[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Wolfgang,
please pull from u-boot-imx.
The following changes since commit cacc342d5aa311673efdc05770cb53246dd41c9f:
Merge branch 'master' of git://git.denx.de/u-boot-arm (2010-10-17 20:25:05 +0200)
git://git.denx.de/u-boot-imx master
Jason Liu (2): MX5: rename mx51 to mx5 MX5: Remove dead code with ENABLE_IMPRECISE_ABORT
Magnus Lilja (1): i.MX31: Fix Litekit board to use new ARM relocation support.
Stefano Babic (1): MX31: add delay between USB port setup and reset
Wolfgang Denk (1): QONG: fix and update board config file
arch/arm/cpu/armv7/{mx51 => mx5}/Makefile | 0 arch/arm/cpu/armv7/{mx51 => mx5}/clock.c | 42 ++++++++++---------- arch/arm/cpu/armv7/{mx51 => mx5}/iomux.c | 2 +- arch/arm/cpu/armv7/{mx51 => mx5}/lowlevel_init.S | 14 ------- arch/arm/cpu/armv7/{mx51 => mx5}/soc.c | 28 ++++++++----- arch/arm/cpu/armv7/{mx51 => mx5}/speed.c | 0 arch/arm/cpu/armv7/{mx51 => mx5}/timer.c | 8 ++-- arch/arm/cpu/armv7/{mx51 => mx5}/u-boot.lds | 0 .../asm/{arch-mx51 => arch-mx5}/asm-offsets.h | 0 .../include/asm/{arch-mx51 => arch-mx5}/clock.h | 0 .../include/asm/{arch-mx51 => arch-mx5}/crm_regs.h | 0 .../include/asm/{arch-mx51 => arch-mx5}/imx-regs.h | 0 .../include/asm/{arch-mx51 => arch-mx5}/iomux.h | 8 ++-- .../mx51_pins.h => arch-mx5/mx5x_pins.h} | 6 +- .../asm/{arch-mx51 => arch-mx5}/sys_proto.h | 0 board/freescale/mx51evk/mx51evk.c | 2 +- board/logicpd/imx31_litekit/config.mk | 2 +- board/logicpd/imx31_litekit/imx31_litekit.c | 10 ++++- board/ttcontrol/vision2/vision2.c | 2 +- boards.cfg | 4 +- drivers/usb/host/ehci-mxc.c | 2 + include/configs/imx31_litekit.h | 7 +++ include/configs/mx51evk.h | 4 +- include/configs/qong.h | 32 +++++++-------- include/configs/vision2.h | 4 +- 25 files changed, 90 insertions(+), 87 deletions(-) rename arch/arm/cpu/armv7/{mx51 => mx5}/Makefile (100%) rename arch/arm/cpu/armv7/{mx51 => mx5}/clock.c (85%) rename arch/arm/cpu/armv7/{mx51 => mx5}/iomux.c (99%) rename arch/arm/cpu/armv7/{mx51 => mx5}/lowlevel_init.S (95%) rename arch/arm/cpu/armv7/{mx51 => mx5}/soc.c (81%) rename arch/arm/cpu/armv7/{mx51 => mx5}/speed.c (100%) rename arch/arm/cpu/armv7/{mx51 => mx5}/timer.c (92%) rename arch/arm/cpu/armv7/{mx51 => mx5}/u-boot.lds (100%) rename arch/arm/include/asm/{arch-mx51 => arch-mx5}/asm-offsets.h (100%) rename arch/arm/include/asm/{arch-mx51 => arch-mx5}/clock.h (100%) rename arch/arm/include/asm/{arch-mx51 => arch-mx5}/crm_regs.h (100%) rename arch/arm/include/asm/{arch-mx51 => arch-mx5}/imx-regs.h (100%) rename arch/arm/include/asm/{arch-mx51 => arch-mx5}/iomux.h (98%) rename arch/arm/include/asm/{arch-mx51/mx51_pins.h => arch-mx5/mx5x_pins.h} (99%) rename arch/arm/include/asm/{arch-mx51 => arch-mx5}/sys_proto.h (100%)
Dear Stefano Babic,
In message 4CBDA6A2.5010806@denx.de you wrote:
Hi Wolfgang,
Applied, thanks.
Stefano Babic
