[U-Boot] [PATCH 1/2] rtl8169: fix cache coherency problem
Fix the problem that cannot access actual data when CPU data cache enabled.
Signed-off-by: Yoshihiro Shimoda shimoda.yoshihiro@renesas.com --- drivers/net/rtl8169.c | 11 ++++++++++- 1 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index e9f6391..b441ec4 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -420,6 +420,8 @@ static int rtl_recv(struct eth_device *dev) ioaddr = dev->iobase;
cur_rx = tpc->cur_rx; + flush_cache((unsigned long)&tpc->RxDescArray[cur_rx], + sizeof(struct RxDesc)); if ((le32_to_cpu(tpc->RxDescArray[cur_rx].status) & OWNbit) == 0) { if (!(le32_to_cpu(tpc->RxDescArray[cur_rx].status) & RxRES)) { unsigned char rxdata[RX_BUF_LEN]; @@ -437,6 +439,8 @@ static int rtl_recv(struct eth_device *dev) cpu_to_le32(OWNbit + RX_BUF_SIZE); tpc->RxDescArray[cur_rx].buf_addr = cpu_to_le32((unsigned long)tpc->RxBufferRing[cur_rx]); + flush_cache((unsigned long)tpc->RxBufferRing[cur_rx], + RX_BUF_SIZE); } else { puts("Error Rx"); } @@ -478,6 +482,7 @@ static int rtl_send(struct eth_device *dev, volatile void *packet, int length) /* point to the current txb incase multiple tx_rings are used */ ptxb = tpc->Tx_skbuff[entry * MAX_ETH_FRAME_SIZE]; memcpy(ptxb, (char *)packet, (int)length); + flush_cache((unsigned long)ptxb, length);
while (len < ETH_ZLEN) ptxb[len++] = '\0'; @@ -497,7 +502,10 @@ static int rtl_send(struct eth_device *dev, volatile void *packet, int length)
tpc->cur_tx++; to = currticks() + TX_TIMEOUT; - while ((le32_to_cpu(tpc->TxDescArray[entry].status) & OWNbit) + do { + flush_cache((unsigned long)&tpc->TxDescArray[entry], + sizeof(struct TxDesc)); + } while ((le32_to_cpu(tpc->TxDescArray[entry].status) & OWNbit) && (currticks() < to)); /* wait */
if (currticks() >= to) { @@ -639,6 +647,7 @@ static void rtl8169_init_ring(struct eth_device *dev) tpc->RxBufferRing[i] = &rxb[i * RX_BUF_SIZE]; tpc->RxDescArray[i].buf_addr = cpu_to_le32((unsigned long)tpc->RxBufferRing[i]); + flush_cache((unsigned long)tpc->RxBufferRing[i], RX_BUF_SIZE); }
#ifdef DEBUG_RTL8169
Dear Ben,
I did not see any comments on this?
Ditto for the other patch:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/55286
Wolfgang Denk wrote:
Dear Ben,
Tested-by: Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com
I checked and tested these. Work file.
Best regards, Nobuhiro
Dear Wolfgang Denk,
In message 20090403215440.D212983797DC@gemini.denx.de I wrote:
Dear Ben,
Any comments?
If you don't have time, I can apply this directly.
Hi Wolfgang,
Dear Wolfgang Denk,
Dear Ben,
Any comments?
This one also looks fine. Please apply directly.
thanks, Ben
Dear Yoshihiro Shimoda,
Applied, thanks.
Ben Warren
Nobuhiro Iwamatsu
Yoshihiro Shimoda
