[PATCH] sunxi: Add arm64 FEL support
So far we did not support the BootROM based FEL USB debug mode on the 64-bit builds for Allwinner SoCs: The BootROM is using AArch32, but the SPL runs in AArch64. Returning back to AArch32 was not working as expected, since the RMR reset into 32-bit mode always starts execution in the BootROM, but not in the FEL routine.
After some debug and research and with help via IRC, the CPU hotplug mechanism emerged as a solution: If a certain R_CPUCFG register contains some magic, the BootROM will immediately branch to an address stored in some other register. This works well for our purposes.
Enable the FEL feature by providing early AArch32 code to first save the FEL state, *before* initially entering AArch64. If we eventually determine that we should return to FEL, we reset back into AArch32, and use the CPU hotplug mechanism to run some small AArch32 code snippet that restores the initially saved FEL state.
That allows the normal AArch64 SPL build to be loaded via the sunxi-fel tool, with it returning into FEL mode, so that other payloads can be transferred via FEL as well.
Tested on A64, H5 and H6.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/cpu/armv8/Makefile | 2 + arch/arm/cpu/armv8/fel_utils.S | 78 +++++++++++++++++++++++++ arch/arm/include/asm/arch-sunxi/boot0.h | 14 +++++ include/configs/sunxi-common.h | 2 - 4 files changed, 94 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/armv8/fel_utils.S
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index 93d26f98568..f7b4a5ee46c 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -27,6 +27,8 @@ obj-$(CONFIG_ARM_SMCCC) += smccc-call.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMV8_SPIN_TABLE) += spin_table.o spin_table_v8.o +else +obj-$(CONFIG_ARCH_SUNXI) += fel_utils.o endif obj-$(CONFIG_$(SPL_)ARMV8_SEC_FIRMWARE_SUPPORT) += sec_firmware.o sec_firmware_asm.o
diff --git a/arch/arm/cpu/armv8/fel_utils.S b/arch/arm/cpu/armv8/fel_utils.S new file mode 100644 index 00000000000..334fdef7fa0 --- /dev/null +++ b/arch/arm/cpu/armv8/fel_utils.S @@ -0,0 +1,78 @@ +/* + * Utility functions for FEL mode, when running SPL in AArch64. + * + * Copyright (c) 2017 Arm Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/system.h> +#include <linux/linkage.h> + +/* + * We don't overwrite save_boot_params() here, to save the FEL state upon + * entry, since this would run *after* the RMR reset, which clobbers that + * state. + * Instead we store the state _very_ early in the boot0 hook, *before* + * resetting to AArch64. + */ + +/* + * The FEL routines in BROM run in AArch32. + * Reset back into 32-bit mode here and restore the saved FEL state + * afterwards. + * Resetting back into AArch32/EL3 using the RMR always enters the BROM, + * but we can use the CPU hotplug mechanism to branch back to our code + * immediately. + */ +ENTRY(return_to_fel) + /* + * the RMR reset will clear all registers, so save the arguments + * (LR and SP) in the fel_stash structure, which we read anyways later + */ + adr x2, fel_stash + str w0, [x2] + str w1, [x2, #4] + + adr x1, fel_stash_addr // to find the fel_stash address in AA32 + str w2, [x1] + + ldr x0, =0xfa50392f // CPU hotplug magic +#ifndef CONFIG_MACH_SUN50I_H6 + ldr x2, =(SUNXI_CPUCFG_BASE + 0x1a4) // offset for CPU hotplug base + str w0, [x2, #0x8] +#else + ldr x2, =(SUNXI_RTC_BASE + 0x1b8) // BOOT_CPU_HP_FLAG_REG + str w0, [x2], #0x4 +#endif + adr x0, back_in_32 + str w0, [x2] + + dsb sy + isb sy + mov x0, #2 // RMR reset into AArch32 + dsb sy + msr RMR_EL3, x0 + isb sy +1: wfi + b 1b + +/* AArch32 code to restore the state from fel_stash and return back to FEL. */ +back_in_32: + .word 0xe59f0028 // ldr r0, [pc, #40] ; load fel_stash address + .word 0xe5901008 // ldr r1, [r0, #8] + .word 0xe129f001 // msr CPSR_fc, r1 + .word 0xf57ff06f // isb + .word 0xe590d000 // ldr sp, [r0] + .word 0xe590e004 // ldr lr, [r0, #4] + .word 0xe5901010 // ldr r1, [r0, #16] + .word 0xee0c1f10 // mcr 15, 0, r1, cr12, cr0, {0} ; VBAR + .word 0xe590100c // ldr r1, [r0, #12] + .word 0xee011f10 // mcr 15, 0, r1, cr1, cr0, {0} ; SCTLR + .word 0xf57ff06f // isb + .word 0xe12fff1e // bx lr ; return to FEL +fel_stash_addr: + .word 0x00000000 // receives fel_stash addr, by AA64 code above +ENDPROC(return_to_fel) diff --git a/arch/arm/include/asm/arch-sunxi/boot0.h b/arch/arm/include/asm/arch-sunxi/boot0.h index 54c144afd8c..46d0f0666c2 100644 --- a/arch/arm/include/asm/arch-sunxi/boot0.h +++ b/arch/arm/include/asm/arch-sunxi/boot0.h @@ -15,6 +15,19 @@ tst x0, x0 // this is "b #0x84" in ARM b reset .space 0x7c + + .word 0xe28f0058 // add r0, pc, #88 + .word 0xe59f1054 // ldr r1, [pc, #84] + .word 0xe0800001 // add r0, r0, r1 + .word 0xe580d000 // str sp, [r0] + .word 0xe580e004 // str lr, [r0, #4] + .word 0xe10fe000 // mrs lr, CPSR + .word 0xe580e008 // str lr, [r0, #8] + .word 0xee11ef10 // mrc 15, 0, lr, cr1, cr0, {0} + .word 0xe580e00c // str lr, [r0, #12] + .word 0xee1cef10 // mrc 15, 0, lr, cr12, cr0, {0} + .word 0xe580e010 // str lr, [r0, #16] + .word 0xe59f1024 // ldr r1, [pc, #36] ; 0x170000a0 .word 0xe59f0024 // ldr r0, [pc, #36] ; CONFIG_*_TEXT_BASE .word 0xe5810000 // str r0, [r1] @@ -36,6 +49,7 @@ #else .word CONFIG_SYS_TEXT_BASE #endif + .word fel_stash - . #else /* normal execution */ b reset diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index a6a4879523a..203cb10fbab 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -163,9 +163,7 @@
#define CONFIG_SYS_MONITOR_LEN (768 << 10) /* 768 KiB */
-#ifndef CONFIG_ARM64 /* AArch64 FEL support is not ready yet */ #define CONFIG_SPL_BOARD_LOAD_IMAGE -#endif
/* * We cannot use expressions here, because expressions won't be evaluated in
Don't you want to also update board/sunxi/README.sunxi64 ?
- Utility functions for FEL mode, when running SPL in AArch64.
- Copyright (c) 2017 Arm Ltd.
- We don't overwrite save_boot_params() here, to save the FEL state upon
- entry, since this would run *after* the RMR reset, which clobbers that
- state.
- Instead we store the state _very_ early in the boot0 hook, *before*
- resetting to AArch64.
- The FEL routines in BROM run in AArch32.
- Reset back into 32-bit mode here and restore the saved FEL state
- afterwards.
- Resetting back into AArch32/EL3 using the RMR always enters the BROM,
- but we can use the CPU hotplug mechanism to branch back to our code
- immediately.
- adr x2, fel_stash
- str w0, [x2]
- str w1, [x2, #4]
- adr x1, fel_stash_addr // to find the fel_stash address in AA32
- str w2, [x1]
- ldr x0, =0xfa50392f // CPU hotplug magic
- ldr x2, =(SUNXI_CPUCFG_BASE + 0x1a4) // offset for CPU hotplug base
- str w0, [x2, #0x8]
+#else
- ldr x2, =(SUNXI_RTC_BASE + 0x1b8) // BOOT_CPU_HP_FLAG_REG
- str w0, [x2], #0x4
- adr x0, back_in_32
- str w0, [x2]
- dsb sy
- isb sy
- mov x0, #2 // RMR reset into AArch32
- dsb sy
- msr RMR_EL3, x0
- isb sy
+1: wfi
- b 1b
- .word 0xe59f0028 // ldr r0, [pc, #40] ; load fel_stash address
- .word 0xe5901008 // ldr r1, [r0, #8]
- .word 0xe129f001 // msr CPSR_fc, r1
- .word 0xf57ff06f // isb
- .word 0xe590d000 // ldr sp, [r0]
- .word 0xe590e004 // ldr lr, [r0, #4]
- .word 0xe5901010 // ldr r1, [r0, #16]
- .word 0xee0c1f10 // mcr 15, 0, r1, cr12, cr0, {0} ; VBAR
- .word 0xe590100c // ldr r1, [r0, #12]
- .word 0xee011f10 // mcr 15, 0, r1, cr1, cr0, {0} ; SCTLR
- .word 0xe12fff1e // bx lr ; return to FEL
+fel_stash_addr:
- .word 0x00000000 // receives fel_stash addr, by AA64 code above
- .word 0xe28f0058 // add r0, pc, #88
- .word 0xe59f1054 // ldr r1, [pc, #84]
- .word 0xe0800001 // add r0, r0, r1
- .word 0xe580d000 // str sp, [r0]
- .word 0xe580e004 // str lr, [r0, #4]
- .word 0xe10fe000 // mrs lr, CPSR
- .word 0xe580e008 // str lr, [r0, #8]
- .word 0xee11ef10 // mrc 15, 0, lr, cr1, cr0, {0}
- .word 0xe580e00c // str lr, [r0, #12]
- .word 0xee1cef10 // mrc 15, 0, lr, cr12, cr0, {0}
- .word 0xe580e010 // str lr, [r0, #16]
- .word 0xe59f1024 // ldr r1, [pc, #36] ; 0x170000a0 .word 0xe59f0024 // ldr r0, [pc, #36] ; CONFIG_*_TEXT_BASE .word 0xe5810000 // str r0, [r1]
- .word fel_stash - .
