[U-Boot] [PATCH 1/3] ARM: imx6q_logic: Enable 256KB OCRAM
Since this board config only supports, the i.MX6D/i.MX6Q configurations, 256K of on-chip RAM is available which increases the space available to SPL to help further reduce board code and further enable device tree functions.
This patch enables 256K of RAM.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 6125ee2bc2..a9e8cbea94 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_OCRAM_256KB=y CONFIG_TARGET_MX6LOGICPD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y
With the 256KB of OCRAM available to SPL now, there should be enough room to enable the pinmuxing in SPL from the device tree.
This patch enables SPL_PINCTRL et al and adds the serial and usdhc pin mux references to the -u-boot.dtsi file so the pins can be configured from the device tree.
diff --git a/arch/arm/dts/imx6q-logicpd-u-boot.dtsi b/arch/arm/dts/imx6q-logicpd-u-boot.dtsi index 625bed8f7d..ee44ed91fe 100644 --- a/arch/arm/dts/imx6q-logicpd-u-boot.dtsi +++ b/arch/arm/dts/imx6q-logicpd-u-boot.dtsi @@ -16,3 +16,15 @@ &usdhc2 { u-boot,dm-spl; }; + +&pinctrl_uart1 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc1 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index a9e8cbea94..c120cb2f54 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -78,6 +78,7 @@ CONFIG_PHY_ATHEROS=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y
Reviewed-by: Fabio Estevam festevam@gmail.com
Subject: [PATCH 2/3] ARM: imx6q_logic: Enable Pin muxing in SPL
+&pinctrl_uart1 {
- u-boot,dm-spl;
+&pinctrl_usdhc1 {
- u-boot,dm-spl;
+&pinctrl_usdhc2 {
- u-boot,dm-spl;
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.17.1
With the 256KB of OCRAM available to SPL now, there should be enough room to enable the pinmuxing in SPL from the device tree. This patch enables SPL_PINCTRL et al and adds the serial and usdhc pin mux references to the -u-boot.dtsi file so the pins can be configured from the device tree. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com diff --git a/arch/arm/dts/imx6q-logicpd-u-boot.dtsi b/arch/arm/dts/imx6q-logicpd-u-boot.dtsi index 625bed8f7d..ee44ed91fe 100644 --- a/arch/arm/dts/imx6q-logicpd-u-boot.dtsi +++ b/arch/arm/dts/imx6q-logicpd-u-boot.dtsi @@ -16,3 +16,15 @@ &usdhc2 { u-boot,dm-spl; };
+&pinctrl_uart1 {
- u-boot,dm-spl;
+&pinctrl_usdhc1 {
- u-boot,dm-spl;
+&pinctrl_usdhc2 {
- u-boot,dm-spl;
Best regards, Stefano Babic
With the OCRAM expanded to 256KB and the SPL_PINCTRL enabled with -u-boot.dtsi entries to include the pinmuxing in SPL, the manual code setting up the pinmux can go away.
This patch removes the legacy pinmuxing code from the board file.
diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index 4bacd8660a..3c1a3a9fa2 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -42,32 +42,6 @@ int dram_init(void) return 0; }
-static iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -static iomux_v3_cfg_t const uart2_pads[] = { - MX6_PAD_SD4_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_SD4_DAT5__UART2_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_SD4_DAT6__UART2_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_SD4_DAT7__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -static iomux_v3_cfg_t const uart3_pads[] = { - MX6_PAD_EIM_D23__UART3_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_EIM_D24__UART3_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_EIM_D25__UART3_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_EIM_EB3__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -static void setup_iomux_uart(void) -{ - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); - imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); - imx_iomux_v3_setup_multiple_pads(uart3_pads, ARRAY_SIZE(uart3_pads)); -} - static iomux_v3_cfg_t const nand_pads[] = { MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NAND_PAD_CTRL), MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NAND_PAD_CTRL), @@ -135,7 +109,6 @@ int overwrite_console(void)
int board_early_init_f(void) { - setup_iomux_uart(); setup_nand_pins(); return 0; } @@ -177,36 +150,6 @@ int spl_start_uboot(void) } #endif
-/* SD interface */ -#define USDHC_PAD_CTRL \ - (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ - PAD_CTL_SRE_FAST | PAD_CTL_HYS) - -static iomux_v3_cfg_t const usdhc1_pads[] = { - MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), -}; - -static iomux_v3_cfg_t const usdhc2_pads[] = { - MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ -}; - -#ifdef CONFIG_FSL_ESDHC_IMX -struct fsl_esdhc_cfg usdhc_cfg[] = { - {USDHC1_BASE_ADDR}, /* SOM */ - {USDHC2_BASE_ADDR} /* Baseboard */ -}; - void board_boot_order(u32 *spl_boot_list) { struct src *psrc = (struct src *)SRC_BASE_ADDR; @@ -236,34 +179,6 @@ void board_boot_order(u32 *spl_boot_list) spl_boot_list[2] = BOOT_DEVICE_BOARD; }
-int board_mmc_init(bd_t *bis) -{ - struct src *psrc = (struct src *)SRC_BASE_ADDR; - unsigned int reg = readl(&psrc->sbmr1) >> 11; - /* - * Upon reading BOOT_CFG register the following map is done: - * Bit 11 and 12 of BOOT_CFG register can determine the current - * mmc port - * 0x1 SD1-SOM - * 0x2 SD2-Baseboard - */ - - reg &= 0x3; /* Only care about bottom 2 bits */ - - switch (reg) { - case 0: - SETUP_IOMUX_PADS(usdhc1_pads); - break; - case 1: - SETUP_IOMUX_PADS(usdhc2_pads); - break; - } - - return 0; -} - -#endif - static void ccgr_init(void) { struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
With the OCRAM expanded to 256KB and the SPL_PINCTRL enabled with -u-boot.dtsi entries to include the pinmuxing in SPL, the manual code setting up the pinmux can go away. This patch removes the legacy pinmuxing code from the board file. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index 4bacd8660a..3c1a3a9fa2 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -42,32 +42,6 @@ int dram_init(void) return 0; }
* mmc port
* 0x1 SD1-SOM
* 0x2 SD2-Baseboard
- switch (reg) {
- case 0:
break;
- case 1:
break;
-#endif
Since this board config only supports, the i.MX6D/i.MX6Q configurations, 256K of on-chip RAM is available which increases the space available to SPL to help further reduce board code and further enable device tree functions. This patch enables 256K of RAM. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@gmail.com diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 6125ee2bc2..a9e8cbea94 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_OCRAM_256KB=y CONFIG_TARGET_MX6LOGICPD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y
Adam Ford
Fabio Estevam
Peng Fan
sbabic@denx.de
