?(?:$Ident|$Constant)$/ && # 10 // foo() // !foo // ~foo // -foo + $dstat !~ /^[!~-]?(?:$Lval|$Constant)$/ && # 10 // foo() // !foo // ~foo // -foo // foo->bar // foo.bar->baz $dstat !~ /^'X'$/ && # character constants $dstat !~ /$exceptions/ && $dstat !~ /^.$Ident\s*=/ && # .foo = + $dstat !~ /^(?:#\s*$Ident|#\s*$Constant)\s*$/ && # stringification #foo $dstat !~ /^do\s*$Constant\s*while\s*$Constant;?$/ && # do {...} while (...); // do {...} while (...) $dstat !~ /^for\s*$Constant$/ && # for (...) $dstat !~ /^for\s*$Constant\s+(?:$Ident|-?$Constant)$/ && # for (...) bar() $dstat !~ /^do\s*{/ && # do {... - $dstat !~ /^({/) # ({... + $dstat !~ /^({/ && # ({... + $ctx !~ /^.\s*#\s*define\s+TRACE_(?:SYSTEM|INCLUDE_FILE|INCLUDE_PATH)\b/) { $ctx =~ s/\n*$//; my $herectx = $here . "\n"; @@ -3222,11 +3834,11 @@ sub process { }
# check for unnecessary blank lines around braces - if (($line =~ /^..*}\s*$/ && $prevline =~ /^.\s*$/)) { + if (($line =~ /^.\s*}\s*$/ && $prevrawline =~ /^.\s*$/)) { CHK("BRACES", "Blank lines aren't necessary before a close brace '}'\n" . $hereprev); } - if (($line =~ /^.\s*$/ && $prevline =~ /^..*{\s*$/)) { + if (($rawline =~ /^.\s*$/ && $prevline =~ /^..*{\s*$/)) { CHK("BRACES", "Blank lines aren't necessary after an open brace '{'\n" . $hereprev); } @@ -3254,6 +3866,53 @@ sub process { } }
+# check for bad placement of section $InitAttribute (e.g.: __initdata) + if ($line =~ /(\b$InitAttribute\b)/) { + my $attr = $1; + if ($line =~ /^+\s*static\s+(?:const\s+)?(?:$attr\s+)?($NonptrTypeWithAttr)\s+(?:$attr\s+)?($Ident(?:[[^]]*])?)\s*[=;]/) { + my $ptr = $1; + my $var = $2; + if ((($ptr =~ /\b(union|struct)\s+$attr\b/ && + ERROR("MISPLACED_INIT", + "$attr should be placed after $var\n" . $herecurr)) || + ($ptr !~ /\b(union|struct)\s+$attr\b/ && + WARN("MISPLACED_INIT", + "$attr should be placed after $var\n" . $herecurr))) && + $fix) { + $fixed[$linenr - 1] =~ s/(\bstatic\s+(?:const\s+)?)(?:$attr\s+)?($NonptrTypeWithAttr)\s+(?:$attr\s+)?($Ident(?:[[^]]*])?)\s*([=;])\s*/"$1" . trim(string_find_replace($2, "\s*$attr\s*", " ")) . " " . trim(string_find_replace($3, "\s*$attr\s*", "")) . " $attr" . ("$4" eq ";" ? ";" : " = ")/e; + } + } + } + +# check for $InitAttributeData (ie: __initdata) with const + if ($line =~ /\bconst\b/ && $line =~ /($InitAttributeData)/) { + my $attr = $1; + $attr =~ /($InitAttributePrefix)(.*)/; + my $attr_prefix = $1; + my $attr_type = $2; + if (ERROR("INIT_ATTRIBUTE", + "Use of const init definition must use ${attr_prefix}initconst\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/$InitAttributeData/${attr_prefix}initconst/; + } + } + +# check for $InitAttributeConst (ie: __initconst) without const + if ($line !~ /\bconst\b/ && $line =~ /($InitAttributeConst)/) { + my $attr = $1; + if (ERROR("INIT_ATTRIBUTE", + "Use of $attr requires a separate use of const\n" . $herecurr) && + $fix) { + my $lead = $fixed[$linenr - 1] =~ + /(^+\s*(?:static\s+))/; + $lead = rtrim($1); + $lead = "$lead " if ($lead !~ /^+$/); + $lead = "${lead}const "; + $fixed[$linenr - 1] =~ s/(^+\s*(?:static\s+))/$lead/; + } + } + # prefer usleep_range over udelay if ($line =~ /\budelay\s*(\s*(\d+)\s*)/) { # ignore udelay's < 10, however @@ -3271,6 +3930,18 @@ sub process { } }