- We cannot use expressions here, because expressions won't be evaluated in
-- 2.17.5
-- You received this message because you are subscribed to the Google Groups "linux-sunxi" group. To unsubscribe from this group and stop receiving emails from it, send an email to linux-sunxi+unsubscribe@googlegroups.com. To view this discussion on the web, visit https://groups.google.com/d/msgid/linux-sunxi/20201119105442.24711-1-andre.p....
Yes, but I am in the process of rewriting this anyway, since some parts apply to 32-bit SoCs as well (SD card, SPI flash), and there is currently no documentation about them. So bear with me, I will post a documentation update ASAP, just didn't want to hold back this patch.
Thanks! Andre.
- state.
- afterwards.
- immediately.
- adr x2, fel_stash
- str w0, [x2]
- str w1, [x2, #4]
- str w2, [x1]
+#else
- str w0, [x2]
- dsb sy
- isb sy
- dsb sy
- msr RMR_EL3, x0
- isb sy
+1: wfi
- b 1b
+fel_stash_addr:
-- 2.17.5
Hi Andre,
thanks for working on this!
Dne petek, 20. november 2020 ob 10:42:15 CET je André Przywara napisal(a):
Thanks! Andre.
call.o
sec_firmware_asm.o
fel_utils.S
upon
that
- state.
- afterwards.
- immediately.
later
- adr x2, fel_stash
- str w0, [x2]
- str w1, [x2, #4]
address in AA32
- str w2, [x1]
hotplug base
+#else
I suggest to turn around those ifdefs, e.g. put specific one first and general last. That way it will be much more readable when new exception will be added. For example, H616 has it's own address.
Best regards, Jernej
- str w0, [x2]
- dsb sy
- isb sy
AArch32
- dsb sy
- msr RMR_EL3, x0
- isb sy
+1: wfi
- b 1b
FEL. */
+back_in_32:
address
VBAR
SCTLR
to FEL
+fel_stash_addr:
above
CONFIG_*_TEXT_BASE
ready yet */
evaluated in
-- 2.17.5
msgid/linux-sunxi/20201119105442.24711-1-andre.przywara%40arm.com.
linux-sunxi/0fd3cbb4-a2c9-85d5-5fbd-057bb654863d%40arm.com.
在 2020-11-19星期四的 10:54 +0000,Andre Przywara写道:
That allows the normal AArch64 SPL build to be loaded via the sunxi- fel tool, with it returning into FEL mode, so that other payloads can be transferred via FEL as well.
Tested-by: Icenowy Zheng icenowy@aosc.io
upon
that
- state.
*before*
- afterwards.
BROM,
code
- immediately.
arguments
anyways later
- adr x2, fel_stash
- str w0, [x2]
- str w1, [x2, #4]
address in AA32
- str w2, [x1]
hotplug base
+#else
- str w0, [x2]
- dsb sy
- isb sy
- dsb sy
- msr RMR_EL3, x0
- isb sy
+1: wfi
- b 1b
fel_stash address
VBAR
SCTLR
#else /* normal execution */ b reset diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi- common.h index a6a4879523a..203cb10fbab 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -163,9 +163,7 @@
evaluated in
2.17.5
Acked-by: Jagan Teki jagan@amarulasolutions.com
For A64 (on Olimex A64-Olinuxino): Tested-by: Priit Laes plaes@plaes.org
Also writing down the command to run as it was not that obvious:
$ sunxi-fel spl sunxi-spl.bin \ write 0x4a000000 u-boot.bin \ write 0x44000 bl31.bin \ write 0x50000 scp.bin \ reset64 0x44000
- state.
- afterwards.
- immediately.
- adr x2, fel_stash
- str w0, [x2]
- str w1, [x2, #4]
- str w2, [x1]
+#else
- str w0, [x2]
- dsb sy
- isb sy
- dsb sy
- msr RMR_EL3, x0
- isb sy
+1: wfi
- b 1b
+fel_stash_addr:
-- 2.17.5
participants (6)
Andre Przywara
André Przywara
Icenowy Zheng
Jagan Teki
Jernej Škrabec
Priit Laes
