[PATCH v2 1/3] mmc: Check support for TRIM operations
When secure/insecure TRIM operations are supported. When used as erase command argument it applies the erase operation to write blocks instead of erase groups.
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- v2: Add mmc unit test change to the series
drivers/mmc/mmc.c | 3 +++ include/mmc.h | 4 ++++ 2 files changed, 7 insertions(+)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 210703ea46..e5f5ccb5f4 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2432,6 +2432,9 @@ static int mmc_startup_v4(struct mmc *mmc)
mmc->wr_rel_set = ext_csd[EXT_CSD_WR_REL_SET];
+ mmc->can_trim = + !!(ext_csd[EXT_CSD_SEC_FEATURE] & EXT_CSD_SEC_FEATURE_TRIM_EN); + return 0; error: if (mmc->ext_csd) { diff --git a/include/mmc.h b/include/mmc.h index 571fa625d0..f6e23625ca 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -241,6 +241,7 @@ static inline bool mmc_is_tuning_cmd(uint cmdidx) #define EXT_CSD_HC_WP_GRP_SIZE 221 /* RO */ #define EXT_CSD_HC_ERASE_GRP_SIZE 224 /* RO */ #define EXT_CSD_BOOT_MULT 226 /* RO */ +#define EXT_CSD_SEC_FEATURE 231 /* RO */ #define EXT_CSD_GENERIC_CMD6_TIME 248 /* RO */ #define EXT_CSD_BKOPS_SUPPORT 502 /* RO */
@@ -315,6 +316,8 @@ static inline bool mmc_is_tuning_cmd(uint cmdidx) #define EXT_CSD_WR_DATA_REL_USR (1 << 0) /* user data area WR_REL */ #define EXT_CSD_WR_DATA_REL_GP(x) (1 << ((x)+1)) /* GP part (x+1) WR_REL */
+#define EXT_CSD_SEC_FEATURE_TRIM_EN (1 << 4) /* Support secure & insecure trim */ + #define R1_ILLEGAL_COMMAND (1 << 22) #define R1_APP_CMD (1 << 5)
@@ -687,6 +690,7 @@ struct mmc { uint tran_speed; uint legacy_speed; /* speed for the legacy mode provided by the card */ uint read_bl_len; + bool can_trim; #if CONFIG_IS_ENABLED(MMC_WRITE) uint write_bl_len; uint erase_grp_size; /* in 512-byte sectors */
The default erase command applies on erase group unit, and simply round down to erase group size. When the start block is not aligned to erase group size (e.g. erasing partition) it causes unwanted erasing of the previous blocks, part of the same erase group (e.g. owned by other logical partition, or by the partition table itself).
To prevent this issue, a simple solution is to use TRIM as argument of the Erase command, which is usually supported with eMMC > 4.0, and allow to apply erase operation to write blocks instead of erase group
drivers/mmc/mmc_write.c | 34 +++++++++++++++++++++++----------- 1 file changed, 23 insertions(+), 11 deletions(-)
diff --git a/drivers/mmc/mmc_write.c b/drivers/mmc/mmc_write.c index 5b7aeeb012..a6f93380dd 100644 --- a/drivers/mmc/mmc_write.c +++ b/drivers/mmc/mmc_write.c @@ -15,7 +15,7 @@ #include <linux/math64.h> #include "mmc_private.h"
-static ulong mmc_erase_t(struct mmc *mmc, ulong start, lbaint_t blkcnt) +static ulong mmc_erase_t(struct mmc *mmc, ulong start, lbaint_t blkcnt, u32 args) { struct mmc_cmd cmd; ulong end; @@ -52,7 +52,7 @@ static ulong mmc_erase_t(struct mmc *mmc, ulong start, lbaint_t blkcnt) goto err_out;
cmd.cmdidx = MMC_CMD_ERASE; - cmd.cmdarg = MMC_ERASE_ARG; + cmd.cmdarg = args ? args : MMC_ERASE_ARG; cmd.resp_type = MMC_RSP_R1b;
