[PATCH 12/15] configs: add qemu_arm64_lwip_defconfig
Add qemu_arm64_lwip_defconfig which was created from qemu_arm64_defconfig with CONFIG_NET_LWIP enabled.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- configs/qemu_arm64_lwip_defconfig | 70 +++++++++++++++++++++++++++++++ 1 file changed, 70 insertions(+) create mode 100644 configs/qemu_arm64_lwip_defconfig
diff --git a/configs/qemu_arm64_lwip_defconfig b/configs/qemu_arm64_lwip_defconfig new file mode 100644 index 0000000000..c8dadbce37 --- /dev/null +++ b/configs/qemu_arm64_lwip_defconfig @@ -0,0 +1,70 @@ +CONFIG_ARM=y +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ARCH_QEMU=y +CONFIG_SYS_MALLOC_LEN=0x1000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x40200000 +CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SECT_SIZE=0x40000 +CONFIG_DEFAULT_DEVICE_TREE="qemu-arm64" +CONFIG_DEBUG_UART_BASE=0x9000000 +CONFIG_DEBUG_UART_CLOCK=0 +CONFIG_ARMV8_CRYPTO=y +CONFIG_SYS_LOAD_ADDR=0x40200000 +CONFIG_ENV_ADDR=0x4000000 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_BEST_MATCH=y +CONFIG_BOOTSTD_FULL=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_USE_PREBOOT=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_PCI_INIT_R=y +CONFIG_CMD_SMBIOS=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_BOOTEFI_SELFTEST=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_DFU=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_TPM=y +CONFIG_CMD_MTDPARTS=y +CONFIG_ENV_IS_IN_FLASH=y +CONFIG_NET_LWIP=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_DFU_MTD=y +CONFIG_DFU_RAM=y +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_FLASH_SHOW_PROGRESS=0 +CONFIG_CFI_FLASH=y +CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS=y +CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y +CONFIG_FLASH_CFI_MTD=y +CONFIG_SYS_FLASH_CFI=y +CONFIG_SYS_MAX_FLASH_SECT=256 +CONFIG_SYS_MAX_FLASH_BANKS=2 +CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y +CONFIG_E1000=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_ECAM_GENERIC=y +CONFIG_SCSI=y +CONFIG_DEBUG_UART_PL011=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_SYSRESET_CMD_POWEROFF=y +CONFIG_SYSRESET_PSCI=y +CONFIG_TPM2_MMIO=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_PCI=y +CONFIG_SEMIHOSTING=y +CONFIG_TPM=y
Setting aside that I would like lwip to default to y, at least in the first few iterations (so that testing is easier), this should be using the #include method rather than duplicating the whole config.
I could certainly do this. By creating a new defconfig, my goal was to minimize the impacts on existing use cases.
I've done that for v2. Let me know if you still prefer I change qemu_arm64_defconfig instead.
Thanks,
Yes but then it makes it harder to out of the box see what the deltas are.
This is fine for v2, yeah. Once that's posted I'll grab everything and: - Throw it at the small HW lab I have - Enable it by default for everyone and throw it at CI - Also throw it at my script for world build before/after and using buildman's bloat checker to see what grew how much where.
At this point you can expect quite a few failures (unresolved symbols to begin with) because so many parts of the network-related code peek & poke various parts of the net implementation without formally depending on NET (i.e., !NET_LWIP). Some more work is clearly needed to port to lwIP, how much is probably something the CI run will help understand.
Thanks,
OK, thanks for setting expectations. And FYI if you hadn't seen: https://docs.u-boot.org/en/latest/develop/ci_testing.html you can trigger them yourself, but Azure sometimes just has issues if we get a slow runner sometimes.
Jerome Forissier
