[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks. Generating the pull request I see that three patches are missing (the three patches by Łukasz Majewski). However, everything in the tree seems correct and the tree is already rebased on uboot_arm. Let me know if you find any issue.
The following changes since commit e36544d37385c4a4b525e18326feb3664d2268fa:
omap: overo: Disable pull-ups on camera PCLK, HS and VS signals (2011-10-14 22:15:13 +0200)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Fabio Estevam (2): mx31pdk: Remove unneeded config imx: fix coding style
Helmut Raiger (1): mx31: provide readable WEIM CS accessor
Marek Vasut (1): I2C: Add i2c_get/set_speed() to mxc_i2c.c
Stefano Babic (15): MX51: vision2: Set global macros misc: pmic: Freescale PMIC switches to generic PMIC driver MX5: vision2: use new pmic driver RTC: Switch mc13783 to generic pmic code MX3: qong: use new pmic driver MX5: efikamx/efikasb: use new pmic driver misc: pmic: use I2C_SET_BUS in pmic I2C misc: pmic: addI2C support to pmic_fsl driver MX35: mx35pdk: use new pmic driver MX5: mx51evk: use new pmic driver MX5: mx53evk: use new pmic driver MX31: mx31_litekit: use new pmic driver MX31: mx31ads: use new pmic driver misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:samsung Enable PMIC driver at GONI target
arch/arm/cpu/arm1136/mx31/generic.c | 11 ++ arch/arm/cpu/arm1136/mx31/timer.c | 23 ++- arch/arm/cpu/arm1136/mx35/generic.c | 2 +- arch/arm/cpu/arm926ejs/mx25/generic.c | 110 +++++++------- arch/arm/cpu/arm926ejs/mx25/reset.c | 2 +- arch/arm/cpu/arm926ejs/mx25/timer.c | 16 +- arch/arm/cpu/arm926ejs/mx27/reset.c | 2 +- arch/arm/cpu/arm926ejs/mx27/timer.c | 14 +- arch/arm/cpu/armv7/mx5/soc.c | 10 +- arch/arm/include/asm/arch-mx31/imx-regs.h | 35 ++++- arch/arm/include/asm/arch-mx31/sys_proto.h | 35 ++++ arch/arm/include/asm/arch-mx5/sys_proto.h | 8 + board/davedenx/qong/qong.c | 107 ++++++------- board/efikamx/efikamx.c | 51 ++++--- board/freescale/mx31ads/mx31ads.c | 16 ++- board/freescale/mx31pdk/mx31pdk.c | 14 ++- board/freescale/mx35pdk/mx35pdk.c | 18 ++- board/freescale/mx51evk/mx51evk.c | 47 +++--- board/freescale/mx53evk/mx53evk.c | 17 ++- board/imx31_phycore/imx31_phycore.c | 41 ++++- board/karo/tx25/tx25.c | 2 +- board/logicpd/imx27lite/imx27lite.c | 6 +- board/logicpd/imx31_litekit/imx31_litekit.c | 30 +++- board/samsung/goni/goni.c | 4 + board/ttcontrol/vision2/vision2.c | 33 +++-- boards.cfg | 3 +- drivers/i2c/mxc_i2c.c | 31 +++- drivers/misc/Makefile | 6 +- drivers/misc/fsl_pmic.c | 235 --------------------------- drivers/misc/pmic_core.c | 147 +++++++++++++++++ drivers/misc/pmic_fsl.c | 66 ++++++++ drivers/misc/pmic_i2c.c | 92 +++++++++++ drivers/misc/pmic_max8998.c | 43 +++++ drivers/misc/pmic_spi.c | 109 +++++++++++++ drivers/rtc/mc13783-rtc.c | 20 ++- include/configs/efikamx.h | 5 +- include/configs/imx31_litekit.h | 9 +- include/configs/mx31ads.h | 8 +- include/configs/mx31pdk.h | 6 +- include/configs/mx35pdk.h | 5 +- include/configs/mx51evk.h | 6 +- include/configs/mx53evk.h | 5 +- include/configs/qong.h | 5 +- include/configs/s5p_goni.h | 4 + include/configs/vision2.h | 22 ++- include/fsl_pmic.h | 5 +- include/max8998_pmic.h | 84 ++++++++++ include/pmic.h | 71 ++++++++ 48 files changed, 1110 insertions(+), 531 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx31/sys_proto.h delete mode 100644 drivers/misc/fsl_pmic.c create mode 100644 drivers/misc/pmic_core.c create mode 100644 drivers/misc/pmic_fsl.c create mode 100644 drivers/misc/pmic_i2c.c create mode 100644 drivers/misc/pmic_max8998.c create mode 100644 drivers/misc/pmic_spi.c create mode 100644 include/max8998_pmic.h create mode 100644 include/pmic.h
