[U-Boot] [PATCH v2] gpio: Add support for microblaze xilinx GPIO
Microblaze uses gpio which is connected to the system reset. Currently gpio subsystem wasn't used for it.
Add gpio driver and change Microblaze reset logic to be done via gpio subsystem.
There are various configurations which Microblaze can have that's why gpio_alloc/gpio_alloc_dual(for dual channel) function has been introduced and gpio can be allocated dynamically.
Adding several gpios IP is also possible and supported.
For listing gpio configuration please use "gpio status" command
This patch also remove one compilation warning: microblaze-generic.c: In function 'do_reset': microblaze-generic.c:38:47: warning: operation on '*1073741824u' may be undefined [-Wsequence-point]
Signed-off-by: Michal Simek michal.simek@xilinx.com --- Changes in v2: - Use asm-generic/gpio.h file - Add gpio_set_value() - Check return value from gpio_get_controller
GPIO support for Microblaze I want to also write gpio support for Zynq and this driver should be also used for arm zynq.
Currently we have support just for only gpio controller but not for various of them. That's why I would like to get some input from you if possible to add dynamic gpio allocation which could be also helpful for OF support.
Output from my gpio status on Microblaze is below.
Thanks, Michal
U-Boot> gpio status
gpio_info: reset/40000000 (0-0) GPIO_0: reset_pin is an INPUT value = 0
gpio_info: led/40040000 (1-5) GPIO_1: UNKNOWN is an INPUT value = 0 GPIO_2: UNKNOWN is an OUTPUT value = 1 GPIO_3: UNKNOWN is an INPUT value = 0 GPIO_4: UNKNOWN is an INPUT value = 0 GPIO_5: UNKNOWN is an OUTPUT value = 0
--- arch/microblaze/include/asm/gpio.h | 40 +-- .../xilinx/microblaze-generic/microblaze-generic.c | 17 +- drivers/gpio/Makefile | 1 + drivers/gpio/xilinx_gpio.c | 364 +++++++++++++++++++++ include/configs/microblaze-generic.h | 3 +- 5 files changed, 386 insertions(+), 39 deletions(-) create mode 100644 drivers/gpio/xilinx_gpio.c
diff --git a/arch/microblaze/include/asm/gpio.h b/arch/microblaze/include/asm/gpio.h index 883f4d4..f5cad56 100644 --- a/arch/microblaze/include/asm/gpio.h +++ b/arch/microblaze/include/asm/gpio.h @@ -1,41 +1,15 @@ #ifndef _ASM_MICROBLAZE_GPIO_H_ #define _ASM_MICROBLAZE_GPIO_H_
-#include <asm/io.h> +#include <asm-generic/gpio.h>
-static inline int gpio_request(unsigned gpio, const char *label) -{ - return 0; -} +/* Allocation functions */ +extern int gpio_alloc_dual(u32 baseaddr, const char *name, u32 gpio_no0, + u32 gpio_no1); +extern int gpio_alloc(u32 baseaddr, const char *name, u32 gpio_no);
-static inline int gpio_free(unsigned gpio) -{ - return 0; -} +#define gpio_status() gpio_info() +extern void gpio_info(void);
-static inline int gpio_direction_input(unsigned gpio) -{ - return 0; -} - -static inline int gpio_direction_output(unsigned gpio, int value) -{ - return 0; -} - -static inline int gpio_get_value(unsigned gpio) -{ - return 0; -} - -static inline int gpio_set_value(unsigned gpio, int value) -{ - return 0; -} - -static inline int gpio_is_valid(int number) -{ - return 0; -} #endif
