[U-Boot] [PATCH 6/7 v4] 83xx, kmeter: QE_ENET10 errata for Silicon Revision 2.1
old code implemented the QE_ENET10 errata only for Silicon Revision 2.0. New code reads now the Silicon Revision register and sets dependend on the Silicon Revision the values as advised in the QE_ENET10 errata.
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/kmeter1/kmeter1.c | 20 ++++++++++++-------- 1 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/board/keymile/kmeter1/kmeter1.c b/board/keymile/kmeter1/kmeter1.c index 4f41f1d..660d87b 100644 --- a/board/keymile/kmeter1/kmeter1.c +++ b/board/keymile/kmeter1/kmeter1.c @@ -24,6 +24,7 @@ #include <miiphy.h> #include <asm/io.h> #include <asm/mmu.h> +#include <asm/processor.h> #include <pci.h> #include <libfdt.h>
@@ -80,19 +81,22 @@ static int board_init_i2c_busses (void)
int board_early_init_r (void) { - void *reg = (void *)(CONFIG_SYS_IMMR + 0x14a8); - u32 val; + unsigned short svid;
/* * Because of errata in the UCCs, we have to write to the reserved * registers to slow the clocks down. */ - val = in_be32 (reg); - /* UCC1 */ - val |= 0x00003000; - /* UCC2 */ - val |= 0x0c000000; - out_be32 (reg, val); + svid = SVR_REV(mfspr (SVR)); + switch (svid) { + case 0x0020: + setbits_be32((void *)(CONFIG_SYS_IMMR + 0x14a8), 0x0c003000); + break; + case 0x0021: + clrsetbits_be32((void *)(CONFIG_SYS_IMMR + 0x14ac), + 0x00000050, 0x000000a0); + break; + } /* enable the PHY on the PIGGY */ setbits (8, (void *)(CONFIG_SYS_PIGGY_BASE + 0x10003), 0x01);
Heiko Schocher