+# check for comparisons of jiffies + if ($line =~ /\bjiffies\s*$Compare|$Compare\s*jiffies\b/) { + WARN("JIFFIES_COMPARISON", + "Comparing jiffies is almost always wrong; prefer time_after, time_before and friends\n" . $herecurr); + } + +# check for comparisons of get_jiffies_64() + if ($line =~ /\bget_jiffies_64\s*(\s*)\s*$Compare|$Compare\s*get_jiffies_64\s*(\s*)/) { + WARN("JIFFIES_COMPARISON", + "Comparing get_jiffies_64() is almost always wrong; prefer time_after64, time_before64 and friends\n" . $herecurr); + } + # warn about #ifdefs in C files # if ($line =~ /^.\s*#\s*if(|n)def/ && ($realfile =~ /.c$/)) { # print "#ifdef in C files should be avoided\n"; @@ -3280,8 +3951,13 @@ sub process {
# warn about spacing in #ifdefs if ($line =~ /^.\s*#\s*(ifdef|ifndef|elif)\s\s+/) { - ERROR("SPACING", - "exactly one space required after that #$1\n" . $herecurr); + if (ERROR("SPACING", + "exactly one space required after that #$1\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ + s/^(.\s*#\s*(ifdef|ifndef|elif))\s{2,}/$1 /; + } + }
# check for spinlock_t definitions without a comment. @@ -3296,8 +3972,8 @@ sub process { # check for memory barriers without a comment. if ($line =~ /\b(mb|rmb|wmb|read_barrier_depends|smp_mb|smp_rmb|smp_wmb|smp_read_barrier_depends)(/) { if (!ctx_has_comment($first_line, $linenr)) { - CHK("MEMORY_BARRIER", - "memory barrier without comment\n" . $herecurr); + WARN("MEMORY_BARRIER", + "memory barrier without comment\n" . $herecurr); } } # check of hardware specific defines @@ -3321,13 +3997,19 @@ sub process { }
# Check for __inline__ and __inline, prefer inline - if ($line =~ /\b(__inline__|__inline)\b/) { - WARN("INLINE", - "plain inline is preferred over $1\n" . $herecurr); + if ($realfile !~ m@\binclude/uapi/@ && + $line =~ /\b(__inline__|__inline)\b/) { + if (WARN("INLINE", + "plain inline is preferred over $1\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\b(__inline__|__inline)\b/inline/; + + } }
# Check for __attribute__ packed, prefer __packed - if ($line =~ /\b__attribute__\s*(\s*(.*\bpacked\b/) { + if ($realfile !~ m@\binclude/uapi/@ && + $line =~ /\b__attribute__\s*(\s*(.*\bpacked\b/) { WARN("PREFER_PACKED", "__packed is preferred over __attribute__((packed))\n" . $herecurr); } @@ -3338,21 +4020,31 @@ sub process { }
# Check for __attribute__ aligned, prefer __aligned - if ($line =~ /\b__attribute__\s*(\s*(.*aligned/) { + if ($realfile !~ m@\binclude/uapi/@ && + $line =~ /\b__attribute__\s*(\s*(.*aligned/) { WARN("PREFER_ALIGNED", "__aligned(size) is preferred over __attribute__((aligned(size)))\n" . $herecurr); }
# Check for __attribute__ format(printf, prefer __printf - if ($line =~ /\b__attribute__\s*(\s*(\s*format\s*(\s*printf/) { - WARN("PREFER_PRINTF", - "__printf(string-index, first-to-check) is preferred over __attribute__((format(printf, string-index, first-to-check)))\n" . $herecurr); + if ($realfile !~ m@\binclude/uapi/@ && + $line =~ /\b__attribute__\s*(\s*(\s*format\s*(\s*printf/) { + if (WARN("PREFER_PRINTF", + "__printf(string-index, first-to-check) is preferred over __attribute__((format(printf, string-index, first-to-check)))\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\b__attribute__\s*(\s*(\s*format\s*(\s*printf\s*,\s*(.