[PATCH] imx: mkimage_fit_atf: fix file size reporting
instead using ls and awk to determine file size use stat instead. This fixes an invalid size reporting for user or group names that have spaces in them.
This adds a dependency on the stat application which is part of the coreutils package which also includes ls.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/mach-imx/mkimage_fit_atf.sh | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-imx/mkimage_fit_atf.sh b/arch/arm/mach-imx/mkimage_fit_atf.sh index fe12b7bb4b..2a17968794 100755 --- a/arch/arm/mach-imx/mkimage_fit_atf.sh +++ b/arch/arm/mach-imx/mkimage_fit_atf.sh @@ -16,7 +16,7 @@ if [ ! -f $BL31 ]; then exit 0 else echo "$BL31 size: " >&2 - ls -lct $BL31 | awk '{print $5}' >&2 + stat -c %s $BL31 >&2 fi
BL32="tee.bin" @@ -26,7 +26,7 @@ if [ ! -f $BL32 ]; then else echo "Building with TEE support, make sure your $BL31 is compiled with spd. If you do not want tee, please delete $BL31" >&2 echo "$BL32 size: " >&2 - ls -lct $BL32 | awk '{print $5}' >&2 + stat -c %s $BL32 >&2 fi
BL33="u-boot-nodtb.bin" @@ -36,13 +36,13 @@ if [ ! -f $BL33 ]; then exit 0 else echo "u-boot-nodtb.bin size: " >&2 - ls -lct u-boot-nodtb.bin | awk '{print $5}' >&2 + stat -c %s u-boot-nodtb.bin >&2 fi
for dtname in $* do echo "$dtname size: " >&2 - ls -lct $dtname | awk '{print $5}' >&2 + stat -c %s $dtname >&2 done
instead using ls and awk to determine file size use stat instead. This fixes an invalid size reporting for user or group names that have spaces in them. This adds a dependency on the stat application which is part of the coreutils package which also includes ls. Signed-off-by: Tim Harvey tharvey@gateworks.com
Best regards, Stefano Babic
stefano.babic@babic.homelinux.org
Tim Harvey