Thanks, Stefano
Le 17/10/2011 10:05, Stefano Babic a écrit :
Hi Albert,
Weird: these two commits:
are attributed to you whereas in your branch they are attributed to Łukasz Majewski -- plus a third one not mentioned above. I did a git request-pull on my side, and find the following entries:
Stefano Babic (15): MX51: vision2: Set global macros misc: pmic: Freescale PMIC switches to generic PMIC driver MX5: vision2: use new pmic driver RTC: Switch mc13783 to generic pmic code MX3: qong: use new pmic driver MX5: efikamx/efikasb: use new pmic driver misc: pmic: use I2C_SET_BUS in pmic I2C misc: pmic: addI2C support to pmic_fsl driver MX35: mx35pdk: use new pmic driver MX5: mx51evk: use new pmic driver MX5: mx53evk: use new pmic driver MX31: mx31_litekit: use new pmic driver MX31: mx31ads: use new pmic driver (the next two commits are missing in your list) MX31: mx31pdk: use new pmic driver misc: pmic: drop old Freescale's pmic driver
Łukasz Majewski (3): (the next commit is missing in your list) misc:pmic:core New generic PMIC driver (the next two commits are misattributed in your list) misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:samsung Enable PMIC driver at GONI target
Note that I find the same list of modifications as stated below, which implies that only the attribution list above is incorrect.
Can you double-check this u-boot-imx/master branch?
Thanks, Stefano
Amicalement,
..and they should not be...
That is correct - everything in the branch seems correct, but the generated pull-request is wrong - weird ! I have already tried to cherry-pick each single patch and then to check, but at the end I got always a wrong pull-request list. I have supposed that is related to UTF character in Łukasz name, but I am probably wrong.
This is correct. It is exactly what I wanted...
Meanwhile (and I do neither touched the u-boot-imx, nor updated my PC), git pull-request delivers today the right list:
Stefano Babic (15): MX51: vision2: Set global macros misc: pmic: Freescale PMIC switches to generic PMIC driver MX5: vision2: use new pmic driver RTC: Switch mc13783 to generic pmic code MX3: qong: use new pmic driver MX5: efikamx/efikasb: use new pmic driver misc: pmic: use I2C_SET_BUS in pmic I2C misc: pmic: addI2C support to pmic_fsl driver MX35: mx35pdk: use new pmic driver MX5: mx51evk: use new pmic driver MX5: mx53evk: use new pmic driver MX31: mx31_litekit: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31pdk: use new pmic driver misc: pmic: drop old Freescale's pmic driver
Łukasz Majewski (3): misc:pmic:core New generic PMIC driver misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:samsung Enable PMIC driver at GONI target
Yes, that is correct.
Everything seems correct, and today even a correct pull-request is generated...no idea really why the list was wrong !
thanks, Stefano
Hi Stefano,
Hi Albert,
Applied to u-boot-arm/master, with the agreed-upon amendment to the list of patches and ownership:
Thanks, Stefano
Amicalement,
Albert ARIBAUD
Stefano Babic
