[U-Boot] [PATCH 1/3] ARM: dts: omap3-evm: Sync dts(i) files from Linux 5.1.5
Signed-off-by: Derald D. Woods woods.technical@gmail.com --- arch/arm/dts/omap3-evm-37xx.dts | 8 ++++---- arch/arm/dts/omap3-evm-common.dtsi | 7 +++++-- arch/arm/dts/omap3-evm-processor-common.dtsi | 10 +++++++++- 3 files changed, 18 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/omap3-evm-37xx.dts b/arch/arm/dts/omap3-evm-37xx.dts index 5a4ba0aea4..a14303b09a 100644 --- a/arch/arm/dts/omap3-evm-37xx.dts +++ b/arch/arm/dts/omap3-evm-37xx.dts @@ -90,19 +90,19 @@ label = "X-Loader"; reg = <0 0x80000>; }; - partition@0x80000 { + partition@80000 { label = "U-Boot"; reg = <0x80000 0x1c0000>; }; - partition@0x1c0000 { + partition@1c0000 { label = "Environment"; reg = <0x240000 0x40000>; }; - partition@0x280000 { + partition@280000 { label = "Kernel"; reg = <0x280000 0x500000>; }; - partition@0x780000 { + partition@780000 { label = "Filesystem"; reg = <0x780000 0x1f880000>; }; diff --git a/arch/arm/dts/omap3-evm-common.dtsi b/arch/arm/dts/omap3-evm-common.dtsi index ee64191e41..17c89df6ce 100644 --- a/arch/arm/dts/omap3-evm-common.dtsi +++ b/arch/arm/dts/omap3-evm-common.dtsi @@ -122,6 +122,7 @@ };
&mmc2 { + interrupts-extended = <&intc 86 &omap3_pmx_core 0x12e>; vmmc-supply = <&wl12xx_vmmc>; non-removable; bus-width = <4>; @@ -132,8 +133,10 @@ wlcore: wlcore@2 { compatible = "ti,wl1271"; reg = <2>; - interrupt-parent = <&gpio5>; - interrupts = <21 IRQ_TYPE_LEVEL_HIGH>; /* gpio 149 */ + /* gpio_149 with uart1_rts pad as wakeirq */ + interrupts-extended = <&gpio5 21 IRQ_TYPE_EDGE_RISING>, + <&omap3_pmx_core 0x14e>; + interrupt-names = "irq", "wakeup"; ref-clock-frequency = <38400000>; }; }; diff --git a/arch/arm/dts/omap3-evm-processor-common.dtsi b/arch/arm/dts/omap3-evm-processor-common.dtsi index ce7f42f944..b4109f48ec 100644 --- a/arch/arm/dts/omap3-evm-processor-common.dtsi +++ b/arch/arm/dts/omap3-evm-processor-common.dtsi @@ -86,6 +86,10 @@ OMAP3_CORE1_IOPAD(0x215e, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc2_dat1.sdmmc2_dat1 */ OMAP3_CORE1_IOPAD(0x2160, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc2_dat2.sdmmc2_dat2 */ OMAP3_CORE1_IOPAD(0x2162, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc2_dat3.sdmmc2_dat3 */ + OMAP3_CORE1_IOPAD(0x2164, PIN_OUTPUT | MUX_MODE1) /* sdmmc2_dat4.sdmmc2_dir_dat0 */ + OMAP3_CORE1_IOPAD(0x2166, PIN_OUTPUT | MUX_MODE1) /* sdmmc2_dat5.sdmmc2_dir_dat1 */ + OMAP3_CORE1_IOPAD(0x2168, PIN_OUTPUT | MUX_MODE1) /* sdmmc2_dat6.sdmmc2_dir_cmd */ + OMAP3_CORE1_IOPAD(0x216a, PIN_INPUT | MUX_MODE1) /* sdmmc2_dat7.sdmmc2_clkin */ >; };
@@ -127,9 +131,13 @@ >; };
+ /* + * Note that gpio_150 pulled high with internal pull to prevent wlcore + * reset on return from off mode in idle. + */ wl12xx_gpio: pinmux_wl12xx_gpio { pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2180, PIN_OUTPUT | MUX_MODE4) /* uart1_cts.gpio_150 */ + OMAP3_CORE1_IOPAD(0x2180, PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_cts.gpio_150 */ OMAP3_CORE1_IOPAD(0x217e, PIN_INPUT | MUX_MODE4) /* uart1_rts.gpio_149 */ >; };
Derald D. Woods