*))\s*)\s*)/"__printf(" . trim($1) . ")"/ex; + + } }
# Check for __attribute__ format(scanf, prefer __scanf - if ($line =~ /\b__attribute__\s*(\s*(\s*format\s*(\s*scanf\b/) { - WARN("PREFER_SCANF", - "__scanf(string-index, first-to-check) is preferred over __attribute__((format(scanf, string-index, first-to-check)))\n" . $herecurr); + if ($realfile !~ m@\binclude/uapi/@ && + $line =~ /\b__attribute__\s*(\s*(\s*format\s*(\s*scanf\b/) { + if (WARN("PREFER_SCANF", + "__scanf(string-index, first-to-check) is preferred over __attribute__((format(scanf, string-index, first-to-check)))\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\b__attribute__\s*(\s*(\s*format\s*(\s*scanf\s*,\s*(.*))\s*)\s*)/"__scanf(" . trim($1) . ")"/ex; + } }
# check for sizeof(&) @@ -3363,8 +4055,11 @@ sub process {
# check for sizeof without parenthesis if ($line =~ /\bsizeof\s+((?:*\s*|)$Lval|$Type(?:\s+$Lval|))/) { - WARN("SIZEOF_PARENTHESIS", - "sizeof $1 should be sizeof($1)\n" . $herecurr); + if (WARN("SIZEOF_PARENTHESIS", + "sizeof $1 should be sizeof($1)\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\bsizeof\s+((?:*\s*|)$Lval|$Type(?:\s+$Lval|))/"sizeof(" . trim($1) . ")"/ex; + } }
# check for line continuations in quoted strings with odd counts of " @@ -3379,6 +4074,18 @@ sub process { "struct spinlock should be spinlock_t\n" . $herecurr); }
+# check for seq_printf uses that could be seq_puts + if ($sline =~ /\bseq_printf\s*(.*"\s*)\s*;\s*$/) { + my $fmt = get_quoted_string($line, $rawline); + if ($fmt ne "" && $fmt !~ /[^\]%/) { + if (WARN("PREFER_SEQ_PUTS", + "Prefer seq_puts to seq_printf\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\bseq_printf\b/seq_puts/; + } + } + } + # Check for misused memsets if ($^V && $^V ge 5.10.0 && defined $stat && @@ -3397,6 +4104,16 @@ sub process { } }
+# Check for memcpy(foo, bar, ETH_ALEN) that could be ether_addr_copy(foo, bar) + if ($^V && $^V ge 5.10.0 && + $line =~ /^+(?:.*?)\bmemcpy\s*(\s*$FuncArg\s*,\s*$FuncArg\s*,\s*ETH_ALEN\s*)/s) { + if (WARN("PREFER_ETHER_ADDR_COPY", + "Prefer ether_addr_copy() over memcpy() if the Ethernet addresses are __aligned(2)\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\bmemcpy\s*(\s*$FuncArg\s*,\s*$FuncArg\s*,\s*ETH_ALEN\s*)/ether_addr_copy($2, $7)/; + } + } + # typecasts on min/max could be min_t/max_t if ($^V && $^V ge 5.10.0 && defined $stat && @@ -3437,6 +4154,33 @@ sub process { } }
+# check for naked sscanf + if ($^V && $^V ge 5.10.0 && + defined $stat && + $stat =~ /\bsscanf\b/ && + ($stat !~ /$Ident\s*=\s*sscanf\s*$balanced_parens/ && + $stat !~ /\bsscanf\s*$balanced_parens\s*(?:$Compare)/ && + $stat !~ /(?:$Compare)\s*\bsscanf\s*$balanced_parens/)) { + my $lc = $stat =~ tr@\n@@; + $lc = $lc + $linenr; + my $stat_real = raw_line($linenr, 0); + for (my $count = $linenr + 1; $count <= $lc; $count++) { + $stat_real = $stat_real . "\n" . raw_line($count, 0); + } + WARN("NAKED_SSCANF", + "unchecked sscanf return value\n" . "$here\n$stat_real\n"); + } + +# check for new externs in .h files. + if ($realfile =~ /.h$/ && + $line =~ /^+\s*(extern\s+)$Type\s*$Ident\s*(/s) { + if (CHK("AVOID_EXTERNS", + "extern prototypes should be avoided in .h files\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/(.*)\bextern\b\s*(.*)/$1$2/; + } + } + # check for new externs in .c files. if ($realfile =~ /.c$/ && defined $stat && $stat =~ /^.\s*(?:extern\s+)?$Type\s+($Ident)(\s*)(/s) @@ -3483,16 +4227,65 @@ sub process { "unnecessary cast may hide bugs, see http://c-faq.com/malloc/mallocnocast.html%5Cn" . $herecurr); }
