[U-Boot] [PATCH 2/2 v3] powerpc/85xx: add CONFIG_SYS_TEXT_BASE_SPL for 85xx nand spl build
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- v3 change: %s/CONFIG_SYS_TEXT_BASE/CONFIG_SYS_MONITOR_BASE/g
arch/powerpc/cpu/mpc85xx/start.S | 18 +++++++++--------- include/configs/MPC8536DS.h | 8 ++++++-- include/configs/MPC8569MDS.h | 8 ++++++-- include/configs/P1_P2_RDB.h | 8 ++++++-- nand_spl/board/freescale/mpc8536ds/Makefile | 4 ++-- nand_spl/board/freescale/mpc8569mds/Makefile | 4 ++-- nand_spl/board/freescale/p1_p2_rdb/Makefile | 4 ++-- 7 files changed, 33 insertions(+), 21 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 291557d..af7e39b 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -146,7 +146,7 @@ _start_e500: beq 2b
/* Setup interrupt vectors */ - lis r1,CONFIG_SYS_TEXT_BASE@h + lis r1,CONFIG_SYS_MONITOR_BASE@h mtspr IVPR,r1
li r1,0x0100 @@ -292,25 +292,25 @@ _start_e500: lis r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_4M)@h ori r7,r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_4M)@l
- lis r8,FSL_BOOKE_MAS2(CONFIG_SYS_TEXT_BASE & 0xffc00000, (MAS2_I|MAS2_G))@h - ori r8,r8,FSL_BOOKE_MAS2(CONFIG_SYS_TEXT_BASE & 0xffc00000, (MAS2_I|MAS2_G))@l + lis r8,FSL_BOOKE_MAS2(CONFIG_SYS_MONITOR_BASE & 0xffc00000, (MAS2_I|MAS2_G))@h + ori r8,r8,FSL_BOOKE_MAS2(CONFIG_SYS_MONITOR_BASE & 0xffc00000, (MAS2_I|MAS2_G))@l
/* The 85xx has the default boot window 0xff800000 - 0xffffffff */ lis r9,FSL_BOOKE_MAS3(0xffc00000, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@h ori r9,r9,FSL_BOOKE_MAS3(0xffc00000, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@l #else /* - * create a temp mapping in AS=1 to the 1M CONFIG_SYS_TEXT_BASE space, the main - * image has been relocated to CONFIG_SYS_TEXT_BASE on the second stage. + * create a temp mapping in AS=1 to the 1M CONFIG_SYS_MONITOR_BASE space, the main + * image has been relocated to CONFIG_SYS_MONITOR_BASE on the second stage. */ lis r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_1M)@h ori r7,r7,FSL_BOOKE_MAS1(1, 1, 0, 1, BOOKE_PAGESZ_1M)@l
- lis r8,FSL_BOOKE_MAS2(CONFIG_SYS_TEXT_BASE, (MAS2_I|MAS2_G))@h - ori r8,r8,FSL_BOOKE_MAS2(CONFIG_SYS_TEXT_BASE, (MAS2_I|MAS2_G))@l + lis r8,FSL_BOOKE_MAS2(CONFIG_SYS_MONITOR_BASE, (MAS2_I|MAS2_G))@h + ori r8,r8,FSL_BOOKE_MAS2(CONFIG_SYS_MONITOR_BASE, (MAS2_I|MAS2_G))@l
- lis r9,FSL_BOOKE_MAS3(CONFIG_SYS_TEXT_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@h - ori r9,r9,FSL_BOOKE_MAS3(CONFIG_SYS_TEXT_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@l + lis r9,FSL_BOOKE_MAS3(CONFIG_SYS_MONITOR_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@h + ori r9,r9,FSL_BOOKE_MAS3(CONFIG_SYS_MONITOR_BASE, 0, (MAS3_SX|MAS3_SW|MAS3_SR))@l #endif
mtspr MAS0,r6 diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 8410bb7..fa9bc93 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -36,7 +36,13 @@ #ifdef CONFIG_NAND #define CONFIG_NAND_U_BOOT 1 #define CONFIG_RAMBOOT_NAND 1 +#ifdef CONFIG_NAND_SPL +#define CONFIG_SYS_TEXT_BASE_SPL 0xfff00000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE_SPL /* start of monitor */ +#else #define CONFIG_SYS_TEXT_BASE 0xf8f82000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif /* CONFIG_NAND_SPL */ #endif