err = mmc_send_cmd(mmc, &cmd, NULL); @@ -77,7 +77,7 @@ ulong mmc_berase(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt) #endif int dev_num = block_dev->devnum; int err = 0; - u32 start_rem, blkcnt_rem; + u32 start_rem, blkcnt_rem, erase_args = 0; struct mmc *mmc = find_mmc_device(dev_num); lbaint_t blk = 0, blk_r = 0; int timeout_ms = 1000; @@ -97,13 +97,25 @@ ulong mmc_berase(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt) */ err = div_u64_rem(start, mmc->erase_grp_size, &start_rem); err = div_u64_rem(blkcnt, mmc->erase_grp_size, &blkcnt_rem); - if (start_rem || blkcnt_rem) - printf("\n\nCaution! Your devices Erase group is 0x%x\n" - "The erase range would be change to " - "0x" LBAF "~0x" LBAF "\n\n", - mmc->erase_grp_size, start & ~(mmc->erase_grp_size - 1), - ((start + blkcnt + mmc->erase_grp_size - 1) - & ~(mmc->erase_grp_size - 1)) - 1); + if (start_rem || blkcnt_rem) { + if (mmc->can_trim) { + /* Trim function applies the erase operation to write + * blocks instead of erase groups. + */ + erase_args = MMC_TRIM_ARG; + } else { + /* The card ignores all LSB's below the erase group + * size, rounding down the addess to a erase group + * boundary. + */ + printf("\n\nCaution! Your devices Erase group is 0x%x\n" + "The erase range would be change to " + "0x" LBAF "~0x" LBAF "\n\n", + mmc->erase_grp_size, start & ~(mmc->erase_grp_size - 1), + ((start + blkcnt + mmc->erase_grp_size - 1) + & ~(mmc->erase_grp_size - 1)) - 1); + } + }
while (blk < blkcnt) { if (IS_SD(mmc) && mmc->ssr.au) { @@ -113,7 +125,7 @@ ulong mmc_berase(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt) blk_r = ((blkcnt - blk) > mmc->erase_grp_size) ? mmc->erase_grp_size : (blkcnt - blk); } - err = mmc_erase_t(mmc, start + blk, blk_r); + err = mmc_erase_t(mmc, start + blk, blk_r, erase_args); if (err) break;
Hi Loic,
Please see below
cmd.cmdarg = args ? args : MMC_ERASE_ARG; cmd.resp_type = MMC_RSP_R1b; err = mmc_send_cmd(mmc, &cmd, NULL);
} else {
* boundary.
Should this return an error, or just go ahead?
} while (blk < blkcnt) { if (IS_SD(mmc) && mmc->ssr.au) {
-- 2.34.1
Hi Simon,
On Sat, 28 Jan 2023 at 23:01, Simon Glass sjg@chromium.org wrote:
Hi Loic,
Please see below
} else {
* boundary.
It would indeed make sense to return an error since mmc_erase does not perform what we expect. Now, since this behavior exists for a while, we may also want to keep it for legacy, though it should be a corner case...
Regards, Loic
-----Original Message----- From: Loic Poulain loic.poulain@linaro.org Sent: Thursday, January 26, 2023 6:24 PM To: sjg@chromium.org; peng.fan@nxp.com; jh80.chung@samsung.com Cc: u-boot@lists.denx.de; Loic Poulain loic.poulain@linaro.org Subject: [PATCH v2 2/3] mmc: erase: Use TRIM erase when available
- cmd.cmdarg = args ? args : MMC_ERASE_ARG;
It there any case to pass by other value?
Best Regards, Jaehoon Chung
- u32 start_rem, blkcnt_rem, erase_args = 0; struct mmc *mmc = find_mmc_device(dev_num); lbaint_t blk = 0, blk_r = 0; int timeout_ms = 1000;
} else {
* boundary.
if (err) break;err = mmc_erase_t(mmc, start + blk, blk_r, erase_args);
-- 2.34.1
Hi Jaehoon,
Not at the moment, but it can be used to support eMMC 'Secure Erase' arg.
Regards, Loic
Hi Loic,
-----Original Message----- From: Loic Poulain loic.poulain@linaro.org Sent: Wednesday, February 8, 2023 5:09 PM To: Jaehoon Chung jh80.chung@samsung.com Cc: sjg@chromium.org; peng.fan@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH v2 2/3] mmc: erase: Use TRIM erase when available
Hi Jaehoon,
I had mis-read. I had read the MMC_TRIM_ARG as MMC_ERASE_ARG. Thanks for kindly explanation. :)
Regards, Loic
Signed-off-by: Loic Poulain loic.poulain@linaro.org Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot-mmc/master.