+# alloc style +# p = alloc(sizeof(struct foo), ...) should be p = alloc(sizeof(*p), ...) + if ($^V && $^V ge 5.10.0 && + $line =~ /\b($Lval)\s*=\s*(?:$balanced_parens)?\s*([kv][mz]alloc(?:_node)?)\s*(\s*(sizeof\s*(\s*struct\s+$Lval\s*))/) { + CHK("ALLOC_SIZEOF_STRUCT", + "Prefer $3(sizeof(*$1)...) over $3($4...)\n" . $herecurr); + } + +# check for krealloc arg reuse + if ($^V && $^V ge 5.10.0 && + $line =~ /\b($Lval)\s*=\s*(?:$balanced_parens)?\s*krealloc\s*(\s*\1\s*,/) { + WARN("KREALLOC_ARG_REUSE", + "Reusing the krealloc arg is almost always a bug\n" . $herecurr); + } + # check for alloc argument mismatch if ($line =~ /\b(kcalloc|kmalloc_array)\s*(\s*sizeof\b/) { WARN("ALLOC_ARRAY_ARGS", "$1 uses number as first arg, sizeof is generally wrong\n" . $herecurr); }
+# check for GFP_NOWAIT use + if ($line =~ /\b__GFP_NOFAIL\b/) { + WARN("__GFP_NOFAIL", + "Use of __GFP_NOFAIL is deprecated, no new users should be added\n" . $herecurr); + } + # check for multiple semicolons if ($line =~ /;\s*;\s*$/) { - WARN("ONE_SEMICOLON", - "Statements terminations use 1 semicolon\n" . $herecurr); + if (WARN("ONE_SEMICOLON", + "Statements terminations use 1 semicolon\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/(\s*;\s*){2,}$/;/g; + } + } + +# check for case / default statements not preceeded by break/fallthrough/switch + if ($line =~ /^.\s*(?:case\s+(?:$Ident|$Constant)\s*|default):/) { + my $has_break = 0; + my $has_statement = 0; + my $count = 0; + my $prevline = $linenr; + while ($prevline > 1 && $count < 3 && !$has_break) { + $prevline--; + my $rline = $rawlines[$prevline - 1]; + my $fline = $lines[$prevline - 1]; + last if ($fline =~ /^@@/); + next if ($fline =~ /^-/); + next if ($fline =~ /^.(?:\s*(?:case\s+(?:$Ident|$Constant)[\s$;]*|default):[\s$;]*)*$/); + $has_break = 1 if ($rline =~ /fall[\s_-]*(through|thru)/i); + next if ($fline =~ /^.[\s$;]*$/); + $has_statement = 1; + $count++; + $has_break = 1 if ($fline =~ /\bswitch\b|\b(?:break\s*;[\s$;]*$|return\b|goto\b|continue\b)/); + } + if (!$has_break && $has_statement) { + WARN("MISSING_BREAK", + "Possible switch case/default not preceeded by break or fallthrough comment\n" . $herecurr); + } }
# check for switch/default statements without a break; @@ -3510,9 +4303,12 @@ sub process { }
# check for gcc specific __FUNCTION__ - if ($line =~ /__FUNCTION__/) { - WARN("USE_FUNC", - "__func__ should be used instead of gcc specific __FUNCTION__\n" . $herecurr); + if ($line =~ /\b__FUNCTION__\b/) { + if (WARN("USE_FUNC", + "__func__ should be used instead of gcc specific __FUNCTION__\n" . $herecurr) && + $fix) { + $fixed[$linenr - 1] =~ s/\b__FUNCTION__\b/__func__/g; + } }
# check for use of yield() @@ -3521,6 +4317,33 @@ sub process { "Using yield() is generally wrong. See yield() kernel-doc (sched/core.c)\n" . $herecurr); }
+# check for comparisons against true and false + if ($line =~ /+\s*(.