diff --git a/board/xilinx/microblaze-generic/microblaze-generic.c b/board/xilinx/microblaze-generic/microblaze-generic.c index befbb3a..2f5f20e 100644 --- a/board/xilinx/microblaze-generic/microblaze-generic.c +++ b/board/xilinx/microblaze-generic/microblaze-generic.c @@ -31,12 +31,17 @@ #include <asm/processor.h> #include <asm/microblaze_intc.h> #include <asm/asm.h> +#include <asm/gpio.h> + +#ifdef CONFIG_XILINX_GPIO +static int reset_pin = -1; +#endif
int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { -#ifdef CONFIG_SYS_GPIO_0 - *((unsigned long *)(CONFIG_SYS_GPIO_0_ADDR)) = - ++(*((unsigned long *)(CONFIG_SYS_GPIO_0_ADDR))); +#ifdef CONFIG_XILINX_GPIO + if (reset_pin != -1) + gpio_direction_output(reset_pin, 1); #endif
#ifdef CONFIG_XILINX_TB_WATCHDOG @@ -52,8 +57,10 @@ int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
int gpio_init (void) { -#ifdef CONFIG_SYS_GPIO_0 - *((unsigned long *)(CONFIG_SYS_GPIO_0_ADDR)) = 0xFFFFFFFF; +#ifdef CONFIG_XILINX_GPIO + reset_pin = gpio_alloc(CONFIG_SYS_GPIO_0_ADDR, "reset", 1); + if (reset_pin != -1) + gpio_request(reset_pin, "reset_pin"); #endif return 0; } diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 9df1e26..830e8e6 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -47,6 +47,7 @@ COBJS-$(CONFIG_OMAP_GPIO) += omap_gpio.o COBJS-$(CONFIG_DB8500_GPIO) += db8500_gpio.o COBJS-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o COBJS-$(CONFIG_S3C2440_GPIO) += s3c2440_gpio.o +COBJS-$(CONFIG_XILINX_GPIO) += xilinx_gpio.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/gpio/xilinx_gpio.c b/drivers/gpio/xilinx_gpio.c new file mode 100644 index 0000000..37fb0c5 --- /dev/null +++ b/drivers/gpio/xilinx_gpio.c @@ -0,0 +1,364 @@ +/* + * Copyright (c) 2013 Xilinx, Michal Simek + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <errno.h> +#include <malloc.h> +#include <linux/list.h> +#include <asm/io.h> +#include <asm/gpio.h> + +static LIST_HEAD(gpio_list); + +enum gpio_direction { + GPIO_DIRECTION_OUT = 0, + GPIO_DIRECTION_IN = 1, +}; + +/* Gpio simple map */ +struct gpio_regs { + u32 gpiodata; + u32 gpiodir; +}; + +#define GPIO_NAME_SIZE 10 + +struct gpio_names { + char name[GPIO_NAME_SIZE]; +}; + +/* Initialized, rxbd_current, rx_first_buf must be 0 after init */ +struct xilinx_gpio_priv { + struct gpio_regs *regs; + u32 gpio_min; + u32 gpio_max; + u32 gpiodata_store; + char name[GPIO_NAME_SIZE]; + struct list_head list; + struct gpio_names *gpio_name; +}; + +/* Store number of allocated gpio pins */ +static u32 xilinx_gpio_max; + +/* Get associated gpio controller */ +static struct xilinx_gpio_priv *gpio_get_controller(unsigned gpio) +{ + struct list_head *entry; + struct xilinx_gpio_priv *priv = NULL; + + list_for_each(entry, &gpio_list) { + priv = list_entry(entry, struct xilinx_gpio_priv, list); + if (gpio >= priv->gpio_min && gpio <= priv->gpio_max) { + debug("%s: reg: %x, min-max: %d-%d\n", __func__, + (u32)priv->regs, priv->gpio_min, priv->gpio_max); + return priv; + } + } + puts("!!!Can't get gpio controller!!!\n"); + return NULL; +} + +/* Get gpio pin name if used/setup */ +static char *get_name(unsigned gpio) +{ + u32 gpio_priv; + struct xilinx_gpio_priv *priv; + + debug("%s\n", __func__); + + priv = gpio_get_controller(gpio); + if (priv) { + gpio_priv = gpio - priv->gpio_min; + + return *priv->gpio_name[gpio_priv].name ? + priv->gpio_name[gpio_priv].name : "UNKNOWN"; + } + return "UNKNOWN"; +} + +/* Get output value */ +static int gpio_get_output_value(unsigned gpio) +{ + u32 val, gpio_priv; + struct xilinx_gpio_priv *priv = gpio_get_controller(gpio); + + if (priv) { + gpio_priv = gpio - priv->gpio_min; + val = !!