#ifdef CONFIG_SDCARD @@ -233,8 +239,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ - #if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) \ || defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_SYS_RAMBOOT diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 6a15da5..b11076f 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -65,7 +65,13 @@ extern unsigned long get_clock_freq(void); #ifdef CONFIG_NAND #define CONFIG_NAND_U_BOOT 1 #define CONFIG_RAMBOOT_NAND 1 +#ifdef CONFIG_NAND_SPL +#define CONFIG_SYS_TEXT_BASE_SPL 0xfff00000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE_SPL /* start of monitor */ +#else #define CONFIG_SYS_TEXT_BASE 0xf8f82000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif #endif
#ifndef CONFIG_SYS_TEXT_BASE @@ -194,8 +200,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ - #if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) #define CONFIG_SYS_RAMBOOT #else diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index b99f383..673e29d 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -46,7 +46,13 @@ #ifdef CONFIG_NAND #define CONFIG_NAND_U_BOOT 1 #define CONFIG_RAMBOOT_NAND 1 +#ifdef CONFIG_NAND_SPL +#define CONFIG_SYS_TEXT_BASE_SPL 0xfff00000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE_SPL /* start of monitor */ +#else #define CONFIG_SYS_TEXT_BASE 0xf8f82000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif /* CONFIG_NAND_SPL */ #endif
#ifdef CONFIG_SDCARD @@ -192,8 +198,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ - #if defined(CONFIG_SYS_SPL) || defined(CONFIG_RAMBOOT_NAND) \ || defined(CONFIG_RAMBOOT_SDCARD) || defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_SYS_RAMBOOT diff --git a/nand_spl/board/freescale/mpc8536ds/Makefile b/nand_spl/board/freescale/mpc8536ds/Makefile index d1c0ef8..9c9d63e 100644 --- a/nand_spl/board/freescale/mpc8536ds/Makefile +++ b/nand_spl/board/freescale/mpc8536ds/Makefile @@ -24,13 +24,13 @@ #
NAND_SPL := y -CONFIG_SYS_TEXT_BASE := 0xfff00000 +CONFIG_SYS_TEXT_BASE_SPL := 0xfff00000 PAD_TO := 0xfff01000
include $(TOPDIR)/config.mk
LDSCRIPT= $(TOPDIR)/$(CPUDIR)/u-boot-nand_spl.lds -LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(CONFIG_SYS_TEXT_BASE) $(PLATFORM_LDFLAGS) +LDFLAGS = -Bstatic -T $(LDSCRIPT) -Ttext $(CONFIG_SYS_TEXT_BASE_SPL) $(PLATFORM_LDFLAGS) AFLAGS += -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_NAND_SPL
diff --git a/nand_spl/board/freescale/mpc8569mds/Makefile b/nand_spl/board/freescale/mpc8569mds/Makefile index d1c0ef8..9c9d63e 100644 --- a/nand_spl/board/freescale/mpc8569mds/Makefile +++ b/nand_spl/board/freescale/mpc8569mds/Makefile @@ -24,13 +24,13 @@ #
diff --git a/nand_spl/board/freescale/p1_p2_rdb/Makefile b/nand_spl/board/freescale/p1_p2_rdb/Makefile index d1c0ef8..9c9d63e 100644 --- a/nand_spl/board/freescale/p1_p2_rdb/Makefile +++ b/nand_spl/board/freescale/p1_p2_rdb/Makefile @@ -24,13 +24,13 @@ #
On Nov 10, 2010, at 2:37 PM, Haiying.Wang@freescale.com Haiying.Wang@freescale.com wrote:
I've split this into two patches. One to rename CONFIG_SYS_TEXT_BASE/CONFIG_SYS_MONITOR_BASE and the other to deal with SPL.
applied to 85xx
- k
Kumar Gala