*?)\b(true|false|$Lval)\s*(==|!=)\s*(true|false|$Lval)\b(.*)$/i) { + my $lead = $1; + my $arg = $2; + my $test = $3; + my $otype = $4; + my $trail = $5; + my $op = "!"; + + ($arg, $otype) = ($otype, $arg) if ($arg =~ /^(?:true|false)$/i); + + my $type = lc($otype); + if ($type =~ /^(?:true|false)$/) { + if (("$test" eq "==" && "$type" eq "true") || + ("$test" eq "!=" && "$type" eq "false")) { + $op = ""; + } + + CHK("BOOL_COMPARISON", + "Using comparison to $otype is error prone\n" . $herecurr); + +## maybe suggesting a correct construct would better +## "Using comparison to $otype is error prone. Perhaps use '${lead}${op}${arg}${trail}'\n" . $herecurr); + + } + } + # check for semaphores initialized locked if ($line =~ /^.\s*sema_init.+,\W?0\W?)/) { WARN("CONSIDER_COMPLETION", @@ -3597,6 +4420,12 @@ sub process { "usage of NR_CPUS is often wrong - consider using cpu_possible(), num_possible_cpus(), for_each_possible_cpu(), etc\n" . $herecurr); }
+# Use of __ARCH_HAS_<FOO> or ARCH_HAVE_<BAR> is wrong. + if ($line =~ /+\s*#\s*define\s+((?:__)?ARCH_(?:HAS|HAVE)\w*)\b/) { + ERROR("DEFINE_ARCH_HAS", + "#define of '$1' is wrong - use Kconfig variables or standard guards instead\n" . $herecurr); + } + # check for %L{u,d,i} in strings my $string; while ($line =~ /(?:^|")([X\t]*)(?:"|$)/g) { @@ -3690,12 +4519,42 @@ sub process { } }
- if ($quiet == 0 && keys %ignore_type) { - print "NOTE: Ignored message types:"; - foreach my $ignore (sort keys %ignore_type) { - print " $ignore"; - } - print "\n\n"; + hash_show_words(%use_type, "Used"); + hash_show_words(%ignore_type, "Ignored"); + + if ($clean == 0 && $fix && "@rawlines" ne "@fixed") { + my $newfile = $filename; + $newfile .= ".EXPERIMENTAL-checkpatch-fixes" if (!$fix_inplace); + my $linecount = 0; + my $f; + + open($f, '>', $newfile) + or die "$P: Can't open $newfile for write\n"; + foreach my $fixed_line (@fixed) { + $linecount++; + if ($file) { + if ($linecount > 3) { + $fixed_line =~ s/^+//; + print $f $fixed_line. "\n"; + } + } else { + print $f $fixed_line . "\n"; + } + } + close($f); + + if (!$quiet) { + print << "EOM"; +Wrote EXPERIMENTAL --fix correction(s) to '$newfile' + +Do _NOT_ trust the results written to this file. +Do _NOT_ submit these changes without inspecting them for correctness. + +This EXPERIMENTAL file is simply a convenience to help rewrite patches. +No warranties, expressed or implied... + +EOM + } }
if ($clean == 1 && $quiet == 0) { @@ -3706,7 +4565,7 @@ sub process { $vname has style problems, please review.
If any of these errors are false positives, please report -them to the maintainer, see boards.cfg. +them to the maintainer, see CHECKPATCH in MAINTAINERS. EOM }
On Thu, Feb 27, 2014 at 08:27:28AM -0500, Tom Rini wrote:
Update to v3.14-rc4's version of checkpatch.pl. In doing so we drop the changes to top_of_kernel_tree() as we pass in --no-tree and drop our changes about MAINTAINERS as that's for reporting checkpatch.pl problems itself (and upstream has said they'll reword this section to be clearer).
Signed-off-by: Tom Rini trini@ti.com
