Pull request for UEFI sub-system for efi-2020-07-rc2-4
The following changes since commit c5c657644bc35fd6b3d6e5517698721e90646b8d:
Merge branch '2020-05-08-assorted-fixes' (2020-05-08 18:58:19 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2020-07-rc2-4
for you to fetch changes up to bdb15776f6d93a1fe7902346db06a2a9fd43381e:
cmd: efidebug: fix -Werror=type-limits warning (2020-05-10 00:01:12 +0200)
No problems were reported by Gitlab CI and Travis: https://travis-ci.org/github/xypron2/u-boot/builds/685166920 https://gitlab.denx.de/u-boot/custodians/u-boot-efi/pipelines/3170
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2020-07-rc2-4
This pull request comprises: * bug fixes * documentation fixes * a new function to determine u16 string sizes and its unit test
---------------------------------------------------------------- AKASHI Takahiro (4): efi_loader: image_loader: fix a Coverity check against array access efi_loader: variable: check a return value of uuid__str_to_bin() cmd: efidebug: fix a wrong handling of arguments cmd: efidebug: add a comment against Coverity check (300329)
Heinrich Schuchardt (5): efi_selftest: add unit test functions to HTML documentation test: unit test for u16_strsize() lib: charset: correct function descriptions doc: add Unicode functions to API description cmd: efidebug: fix -Werror=type-limits warning
Sughosh Ganu (1): charset: Add support for calculating bytes occupied by a u16 string
cmd/efidebug.c | 9 +++- doc/api/efi.rst | 9 ++++ doc/api/index.rst | 1 + doc/api/unicode.rst | 7 +++ include/charset.h | 49 ++++++++++++----- include/efi_selftest.h | 110 +++++++++++++++++++++++++------------- lib/charset.c | 5 ++ lib/efi_loader/efi_image_loader.c | 6 +-- lib/efi_loader/efi_variable.c | 5 +- test/unicode_ut.c | 10 ++++ 10 files changed, 154 insertions(+), 57 deletions(-) create mode 100644 doc/api/unicode.rst