} else {
* boundary.
Verify that erasing blocks does not impact adjacent ones. - Write four blocks [0 1 2 3] - Erase two blocks [ 1 2 ] - Verify [0 1 2 3 ]
Signed-off-by: Loic Poulain loic.poulain@linaro.org --- v2: Add this change to the series
test/dm/mmc.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/test/dm/mmc.c b/test/dm/mmc.c index f744452ff2..b1eb8bee2f 100644 --- a/test/dm/mmc.c +++ b/test/dm/mmc.c @@ -30,7 +30,7 @@ static int dm_test_mmc_blk(struct unit_test_state *uts) struct udevice *dev; struct blk_desc *dev_desc; int i; - char write[1024], read[1024]; + char write[4 * 512], read[4 * 512];
ut_assertok(uclass_get_device(UCLASS_MMC, 0, &dev)); ut_assertok(blk_get_device_by_str("mmc", "0", &dev_desc)); @@ -39,14 +39,14 @@ static int dm_test_mmc_blk(struct unit_test_state *uts) ut_asserteq(512, dev_desc->blksz); for (i = 0; i < sizeof(write); i++) write[i] = i; - ut_asserteq(2, blk_dwrite(dev_desc, 0, 2, write)); - ut_asserteq(2, blk_dread(dev_desc, 0, 2, read)); + ut_asserteq(4, blk_dwrite(dev_desc, 0, 4, write)); + ut_asserteq(4, blk_dread(dev_desc, 0, 4, read)); ut_asserteq_mem(write, read, sizeof(write));
- /* Now erase them */ - memset(write, '\0', sizeof(write)); - ut_asserteq(2, blk_derase(dev_desc, 0, 2)); - ut_asserteq(2, blk_dread(dev_desc, 0, 2, read)); + /* Now erase two of them [1 - 2] and verify all blocks */ + memset(&write[512], '\0', 2 * 512); + ut_asserteq(2, blk_derase(dev_desc, 1, 2)); + ut_asserteq(4, blk_dread(dev_desc, 0, 4, read)); ut_asserteq_mem(write, read, sizeof(write));
Hi Loic,
- Verify [0 1 2 3 ]
This looks good, but can you add the trim command to sandbox_mmc_send_cmd()? Then you can test that as well.
char write[4 * 512], read[4 * 512]; ut_assertok(uclass_get_device(UCLASS_MMC, 0, &dev)); ut_assertok(blk_get_device_by_str("mmc", "0", &dev_desc));
ut_asserteq(4, blk_dread(dev_desc, 0, 4, read)); ut_asserteq_mem(write, read, sizeof(write)); return 0;
-- 2.34.1
On Fri, 27 Jan 2023 at 15:30, Simon Glass sjg@chromium.org wrote:
Hi Loic,
- Verify [0 1 2 3 ]
The TRIM option is not exposed, it is internally managed inside mmc depending on the need for it. So from a testing perspective, I can only test that the mmc erase is doing what we ask correctly.
Regards, Loic
- Verify [0 1 2 3 ]
- ut_asserteq(4, blk_dwrite(dev_desc, 0, 4, write));
- ut_asserteq(4, blk_dread(dev_desc, 0, 4, read)); ut_asserteq_mem(write, read, sizeof(write));
-----Original Message----- From: Loic Poulain loic.poulain@linaro.org Sent: Thursday, January 26, 2023 6:24 PM To: sjg@chromium.org; peng.fan@nxp.com; jh80.chung@samsung.com Cc: u-boot@lists.denx.de; Loic Poulain loic.poulain@linaro.org Subject: [PATCH v2 1/3] mmc: Check support for TRIM operations
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
- mmc->can_trim =
- bool can_trim;
#if CONFIG_IS_ENABLED(MMC_WRITE) uint write_bl_len; uint erase_grp_size; /* in 512-byte sectors */ -- 2.34.1
Signed-off-by: Loic Poulain loic.poulain@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
- mmc->can_trim =
- bool can_trim;
Jaehoon Chung
Loic Poulain