(priv->gpiodata_store & (1 << gpio_priv)); + debug("%s: reg: %x, gpio_no: %d, dir: %d\n", __func__, + (u32)priv->regs, gpio_priv, val); + + return val; + } + return -1; +} + +/* Get input value */ +static int gpio_get_input_value(unsigned gpio) +{ + u32 val, gpio_priv; + struct gpio_regs *regs; + struct xilinx_gpio_priv *priv = gpio_get_controller(gpio); + + if (priv) { + regs = priv->regs; + gpio_priv = gpio - priv->gpio_min; + val = readl(®s->gpiodata); + val = !!(val & (1 << gpio_priv)); + debug("%s: reg: %x, gpio_no: %d, dir: %d\n", __func__, + (u32)priv->regs, gpio_priv, val); + + return val; + } + return -1; +} + +/* Set gpio direction */ +static int gpio_set_direction(unsigned gpio, enum gpio_direction direction) +{ + u32 val, gpio_priv; + struct gpio_regs *regs; + struct xilinx_gpio_priv *priv = gpio_get_controller(gpio); + + if (priv) { + regs = priv->regs; + val = readl(®s->gpiodir); + + gpio_priv = gpio - priv->gpio_min; + if (direction == GPIO_DIRECTION_OUT) + val &= ~(1 << gpio_priv); + else + val |= 1 << gpio_priv; + + writel(val, ®s->gpiodir); + debug("%s: reg: %x, gpio_no: %d, dir: %d\n", __func__, + (u32)priv->regs, gpio_priv, val); + + return 0; + } + + return -1; +} + +/* Get gpio direction */ +static int gpio_get_direction(unsigned gpio) +{ + u32 val, gpio_priv; + struct gpio_regs *regs; + struct xilinx_gpio_priv *priv = gpio_get_controller(gpio); + + if (priv) { + regs = priv->regs; + gpio_priv = gpio - priv->gpio_min; + val = readl(®s->gpiodir); + val = !!(val & (1 << gpio_priv)); + debug("%s: reg: %x, gpio_no: %d, dir: %d\n", __func__, + (u32)priv->regs, gpio_priv, val); + + return val; + } + + return -1; +} + +/* + * Get input value + * for example gpio setup to output only can't get input value + * which is breaking gpio toggle command + */ +int gpio_get_value(unsigned gpio) +{ + u32 val; + + if (gpio_get_direction(gpio) == GPIO_DIRECTION_OUT) + val = gpio_get_output_value(gpio); + else + val = gpio_get_input_value(gpio); + + return val; +} + +/* Set output value */ +static int gpio_set_output_value(unsigned gpio, int value) +{ + u32 val, gpio_priv; + struct gpio_regs *regs; + struct xilinx_gpio_priv *priv = gpio_get_controller(gpio); + + if (priv) { + regs = priv->regs; + gpio_priv = gpio - priv->gpio_min; + val = priv->gpiodata_store; + if (value) + val |= 1 << gpio_priv; + else + val &= ~(1 << gpio_priv); + + writel(val, ®s->gpiodata); + debug("%s: reg: %x, gpio_no: %d, output_val: %d\n", __func__, + (u32)priv->regs, gpio_priv, val); + priv->gpiodata_store = val; + + return 0; + } + + return -1; +} + +int gpio_set_value(unsigned gpio, int value) +{ + if (gpio_get_direction(gpio) == GPIO_DIRECTION_OUT) + return gpio_set_output_value(gpio, value); + + return -1; +} + +/* Set GPIO as input */ +int gpio_direction_input(unsigned gpio) +{ + debug("%s\n", __func__); + return gpio_set_direction(gpio, GPIO_DIRECTION_IN); +} + +/* Setup GPIO as output and set output value */ +int gpio_direction_output(unsigned gpio, int value) +{ + int ret = gpio_set_direction(gpio, GPIO_DIRECTION_OUT); + + debug("%s\n", __func__); + + if (ret < 0) + return ret; + + return gpio_set_output_value(gpio, value); +} + +/* Show gpio status */ +void gpio_info(void) +{ + unsigned gpio; + + struct list_head *entry; + struct xilinx_gpio_priv *priv = NULL; + + list_for_each(entry, &gpio_list) { + priv = list_entry(entry, struct xilinx_gpio_priv, list); + printf("\n%s: %s/%x (%d-%d)\n", __func__, priv->name, + (u32)priv->regs, priv->gpio_min, priv->gpio_max); + + for (gpio = priv->gpio_min; gpio <= priv->gpio_max; gpio++) { + printf("GPIO_%d:\t%s is an ", gpio, get_name(gpio)); + if (gpio_get_direction(gpio) == GPIO_DIRECTION_OUT) + printf("OUTPUT value = %d\n", + gpio_get_output_value(gpio)); + else + printf("INPUT value = %d\n", + gpio_get_input_value(gpio)); + } + } +} + +int gpio_request(unsigned gpio, const char *label) +{ + u32 gpio_priv; + struct xilinx_gpio_priv *priv; + + if (gpio >= xilinx_gpio_max) + return -EINVAL; + + priv = gpio_get_controller(gpio); + if (priv) { + gpio_priv = gpio - priv->gpio_min; + + if (label != NULL) { + strncpy(priv->gpio_name[gpio_priv].name, label, + GPIO_NAME_SIZE); + priv->gpio_name[gpio_priv].name[GPIO_NAME_SIZE - 1] = + '\0'; + } + return 0; + } + + return -1; +} + +int gpio_free(unsigned gpio) +{ + u32 gpio_priv; + struct xilinx_gpio_priv *priv; + + if (gpio >= xilinx_gpio_max) + return -EINVAL; + + priv = gpio_get_controller(gpio); + if (priv) { + gpio_priv = gpio - priv->gpio_min; + priv->gpio_name[gpio_priv].name[0] = '\0'; + + /* Do nothing here */ + return 0; + } + + return -1; +} + +int gpio_alloc(u32 baseaddr, const char *name, u32 gpio_no) +{ + struct xilinx_gpio_priv *priv; + + priv = calloc(1, sizeof(struct xilinx_gpio_priv)); + + /* Setup gpio name */ + if (name != NULL) { + strncpy(priv->name, name, GPIO_NAME_SIZE); + priv->name[GPIO_NAME_SIZE - 1] = '\0'; + } + priv->regs = (struct gpio_regs *)baseaddr; + + priv->gpio_min = xilinx_gpio_max; + xilinx_gpio_max = priv->gpio_min + gpio_no; + priv->gpio_max = xilinx_gpio_max - 1; + + priv->gpio_name = calloc(gpio_no, sizeof(struct gpio_names)); + + INIT_LIST_HEAD(&priv->list); + list_add_tail(&priv->list, &gpio_list); + + printf("%s: Add %s (%d-%d)\n", __func__, name, + priv->gpio_min, priv->gpio_max); + + /* Return the first gpio allocated for this device */ + return priv->gpio_min; +} + +/* Dual channel gpio is one IP with two independent channels */ +int gpio_alloc_dual(u32 baseaddr, const char *name, u32 gpio_no0, u32 gpio_no1) +{ + int ret; + + ret = gpio_alloc(baseaddr, name, gpio_no0); + gpio_alloc(baseaddr + 8, strcat((char *)name, "_1"), gpio_no1); + + /* Return the first gpio allocated for this device */ + return ret; +} diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 0c4e719..17f53ba 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -104,7 +104,7 @@
/* gpio */ #ifdef XILINX_GPIO_BASEADDR -# define CONFIG_SYS_GPIO_0 1 +# define CONFIG_XILINX_GPIO # define CONFIG_SYS_GPIO_0_ADDR XILINX_GPIO_BASEADDR #endif
@@ -312,6 +312,7 @@ #define CONFIG_CMD_IRQ #define CONFIG_CMD_MFSL #define CONFIG_CMD_ECHO +#define CONFIG_CMD_GPIO
#if defined(CONFIG_DCACHE) || defined(CONFIG_ICACHE) # define CONFIG_CMD_CACHE -- 1.8.2.1
Michal Simek
